Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 07-06-2005, 16:04   #1 (permalink)
Member: 143475
Invert softkey - keypad dependent
(*** ISK. Invert SoftKey Text Selectable ***)
Did somebody succeed keypad dependent for this patch?
I tried but without result. I would want to have invert only if I have keypad locked.
I am trying to do date position - keypad dependent, so far-without result
Are these patches already done ?
Regards, GoLL@B.
Old 07-06-2005, 19:48   #2 (permalink)
trustkill's Avatar
Member: 27745
Yes, these patches are in the patches sticky above.
Old 07-07-2005, 13:44   #3 (permalink)
Member: 143475
@masters: Can You help me in looking for these patches? I used search function, wrote "Invert softkey" and next "date position", I looked for results and I didn`t find anything
I looked for in topics: Patching: Technical Discussion,SLIKv56: Flash Patching (3rd part) and in SLIKv56: Flash patches. Can You help me?
Old 07-07-2005, 15:37   #4 (permalink)
Froster's Avatar
Member: 91303
GoLL@B, but what would you like to do with the date? I made such a patch a while ago:
;*** Wyśrodkowana data zależnie od stanu klawiatury ***
;Firmware : SL45v56
;Original Author: trustkill www.gsm-modding.de
;Update: Froster dzięki naukom vBarta
;Released : 8.12.2004
;Jeśli poprzednia wersja patcha została wgrana należy ją usunąć.
;POPRZEDNIA WERSJA Z ORYGINALNEGO PATCHA Trustkilla:
;3B00AA: E6FE1DE0 E6FE1EE0
;Patch wyśrodkowuje datę w zależności od stanu klawiatury.
;Jeśli chcesz aby data była wyśrodkowana na stałe, niezależnie od stanu
;klawiatury wgraj tylko powyższą linię.
3B00AA: E6FE1DE0 DAE4904F
444F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0DAA3924098D098C048402D02
;444FA0: FFFFFFFFFFFFFFFFFFFF FAE4B04FFAE4B64FDB00 ; Przy odblokowanych
444FA0: FFFFFFFFFFFFFFFFFFFF FAE4B64FFAE4B04FDB00 ; Przy blokadzie
444FB0: FFFFFFFFFFFF E6FE1EE0DB00
444FB6: FFFFFFFFFFFF E6FE1DE0DB00
Of course there are more possibilities. I also made the date format dependand - standard and Monday 4 July. If you wish you can write to me on the polish forum of just prv me.
Old 07-07-2005, 23:27   #5 (permalink)
Member: 143475
I would like to change Y coordinations when keypad locked. Is it possible?
And the softkeys? Is this patch already done?
Old 07-08-2005, 08:55   #6 (permalink)
trustkill's Avatar
Member: 27745
I invert my softkey only if function "Invert Display" is NOT selected.
So the only thing I had to to is to put these 2 patches to the same AppMenu, do a shortcut for it and call this shortcut when "#" is long pressed.
The "move date string when locken/unlocked" patch is not made yet.
Maybe someone will do it in the future, BUT there are at least 3 values to be changed when keylocked:
; Vertical movements
;0x18E6C2: 31 XX ; Logo mode
;0x18E67A: 31 XX ; Netsearch mode
;0x18E6A2: 31 XX ; Normal mode
Old 07-08-2005, 10:46   #7 (permalink)
Member: 143475
I have Invert Display in Function 1 in App
Must I do Invert Softkey in Function 1?
How Can I do it? How Can I do this shortcut. Can You give me the code?
I need only 0x18E6C2: 31 XX ; Logo mode, because I use almost always this mode.
Old 07-08-2005, 11:37   #8 (permalink)
trustkill's Avatar
Member: 27745
This evening I will try to explain, I´m @work now...
Old 07-08-2005, 20:28   #9 (permalink)
trustkill's Avatar
Member: 27745
@Gollob: Do you have "Invert Display when keylocked" ?
Old 07-08-2005, 22:00   #10 (permalink)
Member: 143475
No I don`t use it. I`ll try to find it.
ps.ok I`ve got it.
; *** Invert Display @ Keylocked ***
; Firmware : SL45v56
; Author : trustkill
; Release : June 29, 2004
; Homepage: www.gsm-modding.de
; With this patch your Diplay inverts when keylocked by pressing #
; or autokeylocked (calls Funktion 1 in APP Menu)
; needs many other patches too, its useless if you dont know
; what you are doing here...
362AFC: DAC1C8FB DAC7E0D3 --> Call to patch if unlocked
3AD292: E6003600 DAC7E0D3 -> call to patch if locked by #
3B02AA: DAA38040 DAC7C0DC -> call to patch if autolocked (buggy)
Old 07-09-2005, 08:51   #11 (permalink)
Member: 143475
@trustkill What must I do with it?
My selectable invert softkeys.
;;*** ISK. Invert SoftKey Text Selectable ***
;Firmware : SL45v56
;Author : RizaPN
;Release : November 8, 2003
;Update : March 12, 2004 by rc-flitzer
;This patch will invert the soft key display, black text with
;white background
;Update: Patch now selectable through application menu via function 13.
;Please undo previous version.
0x27D6C0: FFFFFFFFFFFFFFFF D7400E00F2F1423A
0x27D6C8: FFFFFFFFFFFFFFFF 9AF102C0E0010D02
0x27D6D0: FFFFFFFFFFFFFFFF E6F16000DB00D740
0x27D6D8: FFFFFFFFFFFFFFFF 0E00F2FC423A9AFC
0x27D6E0: FFFFFFFFFFFFFFFF 01C0E007E6FC4000
0x27D6E8: FFFF DB00
0x20DFFE: E6F16000 DAC7C0D6
0x20E10A: 8870E6FC4000 DAC7D6D68870
; for selection by other function number than 13, change this:
;0x27D6CB: C0 x0 ; where x is function number minus 1 (i.e. 0-F for function 1-16)
;0x27D6E1: C0 x0 ; Do use SAME x-value as in line above!:
Must I change this epoint? DAC7C0D6 ? And Invert Softkey must be in Function 1 in APP?
Old 07-09-2005, 12:44   #12 (permalink)
trustkill's Avatar
Member: 27745
O dear if I only had more time....
I have no documents about the things I did with my phone (its 1 year ago)..
The only thin I found is this, i hope it will help you:
; *** Invert Display Hotkey ***
; Release : June 26, 2004
; With this patch you have a hotkey for "Invert Display"
; instead of "User Group". It overwrites the patch "Flip Screen Hotkey"
; from arsh0r, you better undo that patch before.
; Invert both softkeys & Display when APP Function 1 is selected,
; needs at least JAF.Funny Display & ISK.Invert Softkey selectable:
;0x27D6CB: C0 00
;0x27D6E1: C0 00
0x18E388: 8B00 A804 ;string #8B -> #4A8
0x18E3BC: 8C00 A804 ;string #8C -> #4A8
0x18E4B8: 8B008B00 A804A804 ;same thing
0x3AE310: DAD70245 DAC7E0D3 ;call to patch
0x27D3E0: FFFFFFFFFFFFFFFF 88C0D7400E00F2FC
0x27D3E8: FFFFFFFFFFFFFFFF 423A9AFC02000EFC
0x27D3F0: FFFFFFFFFFFFFFFF 0D010FFCD7400E00
0x27D3F8: FFFFFFFFFFFFFFFF F6FC423A98C0DB00
6700c keypad problem luyanda Nokia Hardware & Hardware-Repair Area 21 03-12-2013 14:20
error = couldn't configure pre-depend dpkg for ncurses, probably a dependency cycle naj iPhone ,iPod & iPad (Apple Inc. Products) 0 06-22-2009 16:56
Battery stand-by depends on...? EmbaTa x1x to x45/x50 7 05-31-2003 19:40
Ki depend from IMSI? Kar@mba Sim Cloning and Scaning 1 01-16-2003 17:19
IMEI Dependent 7650 Software Beats WD2 & APE (Symbian Phones) 0 10-09-2002 18:54
Page generated in 0.57415 seconds with 11 queries
