12-18-2003, 20:27 | #17 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | ; M55 AT+CGSN Patch ; Firmware: M55v11 (conversion by ACiD [mrp]) ; Version 1.0b ; Loader: V-Klay 2.4+ / M55 ; Modified: 30.10.03/00.29.36 ; By SiNgle ; M55 adaptation&improving of patch by Chaos & RizaPN for SL45 ***** ; *** Modify AT+CGSN Command to do Debug *** ; *** Advanced debugging with AT+CGSN *** ; It is a USELESS patch, UNLESS you want to create patch and need to read ; the RAM area while the phone is ON. ; By applying this patch, it is possible to dump RAM and flash area through ; the serial port (use Hyperterminal like software) using normal AT ; command. ; SiNgle: change will provide more correct adress detection of our strings 004557E8: D849C200 F4147500 0055145E: FFFFFFFFFFFFFFFF E004BB029DFECB00 00551466: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49992827F230008D0C47F20A008D06 00551476: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182 00551486: FFFFFFFFFFFF CB001F88CB00 0055148C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182 0055149C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997 005514AC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0 005514BC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDAC31EC4080698C0 005514CC: FFFFFFFFFFFFFFFF 98F098E09850CB00 005514D4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4 005514E4: FFFF CB00 005514E6: FFFFFFFF 998C7C44 005514EA: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00 005514F4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC3A29AF084F095DC49993827F32A00 00551504: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FAC2D849BBA9F0F4BBA7F0E44930 00551514: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D2127F312002D18E6FD0D0A 00551524: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC 00551534: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D25 00551544: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D23DC4FB98E08E10DFADA759215 00551554: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBBFF0EFBBBD0D1926F04000F020BBC3 00551564: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D03B98208210DFB2020A758A7A708E1 00551574: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0AF010F0DEF0C2DC4F998D498D3DF5 00551584: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 28C13DFABBA506F04000FAC3A894 00551592: FFFFFFFFFFFF ECFFECFEDB00 ; Commands are: ; AT+CGSN ; Display IMEI, as usual ; AT+CGSNage,offset ; Dump 128 bytes of memory starting at address pageffset ; AT+CGSN.page,offset,data ; Search data on the given page, starting from offset. Data is a ; hexadecimal string without spaces. Offset is in range 0...3FFF. ; AT+CGSN*page,offset,data ; Write data to memory (RAM) at address pageffset. Data is a hexadecimal ; string without spaces. ; AT+CGSN@seg,offset ; Inter-segment call to address segffset. On return, values of r14 and r15 ; will be displayed. Note that seg is the segment, not the page (eg. if you ; wrote procedure to 11:500, call it at 4:4500). Procedure should end with ; far return. If the procdure consumes much time, make sure to insert ; srvwdt instruction in its loop. |
12-19-2003, 19:09 | #18 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia Age: 51
Member: 45697 Status: Offline Thanks Meter: 0 | ;*** Developer menu*** ;Firmware: M55v10 ;Loader: V-Klay 2.5 800A94: 2D 0D ;Firmware: M55v11 80177A: 2D 0D ;*** Explorer without SIM card*** ;Firmware: M55v10 368930: C404 5E05 368F46: C404 5E05 ;Firmware: M55v11 368BEE: C404 5E05 369204: C404 5E05 ;***Remove the question about copy address book when sim-card changed*** ;Firmware: M55v10 4F0F52: 3D 0D ;Firmware: M55v11 4EFA90: 3D 0D Last edited by WASP; 12-19-2003 at 19:19. |
12-20-2003, 12:50 | #19 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | ; Provider Name -> Time ; Firmware : M55 v11 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 000CC390: E04E00E0 DA68FA7D 000CC394: 66FEFF3F E6FE0001 000CC398: F2FF02FE E6FF0300 00487DFA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88608870888088C0D7400D00F3FEFE63 00487E0A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C7BB28D7400300F7FE00C1F078D740 00487E1A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F7FE01C1E7FE3A00D7400300F7FE 00487E2A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 02C1D7400D00F3FEFC63F0C7BB13D740 00487E3A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F7FE03C1F078D7400300F7FE04C1 00487E4A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E10ED7400300F7FE05C198C098809870 00487E5A: FFFFFFFF 9860DB00 00487E5E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC0EFEE0A65B66F2F70EFE1B67F2F8 00487E6E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFE20C8F08C06F7300006F83000CB00 |
12-20-2003, 12:50 | #20 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | Yet another Profil Logo ; Provider Name -> Profil Logo ; Firmware : M55 v11 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com ; Loader: V-Klay 2.4+ / M55 000CC394: 66FEFF3FF2FF02FE DA68A07ECC00CC00 00487EA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFA101D7401300F3FC22E648603D03 00487EB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE503FDB0048613D03E6FE603FDB00 00487EC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48623D03E6FE703FDB0048633D03E6FE 00487ED0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 803FDB0048643D03E6FE903FDB004865 00487EE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D03E6FEA03FDB00E6FEB03FDB00 00487F50: FFFFFFFFFFFFFF 4E6F726D616C00 ; Normal 00487F60: FFFFFFFFFFFF 517569657400 ; Quiet 00487F70: FFFFFFFFFFFF 4E6F69737900 ; Noisy 00487F80: FFFFFFFFFFFFFFFF 436172204B697400 ; Car Kit 00487F90: FFFFFFFFFFFFFFFF 4865616473657400 ; Headset 00487FA0: FFFFFFFFFFFFFF 55736572203100 ; User 1 00487FB0: FFFFFFFFFFFFFF 55736572203200 ; User 2 |
12-20-2003, 12:51 | #21 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | *** DigiClock in KeyLocked mode *** ; M55 v11 ; by ACiD [mrp], RizaPN ; www.gsm-dev.com ; Loader: V-Klay 2.4+ / M55 000DD650: E6FCB101 DA75B015 005515B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7500D00F2F1FE63F2F2FC638820 005515C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E0AEBB1426FC09009810BB03E6FC 005515D0: FFFFFFFF B101DB00 005515D4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 005515E4: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00 005515EE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE4C01E6FD1200DA2DB2D298C0 005515FE: FFFFFFFFFFFF 06FC1600CB00 ; change pictures: ; Pictures 332..341 = digit 0..9 ; Picture 342 = seperator ; Picture 343 = background |
12-20-2003, 12:52 | #22 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | M55 v11 Digiclock Pics by ACiD [mrp] ; ################################################## ##################### ; ### This file is made by ©SiemensPictureChange 2.0 - Build 1.0.1.0 ### ; ### programmed ©2003 by ACiD[mrp], Cluni and b@iLLi ### ; ### ### ; ### GSM Development Crew - www.gsm-dev.com ### ; ### GSM Multifund, Handyhacking - http://www.gsm-multifund.de/board ### ; ### ### ; ### Date: 14.12.2003 - Time: 14:37:31 ### ; ### Patch for: SIEMENS M55 v11 ### ; ################################################## ##################### ; ##### Picture 332 ##### ; Picture Table Index 308A60: 311301003F3F3801 162E010000008000 ; Picture Data 000000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000030FFFC31FFFE33FFFF33C00F33C 000010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 000020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 000030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 000040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 000050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 000060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 000070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF31FFF 000080: FFFFFFFFFFFFFFFFFFFF E30FFFC3000003000003 ; ##### Picture 333 ##### ; Picture Table Index 308A68: 3113010094133A01 162E01008A008000 ; Picture Data 00008A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00000300380300780300780300780300 00009A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 780300F80300F80300F80300F80300F8 0000AA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0301F80301F80301F803007803007803 0000BA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00780300780300780300780300780300 0000CA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 78030078030078030078030078030078 0000DA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03007803007803007803007803007803 0000EA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00780300780300780300780300780300 0000FA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 78030078030078030078030078030078 00010A: FFFFFFFFFFFFFFFFFFFF 03007803000003000003 ; ##### Picture 334 ##### ; Picture Table Index 308A70: 3113010019143A01 162E010014018000 ; Picture Data 000114: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000031FFFC31FFFE33FFFF33C00F33C 000124: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 000134: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F30000F30000F3 000144: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0001E30001E30003C30007C300078300 000154: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0F83000F03001F03001E03003C03003C 000164: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300780300F80300F00301F00301E003 000174: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03E00303C00307C0030780030F00031F 000184: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00031E00033E00033C00037FFFF37FFF 000194: FFFFFFFFFFFFFFFFFFFF F37FFFF3000003000003 ; ##### Picture 335 ##### ; Picture Table Index 308A78: 311301009E143A01 162E01009E018000 ; Picture Data 00019E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000030FFFC31FFFE33FFFF33C00F33C 0001AE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 0001BE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F30000F30000F3 0001CE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0001F30007E3000F83001F03003C0300 0001DE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7803003C03001F03000F830007E30001 0001EE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F30000F30000F30000F33C00F33C00F3 0001FE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 00020E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF31FFF 00021E: FFFFFFFFFFFFFFFFFFFF E30FFFC3000003000003 ; ##### Picture 336 ##### ; Picture Table Index 308A80: 3113010023153A01 162E010028028000 ; Picture Data 000228: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 000003001E03001E03001E03003C0300 000238: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C03007C0300780300780300F80300F0 000248: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F00301F00301E00301E78303C783 000258: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03C78303C7830787830787830787830F 000268: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 07830F07830F07831E07831E07831E07 000278: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 833C07833C07833C07837FFFF37FFFF3 000288: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7FFFF300078300078300078300078300 000298: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 07830007830007830007830007830007 0002A8: FFFFFFFFFFFFFFFFFFFF 83000783000003000003 ; ##### Picture 337 ##### ; Picture Table Index 308A88: 31130100A8153A01 162E0100B2028000 ; Picture Data 0002B2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000033FFFF33FFFF33FFFF33C00033C 0002C2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00033C00033C00033C00033C00033C00 0002D2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 033C00033C00033C00033C00033C0003 0002E2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00033FFFE33FFFF33FFFF30000F300 0002F2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F30000F30000F30000F30000F30000 000302: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F30000F30000F30000F33C00F33C00F3 000312: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 000322: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF33FFF 000332: FFFFFFFFFFFFFFFFFFFF F31FFFE3000003000003 ; ##### Picture 338 ##### ; Picture Table Index 308A90: 311301002D163A01 162E01003C038000 ; Picture Data 00033C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000030FFFC31FFFE33FFFF33C00F33C 00034C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 00035C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00033C00033C0003 00036C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00033C00033C00033C00033FFFE33F 00037C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFF33FFFF33C00F33C00F33C00F33C00 00038C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 00039C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 0003AC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF31FFF 0003BC: FFFFFFFFFFFFFFFFFFFF E30FFFC3000003000003 ; ##### Picture 339 ##### ; Picture Table Index 308A98: 31130100B2163A01 162E0100C6038000 ; Picture Data 0003C6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000033FFFF33FFFF33FFFF33C00F33C 0003D6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00E33C01E33C01E33C01E33C01E33C01 0003E6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C30003C30003C30003C3000383000783 0003F6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 000783000783000783000703000F0300 000406: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0F03000F03000E03001E03001E03001E 000416: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03001E03003C03003C03003C03003C03 000426: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 003C0300780300780300780300780300 000436: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F00300F00300F00300F00300F00301E0 000446: FFFFFFFFFFFFFFFFFFFF 0301E003000003000003 ; ##### Picture 340 ##### ; Picture Table Index 308AA0: 3113010037173A01 162E010050048000 ; Picture Data 000450: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000030FFFC31FFFE33FFFF33C00F33C 000460: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 000470: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 000480: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33E01F31F87E30FCFC303FF0300 000490: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FC0303FF0307CF831F87E33E01F33C00 0004A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 0004B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 0004C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF31FFF 0004D0: FFFFFFFFFFFFFFFFFFFF E30FFFC3000003000003 ; ##### Picture 341 ##### ; Picture Table Index 308AA8: 31130100BC173A01 162E0100DA048000 ; Picture Data 0004DA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000031FFFC31FFFE33FFFF33C00F33C 0004EA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33C00F33C00 0004FA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F33C00F33C00F33C00F33C00F33C00F3 00050A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 00051A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33FFFF33FFFF31FFFF30000F30000 00052A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F30000F30000F30000F30000F30000F3 00053A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C00F33C00F33C00F33C00F33C00F33C 00054A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00F33C00F33C00F33C00F33FFFF31FFF 00055A: FFFFFFFFFFFFFFFFFFFF E30FFFC3000003000003 ; ##### Picture 342 ##### ; Picture Table Index 308AB0: 31130100 0D2E0100 ; Picture Data 2E9841: 0000000F8381FF080003FF8E067F3E00 00070007000700070007000700070007 2E9851: 7FFF98707F078FFFFFB0FC7F81E7FFFF 00070007000700070F070F070F070F07 2E9861: 40BE7FE037F83F01867FF007F01F0F04 0F070007000700070007000700070007 2E9871: 7F0203FFFF4F0C7F0783E00E2E187F0C 0007000700070007000700070F070F07 2E9881: FBE00E00107F1831FFFE00F67F3871F0 0F070F070F0700070007000700070007 2E9891: 1E00E1FF0C71F83C30E07F0700FFFC0E 0007000700070007000700070F0F0F0F 2E98A1: 007F6380FFFC03807FC70CEFFCC0F07F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E98B1: 871856D8603C7F00706FF8700E7F0020 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E98C1: 7FF838007F 0F0F0F0F0F ; ##### Picture 343 ##### ; Picture Table Index 308AB8: 31130100 01010100 ; Picture Data 2E98C6: 00000FFFFE007F00003A4913007F0000 7F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E98D6: 632488807F4FFF419444807F000000FF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E98E6: FFC07F000000D444C07F000000522240 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E98F6: 7F0000005222407F20CFF07FFFC07F00 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E9906: 00003222407F0000003222807F5FFF00 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E9916: 3FFF807F0000003FFF007F0000003000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E9926: 007F0000003000007F0000007AFD007F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E9936: 00021CFFFF807F0000000701807F0000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2E9946: 000E03007F 0F0F0F0F0F |
12-20-2003, 12:53 | #23 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | ; deletes the softkeys from mainscreen ; Author: SiNgle, ACiD [mrp] ; Phone: M55v11 ; Loader: V-Klay 2.4+ / M55 0D5824: 3D05 CC00 0D5746: 2D04 0D04 ; press right_key to start the menu |
12-20-2003, 12:53 | #24 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | ; Date on MainScreen as Tu 09 Dec ; (c) SiNgle ; 09.12.03 ; ver 0.1b ; FW M55v11 ;converted & tested for v11 by nagual 0D5862: E077 E0D7 9FD7AA: DABFB2D3 DA5580B2 0035B280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 889088808860D460060046F60D003D56 0035B290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F09FF08E8880889088C088D0DABF90CB 0035B2A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 68475C14D7405601D414403398D098C0 0035B2B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98909880DC49B8180882E7F22000DC49 0035B2C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B9285044DC4DF48C0300E0A5F6F40EFE 0035B2D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D1004B55CC00F2F50EFE06F53000F015 0035B2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F50CFE06F530005C857015DC59E428 0035B2F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0100E4380200E7F22000DC49E4280300 0035B300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08845044DC4DF48C020028415C2406F4 0035B310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4E33D7405601A8140842D7405601A944 0035B320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E105DC79B928E4380100E4480200E458 0035B330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03000884986098809890DB00FABFB8D3 0035B340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4D6F5475576554684672536153754A61 0035B350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E00466562004D617200417072004D61 0035B360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 79004A756E004A756C00417567005365 0035B370: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 70004F6374004E6F760044656300 |
12-20-2003, 12:54 | #25 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | Operator -> Time Only Like 09:23 ;!!! With Beep and Cool Diodes Flash !!! ;(Ñ)SiNgle ;Probider -> Time Patch Ver. 0.61b ;M55v10 ;Released 10.12.03 0CB5C0: 66FEFF3FF2FF02FE DA5550B0CC00CC00 0035B050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88708880889088C088D0E0D8E6F9F223 0035B060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2FCCE23BB21BB1CD7400D00 0035B070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCCC23BB2DE0D8E6F9F423BB17F0FE 0035B080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C8E76FE3A00BB0E7C8FF0EF76FE0020 0035B090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E6FEF223E0DF98D098C098909880 0035B0A0: FFFFFFFF 9870DB00 0035B0A4: FFFFFFFFFFFFFFFF DC48B8E90892CB00 0035B0AC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0ADF6FC0EFED1004BDDCC00F2FC0EFE 0035B0BC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FC3000F0ECF2FC0CFE06FC30005C8C 0035B0CC: FFFFFFFF 70ECCB00 0035B0D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C048C1ED1F48C03D1BD7400D00F2FC 0035B0E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F02348C12D15E6FC4100DAA2B629E02C 0035B0F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD6400E00EDA9EEEF3E02CE00DE6FE 0035B100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0004DA9EEEF3E01CD7400D00F6FCF023 0035B110: FFFFFFFFFFFFFFFF 98C0CB00E00C0DF8 |
12-20-2003, 12:55 | #26 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | Proceed to remove "," Now we remove all "," in addrbook and other places except incoming calls ;M55V10 ;(C) SiNgle 49EF9A: DA90044E cc00cc00 4A73F4: DA90044E cc00cc00 4A7BF8: DA90044E cc00cc00 4a7d36: DA90044E cc00cc00 4a7dee: DA90044E cc00cc00 4adc52: DA90044E cc00cc00 4bbd98: DA90044E cc00cc00 4bbeba: DA90044E cc00cc00 4bcfc4: DA90044E cc00cc00 4df88c: DA90044E cc00cc00 4f24e8: DA90044E cc00cc00 |
12-20-2003, 12:56 | #27 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | ;Remove the question about copy address book when sim-card ; changed and the selection of the default book. ; Firmware : M55 v11 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 4EFA6A: DA8C8C90 E6FC1000 ; mov r12, #10h 4EFA6E: 48403D04 DA2EA4B8 ; calls HideSelectDefaultBook() 4EFA72: DA8C0CBF FA6E96FA ; don't ask to copy bull**** |
01-11-2004, 01:33 | #29 (permalink) |
Junior Member Join Date: Jan 2004 Location: http://nec.intact.pl Age: 40
Member: 49004 Status: Offline Thanks Meter: 0 | MORE SPACE FOR JAVA (1,4 MB) Hi! I heve described this patch on polish forum and many people from yesterday are using it. It'll allow you to make new space in your phone memory by deleting useless languages support. For example you are from Germany and than you don't need Dutch, French and other. Whole language pack takes ~2,02 MB and new one with english and your one 650KB... That's 1,4 MB free in your phone!!! And second patch makes second partition B:. More info i'll write in eglish if i take some sleep... My LangPatch www.glucholazy.net/Tutorial_Java.txt Drive patch by Chaos http://www.glucholazy.net/Chaos_patch.vkp http://www.glucholazy.net/Siemens_La...ditor_v141.rar http://alexsid.antex.ru/files/Progra...omparer.v2.rar It's 1000% working! I'm using it too I'll give U more infos about this but i feel a little sick so i'm going to sleep. BYE I take no ressponsible for my advices and U R using it for your own risk. Last edited by polk; 01-11-2004 at 02:07. |
01-15-2004, 04:58 | #30 (permalink) |
Junior Member Join Date: Feb 2003
Member: 21856 Status: Offline Thanks Meter: 0 | Java program must be placed and renamed as: A:\Java\Jam\Prog\Prog.jar ;HotKey "1" -> Java-Starter ;(C) SiNgle, Chaos ;M55v10 ;Released 14.01.04 0DB8AA: DA209036 DA9ff005 0DB8AE: 48423d02 EA004AB9 7f05f0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF e6fcfe05e6fd7c02e01eFA9178ea 7f05fe: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 413A5C4A6176615C6A616D5C50726F67 7f060e: FFFFFFFFFFFFFFFFFFFF 5C50726F672E6A617200 |
m55 v10 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 11 | 12-12-2004 03:41 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
M55 Graphic Patches | iccume | x4x, x5x Flashpatching | 17 | 03-06-2004 18:24 |
m55 v11 patches (some new, some old) | |FeRRaRi| | E-Gold Based Phones | 4 | 02-27-2004 03:17 |
dead m55 after freia m55 AMD patch | lypen17 | E-Gold Based Phones | 3 | 02-27-2004 00:30 |
