Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-06-2005, 21:37   #1 (permalink)
Member: 42457
DSM: Problem Discussion
Some people occour problems with DSM1 and DSM2 - Patch "DSM = Direct Send Message by RizaPN"
Okay.... how does these problem be announced?
Simply.. You write SMS Message, go to adressbook entry and phone switches off
For several weeks I made complete new backup of my SL45 firmware and now I tried DSM2 and it worked perfectly! Really! Then I deinstalled it and made DSM1 run and phone crashed. Now I switched back to DSM2 - phone crashed. I played a bit aroound with this patch and now I've got a check were we can test if DSM runs well or runs bad.
We go to SIM-Location, go to one entry (doesn't matter which one) select "Read" with left SK and press right SK (named SMS or SpeechControl - this depends on DSM2 patch installtion, you've got several options were this patch will be intagrated) what does happen?
If you got entry SpeechControl and you'll see screen "Press Start to start recording...." the chance is good, DSM could work
If you got entry SpeechControl and you will jump back to SIM-list well... then there's something wrong
If you got entry SMS, you'll switch to SMS editor. Try to send message... Does phone switch off?
If you got entry SMS, can you switch to SMS editor?
This patch gots really strange strange behaviour.... maybe someone can fix this?
File Type: txt DSM. Direct Send Message version1.vkp.txt (1.2 KB, 4 views)
Old 11-07-2005, 05:49   #2 (permalink)
Member: 70080
Mey be easier rewrite code, and debug, source DSM2 - in rizapn_asm.zip
Old 11-07-2005, 15:15   #3 (permalink)
Member: 42457
Hmm... well I'm not a patcher
But this will be best soltution surly. My "solution" in this case is to disable SIM part of this patch.
It would be nice if someone can debug this patch
Old 11-11-2005, 13:45   #4 (permalink)
trustkill's Avatar
Member: 27745
Yes, phone switchs off ! I use DSM v2
Old 11-12-2005, 10:36   #5 (permalink)
Member: 42457
@trustkill
Only way to "fix" this problem is to undo this part
;If you do not want to have "SMS" in the phonebook View screen, unmark these:
0x1A51C6: 4F02 3C02 ;text SMS
0x3E87FE: 46FC4500 DAE4A44B ;entrypoint
But then VoiceControll won't work with this item - see my first posting related! I just changed entrypoint and made a "workaround" solution. I'm not 100% happy with this but I eleminated way that phone could crash
SERVER STATUS USE V 2.2.0.0 - HWK Upgrade/Installation/Support Server Problem Discuss GsmMunna HWK 842 12-24-2011 22:25
Nokia 6500s camera problem discussion mobilagy Nokia Hardware & Hardware-Repair Area 6 02-11-2010 07:33
***NsPro v3.0.0 release Problems/Discussion Phoneze NSPRO 31 06-26-2007 17:23
Pocket PC Phones Problems discussion darin HTC & PDA WM( With Touchscreen) 4 11-01-2006 08:14
langeditor problems, discussing modrone x4x, x5x Flashpatching 13 09-23-2005 09:36
Page generated in 0.32940 seconds with 12 queries
