Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-10-2007, 06:41   #1 (permalink)
bkq
Member: 192899
Can SL45 access two partition in one MMC card?
I splited 32M card in two partition (in linux), each partition is 15M.
But SL access only first partition. Is there any solution to this problem?
The reason why I split MMC card is that I want to use 2G MMC card with SL45. When i used 2G MMC+ card with SL45, it recognize capacity of the card. But it can't read or write file on the card.
Old 03-12-2007, 16:34   #2 (permalink)
Member: 264245
Siemens phones (from SLIK to S75) don't work with MMC more than 1 GB
Recognizing capacity - maximum what phone can do with MMC.
Old 03-13-2007, 10:02   #3 (permalink)
Member: 93204
Really? That's interesting. Have you got any proofs?
Do you think that this is fake?
Old 03-15-2007, 17:00   #4 (permalink)
bkq
Member: 192899
I had same result when put 2G MMC Plus Transcend in SL45.
This is the "entire picture":
Old 03-17-2007, 04:43   #5 (permalink)
Member: 414158
you can use 56 this falsh can use 2g card
Old 03-17-2007, 19:01   #6 (permalink)
bkq
Member: 192899
My firmware is slik 56.
Old 03-30-2007, 11:33   #7 (permalink)
Member: 42457
@bkg
as you wrote "2G MMC+" - card
MMC+ can't be handeld by SLIK phone. I think it has something to do with the current used by these cards. Just MMCs should work.
SLIK uses FAT16 - so the physically border is setted to 2GB not more.
Sized more than 2GB is a fake less sizes (including 2GB) could work. Try simply more cards or ask people which card they use (including serial number or manufacturing date)
PS: I'm back again
Old 03-30-2007, 11:53   #8 (permalink)
Member: 93204
Originally Posted by cyperghost View Post
@bkg
Not exactly, dear cyperghost . MMC+ has backward compatibility with MMC.
True, byt not precise. FAT gives access to 2GB of data. If it's more, then simply is not accessible. But first 2GB works.
Old 03-30-2007, 15:46   #9 (permalink)
Member: 42457
Hello G_Spot
You're 100% right - I should better write. If more than 2GB are displayed in SLIKs Infoscreen than it's a fake.
Hmm... about MMC and MMC+
Okay backward compatibility. You know MS Word 6? Those documents should be compatible with WordXP but it is not 100% compatible
and I read in a German article about the difference between MMC and MMC+
"Quasi vollständige Kompatibilität zu allen digitalen Geräten mit MMC-Slot"
to some degree a complete compatibility to all digital devices with mmc-Slot.
But thanks for the usefull infos
cyperghost
source:
http://www.speichertempel.de/Details..._transcend.php
http://www.mmca.org/home
Old 03-31-2007, 15:56   #10 (permalink)
bkq
Member: 192899
@bkg
I used 1G MMC+ with my SL45 and it worked greet. I don't think MMC+ is problem.
Two network in one sim? visionmaster20 Sim Cloning and Scaning 27 06-22-2007 18:34
SL45 handsfree only works in one side? eddyb Siemens Hardware Repair Area 0 04-17-2004 22:39
Universal simcard to hold two sims in one man0n Sim Cloning and Scaning 0 08-29-2003 16:46
Page generated in 2.55906 seconds with 12 queries
