Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-17-2005, 15:17   #1 (permalink)
Member: 143475
ANM - why doesn`t it record?
I applied these patches:
; *** DMM.  v1. 1 ***
; sl45v56
; Autor:rizapn
; Sierpień 14, 2004
; Update: Aug 24, 2004 ( v1. 1)
0x352776: 46F60900 FAE4104C
0x444C00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A2A20444D4D2076312E31202A2A2A
0x444C10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700C00F3F81E10F7FC1E1046F60900
0x444C20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D02FAD57A274981CD044987AD02FAD5
0x444C30: FFFFFFFFFFFF AE28FAD51228
; *** BLR. Mrugające Światło kiedy Dzwoni v1. 1  ***
;-----POTRZEBNY MI TYLKO DO AMM ZOBACZ PONIŻEJ I OPIS AMMa v2 !!!
; Autor:rizapn
; Lipiec 3, 2004
; Selectable APP Profile1 - Function8
0x3AFC5A: E6FC2003 FAE41059
0x445900: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A2A20424C522076312E31202A2A2A
0x445910: FFFFFFFF CC00CC00
0x445914: FFFFFFFF CC00CC00
0x445918: FFFFFFFF CC00CC00
; --------------------------------------------Jeżeli chcesz miganie (BLINKING)
0x44591C: FFFFFFFF D7400E00
; --------------------------------------------Jeśli nie chcesz migania (NOT BLINKING)
;0x44591C: FFFFFFFF 0D15CC00
0x445920: FFFFFFFF F2F4423A
; APP Profile1 - Function15 ( e0), zmodyfikuj jak chcesz:
0x445924: FFFFFFFF 9AF41080
0x445928: FFFFFFFFFFFFFFFF DAC1B6FBE6FC8000
0x445930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00DE6FE3E59E6FFE400FADA68FCDAC0
0x445940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C0AFE6FC00010D02E6FC8001FADA5EFC
;*** ANM. Answering Machine v2 z dodatkami***
; ----------------WYBIERANIE Profil 2, Fcja 3 (JAK W ORYGINALE)
;Firmware : sl45v56
;Author : rizapn
;Created : August 13, 2004
;Updated : Aug 24, 2004
;Need DMM patch and BLR (as an incoming call patch manager) !
;This patch will add Answering Machine capability into our
;lovely SL45. The function is selectable through the APP
;menu Profile 2, item 3 (modifyable). Answering message is
;a VMO file, A:\Voice memo\am.vmo
;If you are not install the latest ICF (Incoming Call Filter)
;patch, then the answering machine will be activated if the
;call is unanswered after some predefined time.
;v2->add setMicOFF() --> but not work
;v2->combine with "Record All Calls" patch
;Disable this ANM for outgoing Call:
0x3AC4D4: DAF09AC3 DAE4144D
;Enable ANM for incoming Call from the BLR patch:
0x445910: CC00CC00 DAE4E84C
0x3AFDBE: F0C9 DAE4
0x3AFDC0: F0D6 DC4C
;Call to main ANM functions:
0x3AC528: DAF09AC3 DAE4604C
0x444C50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A2A2A20414E4D207632202A2A2A2A
0x444C60: FFFFFFFFFFFF DAF09AC3BB23
;Modify this (value 20) to select another APP menu item:
0x444C66: FFFFFFFF 9AF10D20  ; FUNKCJA 3
0x444C6A: FFFFFFFFFFFF BB2E2D164981
0x444C70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0647F80A002D1F47F8E0002D4AE7F8
0x444C80: FFFFFFFFFFFFFFFFFFFFFFFF FF00BB27D7403600F2F16C09  ; P2 DLA RAC
;JEŚLI CHCESZ to have Record All Calls function,
;APP default menu item is Profile1-Func14 (value=D0):
;;0x444C8C: FFFFFFFF 9AF14110
;If You don`t want to have Record All Calls function:
0x444C8C: FFFFFFFF EA00124D
0x444C90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB1B47F8FF003D3D0D12E118BB1AE6FC
0x444CA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1E0DE6FD9103DAD5B2360D33D7403600
0x444CB0: FFFFFFFFFFFF F2F16C09CB00
;Beep between VMO and Recording, modify as you wish (original=13):
0x444CB6: FFFFFFFF E6FC3b00 ;3b = 4x Razy Głośne PIKNIĘCIE
0x444CBA: FFFFFFFFFFFF DAC31400E7F8
0x444CC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E000BB07FAD414F3D7400C00F3F81E10
0x444CD0: FFFFFFFFFFFFFFFFFFFFFFFF CB00D7400C00F7F81E10CB00
;Counter for auto-answered (~800ms each, I use 40):
0x444CDC: FFFFFFFF E7F84000
0x444CE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBF8F0C9F0D6DB00BBE19AF11220BBEC
0x444CF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D102981BBEE3D0DE6FCC834E0EDE6FE
0x444D00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1800DAC164B1D7500C00F68E7C2BF68E
0x444D10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BE2CDB00E7F8FF00BBDCFAF09AC3413A
0x444D20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C566F696365206D656D6F5C616D2E76
0x444D30: FFFFFFFF 6D6F0000
;Known unsolved problem/request:
;- microphone is ON, so the background sound will be heard by the caller
;- beep between playing and recording is not heard by the caller
;- answering machine indicator (activation and recorded message)
;- recorded message filename is not too informative
; ----------------           NAKŁADKA         -------------------------
;ZMIANA NAZWY PLIKU Z VOICE MEMO NA SEKRETARKA
0x444D21: 566F6963 53656B72
0x444D26: 206D656D6F 7461726B61
0x444CDE: 40 01 ; <= change time to activate ANM (shorter)
***MANM - Microphone off during answering machine mode v2 ***
;Firmware: sl45v56
;Author: vBart
;Created: 01.06.05. RP.
;Chuck MANMv1.
;For ANMv2
;444CC4: FAD414F3 FAE4904D
;444D90: FFFFFFFFFFFFFFFFFFFF DAC2D647FAD414F3DB00
;For ANMv2 & "Answering Machine while Incoming Call Ringing v2"
27D0f0: DAD414F3 DAE4904D
;*** VWC. (just another) Vibra When Connected ***
;Firmware : SL45v56
;Author : rizapn
;Published : July 03, 2004
;Turn on vibra when the outgoing call is connected (only if Vibra flag is on).
0x3AC4C8: F0C8F0D9 DAC7C0E6
0x3AC51C: F0C8F0D9 DAC7C4E6
0x27E6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00C0D0DD7403700F2FC043ACD0CDADE
0x27E6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A6172D0988C0DAC36C0298C028C1D740
0x27E6E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3700F6FC043AF0C8F0D9DB00FFFFFFFF
;if you want to change the number of vibration (my default is 1 times), use this:
;0x27E6C1: FF xC ; x is 0..F
;if you want to skip Vibra flag (always vibrate when connected), use this:
;0x27E6D3: 09 00
;****RAC-Record All Calls V3***
;Firmware : sl45v56
;Author : DeadManS
;Created : August 14, 2004
;Version Changes - v3 - No more need java midlet. Based on RizaPN entrypoint from
; VWC patch, so you need to install it.
;------------------------PRZEADRESOWAŁEM:
; DZIAŁA NA ZMIANĘ Z AUTO SEKRETARKĄ -KIEDY FUNKCJA NIE JEST ZAZNACZONA
;------------------------PROFIL 2 - FUNKCJA 3 (tak jak Auto Sekretarka)
3AC51C: DAC7C4E6 DAE080D2
02F56E: DAE66653 DAE0acD2
0040D280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403600F2FC6c098AFC0D20D7400300
0040D290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCFE048AFC07000FFCD7400300F6FC
0040D2a0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE04DAD414F3DAC7C4E6DB00D7400300
0040D2b0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCFE040EFCD7400300F6FCFE04F0C8
0040D2c0: FFFFFFFFFFFF DAE66653DB00
;WYŁĄCZENIE NAGRYWANIA DLA "ANM", SKOK Z "RECORD ALL CALLS" Prof.2 Funkcja 1
;WYBIERANIE DLA VWC A WIĘC I DLA RAC
3AC4C8: DAC7C0E6 DAE0D0D2 ;FRAGMENT Z VWC
40D2D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C0D7403600F2FC6C099AFC030098C0
40D2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FAE0F0D298C0FAE0EAD2DAC7C0E6DB00
40D2F0: FFFFFFFFFFFF F0C8F0D9DB00
3AC51C: DAE080D2 DAE000D3 ;FRAGMENT Z RAC
40D300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C0D7403600F2FC6C099AFC030098C0
40D310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FAE020D398C0FAE01AD3DAE080D2DB00
40D320: FFFFFFFFFFFF F0C8F0D9DB00
;FAMM
444D94: FAD414F3 FAC780D2; <--SKOK z patcha Wyłączenie Mikrofonu v2( entry from  MANM)
27D280: FFFFFFFFFFFFFFFF DAC62251DADCE846
27D290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F01602E00CC4C03000E6FD2501C4D0
27D2A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 320088C0E6FCEE3EE6FDC502E02E00E0
27D2B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FEFF3FF2FF02FEDAEE1211DADCE846 ; IrDA (toggle)
27D2C0: FFFFFFFFFFFF 06F01802DB00
;Przykład: picture 340
4B22CE: 07081F06901F07401F06D61F07401F06 73303FDB335F8AD39FFAD37F8A139F8A
4B22DE: 901F07081F 135F8A103F
;Zmieniony obrazek IrDy
; ##### Picture 1 #####
; Picture Table Index
4BA4BE: 0C0C0100 13070100
; Picture Data
493F96: 0A8F000F0A8F1FCF202F2AAF356F1FCF F0001F90EEFF90A89FF0ACDFA0A89F90
493FA6: 104F3FEF7FFF000F A89F94E89F0F0F0F
;;OBRAZEK "AM"
; ##### Picture 330 #####
; Picture Data
4B2207: 008E1F08131F0C971F3E1F1F0CBF9F08 381F9FFE1F9FC6181FFE1F9FFE019FC6
4B2217: 001F00841F 1F9FC69FBF
And my ANM turns on dictaphone when someone calls but I don`t have record after he disconnects? Why?
Old 11-17-2005, 19:04   #2 (permalink)
trustkill's Avatar
Member: 27745
Why don´t you use ANMv2 ?
Old 11-18-2005, 15:59   #3 (permalink)
Member: 143475
This is *** ANM. Answering Machine v2 ***
I used it on "clear software" and it works... so which patch causes that it doesn`t work?
My problem: After somebody recorded message, I have screen of connecting all the time... When I enter to Voice Memo, I don`t have voice message. Why, I checked RAC - without ANM and it works perfectly...
Has anybody had the same problem?
Can somebody help me?
Thanks in advance, Regards, GoLL@B.
Iodine: Why You Need It, Why You Can't Live Without It (4th Edition By David Brownste IPMART ipmart WebShop 0 02-23-2010 07:00
Why You Delete it??? I Need Some Answer...pls... bornagaintobe Universalbox 2 07-14-2009 16:32
PPM gone all funny ??why ?? can't flash it ?? KHEANG HWK 6 07-04-2007 16:24
Why Dejan put it free???? mr_rocco Nokia Base Band 5 ( BB-5 ) 4 05-13-2007 02:11
Doesn’t it become possible Full Read Out and Flash TOSHIBA’s firmware? tkhs1157 VygisToolbox 1 06-25-2006 07:47
Page generated in 0.25212 seconds with 11 queries
