Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 08-25-2004, 21:38   #136 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: Flash lights + other type of sound when some keys pressed
; © Matr!x - 11/03/04
; Converted to M55V91 by KoTsK
; Plz set the Key tone as described below:
; Menu > Setup > Keys > Key tones > Click
823F30: E048EA00A43F DA5570D2CC00
#pragma enable old_equal_ff
35D270: DA55B0D2E03CE6FD6400E00EDA9F7475
35D280: E03CE00DE6FE0004DA9F7475E01CE02C
35D290: E6FD6400E00EDA9F7475E02CE00DE6FE
35D2A0: 0004FA9F7475E01C
35D2B0: E6FC0400 ;#0004h = tone
35D2B4: FAA2AA39
#pragma disable old_equal_ff
; enable these lines if you need another tone
;35D2B2: 04 18
;35D2B4: FA DA
;#pragma enable old_equal_ff
;35D2B8: E6FC1300FAA2AA39
;#pragma disable old_equal_ff
;enable this line to turn off tone
;35D270: DA55B0D2 CC00CC00
;enable this line to turn off dyn. light
;35D274: E03C DB00
Experiment with tone/sound ...
SiemensDebugger's SOUND.INI file is a good sample for number of tones.
Simply convert the number into hexadecimal.
Old 08-26-2004, 11:58   #137 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: Backlight blinking on dynamic light action
; Original by ??????? - 13/03/04
; Converted by KoTsK - 26/08/04
; Set the dynamic light mode to some action, e.g. sms or incoming call
; *** speed ***
0x81312C: F6FD3A34,EA007C33 DA259640,DAA074D2
0x8134A4: F6FD3E34,EA00F436 DA259640,DAA054D6
; *** lighthouse ***
0x81315A: F6FD3A34,EA007C33 DA259640,DAA074D2
0x8134D2: F6FD3E34,EA00F436 DA259640,DAA054D6
; *** wave ***
0x813188: F6FD3A34,EA007C33 DA259640,DAA074D2
0x813500: F6FD3E34,EA00F436 DA259640,DAA054D6
; *** beat ***
0x8131B6: F6FD3A34,EA007C33 DA259640,DAA074D2
0x81352E: F6FD3E34,EA00F436 DA259640,DAA054D6
; *** runway ***
0x8131E4: F6FD3A34,EA007C33 DA259640,DAA074D2
0x81355C: F6FD3E34,EA00F436 DA259640,DAA054D6
; *** trance ***
0x813212: F6FD3A34,EA007C33 DA259640,DAA074D2
0x81358A: F6FD3E34,EA00F436 DA259640,DAA054D6
Old 08-28-2004, 04:00   #138 (permalink)
anuroj_007's Avatar
Member: 66180
;Replacement standard vibry M55v10
;© Divisi0n_by_zer0
39A696: F401 FA00 ;Duration vibry in ms
39A69A: F401 FA00 ;Duration of a pause in ms
Old 08-28-2004, 18:56   #139 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: Advanced Net Indicator in Keylock Mode v1 beta
; © ACiD [mrp], based on Chaos' EntryPoint ® KoTsK
; Greetings to all those Siemens patchers out there
; SiNgle, Skylord, RizaPN, Chaos, DarkBear
; To show graphical network indicator on main screen (keylock mode).
; This patch is not compatible with digital clock in keylock mode.
; But you still can use digital clock in screensaver mode
; Problems fixed
; * GSM900 / GSM1800 detection
; * -5dB Offset
; * don't show keylock fashions fixed
0DD650: E6FCB101 DA752016
551620: 88E088D08870E00CE6FD1200E6FE4D00
551630: DA2DB2D2E6FF603AE6FD1E00D7400900
551640: D41F0600E10346F16800ED2E46F13200
551650: 8D2BE6FE510046F16400ED07E6FE5000
551660: 46F15000ED02E6FE4F00E6F768002071
551670: E0230B73F2F70EFE88E0D7400900A85F
551680: 46F57D008D03E6FE53000D02E6FE5200
551690: E02C88C088D088F0DA2DB2D298F098D0
5516A0: 98C098E0E06CBB0C08D606FF0C0046FF
5516B0: 9C3AFDC4987098D098E0E6FCB101DB00
5516C0: 88F088E088D088C08870DA2DB2D29870
5516D0: 98C098D098E098F008C1A0073DF1CB00
; ps ...
; i have put 2 graphics modes, bright and dark in the zipped (attachment).
; just one of them as you like ...
File Type: txt advanced net indicator in keylock mode gfx.zip.txt (12.0 KB, 107 views)
Old 08-29-2004, 19:09   #140 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: Backlight blinking on dynamic light action
;speed
0x81307E: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x8133F6: F6FD3E34 EA004636 DA259640,DAA016D6
;lighthouse
0x8130AC: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x813424: F6FD3E34 EA004636 DA259640,DAA016D6
;wave
0x8130DA: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x813452: F6FD3E34 EA004636 DA259640,DAA016D6
;beat
0x813108: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x813480: F6FD3E34 EA004636 DA259640,DAA016D6
;runway
0x813136: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x8134AE: F6FD3E34 EA004636 DA259640,DAA016D6
;trance
0x813164: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x8134DC: F6FD3E34 EA004636 DA259640,DAA016D6
;?eternity?
0x813192: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x81350A: F6FD3E34 EA004636 DA259640,DAA016D6
;?strobo?
0x8131C0: F6FD3A34 EA00CE32 DA259640,DAA036D2
0x813538: F6FD3E34 EA004636 DA259640,DAA016D6
Old 08-31-2004, 09:41   #141 (permalink)
Member: 78678
Change sound of camera with Old,Real sound of photographic
M55v11/91
Old 08-31-2004, 18:03   #142 (permalink)
P .
Member: 79203
hello, i'm new here, does someone know a patch to turn of the dinamic lights when the keylock is on?
Old 09-01-2004, 09:49   #143 (permalink)
Member: 49922
; SupernetMonitor v1.1
; Better visualization on NET bar.
; (c) Chaos
; Ported for M55v11 by AlexSid
; M55 v91
0DD53D: 2DB2D2 9F6005
7F0560: FFFFFFFFFFFFFFFF E6FF603AE00CD740
7F0568: FFFFFFFFFFFFFFFF 0900D41F0600E103
7F0570: FFFFFFFFFFFFFFFF 49202D1C47F2FF00
7F0578: FFFFFFFFFFFFFFFF 2D19E11347F26900
7F0580: FFFFFFFFFFFFFFFF ED15E12347F26100
7F0588: FFFFFFFFFFFFFFFF ED11E13347F25800
7F0590: FFFFFFFFFFFFFFFF ED0DE14347F25000
7F0598: FFFFFFFFFFFFFFFF ED09E15347F24400
7F05A0: FFFFFFFFFFFFFFFF ED05E16347F23900
7F05A8: FFFFFFFFFFFFFFFF ED01E173D7400900
7F05B0: FFFFFFFFFFFFFFFF A85F46F57D008D02
7F05B8: FFFFFFFFFFFFFFFF 07F30800C03E06FE
7F05C0: FFFFFFFFFFFFFFFF C00146FEC6018D02
7F05C8: FFFFFFFFFFFFFFFF 26FE6700E00D88C0
7F05D0: FFFFFFFFFFFFFFFF 88F0DA2DB2D298F0
7F05D8: FFFFFFFFFFFFFFFF 98C048C00D0108C1
7F05E0: FFFFFFFFFFFFFFFF 08C406FF0C0046FF
7F05E8: FFFFFFFFFFFF 9C3AFDBDDB00
; Picture Data attached...
Old 09-01-2004, 19:54   #144 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: Flash SMS Directly from the Phone
; © RizaPN, KoTsK - 01/09/2004
; Give a possibility to send a Flash SMS directly from the phone.
; Add a space in the beginning of the message to send it as a flash SMS,
; otherwise it will send as a normal ones.
0x99A814: E6FCB210 DA508271
0x307182: FFFFFFFF E6F2F05F
0x307186: FFFFFFFF D7506100
0x30718A: FFFFFFFF F3F20510
0x30718E: FFFFFFFF F3F30610
0x307192: FFFFFFFF 61252D02
0x307196: FFFFFFFF 61353D04
0x30719A: FFFFFFFF D7406100
0x30719E: FFFFFFFF F7F4F70F
0x3071A2: FFFFFFFF E6FCB210
0x3071A6: FFFF DB00
Old 09-03-2004, 10:01   #145 (permalink)
Member: 49922
; Dynamic Light when key locked & sound turned off v2
; (C) Matr!x (P) !Freeman!
; M55 v11/v91
0D2D20: DA98A08F DA5570D0
0D2D4E: DAA2FA3E DA55C0D0
35D070: DA98A08FE03CE6FD6400E00EDA9F7475
35D080: E03CE00DE6FE0004DA9F7475E01CE02C
35D090: E6FD6400E00EDA9F7475E02CE00DE6FE
35D0A0: 0004FA9F7475E01C
35D0C0: DAA2FA3EE03CE6FD6400E00EDA9F7475
35D0D0: E03CE00DE6FE0004DA9F7475E01CE02C
35D0E0: E6FD6400E00EDA9F7475E02CE00DE6FE
35D0F0: 0004FA9F7475E01C
Old 09-03-2004, 21:10   #146 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: Provider -> Batt Voltage + Percent Level + Temperature
; © ACiD[mrp], avkiev, ZZToP
; format sample: 3,938=75% 25,3'C
0CB786: E04E00E066FEFF3FF2FF02FE E6FE2001E6FF0300DA500898
0CC390: E04E00E066FEFF3FF2FF02FE E6FE2001E6FF0300DA500898
309808: 88608870888088C0
309810: 88D0D7401100F2FC1C21F6FC0EFEE6FD6400
309822: 5BDDF2FC0EFEF2FD0CFEBB5FD7600300
309832: F7FE20C1E7FE2C00F7FE21C1F078
309840: F7FE22C1F0CDBB52D7600300F7FE23C1
309850: F078F7FE24C1E7FE3D00F7FE25C1D7401300
309862: F2FCEC27BB42D7700300F7FE26C1
309870: F078F7FE27C1E7FE2500F7FE28C1E7FE2000
309882: F7FE29C1D7401100F2FC1E61E6FDAA0A
309892: 20CDF6FC0EFEE0AD4BDDF2FC0EFE
3098A0: F2FD0CFEBB23D7600300F7FE2AC1F078
3098B0: F7FE2BC1E7FE2C00F7FE2CC1F0CDBB16
3098C0: F078D7700300F7FE2DC1E7FE2700F7FE2EC1
3098D2: E7FE4300F7FE2FC1E10EF7FE30C1
3098E0: 98D098C0988098709860DB00F6FC0EFE
3098F0: E0A65B66F2F70EFEF2F80CFE06F73000
309900: 06F83000CB00
Old 09-04-2004, 21:09   #147 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: Flash SMS Directly from the Phone
; !!! plz uninstall the prev. "flash sms sender" patch !!!
0x99A84C: E6FCB210 DA508271
0x3071A6: FFFF DB00
Old 09-05-2004, 14:39   #148 (permalink)
anuroj_007's Avatar
Member: 66180
;*** Disable function of keypad while phone's ringing ***
;(C) Skylord, Matr!x
;(p)Sep. M55v10
;Turning off keys during phone ringing.
;except the GREEN for "answer" and the RED for "reject"
382D54: 05 00
382D58: 36003E FFFF00
382D5E: 2B02 FFFF
382D72: 5C 00
382D74: 5C 00
382D76: 5B02 FFFF
Old 09-05-2004, 19:39   #149 (permalink)
KoTsK's Avatar
Member: 17360
!!! re-edited !!!
; M55V11: UNHIDE PICTURES AND/OR REMOVE PIT-TABLES OF SPECIFIC PROVIDERS
; © KoTsK, based on SiNgle & AlexSid patch
To unhide all 79 invisible pictures of three specific providers (T-Mobile/O2/Vodafone).
After that they'll be possible to viewed/changed with SPC2.
362A96: 000042010103 000042014F03
309808: 655005000000430165500500901F4301
309818: 655005000000440165500500901F4401
309828: 655005000000450165500500901F4501
309838: 655005000000460165500500901F4601
309848: 655005000000470165500500D81B4A01
309858: 6550050000004B0165500500901F4B01
309868: 6550050000004C0165500500901F4C01
309878: 6550050000004D0165500500901F4D01
309888: 6550050000004E0165500500901F4E01
309898: 6550050000004F0165500500901F4F01
3098A8: 655005000000500165500500901F5001
3098B8: 655005000000510165500500901F5101
3098C8: 655005000000520165500500901F5201
3098D8: 655005000000530165400500901F5301
3098E8: 65400500000054016540050040195401
3098F8: 654005000002000165400500401B0001
309908: 654005000000550124420500D81B4801
309918: 244205002025480124420500682E4801
309928: 24420500000049012442050048094901
309938: 244205009012490124420500901F4701
309948: 24420500D82847012442050020324701
309958: 24420500000048012442050048094801
309968: 244205009012480124420500D81B4901
309978: 244205002025490124420500682E4901
309988: 2442050000004A012442050048094A01
309998: 2442050090124A01204205009C2A4101
3099A8: 20420500DC3241012042050008184201
3099B8: 20420500482042012042050088284201
3099C8: 20420500C8304201131E0500603C4001
3099D8: 131E05001C3B4101131E0500563D4101
3099E8: 131E050008394201131E0500423B4201
3099F8: 131E05007C3D42011D170500853C4701
309A08: 1D170500E63C48011D170500E63C4901
309A18: 1D170500683B4A011D170500EC3C5401
309A28: 1D170500B63900011D170700B0374801
309A38: 1D170700B03749011D170700D0385301
309A48: 1D170700803254011D170700B6375401
309A58: 1D170700803400011D170500513C0001
309A68: 130F05009A3E4001130F0500683B4701
309A78: 130F0500033E4A01
;If you want the three specific providers to use only the 1st index pictures
;then enable these lines:
;362AAA: 401955010103 000042014F03
;362ABE: 000056010103 000042014F03
;362AD2: 081856010103 000042014F03
;after that you can load these BIN files (attached):
; 1) M55V11_PIT2_REMOVER_355940.bin @ Addr: 0x355940 | Size: 0x001808 bytes
; 2) M55V11_PIT3_REMOVER_358000.bin @ Addr: 0x358000 | Size: 0x001808 bytes
; 3) M55V11_PIT4_REMOVER_359808.bin @ Addr: 0x359808 | Size: 0x001808 bytes
;ps:
;In zip file you'll found the 3 backups of original PIT-tables as named as
;"M55V11_PIT<number>_BUILDER_<address>.bin" that can be used to re-build
;those three specific provider's PIT-tables.
Old 09-08-2004, 06:51   #150 (permalink)
Member: 49922
Modif on vertical Net & Bat as Nokia style
M55 v10
- SiemensMania.cz
- Grad_Cierne pict by Toki
* for Nokia net bat style : include vertical net bat patch & Graphics
* for Grad_Cierne : Only Graphics
see attachment...
m55 v10 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 11 12-12-2004 03:41
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 11:32
M55 Graphic Patches iccume x4x, x5x Flashpatching 17 03-06-2004 18:24
m55 v11 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 4 02-27-2004 03:17
dead m55 after freia m55 AMD patch lypen17 E-Gold Based Phones 3 02-27-2004 00:30
Page generated in 0.56023 seconds with 9 queries
