12-12-2005, 19:37 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Somewhere in Poland Age: 36
Member: 143475 Status: Offline Thanks Meter: 0 | Mini GPS 1.4 where is x and y ? Code: *** MiniGPS v1.4 *** ;Firmware: SL45v56 ;Author: DeadManS ;Release: November 03, 2004 ;Update: December 29, 2004 ;Need SOL3! ; you can store names of ci in FullFlash (block 1?) max size of block ;16kB( 4000h), also use 5169 block of eeprom from 1.2 version (not more 1 kB) ;you must open file in hex editor, edited FF in the end of file ;and then write in Fflash from 1C0000 ; HAPPY NEW YEAR!!!...)) 00F398: 66FCFF3F DAE0BAD4 3b36b8: 88908880 DAE060D3 ;---- New block. Segment address:E00000-------- 0040D360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C0884088508860D7403400F3F81B3E 0040D370: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4980EA2068D4D7400E00F2F4861D3C84 0040D380: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7402000F2F5000040452D4DD7402000 0040D390: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6F40000E00C88C088C088C0E6FC0004 0040D3A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C0E6FC3114E6FD1C00E6FE2000E00F 0040D3B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC23E2F06F00800E004E02CB8C0E02C 0040D3C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD2000DC4DE48C0400E00EE6FF2000 0040D3D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC73280E004D7402000F6F40600E6FC 0040D3E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F002E00DBB4848412D07E6FC2000E6FD 0040D3F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1C00BB4148402D1708D5E02EDC4CA9CD 0040D400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47FC0D002D06D7402000B9CE08D108E1 0040D410: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0DF5E004D7402000B98ECC00CC00CC00 0040D420: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC00CC00CC00E00C88C0D7508303F2FF 0040D430: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3215F2FD3415E6FE6500E00CDAC0D0E5 0040D440: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0802E02EE6FF2000E084884088F088E0 0040D450: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7508303F2FF3215F2FD3415E6FE6500 0040D460: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CDAD658A3080698609850984098C0 0040D470: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88908880DB00D7502000F2F40200F2F5 0040D480: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0400DC4CA9CD47FCFF003D02E004CB00 0040D490: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 418C3D11DC4CF4CD0100419C3D0CDC4C 0040D4A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F4CD020041AC3D07DC4CF4CD030041BC 0040D4B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02E014CB0008D10DE488C0E6FD2000 0040D4C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC1C00E6FF0204E6FEFF00DAC71684 0040D4D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD8303E6FC2815DADF3EA746F4FFFF 0040D4E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1FF0C488C0E6FE2000E6FD1C00E6FF 0040D4F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0004DADFAEAB98C0DADF70C5E00C88C0 0040D500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088C0E6FC000488C0E6FC3114E6FD 0040D510: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1C00E6FE2000E00FDAC2922F06F00800 0040D520: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C066FCFF3FDB00613A5C63692E7478 0040D530: FFFFFFFFFFFF 740009000700 |
12-14-2005, 19:52 | #3 (permalink) |
Member: 143475 Status: Offline Thanks Meter: 0 | Ok, I`ll check it. Can somebody explain me what must I do: ";Need SOL3! ; you can store names of ci in FullFlash (block 1?) max size of block ;16kB( 4000h), also use 5169 block of eeprom from 1.2 version (not more 1 kB) ;you must open file in hex editor, edited FF in the end of file ;and then write in Fflash from 1C0000" Must I edit my block 5169 and there I can write my names? Or how to do it? |
12-15-2005, 20:38 | #4 (permalink) |
Junior Member Join Date: Nov 2004 Age: 42
Member: 91950 Status: Offline Thanks Meter: 0 | for v1.4 40D530: 74 z4 ;font style - not sure 40D532: 09 0h ;height (for this font) 40D534: 07 2y ;y pos I don't know about x pos.. it seems it's centered automaticaly, yes use a hex editor on 5169 block, end with a FF (not sure about the first block) and a question/request: can it be made to display over the background bitmap, it stays hidden like the operator name, and like in 1.2 keylock dependent movement?? |
12-19-2005, 15:42 | #5 (permalink) |
Member: 143475 Status: Offline Thanks Meter: 0 | Ok, May I try... but How must I write my names? I opened my 5169 block. It looks: 00 00 00 00 01 00 00 00 31 14 00 00 18 04 00 00 00 00 00 00 65 2F 01 00 00 00 00 00 and later only FF FF. How to do it? I must start writing from end? So I write... f.e F4BBDzialoszyn (F4BB - code , Dzialoszyn - name (of course it will be prepared in hex) but how must I write? Dzialoszyn --> (44 7A 69 61 6C 6F 73 7A 79 6E), F4BB --> ( 46 34 42 42 ) So in the end it should look like: ... FF FF FF FF 46 34 42 42 44 7A 69 61 6C 6F 73 7A 79 6E ?? Thanks for help. |
12-30-2005, 14:33 | #6 (permalink) |
Member: 143475 Status: Offline Thanks Meter: 0 | I did keypad dependent and APP dependent but I have a problem... When MiniGPS works only if keypad is locked it doesn`t use txt file so I have only code... not description... Is it possible to correct it? For minigps (I found) 40D532: 09 0h ;height (for this font) 40D534: 07 yy ;y pos 40D448: E084 E094 ; E0x4 - x - font I have found x position too but I don`t have it at the moment. I`ll give it later. |
YES where is laser and setool crew | mbourtelephone | SETool2 | 23 | 04-30-2008 06:54 |
where is mbus and fbus for infinity slim plus | f164 | Infinity-Box | 3 | 04-05-2008 23:20 |
Where is Julvir and Mr. gorr? | i_am_rocky | Redbox | 7 | 11-23-2006 11:48 |
Where is Z500v and E350e in NSdoungal, | Irfangk786 | NSPRO | 2 | 11-14-2005 23:09 |
where is nec and alcatel support in SUPPORT AREA? | ilcisi | Phoenix Black Box | 5 | 08-24-2005 06:13 |
