08-30-2004, 07:53 | #1 (permalink) |
Freak Poster Join Date: May 2004
Member: 65231 Status: Offline Thanks Meter: 0 | Interesting battery issue Also, a question, when I flash fubu, do I need to have battery fully charged or it doesn't matter? (since it says to have battery fully charged when changing fw, but I don't know about flashing full flash with VKlay) |
08-30-2004, 09:42 | #2 (permalink) |
Crazy Poster Join Date: May 2004 Location: Wloclawek;Poland Age: 38
Member: 66558 Status: Offline Thanks Meter: 0 | Try to change your battery settings (using *blk files). I had the same problem, and now it is okay. About battery charge when flashing, I'm not shure, but I think it is not nesesary to have full battery. |
08-30-2004, 09:43 | #3 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | The battery parametes are stored in the EEProm area. If you use a Fubu from annother mobile then the battery paramters are also changed and this can be the result of the strange behavior now. IMHO there's no need to fullflash with charged battery if you make a backup of your EEP before. Or if you use a Fubu of annother mobile and after flashing you use your EEP again....... But please don't start to play around with the parameters using sensortools. There are thounsands of those blk files but noone will fit to your phone with one exeption, your own you've read out from YOUR phone (of course the one from your original FW version ) About flashing... in x35 and x45 series you can use UniSiemens as flasher. The interface is much more user friendly and works best with SL45 |
09-01-2004, 09:29 | #7 (permalink) |
Member: 65231 Status: Offline Thanks Meter: 0 | Yes, I also have those kind of variations, when sending sms, using java or calling, there appears variation in battery fullness but it's not so big difference in my case. More like 10-15%. So, how did you solve your problem? |
09-01-2004, 18:52 | #9 (permalink) |
Member: 65231 Status: Offline Thanks Meter: 0 | Those varaiations are not a problem for me normally, but it is irritating when charging battery. Because, it shows 100 % quickly even though battery is not loaded. Also, this did not happen before, even though I used java and other... so does anyone know what may be the problem and how to solve it? |
SciPhone i68+ battery issue | grim804 | Chinese Models & Cloned Phones | 0 | 03-04-2009 08:00 |
Battery issue | omegan | HTC & PDA WM( With Touchscreen) | 0 | 04-01-2008 01:53 |
W300i Battery Issue? | BigRed01 | Sony Ericsson | 1 | 11-25-2007 12:28 |
W300i Battery Issue? | BigRed01 | Sony Ericsson | 1 | 11-20-2007 14:21 |
Charging 2nd battery issue | zalaros | E-Gold Based Phones | 1 | 02-04-2005 18:43 |
