Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 06-10-2004, 23:58   #1 (permalink)
Member: 68376
Post TOC for Sticky: SLIKv56: Flash patches.
Listed are all headings from: Sticky: SLIKv56: Flash patches.
I copied and pasted them all so everyone has an easier time to search through the sticky without having to go through each page.
I create some sort of index and remove duplicates when I get the chance.
Maybe even create a database so that similiar things / diff versions are collected together.
Probability: very highly unlikely =)
Anyways.. I hope this makes it easier for people to search for patches.
Page 1
Create new shortcut for Inbox SMS (located on the SIM card)
Create new shortcut for Outbox SMS (located on the SIM card)
Eliminate the additional "_nnn_nnn" string when moving SMS to the archive folder
Get access to "SIM Location" directly using front UP Arrow key
Add "Send via IrDA ..." options in CardExplorer
Overwrite "VoiceDialling" shortcut with "Display" shortcut
Overwrite "VoiceDialling" shortcut with "Illumination Toggle"
Use # short button to release the key-lock
Use[*][GREEN] as an Illumination Toggle shortcut
Disable "Do you want to copy all SIM Card content to the phonebook" message when change SIM Card
Use[*] [0] and [#] followed by [GREEN] button as shortcuts
Use LEFT Arrow key as a "SIM-Location" shortcut
Use RIGHT Arrow key as a "Card-Explorer" shortcut
Long press of left side [+] button for "Illumination Toggle" and its short press for IrDA
Page 2
Overwrite selectable "User Group" shortcut/hotkey with "Archive"
ADDITIONAL FIX SHORTCUT PATCHING SUMMARY
1) Use LEFT Arrow key as a "SIM-Location" shortcut :
2) Use RIGHT Arrow key as a "Card-Explorer" shortcut :
3) Modify 0[UpperRight] from "Select Line" to "Archive" :
4) Modify #[UpperRight] from "View New CB" to "Java"
5) Use * 0 and # followed by [GREEN] as another shortcut :
Short # to unlock keypad, UP arrow and PTT button for VoiceDial when keypad is locked
ADD NEW OPTION MENU FOR SL45 FW56 - > BAND SELECTION
Short UP arrow to unlock keypad, and PTT button for VoiceDial when keypad is locked
Turn off Aeroplane Check
Toggling between SIM-Location and Addressbook when entering SMS Recipient No.
Assign Any Ringtone to Any Phone Number
Use Screen Style Images as a Screen Saver when Keypad is Locked
Use only long press of # to unlock keypad
Eliminate "Keylocked" message box when locking the keypad
SLOW Animated Operator Logo when Keypad is locked
Unhide Calendar Menu while Call in progress
SLOW Animated Operator Logo v04
unlock mp3-auto-play with dobbleclick on the Play-button, when keypad is locked
Unhide "Send Via IrDA" Options for JAR file
Page 3
Make melody for earphone same with the normal speaker
Hide SIM Application Menu
Doing something else while playing MP3
Add Menu item under Voice Command
More Fixed Shortcut
Enabling NetMonitor
Doing something else while playing MP3 (v02)
Use SIM-Location for SMS while playing MP3
Modify MP3 Player's Fast Forward to become Skip or Quit Function
Unhide Card-Explorer Menu for Phone without SIM Card
RED Button Modification
Assign a shortcut to concrete midlets
Page 4
More shortcut, 0-9,#, and + followed by [RIGHT Arrow] for Midlet Access
Assign a shortcut to concrete midlets - version 2
Left Arrow for SIM-Location (During Calls Mode)
39. Right Soft Key for SIM-Location (Saving Number)
40. Modify Characters for Filename Input
43. Using midlet for Screen Saver when Keylocked v03
41. Insert "Timbre" Options for MP3Player
42. Graphical Menu
50. Use Graphical Menu in the MP3 Player
51. #[RightSoft] as Vibra Toggle
52. 0[RightSoft] for Profile swapping (Normal/Quiet)
53. Modify MultiLine Indicator to become Vibra Indicator
press of left side [+] button for "Profile-menu“
Set[*][RightSoft] for Profile swapping (Normal/Quiet)
Page 5
the short alert when dialing in 50 seconds
54. Call Minutes Beep Modification
Show an icon "home/office/mobile" on incoming call
"Overwrite Menu mode and Help options inside configuration menu by Time/Charge and Divert"
Show an icon "home/office/mobile" on incoming call - v3
56. Modify LeftSoft Key Text for More Shortcut Patch
63. Password for Functions Access
Modify surf/fun menu options
D03. Modify AT+CGSN Command to do Debug
55. Skip Addressbook for SMS Viewing v03
Advanced debugging with AT+CGSN
Access to GFX menu instead normal menu during a call
69. Modify Date Display Format
Page 6
Read New SMS While Key Locked
Read New SMS, Missed Calls While Key Locked V02
66B. Selectable Operator Logo
Allow Java midlets to access root folders
72. No Temporary Light After Key Unlocked v02
Read New SMS While Key Locked V03
Calling Images (Picture on an entering bell) V.1
Calling Images - V2a (stable)
Disable Java-classes verification
Selectable Operator Logo + default pictures. Version 4
Page 7
Modify MultiLine Indicator to become Vibra Indicator. Version 3
Show icon of current profile. Version 2; (extended customization possibility)
Calling Images (Incoming call pictures) V3
Left-Arrow-Key for as a "Profile" shortcut
Overwrite "VoiceDialling" shortcut with "Profile swapping"
press of left side [+] button for "Profile Swapping"
Overwrite "VoiceDialling" shortcut with "Inbox SMS"
Overwrite "Conceal ID" shortcut with "Inbox SMS"
Assign any ringtone to any number - v2
View time by green key on playing MP3
Display number on adjust volume
Add more Timbre for MP3Player
Assign any ringtone to any number + blacklist - v3
Assign any ringtone to any number + blacklist - v3a
Pseudo Polyphonic Ringtones Instead Discreet
View time by green key on playing MP3 v1.1
Fix a bug in some phones switching off in several midlet
on click on messages directly goto SMS menu
Page 8
invert display
No Temporary Light After Key Unlocked v03
NOKIA_BATTERY_AND_NET_SYMBOL
Prevent phone switching off on receiving SMS ***Modify playlist extension from *.mpl to *.m3u
add support of Kingmax v02 and v03 MMC
74. Selectable Display Invert
73. Just Another Additional Display for MP3Player
Mirror Screen Horizontally & Vertical Flip
75. Flash SMS Directly from the Phone
Modify date on standby screen to be "DD,dd.mm." (No year)
Unhide AddressBook for phone without SIM card
Page 9
76. Just Another Funny Display
77. Modify Auto KeyLock Time-Out
78. Modify Battery Empty Warning Sound
MPX. Skip and Exit button for MP3Player
SOL. Selectable Operator Logo (New version)
HBP. Hourly Beep
ICF. Incoming Call Filter
Images for Incoming Call Filter by RizaPN
Set of patches (c) mamaich. Version 0.6 beta
Correction - Show an icon "home/office/mobile" on incoming call v3
BSK. Blank Screen for KeyLock by long pressing # Button
BSA. Blank Screen for Battery Saving v2
APP. New Setup->Application Menu for Patch Setting
ISK. Invert Soft Key Text
Page 10
BST. Blank Screen Test
ICI. Incoming_Call_Images
SOL. Little custom tricks
Offline SMS - Archive
AFA. Another_Function_of_Appointment
LOL. Loadable_Operator_Logo
Set of patches (c) mamaich. Version 0.7 beta
APS+ALF Automatic Profile Swapping and Auto Backlight Function
change call active sound
BEW. Modify Battery Empty Warning Sound
Do not allow to enter '112' in keylocked mode
Page 11
no dialtone in silent mode
DIG. Digital Clock when KeyLocked
C45 Digital Clock sample pictures
I have modified the CatClock patch so that it is compatible with the SOL(new version) patch from RizaPN.
CLST. Call List via GREEN button
MSC. More fixed Shortcut v2.0
JACT. Just Another CallingTime
SRB. SMS RED Button Redefinition
MSM. More Shortcut for Midlet Access
Midlets through entrypoints
Page 12
SOL3. Selectable Operator Logo
S3TC. Application Menu - SOL3 Text Correction
SOL3˛ Selectable Operator Logo
VDL. Voice Dial/Command Light
CatClock for SOL3 - Nice work Riza
ISK. Invert SoftKey Text Selectable
CMB. Call Minutes Beep Modification v2
RWNSM. Read & Write New SMS in Mp3
These patch allow to record only outgoing calls
Short press recod button start recording without promt, long press record button start ;playng last recorded message whith promt
Starting midlet then new sim-card is installed in SL45
Start dictaphone recording at start of outgoing calling v0.2
Auto record Voice call
Automatic recording for incoming & outgoing voice calls
Page 13
Show both name & phone number at incoming call
Drawing signal level in dB and battery level in mV
No battery sound in silent or beep mode (like in S/M45)
Turning on/off backlight while writing SMS
Here's an update for the auto record patch. You have to apply it additionally to the previous patch.
Voltage of battery in MP3 by Green button
Date as Mo,12 Apr
Round Softkeys v1
Round Softkeys v1 - other round corners
Buttons Animation 'Menu' and left SoftKeys v 1.2
Patch combination:
; some actions during MP3 listening
; shows voltage of battery by pressing green button
; switches illumination by pressing record button
Indicators: volume, bass, treble, clock and change bass and treble in MP3 and digital clock (on Info button)
Mp3 while keylocked
Automatic recording for incoming & outgoing voice calls v2.1
Page 14
Shutdown melody
Eliminate message "New text message recieved"
Round Softkeys v1 - selectable
Autoredial with constant pause
Compression of SMS, beta 2
Show both name & phone number at incoming call v2
Shows battery status in percent
No sound on start of recording
Change logon-sound
Remove, center etc. Date & Clock
Change logon-sound v2
Show current temperature instead of time
Compression of SMS, final version
Selectable Hourly Beep
Page 15
Flip Screen switch hotkey
SDS. SMS Delete Shortcut
APO. Auto Power ON
Improved Net Indicator for SL45
SVS. SMS View Shortcut
Old 06-10-2004, 23:59   #2 (permalink)
Member: 68376
In case I need more room for future patches.
The above post almost reached 10000 words
Old 06-11-2004, 21:24   #3 (permalink)
trustkill's Avatar
Member: 27745
Respect ! You did a good work !
Maybe some mod would be so kind and put this one as a sticky ?!
Old 06-12-2004, 00:25   #4 (permalink)
Member: 9891
Thanks Meter: 2
Yes, TOC idea is very helpfull, but I think it is better to modify the 1st page of each Flash patch topics to become a TOC ones, rather than put another Sticky (there will be too many) for ...
So, everybody who need to go to the specific patch, just need to check the 1st page and then get the correct link ...
I will do it for some Sticky which was started by me ...
rizapn
Old 06-12-2004, 01:08   #5 (permalink)
Member: 52459
Smile OH MY GOOOD!thx man..
if you put all these patches in to few pages, All of us will be very very very happy.
cos while searcing for a patch i could be blind,i checked nearly 90 pages to find what is function 15.
i hope we can see these pages soon.1000 of thx again
ps: i saw some patches that i missed while looking, lets see
Old 06-12-2004, 01:15   #6 (permalink)
Member: 9891
Thanks Meter: 2
Sorry, after rechecking the Sticky, both SL_Flash_Patches and SME_Flash_Patches was not started by me, so I can not modify the 1st page ...
rizapn
Old 06-12-2004, 01:16   #7 (permalink)
Member: 52459
Question To master Riza
i wanna ask can we have the call logging patch soon? i know trustkill was masking this patch but,im not sure, maybe with your help.Also is it possible to write logs in sl45 into a txt file( like c55)
i hardly need this patch(cos friends nagging my head like" I call you 20 times but you just did a ring" Of course because of my sl45 cant count how many times he call,just see who and when)
thx
Old 06-24-2004, 18:18   #8 (permalink)
Member: 30924
thank u for ur great help
Old 06-30-2004, 07:14   #9 (permalink)
Member: 68376
Hmmm for some reason I am not given the privilege or access rights to modify my own posts????
I am wanting to add to my original post and add links to the actual pages.
I'll put the links here for now but was hoping I could place them in original post
Page 1
Page 2
Page 3
Page 4
Page 5
Page 6
Page 7
Page 8
Page 9
Page 10
Page 11
Page 12
Page 13
Page 14
Page 15
Page 16
Page 17
EDIT: I was able to edit this one but still no luck with original post????
Old 08-11-2004, 20:04   #10 (permalink)
trustkill's Avatar
Member: 27745
Moving the thread back on focus...
Old 08-12-2004, 05:54   #11 (permalink)
Member: 68376
Thx Trustkill.
I might just start a new one up every few months or so.
I still cannot edit my own posts.
I have seen the threads re: New adminitrator
And I saw the reply how they do not see why someone would want to edit a post that is older than 2 days =/
What are your thoughts?
Old 08-17-2004, 09:43   #12 (permalink)
xc8
Member: 29824
RoadMap and more...
The TOC is a GREAT idea..
One other idea (for my opinion) is a "roadmap of patches"..
I see a lot of patches revised and impoved..
That is you have to undo the old patch in order to apply the new..
The roadmap may be like this
[Patch xxx by aaa v.1]-> [Patch xxx by aaa v.2] ....
[Patch uuu by bbb v.1]....
of course the [xxxxxx] are links to the patches...
Also, a big thing that is missed from the pathes is a patch memory map
like this :
|Address From - to | Comments |
|0x30000-0x30040 | used by xxx patch by YYYY |
|0x30060-0x30090 | used by cccc patch by aaaa |
I think this will help any future patch conflicts..
Regards
Chris
Old 08-17-2004, 10:40   #13 (permalink)
Member: 9891
Thanks Meter: 2
@xc8 ...
good idea, hope somebody will start doing that documentation stuff ... It will help most people, including patchers ...
rizapn
Old 08-21-2004, 08:41   #14 (permalink)
Member: 68376
I could do that.... Take a lot of time though...
Cross referencing will be a PAIN!
Not inlcined v/ much due to lack of edit feature in forums.
Any word on this yet?
What I might do is create a new thread.
Every week or so I shall just add post to thread for 12 weeks.
After 12 weeks I shall re-create thread with all updates and links.
I am off on holidays in a week for 2 months soooo...... this task is still up for anyone else interested. Just don;t expect anything from me while on holidays. =)
Old 08-21-2004, 16:03   #15 (permalink)
Member: 41707
I started (half a year ago) to organize all the patches in an SQL db.
Then I created a php script to display all patches with tickboxes that displays all the patches that were ticked.
However the db is quite old (and i cannot update it, we have OLYMPICS here in greece)
Once i update it i will repost...
SLIKv56: Flash patches. arman68 x4x, x5x Flashpatching 685 10-02-2011 10:56
Here Correct method for unlock u700 flash patch zakryia UST Pro II 36 05-14-2008 13:38
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 10:51
"Bugs" in Thread SLIKv56: Flash patches trustkill Siemens-Benq Flash Patching 2 07-13-2004 07:33
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 03:20
Page generated in 0.32079 seconds with 10 queries
