Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 07-17-2004, 12:26   #1 (permalink)
PYCON's Avatar
Member: 26267
FLASHING EEPROM ( SL45i ) -> CORRUPTED PATCHES ???
Hi men. Temporanealy it seems to be solved my problem with SL45i & Sensor Tool EElite BLOCK ID67. How? I've just flashed my phone with my original EEPROM.BIN file of 2 years ago... But I've a question. I saved that eeprom backup before the age of SL patches, therefore before the first patch. So... flashing eeprom I've corrupted some patches? Will I have problems? The phone starts with ALL the patches of APP Menu enabled... strange... Then I seems to be normal... but I'm afraid to have corrupted something of the patches ( at least 150 applied ).
Old 07-17-2004, 13:16   #2 (permalink)
Member: 9891
Thanks Meter: 2
Most of the patches has nothing to do with EEPROM.
As far as I remember, the patches which use EEPROM data are :
1. APP menu --> no problem, just modify them, and everything will be stored in the new EEPROM,
2. Password for SMS --> you may need to recreate the EEPROM block needed by this patch,
3. SMS Counter Info --> the displayed data will be changed based on the EEPROM value,
4. LOL (Loadable Op.Logo) --> just reload the screen style,
5. New menu item for Voice Command --> delete all, and then recreate
rizapn
Old 07-17-2004, 14:59   #3 (permalink)
PYCON's Avatar
Member: 26267
Thx a lot, great Riza... As in your post :
1) How do u mean with "modify" the APP Menu?
2) I've not applied SMS Password...
3) No problem, I'll just reset the values.
4) Just surf in the animations stored on the MMC, not a problem.
5) Ulp! I must delete all voice command... then recreate them?
Thank u friend.
Old 07-17-2004, 15:48   #4 (permalink)
Member: 9891
Thanks Meter: 2
1) My "modify" was: go to the APP menu, and then select which function do you really need ... it was selected all because the value in EEPROM is 0xFFFF
5) If it is so important, just leave like that. You just need to delete them if you find some problem (if the value stored in the EEPROM is greater than the maximum ones used by your current firmware).
rizapn
Old 07-17-2004, 15:49   #5 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
Pycon, I've just answered you in our Italian forum
Old 07-17-2004, 20:07   #6 (permalink)
PYCON's Avatar
Member: 26267
@ RIZA
Great, I've solved the problem. Thank u very much... I flashed with the original eeprom, I've just to set some settings again. No problems... Now Sensor Tool has returned working fine.
@ LALO
Ya, I've read... Grazie assai amigo...
Old 11-29-2004, 19:39   #7 (permalink)
Member: 69547
SOS! BIG PROBLEM!
Lately, my SL45i (upgraded from SL45 using Chinese version 55 firmware) switched itself off automatically. I found RizaPN's advice here in the forum to write his eeProm. The auto-off problem upon receiving/sending calls and SMS has been rectified, but a problem of graver magnitude has emerged: when I copied phone numbers from SMS received, or keyed in phone numbers into phonebook on the MMC, the phone hanged, and the MMC has been destroyed! A 128 MB and 64 MB cannot be formatted or accessed using the phone! Using a card reader connected to the USB port of my notebook to format or access the card too has failed--the hour glass keeps appearing forever, and restarting my notebook cannot be restarted by control-alt-del, but must be reset!
1> Anyway I can get back data on the MMCs?
2> What is the cause of the above?
3> How to recetify this?
I gave up using NOKIA 3650 and returned to the beloved SL45i, but this is truely sad for me losing valuable phone numbers and notes written MicroReader stored on the MMCs. Any advice will be greatly appreciated!
Cordially,
Hon [email protected]
Old 11-29-2004, 21:22   #8 (permalink)
trustkill's Avatar
Member: 27745
@k1ngkong: Why do you post the same thing twice ?
Need Urgent Reply !! Can Mx -> Imei patch -> 2310 Faisal_Computer MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-10-2010 14:49
contact service after flash nokia 1680c > Patch file not found one9 Universalbox 6 01-07-2009 09:09
SL45i -> Nokia 6100 -> SL45i cyperghost Off Topic Zone 4 09-12-2005 22:31
help in sl45i black list patch lazioroma x4x, x5x Flashpatching 23 12-15-2004 22:37
downgrade sl45i -> sl45 ?! geleto x1x to x45/x50 6 07-03-2003 02:59
Page generated in 0.31474 seconds with 8 queries
