Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-19-2005, 06:36   #31 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
@sl45vietnam:
If i use BL-5C battery, would it be ok if i dont remove the fuse/ic from the nokia battery?
Old 02-19-2005, 06:52   #32 (permalink)
Member: 84390
Thanks Meter: 3
I've never use BL-5C. I used BL-4C and I didn't remove the fuse/IC from Nokia battery (using both fuse/IC of nokia and sl45), and until now it's OK, not any problem. But I think it's more better: you should remove the Nokia fuse/IC battery if you have original one of sl45 battery... But I'm lazy...
Old 02-19-2005, 06:57   #33 (permalink)
abomin's Avatar
Member: 48199
I use BR-5C and on it`s board wasn`t any IC, only thermoresistor and capasitor (I think). I removed that plate.
Old 02-19-2005, 07:02   #34 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
Im not sure if it is IC , but BL-5C has something that is on top of the cell. Will it be ok if i dont remove it? Because the batteries here are made of aluminum and i cant solder aluminum
If i dont have to remove it, where do i solder the + and - wires to connect to the sl45 ic? there are 3 terminals in the nokia battery
Old 02-19-2005, 07:10   #35 (permalink)
Member: 84390
Thanks Meter: 3
I've solder only + and - of BL4C to board of sl45 batt.
Old 02-19-2005, 07:30   #36 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
@abomin:
would it be ok if i dont remove the plate? what will happen if i remove it or not?
Old 02-19-2005, 09:46   #37 (permalink)
abomin's Avatar
Member: 48199
I`ve only disassembled BR-5C, but IMHO BL-5C is the same. I removed that plate with plastic top because this plastic top more thick than aluminium can. I think you can solder directly on + and - on the board. BTW, never open or heat aluminium can! It contains Lithium and may burns when contacts with atmospheric oxigen.
Old 02-22-2005, 16:51   #38 (permalink)
Member: 42457
I've an idea of building an adapter. So diassembling the Nokia battery may not be used anymore. My idea is to use an Europlatine (Click for picture) and solder three cables directly on the Nokia battery connectors and use the europlatine as connector for the SL.
_________________
I need your help now. Left and Right connector are + and - pole. For what in hell is the middle one?
Thanks
cyperghost
Old 02-22-2005, 19:05   #39 (permalink)
Khatiger's Avatar
Member: 61649
Thanks Meter: 111
Hi SL45Vietnam. I'm Zinzen at VOZ.
Can I put BL4C Nokia Batt in SL45 case without Siemens IC and fuse?
I've tried, it was okie untill I did some patch yesterday. Now when the rest of batt is 50~75%, my wife shutdown without say goodbye.
Old 02-23-2005, 16:58   #40 (permalink)
Member: 84390
Thanks Meter: 3
I think some patch effect your battery, because some patches use power from battery. I've never tried remove IC and fuse like you (because my battery is OK until now), I think it'll be more better if you use Siemens battery board (including IC and fuse).
Old 02-24-2005, 05:35   #41 (permalink)
Khatiger's Avatar
Member: 61649
Thanks Meter: 111
wrong work . I've found original batt and used its board with BL-4C batt. when I done, my phone work with only 1 call. Before it, my phone can play Mp3 about 6hours woth volume 7.
I've undo some patch toooo.
Ah, can U tell me how to connect SL45 with Sensor tools? I can do it.
@ CharlieLao: middle connector is temperature signal.
Old 02-27-2005, 10:09   #42 (permalink)
Member: 85188
What patches you are install?
I ask for the sol3 and consumation, but answer me, that if I install the batery is not down more fast
Old 02-27-2005, 21:23   #43 (permalink)
Khatiger's Avatar
Member: 61649
Thanks Meter: 111
Thank Hookah.
There patch is show battery and net symbol in percent, show temperature and invert display color. I've undo them too..
But from yesterday, I've lost the chance for apply any patch. I've lost my phone..
Seeking for new SL45, but 'till not found.
Old 03-01-2005, 13:36   #44 (permalink)
Member: 42457
Cool
Ladies and Gentleman
I proudly present: Nokia BL-5C in standard SLIK housing, without diassembling the battery. I explained the way in my further post but. I attached one sample picture. IMHO this is the best way to make ANY battery work with SLIK
What do you think of it?
It works best btw
Old 03-01-2005, 19:59   #45 (permalink)
Khatiger's Avatar
Member: 61649
Thanks Meter: 111
It works best btw
Good work.
I've lost my phone, 'cause I can't show you any picture. But in my SL45, Nokia batteries can be easy move or install with a tray. I'vnt solved, put it (BL-xC) only.
SC box gets hot with 12v 1000 mah adapter emicabher Smart-Clip 10 06-10-2008 16:25
Enormous consumption of battery in SLIK56 kalac x4x, x5x Flashpatching 8 05-11-2005 22:40
I need .blk file for SL45 540 mah battery beshko x1x to x45/x50 2 10-06-2004 21:52
Settings 1000 mAh Li-pol battery for x55 difer E-Gold Based Phones 2 05-03-2004 01:22
1000 mAh blk for SL42 - SL54i! InCoMiNg x1x to x45/x50 1 06-20-2003 01:50
Page generated in 0.49012 seconds with 9 queries
