02-09-2006, 17:36 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | FAM 3.3 and EBIN I remember, there was a patch called "EBIN FAM3.2/BFA2.2 Patch2Patch". Maybe this is the reason ? Someone can do a "EBIN FAM 3.3 Patch2Patch" ? |
02-09-2006, 21:53 | #4 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | I have FAM2.1, with this EBIN is running fine. But FAM 3.3 collides with FAM 2.1, so I thought: You better undo the old version (2.1). After that EBIN doesn´t work / I have a call in my FAV Menu to the ZAD.bin (Megadial). Someone can tell me which FAM/BFA Versions I have to intall that all is OK ? |
02-09-2006, 22:01 | #5 (permalink) |
Freak Poster Join Date: May 2005 Location: Somewhere in Poland Age: 36
Member: 143475 Status: Offline Thanks Meter: 0 | Hmm I wrote that everything is fine because my phone didn`t turn off... So what`s wrong? What errors have you got? May I have it too and I didn`t notice... |
02-10-2006, 07:09 | #6 (permalink) | |
Junior Member Join Date: Sep 2005 Age: 44
Member: 181678 Status: Offline Thanks Meter: 0 | Quote:
FAM 3.3 does only for mp3 and EBIN worked on FAM 3.2 Maybe you need to redo EBIN... | |
02-12-2006, 12:22 | #7 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 41
Member: 91303 Status: Offline Thanks Meter: 0 | Hello! I tried to simply readdress fam 3.3 to address above fam 3.2 but after applying the patch, running mp3 and trying to enter card explorer the phone turns off. I double checked all the e-points but I found no mistake on my part. Does anyone of you found the solution for this problem? I also use fam 2.1 and 3.2 as Trustkill. |
02-12-2006, 12:40 | #8 (permalink) | |
Member: 27745 Status: Offline Thanks Meter: 0 | Aaah, now I see that I am not the only one who has this problem. Can we say that FAM 2.1 and 3.2 are not compatible ? Why are YOU using FAM 2.1 ? I dont know the reason why I have it, but if I undo FAM 2.1 some thing won´t work anymore... EDIT: I´ve seen our russian friends have this problem, too: Quote:
02-12-2006, 13:47 | #9 (permalink) |
Member: 91303 Status: Offline Thanks Meter: 0 | I use fam 2.1 because without it EBIN doesn't work and I need it. With fam 3.2 everything works perfectly, so they ARE compatibile. The problem is 3.3. I don't understand why after replacing it to an other address it doesn't work. |
02-13-2006, 13:44 | #11 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | OK now its clear: 1st: EBIN needs FAM 2.1 2nd: FAM 3.3 is not compatible with FAM 2.1 Solution: We have to redo either EBIN or FAM 3.3 @rst7: HELP ! :-) |
02-13-2006, 14:38 | #13 (permalink) |
Member: 143475 Status: Offline Thanks Meter: 0 | I don`t understand. I use this patches and my EBIN works... FAM 3.2 (only) ; *** FAM3.2 File Access Modification v3.2 *** (C)Rst7/CBSIE ; *** FAM3.2 ??????????? ??????? ? ?????? v3.2 *** ; void FilesysICall(void huge * proc, void far *param) at 0xE47FFC, ; ??? proc - void proc(void far *param), ; _NOT_DISTURB_ FAM2 ; sources on cbsie_narod_ru ; ??????? ?? ???????? ???. ???????. 0x449EDA: 46F82200 FAE4707E ; ??? ????? 0x447E60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A2A2046414D2076332E32202A2A2A ; ?????????? ??????? 0x447E70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F840002D0446F82200FAE4DE9ED440 0x447E80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0A00D4500C00D4C00E00D4D01000DAC7 0x447E90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88EEFAE448AB88F088E088D088C0E6FC 0x447EA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7038E0EDE6FE4000E00FDAC130AA06F0 0x447EB0: FFFFFFFF 0800DB00 ; ????? ????? FilesysICall ; ????? ??????? R12/R13 ? ????????? MMC_FILE_SYSTEM 0x447FFC: FFFFFFFF FAE4967E BFA 2.2b ;*** BFA. Binary file access v2.2b *** ; FW: SL45v56 ; v2.2b does not collide with BFP.Bitmap file preview 0x189E6E: 656D 6269 0x189E70: 6C 6E 0x189E95: 2E656D6C 2E62696E 0x18A22A: 1876 0E75 ; 0x38750C: E6FFE202 0D7CDAEF 0x387510: DAD712D90804 4036FAD81876 ; 0x4F3640: FFFFFFFFFFFFFFFF F0E8F0F906FEB200 0x4F3648: FFFFFFFFFFFFFFFF E6FC5636E6FDEF00 0x4F3650: FFFFFFFFFFFFFFFF DAE4FC7FDB00E00E 0x4F3658: FFFFFFFFFFFFFFFF E00FDADF3EA7F084 0x4F3660: FFFFFFFFFFFFFFFF 46F8FFFFEA208236 0x4F3668: FFFFFFFFFFFFFFFF F0C8E00DE6FE2000 0x4F3670: FFFFFFFFFFFFFFFF E6FFFF7FDADFAEAB 0x4F3678: FFFFFFFFFFFFFFFF F0C8DADF70C5DA08 0x4F3680: FFFFFFFF 0000DB00 FAM 3.3 ; *** FAM3.3 File Access Modification v3.3 *** (C)Rst7/CBSIE ; Use only with FAM3.2! ; Adds pause MP3 at the reference to a MMC ; transition to check additional functions 0x449EDA: FAE4707E FAE4A07F ; patch code 0x447F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A2A2046414D2076332E33202A2A2A ; add function 0x447FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAD0825E48402D13E6FCD27FE6FDE400 0x447FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ECFDECFCE6FCE835E0EDE6FEAC00E6FF 0x447FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2400DAC130AADAD0825E48403DFCFAE4 0x447FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 707EE6FCE835E0EDE6FEAC00E6FF2600 0x447FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC130AADAD0825E48402DFCDB00 EBIN ;*** EBIN. Entry-point for Binary file *** ;Firmware : sl45v56 ;Author : rizapn ;Created : March 2, 2005 ;Executing binary file through entry point ;The needed BIN file should be *copied* into the folder a:\zbin ;and the filename should be zaX.bin ... (X = a..p) ;The entry-point are : ; zaa.bin -> 0E47310h, zab.bin -> 0E47314h, zac.bin -> 0E47318h, ; zad.bin -> 0E4731Ch, ... zap.bin -> 0E4734Ch ;We can also execute some other file by using : mov r4, #YYXX ;then calls 0E47350h (filename = a:\zbin\zYX.bin). For example : ; zaq.bin -> E6F41000FAE45073 ; 1000 -> aq (10=16dec=q, 00=0=a) ; zba.bin -> E6F40001FAE45073 ; 0001 -> ba (00=a, 01=b) 0x447300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A204542494E2076312E30202A2A2A 0x447310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0040D1EE0140D1CE0240D1AE0340D18 0x447320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0440D16E0540D14E0640D12E0740D10 0x447330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0840D0EE0940D0CE0A40D0AE0B40D08 0x447340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0C40D06E0D40D04E0E40D02E0F40D00 0x447350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8840E6FC100088C0E6FC0008E0FDE6FE 0x447360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9233E6FF9103DAC7B4830802984006F4 0x447370: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6161E6FF2000E00EE0FDE6FC0008DC5D 0x447380: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E49C0900E48C0A00E085E004FAE4F87F 0x447390: FFFF DB00 ;Filename: 0x447392: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C7A62696E5C7A61612E6269 0x4473A0: FFFF 6E00 Correction for EBIN (may it`s that ? ) ; EBIN FAM3.2/BFA2.2 Patch2Patch (C)2005 by Rst7/CBSIE ; ; Need FAM3.2 and BFA2.2 patches ; ; Apply after EBIN, don't undo EBIN! ; ; For original BFA2.2 ;0x447388: E085E004FAE4F87F F0ECF0FDFAE49849 ; ; For BFA2.2b - readressed to 0x4F3640 0x447388: E085E004FAE4F87F F0ECF0FDFAEF4836 ;GoLL@B. |
3G & 3Gs easy and safe UNLOCK & Jailbreak solution OS 3.0 and 3.1 | matin-gsm | iPhone 2 / iPhone 3G / iPhone 3GS | 21 | 01-29-2010 05:59 |
5800d-1 unlock problem v.3.3 and 3.2 | unchiu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 01-17-2010 22:33 |
Motorola V70, V66, V60, T280 Unlocker and IMEI changer! New PST software ver.3.3!!! | VictorGSM | Main Sales Section | 0 | 04-16-2002 01:40 |
Motorola V70, V66, V60, T280 unlocker and IMEI changer! New PST software ver.3.3!!! | VictorGSM | Main Sales Section | 1 | 04-13-2002 18:58 |
Eprom tool 3.0/3.1 and 3210<->3310 | koax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-04-2002 16:00 |
