Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-19-2006, 14:12   #1 (permalink)
Member: 153653
Disable PIN check?
hi.
i wonder if someone found a way how to disable main PIN checking option (when turning on the SL45i) or write to fw this code so phone can use it in autologin way.
there is already patch to disable PIN2 checking so maybe someone of you know some way.
i would like to use Auto Power On patch but with pin check it's useless
regards.
Old 02-19-2006, 14:20   #2 (permalink)
Member: 42457
So it seems you can't disable PIN check? It's a pity that providers sometimes don't offer this possibility on their SIM cards.
Old 02-19-2006, 14:20   #3 (permalink)
Member: 150519
Rst7 wrote, that disabling PIN1 is impossible!
Just disable "Enter pin" promt in menu-9-3-4
Old 02-19-2006, 14:38   #4 (permalink)
Member: 42457
Is I wrote, not all SIM cards allow it to disable PIN1 checking
Old 02-19-2006, 17:04   #5 (permalink)
Member: 153653
hi.
Originally Posted by cyperghost
... not all SIM cards allow it to disable PIN1 checking
exactly!
so no chances to disable?
but maybe something with autologon.
i.e when the phone starts up it can read PIN code from firmware and use it instead of.
hint: when i used AT+CSGN Debugger, i have found that hear (about page:2 offset:399A) are those numbers what we entered when prompted about PIN.
regards.
Old 02-19-2006, 17:29   #6 (permalink)
Member: 70080
on incorrect PIN1 not worked A3/A8 algoritm
Old 02-20-2006, 10:11   #7 (permalink)
Member: 153653
hi.
but i know what the PIN1 is, so it is only question of reading it automatically.
Latest version of NSU checks for SIM card, any way to disable/prevent check? kocoman Nokia Base Band 5 ( BB-5 ) 0 04-20-2007 02:09
ZULEA!?W800 R1AA008 disable OTP_imei-check? Die 1973 SonyEricsson (USB-Smart) 0 12-23-2005 06:01
disable aero check & siemens eeprom tool by skylord doesn't work... eio x1x to x45/x50 1 05-05-2003 13:57
Disable CRC Check Kunio x1x to x45/x50 1 04-07-2003 21:06
How To disable Aircraft check on S45i Gsm Trade x1x to x45/x50 3 01-02-2003 19:04
Page generated in 0.27779 seconds with 11 queries
