M55 Flash Patches [GLOW=red]please, this is for patches only. [/GLOW] maybe some mod can make this sticky... All patches for v_klay v2.4+ Loader (14MB) Some patches are for v10 and others for v11 please take care! ; 50 Secound Beep ; Firmware : M55v10 ; Author : SiNgle & RizaPN ; Loader: V-Klay 2.4+ / M55 00413C: F2F40CFE DA6800BD 48BD00: FFFFFFFFFFFFFFFF F2F40CFE46F43200 48BD08: FFFF DB00 |
; Firmware : M55v10 ; Author : RizaPN, ACiD [mrp] ; Homepage: www.gsm-dev.com ; Loader: V-Klay 2.4+ / M55 ; change batt empty sound to... ;73FFD3: 3C 1C ; Tut 73FFD3: 3C 0C ; switch off ;73FFD3: 3C 4C ; klick (keypressed) |
; M55 AT+CGSN Patch ; Firmware: M55v10 ; Version 1.0b ; Loader: V-Klay 2.4+ / M55 ; Modified: 30.10.03/00.29.36 ; By SiNgle ; M55 adaptation&improving of patch by Chaos & RizaPN for SL45 ***** ; *** Modify AT+CGSN Command to do Debug *** ; *** Advanced debugging with AT+CGSN *** ; It is a USELESS patch, UNLESS you want to create patch and need to read ; the RAM area while the phone is ON. ; By applying this patch, it is possible to dump RAM and flash area through ; the serial port (use Hyperterminal like software) using normal AT ; command. ; SiNgle: change will provide more correct adress detection of our strings 455450: 5C37C200 B6BD6800 48BD20: FFFFFFFFFFFFFFFF E004BB029DFECB00 48BD28: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC48992927F230008D0C47F20A008D06 48BD38: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182 48BD48: FFFFFFFFFFFF CB001F88CB00 48BD4E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182 48BD5E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997 48BD6E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0 48BD7E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDAC302B2080698C0 48BD8E: FFFFFFFFFFFFFFFF 98F098E09850CB00 48BD96: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4 48BDA6: FFFF CB00 48BDA8: FFFFFFFF 998C7C44 48BDAC: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00 48BDB6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC3DA88F094F085DC48993927F32A00 48BDC6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FAC25C37BBA9F0F4BBA7F0E44930 48BDD6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D2127F312002D18E6FD0D0A 48BDE6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC 48BDF6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D25 48BE06: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D23DC4FB98E08E10DFADA6854BE 48BE16: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBBFF0EFBBBD0D1926F04000F020BBC3 48BE26: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D03B98208210DFB2020A758A7A708E1 48BE36: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0AF010F0DEF0C2DC4F998D498D3DF5 48BE46: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 28C13DFABBA506F04000FAC3EC80 48BE54: FFFFFFFFFFFF ECFFECFEDB00 ; Commands are: ; AT+CGSN ; Display IMEI, as usual ; AT+CGSN:page,offset ; Dump 128 bytes of memory starting at address page:offset ; AT+CGSN.page,offset,data ; Search data on the given page, starting from offset. Data is a ; hexadecimal string without spaces. Offset is in range 0...3FFF. ; AT+CGSN*page,offset,data ; Write data to memory (RAM) at address page:offset. Data is a hexadecimal ; string without spaces. ; AT+CGSN@seg,offset ; Inter-segment call to address seg:offset. On return, values of r14 and r15 ; will be displayed. Note that seg is the segment, not the page (eg. if you ; wrote procedure to 11:500, call it at 4:4500). Procedure should end with ; far return. If the procdure consumes much time, make sure to insert ; srvwdt instruction in its loop. ; SiNgle: ; WARNING!!! ; This patch is not much tested yet, use with care! |
; Disable Java Class Verification ; Firmware: M55v10 ; Author : SiNgle & Chaos ; Loader: V-Klay 2.4+ / M55 7577BE: 3D 0D |
; *** Handsfree on Left_Key *** ; Firmware : M55 v10 ; Author : ACiD [mrp] & SiNgle for M55v10 ; Loader: V-Klay 2.4+ / M55 0D4EB8: DA2CA0C2 DA2CB0FC ; call UserPoz on LeftKey ; one time left key -> Handsfree on ; secound time -> Handsfree off |
; Provider Name -> Time ; Author: SiNgle ; Phone: M55v10 ; Loader: V-Klay 2.4+ / M55 ; Bug: Es wird HH::MM angezeigt 0CB5C0: 66FEFF3F DA6840bf 0CB5C4: F2FF02FE cc00cc00 ;---- New block. Segment address:680000-------- 48BF40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8840885088C088D0D7400D00F2FCCE23 48BF50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F05CE0ADF6FC0EFED1004BDDF2FC0EFE 48BF60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FC3000F0ECF2FC0CFE06FC30005C8C 48BF70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70ECE6FCF223E0DDDABF7ED3E6FCF423 48BF80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0DDE6FE3A3ADABF7ED3D7400D00F2FC 48BF90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC23F05CE0ADF6FC0EFED1004BDDF2FC 48BFA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFE06FC3000F0ECF2FC0CFE06FC3000 48BFB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C8C70ECE6FCF623E0DDDABF7ED3E6FE 48BFC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF F223E0DF98D098C098509840DB00 |
; Provider Name -> Profil Logo Working on all phones ; Author: ACiD [mrp] & SiNgle ; Loader: V-Klay 2.4+ / M55 0CB5C0: 66FEFF3FF2FF02FE DA43EC74CC00CC00 2374EC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FF0D01D7401300F3FC222648603D03 2374FC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6034DB0048613D03E6FE7434DB00 23750C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48623D03E6FE8834DB0048633D03E6FE 23751C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9C34DB0048643D03E6FEB034DB004865 23752C: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D03E6FEC434DB00E6FED834DB00 237460: FFFFFFFFFFFFFF 4e6f726d616c00 ; = "Normal" 237474: FFFFFFFFFFFF 4c6569736500 ; = "Leise" 237488: FFFFFFFFFF 4c61757400 ; = "Laut" 23749C: FFFFFFFFFFFFFFFF 436172204B697400 ; = "Car Kit" 2374B0: FFFFFFFFFFFFFFFF 4865616473657400 ; = "Headset" 2374C4: FFFFFFFFFFFF 4e6163687400 ; = "Nacht" 2374D8: FFFFFFFFFFFFFF 41726265697400 ; = "Arbeit" |
Provider - Time ;Author: Single ;Release: 03.12.03 ;M55V10 Vklay 2.4 ;Ver 0.6b Time string Like "12:22 We 03 Dec" With beeps every hour & Cool Flash by up Diodes 0CB5C0: 66FEFF3F DA5550b0 0CB5C4: F2FF02FE CC00CC00 0035b050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88708880889088C088D0E0D8E6F9F223 0035b060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2FCCE23BB7BBB76D7400D00 0035b070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCCC23CA0084B1E0D8E6F9F423BB70 0035b080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0FE5C8E76FE3A00BB677C8FF0EF76FE 0035b090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0020BB62D7400D00F2FED223E6FDFE38 0035b0A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD740A201A87D08D200C728E148E0 0035b0B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF8D7400D00F2FDD42368D33D09D740 0035b0C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D00E6F7DA00F2FDD22328D39D0108C1 0035b0D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2FDD02300CDE07DF6FC0EFE 0035b0E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D1004BDDCC00F2FC0CFE5C1C46F7DA00 0035b0F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0306FCF2310D0206FCE031D7405601 0035b100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A8ECBB2AD7400D00F2FCD023BB29F0FE 0035b110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C8E76FE2000BB207C8FF0EF76FE0020 0035b120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB1BD7400D00F2FCD22328C15C2CE6FD 0035b130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 043200DCD7405601A8EDBB0E08D2D740 0035b140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5601A8EDBB09E6FEF223E0DF98D098C0 0035b150: FFFFFFFFFFFFFFFF 989098809870DB00 0035b158: FFFFFFFFFFFFFFFF DC48B8E90892CB00 0035b160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0ADF6FC0EFED1004BDDCC00F2FC0EFE 0035b170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FC3000F0ECF2FC0CFE06FC30005C8C 0035b180: FFFFFFFF 70ECCB00 0035b184: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C048C12D1F48C03D1BD7400D00F2FC 0035b194: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F02348C12D15E6FC4100DAA2B629E02C 0035b1A4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD6400E00EDA9EEEF3E02CE00DE6FE 0035b1B4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0004DA9EEEF3E01CD7400D00F6FCF023 0035b1C4: FFFFFFFFFFFFFFFF 98C0CB00E00C0DF8 0035b1E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5475576554684672536153754D6F5475 0035b1F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000576554684672536153754D6F5475 0035b200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 576500004A616E00466562004D617200 0035b210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 417072004D6179004A756E004A756C00 0035b220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 41756700536570004F6374004E6F7600 0035b230: FFFFFFFF 44656300 |
; SlowLightUp Patch ; (c) SiNgle ; 28.11.03 ; ver 1.0 ; FW M55v10 80C734: DAA0E8C6 DA5540B0 ; Keyb,sms... 35b040: FFFFFFFFFFFFFFFF E6FE0004DAA0E8C6 ; Patch 35b048: FFFF db00 80C81E: DA9EEEF3 DA5540B0 ; After Phone ON |
; *** Profil Logo Patch *** ; M55 v10 ; by ACiD [mrp] ; Loader: V-Klay 2.4+ / M55 ; shows an profil Logo on MainScreen ; uses Picture 323...329 for Profil Logos (old SMS pictures) 0DCCF0: DA2DCCC4 DA3700f5 ; call refresh Profil Logo 17F500: FFFFFFFF DA2DCCC4 ; call PicturePaint (Akku Symbol malen) 17F504: FFFFFFFF DA8CF8BB ; call GetSelectedProfile 17F508: FFFF C08C ; movbz r12, rl4 ;hier steht jetzt die Profilnummer in r12 17F50A: FFFF F0EC ; mov r14,r12 17F50C: FFFFFFFF E6FC4301 ;mov r12, #143 17F510: FFFF 00EC ;add r14, r12 17F512: FFFF E01C ;mov r12, #1 (xPos) 17F514: FFFF E08D ;mov r13, #8 (yPos) 17F516: FFFFFFFF DA2DCCC4 ; call PicturePaint (Akku Symbol malen) 17F51A: FFFF DB00 ;rets ; *** Profil Logo Pictures *** ; ################################################## ##################### ; ### This file is made by ©SiemensPictureChange 2.0 - Build 1.0.1.0 ### ; ### programmed ©2003 by ACiD[mrp], Cluni and b@iLLi ### ; ### ### ; ### GSM Development Crew - www.gsm-dev.com ### ; ### GSM Multifund, Handyhacking - http://www.gsm-multifund.de/board ### ; ### ### ; ### Date: 09.11.2003 - Time: 14:26:35 ### ; ### Patch for: SIEMENS M55 v10 ### ; ################################################## ##################### ; ##### Picture 323 ##### ; Picture Table Index 308A18: 32140100 20080300 ; Picture Data 2C3F20: 7FFFE403FFF7FF6EBF9000FFFFFF7DDF FFFFFFFFFFFFFFFF0F3FFFFFFFFF3FFF 2C3F30: 20207F5FFF7FFE40203EEFBF7DDF00A8 0F3FFFFFFFFF3FFF333C3C300F0F3FFF 2C3F40: 3FEFFF7E9C81AC1EEFFF7FF903AE1F5F 3333CCF333F33FFF3C33CCF333333FFF 2C3F50: FF7FF9052B0FFFFF7FF900200FFFFF6F 3C3C3CF333C33FFFFFFFFFFFFFFFFFFF 2C3F60: F900200FF7FF7FF900200FFFFF7F7E00 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C3F70: 200FFEBF7FF900201FFF7F7FFC80001B 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C3F80: FEBF7EBCC0703EBFFF7F7E40003DDFFF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C3F90: 3EBFA0207DFFFF7FFF1021FDDFFF3FFD 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C3FA0: CC03DE3FFF0000000000003F 0F0F0F0F0F0F0F0F0F0F0F0F ; ##### Picture 324 ##### ; Picture Table Index 308A20: 32140100 20080300 ; Picture Data 2C7F20: 00008002403D3F3C012104C0663F0201 FFFFFFFFFFFFFFFF3FFF3FFFFFFFFFFF 2C7F30: 934000473F1D003026C1E33F3301B366 3FFFFFFFFFFFFFFF3FCF3C3CFFFFFFFF 2C7F40: C2583F1981B366C6683F0F81B366C438 3F3333F33FFFFFFF3F3F3F33FFFFFFFF 2C7F50: 3F0081B366C4003F0081FB7FC6003F07 03C330FC3FFFFFFFFFFFFFFFFFFFFFFF 2C7F60: C7B366E303BF0548036060063F062FF0 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C7F70: 0FE01E3F002FFFFFE0353F0028FFFC20 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C7F80: 253F00CA0842A3F33F008C820962503F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C7F90: 0007DA9FC2703F0003FFFF80003F0000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2C7FA0: FFFE00003F0000000000003F 0F0F0F0F0F0F0F0F0F0F0F0F ; ##### Picture 325 ##### ; Picture Table Index 308A28: 32140100 20080300 ; Picture Data 2CBF20: 7FC0FC07E07FFF4061FE0FF0C07F4037 FFFFFFFFFFFFFFFF3FFFFFFFFFFFFFFF 2CBF30: FFBF79807F7E1FCFBCFF0FFF200F9FF9 3FFFFF3FFFFFFFFF3F0F330FFFFFFFFF 2CBF40: FE00BF200F7FF3FE00BF3FCE7FFFFE7F 3FF3333FFFFFFFFF3F33333FFFFFFFFF 2CBF50: BF380FFFFFFE03BF080FFFFFFE023F0F 03C3C3CFFFFFFFFFFFFFFFFFFFFFFFFF 2CBF60: CFFFFFFE7E3F0FE7FFFFFCFE3F0033FF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CBF70: FFF9803F3C1FFFFFFF07BF071FFFFFFF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CBF80: 1E3F01C0FFFFE0703F00603FFF80C03F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CBF90: 1C300FFE01033F070003F8001C3F0180 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CBFA0: 00E000603F0000000000003F 0F0F0F0F0F0F0F0F0F0F0F0F ; ##### Picture 326 ##### ; Picture Table Index 308A30: 31130100 20080300 ; Picture Data 2CFF20: 00A803F003807F00A80FFC07807F00A8 FFFFFFFFFFFFFFFFC0FFFFFCF33FFFFF 2CFF30: 3E0F07807F00A87C0F83807F00F87CC7 3F3FFFFCCFF3FFFF3FF0F0FC3F30FFFF 2CFF40: 87807F00F8FCC7C7807F00F8F7C7C380 3FFF33FC3F33FFFF3F3333FCCF33FFFF 2CFF50: 7F00F9EF8FE7807F0071EF1FE7807F00 C0FC33FCF33CFFFFFFFFFFFFFFFFFFFF 2CFF60: 01EF1FE0007F0071ED1FE3807F0071EF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CFF70: FFE3807F0071EFFFE3807F0070F71FC3 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CFF80: 807F0070FB1FC3807F00707F1F83807F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CFF90: 00707FFF83807F00703FFF03807F0070 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2CFFA0: 0FFC03807F 0F0F0F0F0F ; ##### Picture 327 ##### ; Picture Table Index 308A38: 31130100 20080300 ; Picture Data 2D3F20: FE0203F00807FFFF838E1C101FFFFFC0 FFFFFFFFFFFFFFFF3CFFFFFF3FFFFFFF 2D3F30: 9806607FFFFFE0100200FFFFFFF83003 3CFFFFFF3FFFF3FF00F3C3F03C3CF0FF 2D3F40: 01FFFFF00020010003FFFC002001000F 3CCCFCCF33F333FF3CCFCCCF3F33F3FF 2D3F50: FFFE002001001FFFFF1F21613E3FFFFF 3CF0F0F030FC3CFFFFFFFFFFFFFFFFFF 2D3F60: 803123007FFFFF001122003FFFFE0019 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D3F70: 26000FFFFC000FFC0007FFF00003F000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D3F80: 01FFFFF0C27083FFFFFFE18788E1FFFF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D3F90: FFC3023030FFFFFF8001F0007FFFFF00 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D3FA0: 01E0001FFF 0F0F0F0F0F ; ##### Picture 328 ##### ; Picture Table Index 308A40: 31130100 20080300 ; Picture Data 2D7F20: BFD7FFFFFFFF7FFEEFFFFFFBFFFFFFD7 FFFFFFFFFFFFFFFFC3FF333FFFFFFFFF 2D7F30: 8FE3FFAFFFFFFE0380FFDFFFAFFC0000 3CCFF33FFFFFFFFFCFC3333CFFFFFFFF 2D7F40: 7FAFFF77F800003FFFFFFFF000001FFF F3CF33333FFFFFFF3CCF3333FFFFFFFF 2D7F50: FF77C000000F7EFF8F80010003FFFFFF C3F3333C3FFFFFFFFFFFFFFFFFFFFFFF 2D7F60: C007C003FFFFFFE0038007FFFFFFF000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D7F70: 000FFFFFFFF800001DFFFFEBFC00007F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D7F80: 5FFFF7FE0000FEEFFFEBFF8003FFFEFF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D7F90: FFFFE01FFEEFFF7EFFFFFFBF4FFFFFF7 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2D7FA0: FFFFFFFDFF 0F0F0F0F0F ; ##### Picture 329 ##### ; Picture Table Index 308A48: 31130100 20080300 ; Picture Data 2DBF20: 00000FFFC7C07F3478000007607F20FE FFFFFFFFFFFFFFFF3FF3FFFF3FFFFFFF 2DBF30: 1FF80FC07F1FFE00003F807F39D78780 3FF3FFFF3FFFFFFFCCCFCFC333CF0FFF 2DBF40: FE007F7CA00781FFFC7F64706187FFFF CCCF333F0F333FFFF33F3F3F333F3FFF 2DBF50: 7F736EF38FFFFC7F2A1333CFFE007F7D F33FC3C333C33FFFFFFFFFFFFFFFFFFF 2DBF60: FE7BFFFC007F6580007FF8007F649CBB 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2DBF70: FFFC007F760003FFFF007F39E06001FF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2DBF80: 807F3F0800003FC07F1FBFE0000FE87F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2DBF90: 43FBC3FF03FC7F24E0000000F87F8000 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 2DBFA0: 000000307F 0F0F0F0F0F |
; Date on MainScreen as Tu 09 Dec ; (c) SiNgle ; 09.12.03 ; ver 0.1b ; FW M55v10 0D4A5A: E077 E0D7 9FD7AA: DABFB2D3 DA5580B2 0035B280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 889088808860D460060046F60D003D56 0035B290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F09FF08E8880889088C088D0DABF90CB 0035B2A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 68475C14D7405601D414403398D098C0 0035B2B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98909880DC49B8180882E7F22000DC49 0035B2C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B9285044DC4DF48C0300E0A5F6F40EFE 0035B2D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D1004B55CC00F2F50EFE06F53000F015 0035B2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F50CFE06F530005C857015DC59E428 0035B2F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0100E4380200E7F22000DC49E4280300 0035B300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08845044DC4DF48C020028415C2406F4 0035B310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4E33D7405601A8140842D7405601A944 0035B320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E105DC79B928E4380100E4480200E458 0035B330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03000884986098809890DB00FABFB8D3 0035B340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4D6F5475576554684672536153754A61 0035B350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E00466562004D617200417072004D61 0035B360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 79004A756E004A756C00417567005365 0035B370: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 70004F6374004E6F760044656300 |
; *** DigiClock in KeyLocked mode *** ; M55 v10 ; by ACiD [mrp], RizaPN ; Loader: V-Klay 2.4+ / M55 000DC86A: E6FCB101 DA5500B4 0035B400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7500D00F2F1CE63F2F2CC638820 0035B410: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E0AEBB1426FC09009810BB03E6FC 0035B420: FFFFFFFF B101DB00 0035B424: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 0035B434: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00 0035B43E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE4C01E6FD1200DA2DCCC498C0 0035B44E: FFFFFFFFFFFF 06FC1600CB00 ; change pictures: ; Pictures 332..341 = digit 0..9 ; Picture 342 = seperator ; Picture 343 = background |
; beep 10 Sekunden befor every minute in call ; Firmware : M55v11 ; Author : ACiD [mrp], SiNgle, RizaPN ; Loader: V-Klay 2.4+ / M55 00413C: F2F40CFE DA9F8601 7F0186: FFFFFFFFFFFFFFFFFFFF F2F40CFE46F43200DB00 |
; Firmware : M55v11 ; Author : RizaPN, ACiD [mrp] ; Homepage: www.gsm-dev.com ; Loader: V-Klay 2.4+ / M55 ; change batt empty sount into... ;72FFD1: 3C 1C ; Tut 72FFD1: 3C 0C ; switch off ;72FFD1: 3C 4C ; klick (keypressed) |
; Disable Java Class verification ; Firmware: M55v11 ; Author : ACiD[mrp], SiNgle, Chaos ; Loader: V-Klay 2.4+ / M55 7584A8: 3D 0D |
