Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 05-31-2008, 08:58   #1 (permalink)
astana2007's Avatar
Member: 285345
c55 light blinks only
I have a c55 on light blinking.
I face this problem 2 times before.
problem solved both times using JOCKER.
but this time problem is not solving.
here the logs
****** Joker Siemens EGOLD Phone Version 0.3.5.6c Inofficial opened. ******
****** Friday, May 30, 2008, at 23:33:52 ******
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
HWID: 130 (C55)
C55 lg6 Sw24 03.06.03 13:58:40
IMEI: 351011521688921
Code(05): OTP closed
Code(08): BootKEY is unknown
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 4200 mV.
SecurityMode: Customer
Instance Format...
No Ping mobile
Old 05-31-2008, 09:03   #2 (permalink)
astana2007's Avatar
Member: 285345
****** Saturday, May 31, 2008, at 01:01:46 ******
Open file "H:\Devices\Mix\siemens joker\Files\C55_full_v18_lg91\C55_full _v18_lg91.bin" for write in Flash.
FullFlash file info:
FlashID: 002C/0017
SIEMENS C55 Sw18 lg91
RealLgPack: lg91
Start...
Loading BootsModel(C55)...
StartBoot does not answer!
****** Joker Siemens EGOLD Phone Version 0.3.5.6c Inofficial closed. ******
****** Saturday, May 31, 2008, at 01:02:44 ******
Old 05-31-2008, 09:50   #3 (permalink)
Member: 369802
FlashID: 002C/0017
RealLgPack: lg91
Start...
try freia 18 it works perfectly for me.good luck
Old 05-31-2008, 11:39   #4 (permalink)
Moderator
dagos's Avatar
Member: 416908
here the logs
Start...
HWID: 130 (C55)
Instance Format...
No Ping mobile
...hmm,
seems to be bootcore. Verify first cable, COM port connection, baudrate to 115200 and try to enter in service mode. If enter, fullflash again (check ReCalc Keys). If not, try with Freia.
BTW: make more times format, destroy your phone...
dagos
Old 05-31-2008, 12:09   #5 (permalink)
astana2007's Avatar
Member: 285345
JOKER is unable to solve the problem.
Now I m looking towards freia18.
can u tell me how to use it.
I never use this software before today.
Old 06-01-2008, 05:33   #6 (permalink)
Moderator
dagos's Avatar
Member: 416908
OK,
In attachemment you have the Freia software.
Select Phone Model: C55 and go to "Configuration Functions". Select on which port you used (I suppouse to you have serial cable), select speed to 115200 and boottype to normal.
For flash: Go to "Write flash to phone" and select the fullflash file (.fls or .bin provided by V-Klay, not from Joker or SST!!!).
If you want to flash bootcore area, you need to select Bootcore, for Eeprom select EEProm1 and for firmware upgrade select Firmware (this is fullflash, but not write the bootcore area). Click to OK, push shortly the phone Power On button and wait...
For unlocking: Go to the "Unlocking functions", select "Direct unlock no map is saved", click on "Use original IMEI" and unlocking process is started.
Note: after each fullflash, you need to unlock your phone.
Working fullflash (backup from my phone) you finded on:
-for Joker http://rapidshare.com/files/90826811/C55lg4Sw24_FF.rar
-for Freia http://rs373.rapidshare.com/files/97767619/C55.rar
Search on my responses to the other members to know detailed how to flash or unlock using Freia.
dagos
The Following User Says Thank You to dagos For This Useful Post:
BLACKBERRY 7290 RED light blinking only ? harish35200 BlackBerry (RIM) 2 12-24-2008 06:37
l7 keypad light blink only help mobilejunc Motorola Hardware Repair Section 3 09-05-2008 14:50
6131 light blink only ruvanw1979 Nokia Base Band 5 ( BB-5 ) 8 11-20-2007 20:35
Z520i lcd light blinking only cellbhai Sony Ericsson Hardware Repair Area 1 11-25-2006 18:55
Page generated in 0.26094 seconds with 11 queries
