Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 09-10-2004, 00:24   #151 (permalink)
KoTsK's Avatar
Member: 17360
Wink
as the posting above
; M55V11: VERTICAL NET & BATT ICONS (AS NOKIA STYLE)
; © KoTsK - 10/09/2004
; Picture by Toki
Old 09-12-2004, 06:46   #152 (permalink)
anuroj_007's Avatar
Member: 66180
Profil pod zasięgiem, status wibracji pod baterią, temperatura i napięcie naprzemian na baterii:
M55 V10
Kod:
0DCCF1: 2DCCC4 3700F5
17F500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4DA8CF8BBC08CF0ECE6FC4301
17F510: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 00ECE01CE08DDA2DCCC4FA9F0009
7F0900: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC00CC00D7400C00F2F100009AF14C00
7F0910: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7401100F2F1E020F6F10EFEE6FFE803
7F0920: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5BFFF2FE0EFEF2FF0CFEE02DE6FC4F00
7F0930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FE190088F0DA2DCCC4E6FE2300E02D
7F0940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC5200DA2DCCC498F0F6FF0EFEE6FF
7F0950: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 64005BFFF2FE0EFEF2FF0CFEE02DE6FC
7F0960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 550006FE190088F0DA2DCCC498F0F6FF
7F0970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEE0AF5BFFF2FE0EFEF2FF0CFEE02D
7F0980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC590006FE190088F0DA2DCCC498F0
7F0990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FF0EFEF2FE0EFEE02DE6FC5D0006FE
7F09A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1900DA2DCCC40D44D7401100F2F1E220
7F09B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F1AA0AF6F10EFEE6F164005B11F2FE
7F09C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEF2FF0CFEE02DE6FC4F0006FE1900
7F09D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA2DCCC498F0F6FF0EFEE0AF5BFF
7F09E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE0EFEF2FF0CFEE02DE6FC530006FE
7F09F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 190088F0DA2DCCC4E6FC5600E02DE6FE
7F0A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2300DA2DCCC498E0E02DE6FC5A0006FE
7F0A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1900DA2DCCC4E6FE2400E02DE6FC5E00
7F0A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC40FF1D7400C00F6F100000D05
7F0A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EF1D7400C00F6F10000D7400D00F2FF
7F0A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EE1C9AFF03F0E6FE4A010D02E6FE4B01
7F0A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC4A00E08DDA2DCCC4DB00FFFFFFFF
for GFX pls click here
http://www.siemensinfo.pl/patch/Bo$s...i%20cyfry.rar:
password :www.forum.siemensinfo.pl
Old 09-20-2004, 18:10   #153 (permalink)
Member: 74486
Here are all (or nearly all) the M55 patches for someone who can read russian.
I can translate, but it's too long.
Old 09-21-2004, 09:31   #154 (permalink)
Member: 32993
4.08MB v2
;***Increase discA to 4,278,191bytes (4.08MB) v2***
;M55v10
download
Full T9base with length up to 192kb. (En T9 ~30kb).
It's possible to use place of standart rings for pics (~100kb).
EEFS moved to DF and now backuped with standart settings of V_Klay when backuping EEPROM (fromC0000 len:40000).
Compatible with all patches FW10, but need to install to clear FF.
Uncompatible with graphic patches and patches that change string in original langpack.
If graphic patch was installed - it will be saved.
Change pictures after install this patch you can by PicPac using included free.ini.
There only one PIT left in phone.
You'll need a PicPac to install this patch. FF with patch you can download here.
Old 09-23-2004, 10:39   #155 (permalink)
Member: 49922
; A melody for everyone in a directory. (C) ZH-Soft
; M55 v91
; Play only mid
; to put a melody - a name of a file it is necessary to enter in field Email2
; if to leave his empty - will play standard for the given group
; a name of a file no more than 14 symbols, not important even or odd кол-in
; to enter together with expansion
; melodies should be in folder A:\Sounds\
11C3F0: E6FE3E37 DA9F503F
11C3F8: DAA4A44C cc00cc00
007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7400D00F2FC5C1948C02D46
007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC5C19F2FD5E19F2FE6019
007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6219D7700A00F6FC4837F6FD4A37
007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4C37F6FF4E37D7700D00F2FC6419
007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD6619F2FE6819F2FF6A19D7700A00
007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC5037F6FD5237F6FE5437F6FF5637
007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC413AE6FD5C53E6FE6F75D7600A00
007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC3E37F6FD4037F6FE4237E6FC6E64
007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD735CD7500A00F6FC4437F6FD4637
007F3FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE3E37E0AF98D098C0DB00E6FE3E37
007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4A44C
Old 09-24-2004, 04:29   #156 (permalink)
Member: 49922
; M55 v11
; Play only mid
11C3F8: DAA4CA4B cc00cc00
007F3FF0: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA4CA4B
@ M55us3r :
You're posting in the wrong section! this thread for patch ONLY!
Old 09-25-2004, 07:02   #157 (permalink)
Member: 32993
Archive with pics from patch ***menu in XPstyle 24BPP*** Menu repainted to 4096colors. You can see it on picture. In archive color scheme, file with zones for Photoshop and 2 dirs with different versions of patch: 1st - big pics of menu aren't cross border, 2nd - big pics are cross over border.
download
Old 09-26-2004, 05:50   #158 (permalink)
anuroj_007's Avatar
Member: 66180
; M55V10: MULTI-INDICATOR
;REMAKED BY Anuroj_007 fROM
; M55V11/V91: MULTI-INDICATOR
; (C)ZH-Soft, ACiD (P)AlexSid, !Freeman!, lalo.lerry (I)KoTsK
; + NETWORK PEAK LEVEL (dB)
; + BATTERY LEVEL (%)
; + ENVIRONMENT TEMPERATURE (°C)
; + VIBRA INDICATOR
; + PROFILE INDICATOR
; !!! Need patch: GFX KOTSK.VKP( in POST#126)
0DCCF0: DA2DCCC4 DA9F9008
7F0890: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4D7400900F2F1663AE103F6F1
7F08A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFEE6FF64005BFFF2FE0EFEF2FF0CFE
7F08B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E04CE0AD06FE190088F0DA2DCCC498F0
7F08C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FF0EFEE0AF5BFFF2FE0EFEF2FF0CFE
7F08D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E08CE0AD06FE190088F0DA2DCCC498E0
7F08E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0CCE0AD06FE1900DA2DCCC4E00CE0AD
7F08F0: FFFFFFFFFFFFFFFFFFFFFFFF E6FE2500DA2DCCC4FA9F0009
#pragma enable old_equal_ff
7F0900: DA2DCCC4D7401300F2F1EA27F6F10EFE
7F0910: E6FF64005BFFF2FE0EFEF2FF0CFEE6FC
7F0920: 4A00E6FD000006FE290088F0DA2DCCC4
7F0930: 98F0F6FF0EFEE0AF5BFFF2FE0EFEF2FF
7F0940: 0CFEE6FC5000E6FD000006FE290088F0
7F0950: DA2DCCC498F0F0EFE6FC5600E6FD0000
7F0960: 06FE2900DA2DCCC4FA9F9209
7F0992: DA2DCCC4D7401100F2F1E22026F1
7F09A0: AA0AF6F10EFEE6F164005B11F2FE0EFE
7F09B0: F2FF0CFEE0ADE6FC500006FE190088F0
7F09C0: DA2DCCC498F0F6FF0EFEE0AF5BFFF2FE
7F09D0: 0EFEF2FF0CFEE0ADE6FC540006FE1900
7F09E0: 88F0DA2DCCC4E6FC5800E0ADE6FE2300
7F09F0: DA2DCCC498E0E0ADE6FC5A0006FE1900
7F0A00: DA2DCCC4E6FE2400E0ADE6FC5E00DA2D
7F0A10: CCC4FA9F200A
7F0A20: DA2DCCC40FF1D7400C00F6F100000D05
7F0A30: 0EF1D7400C00F6F10000D7400D00F2FF
7F0A40: EE1C9AFF03F0
7F0A46: E6FEAF01 ;#1AFh ---> FirstPictureNumber.VibraOn
7F0A4A: 0D02
7F0A4C: E6FEB001 ;#1B0h ---> FirstPictureNumber.VibraOff
7F0A50: E6FC3600 ;#036h ---> Xpos.Vibra
7F0A54: E0AD ;#00Ah ---> Ypos.Vibra
7F0A56: DA2DCCC4FA9F800A
7F0A80: DA2DCCC4DA8CF8BBC08CF0EC
7F0A8C: E6FC3300 ;#33h ---> FirstPictureNumber.Profile
7F0A90: 00EC
7F0A92: E6FC1600 ;#16h ---> Xpos.Profile
7F0A96: E0AD ;#0Ah ---> Ypos.Profile
7F0A98: DA2DCCC4DB00
#pragma disable old_equal_ff
23/08/2004 - !!! gfx kotsk.vkp is updated !!!
- 025..040 = small font 0..9, ., °C, -, K, M, %
- 041..050 = battery digit 0..9
- 051..057 = profile indicators
- 058..070 = digital clock 2-bit
- 228 = full screen blank-in-black analog clock
- 323..329 = profile indicators 2-bit
- 332..344 = digital clock 1-bit
- 351..356 = net signal 1 (numeric)
- 357..362 = net signal 2 (numeric)
- 364..379 = battery icons (charging pictures fixed!)
- 431..432 = vibra indicators
- 448..453 = net signal (numeric)
- PIT-tables fixed!
Old 09-27-2004, 03:19   #159 (permalink)
Member: 49922
; Melody for everyone in a directory. v1.1 (C) ZH-Soft
; M55 v91
; Пофиксен a bug with recurrence of a melody.
; a name of a file no more than 15 symbols together with expansion.
; to put on the person mid - it (чел) should be in group
; on which it is put by default mid.
; and to put wav - in group on which by default costs wav.
007F3F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7700D00F2FC5C19F2FD5E19
007F3F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE6019F2FF621948C02D40D7700A00
007F3F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4837F6FD4A37F6FE4C37F6FF4E37
007F3F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC6419F2FD6619F2FE6819
007F3F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF6A19D7700A00F6FC5037F6FD5237
007F3FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE5437F6FF5637E6FC413AE6FD5C53
007F3FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6F75D7600A00F6FC3E37F6FD4037
007F3FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE4237E6FC6E64E6FD735CD7500A00
007F3FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC4437F6FD4637D7400D00F68E5C19
; M55 v11
; Melody for everyone in a directory. v1.1 (C)ZH-Soft (p)Sep.
; M55 v10
11B258: E6FE0E37 DA5560B4
11B260: DAA43C3F cc00cc00
35B460: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0D7700D00F2FC2219F2FD2419
35B470: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE2619F2FF281948C02D40D7700A00
35B480: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC1837F6FD1A37F6FE1C37F6FF1E37
35B490: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7700D00F2FC2a19F2FD2c19F2FE2e19
35B4A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF3019D7700A00F6FC2037F6FD2237
35B4B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE2437F6FF2637E6FC413AE6FD5C53
35B4C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6F75D7600A00F6FC0E37F6FD1037
35B4D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FE1237E6FC6E64E6FD735CD7500A00
35B4E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC1437F6FD1637D7400D00F68E2219
35B4F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE0E37E0AF98D098C0DB00E6FE0E37
35B500: FFFFFFFFFFFFFFFFFFFF E0AF98D098C0FAA43C3F
Old 10-03-2004, 19:43   #160 (permalink)
Member: 78197
Multi Indicator with new pictures (for v11/91)
File Type: txt Multi Indicator with new pictures.zip.txt (16.9 KB, 231 views)
Old 10-12-2004, 11:34   #161 (permalink)
Member: 77887
Style XP M55
STYLE XP M55
Of the of images I have found online her others I have done her everything added and I I would say that the transformation is valid
P.S.: the patches are all for the version 11
Animation of start
Patch: http://members.xoom.virgilio.it/rikka171/G... rt_xp_style.vkp
Images: http://members.xoom.virgilio.it/rikka171/G... / boot_img_1.zip
Animation of closing
Patch: http://members.xoom.virgilio.it/rikka171/G... ra_xp_style.vkp
Images: http://members.xoom.virgilio.it/rikka171/G... hutdown_img.zip
Animation PIN
Patch: anchor have not done her, cmq under find the images to do her/it from you!!!
Images: http://members.xoom.virgilio.it/rikka171/G... Pin/pin_img.zip
Animation if don't have the PIN
Patch: http://members.xoom.virgilio.it/rikka171/G... _nopin__v11.vkp
Images: http://members.xoom.virgilio.it/rikka171/G... n_nopin_img.zip
Sounds for lighting and spengimento
Start: http://members.xoom.virgilio.it/rikka171/G... ounds/Start.wav
Shutdown: http://members.xoom.virgilio.it/rikka171/G... ds/Shutdown.wav
Colour scheme
This is decidedly from migliorare,ma I don't have a lot of time... if you want to contribute you are the welcome ones
http://members.xoom.virgilio.it/rikka171/G... Win%20XP_v2.col
Menù
Patch: http://members.xoom.virgilio.it/rikka171/G... le_menu_v11.vkp
Images: http://members.xoom.virgilio.it/rikka171/G... le_menu_img.zip
You play On/Off/Beep
Patch: http://members.xoom.virgilio.it/rikka171/G... _on_off_v11.vkp
Bloccotasti
Patch: http://members.xoom.virgilio.it/rikka171/G... _v11.vkp
Old 10-12-2004, 11:36   #162 (permalink)
Member: 77887
VERY MANY MANY WALLPAPERSS STYLE XP!!!
http://notasite.gamersrevolt.it/Host...wallpapers.rar
Old 10-12-2004, 11:38   #163 (permalink)
Member: 77887
Very beautiful
Lighting and turning off Scorpio M55!!!!
http://barcello.altervista.org/M55/A..._scorpione.zip
To unload the file owe to make to save with name
Old 10-23-2004, 07:08   #164 (permalink)
anuroj_007's Avatar
Member: 66180
; Show Batt Volt Patch
; Multi-Indicator Patch M55 v10 must be patched before!!
7F0A9C: DB00FFFF FA9FA00A
7F0AA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2DCCC4D7401100F2F1E020F6F10EFE
7F0AB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFE8035BFFF2FE0EFEF2FF0CFEE6FD
7F0AC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1200E6FC500006FE190088F0DA2DCCC4
7F0AD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE2300E6FD1200E6FC5400DA2DCCC4
7F0AE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98F0F6FF0EFEE6FF64005BFFF2FE0EFE
7F0AF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FF0CFEE6FD1200E6FC560006FE1900
7F0B00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA2DCCC498F0F6FF0EFEE0AF5BFF
7F0B10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE0EFEF2FF0CFEE6FD1200E6FC5A00
7F0B20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FE190088F0DA2DCCC498E0E6FD1200
7F0B30: FFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC5E0006FE1900DA2DCCC4DB00
Old 10-28-2004, 14:21   #165 (permalink)
Member: 88849
Arrow ; Upgrade disk А up to 3,5 mb !!!
[B]; Upgrade your disc A up to 3.5 mb
; (с)Def nightmare; M55v11 M55v91
; 1. Copy full file system from disc A & B to PC
; Disc B - if it opened and if you have cool info there.
; we do not need to move "graphcach " file from it
; 2. unchech "V" from MENU|SETUP|display with logo at On and OFF
; 3. Switch OFF the phone
; 4. READ FULL FLASH (BACKUP) from phone
; 5. WRITE PATCH to phone
; 6. WRITE this file http://alexsid.antex.ru/dn.php?file=...A0000_11_2.rar
; address: 0x5A0000 , size: 0x20000 , offset: 0
; This is patched lang pack (2 second LG) edited by author.
; You can use other lang pack from 11 version BUT size must be low than
; 0x20000 b
; 7. write this file http://alexsid.antex.ru/dn.php?file=...000_11_rus.rar
; address: 0x680000 , size: 0x20000 , offset: 0
; THIS file have RUSSIAN T9 ONLY
; you must Use Winrar for files from 5 and 6 item
; 8. SWITCH ON the phone
; It is switch on with blue display- it is O.K. ....it is format the Disc
;(3 minuts)
; Wait
; 9. We must use DES to access disc A (go to disc A)
; 10. go to Address book
; and rename all files *.adr to *.ad_ and .lock to .loc_
; 11. go to PersistentData\SMS
; and rename SMS.dat to SMS.da_
; 12. Copy from backuped disc A (4 item )and B to new disc A
; Disc B is 256 kb now !
; 13. Switch OFF and SWITCH ON the phone
; 14. go to Address book
; and delete all files *.ad_ and .loc_
; 15. go to PersistentData\SMS
; and delete this file SMS.da_
; 16. Switch OFF and SWITCH On the phone..
; Congratulations with worked phones
; BUT!!!!! do not use ANIMATION at switch on /OFF after this patch
; Check Java app. if they not run
; (still "please wait") - we have problems ....
; first try to change Developer Menu|Java|Trace Level (if can be after enable
; NetMonitor (which we have at Developer Menu).
; if Java still not working - write backup from 4 ...
;*** PUT "GREY" phones to first (main) PIT-table ***
; © SiNgle (P) AlexSid
362AAA: 40195501 00004201
362AC0: 5601 4201
362AD2: 08185601 00004201
;*** www.remove_links_to_graphcach_v3 *** © !Freeman!
; transformed for M55v11 by AlexSid
;UNCKECH startup logo/ animation at swith on off and remove file-graphcach from disc B
4574B5: 67726170686361636800 FFFFFFFFFFFFFFFFFFFF
4574E2: 423A5C00 00000000
; table of blocks from Disc A
4269B4: 200000000100F4288901 1E000000020000127C02
#pragma disable warn_if_new_exist_on_apply
; размер EEFS
427856: 03 01
#pragma enable warn_if_new_exist_on_apply
; Size of dosc B
426A40: 07 01
; Blocks of new disc B
4269EC: 0000A8004000 0000FF004000
7F1000: FFFFFFFFFFFF 0000D0004000
7F1006: FFFFFFFFFFFF 0000D1004000
7F100C: FFFFFFFFFFFF 0000D2004000
7F1012: FFFFFFFFFFFF 0000D3004000
7F1018: FFFFFFFFFFFF 0000D4004000
7F101E: FFFFFFFFFFFF 0000D5004000
7F1024: FFFFFFFFFFFF 0000D6004000
7F102A: FFFFFFFFFFFF 0000D7004000
7F1030: FFFFFFFFFFFF 0000D8004000
7F1036: FFFFFFFFFFFF 0000D9004000
7F103C: FFFFFFFFFFFF 0000DA004000
7F1042: FFFFFFFFFFFF 0000DB004000
7F1048: FFFFFFFFFFFF 0000DC004000
7F104E: FFFFFFFFFFFF 0000DD004000
7F1054: FFFFFFFFFFFF 0000DE004000
7F105A: FFFFFFFFFFFF 0000DF004000
7F1060: FFFFFFFFFFFF 0000E0004000
7F1066: FFFFFFFFFFFF 0000E1004000
7F106C: FFFFFFFFFFFF 0000E2004000
7F1072: FFFFFFFFFFFF 0000E3004000
7F1078: FFFFFFFFFFFF 0000E4004000
7F107E: FFFFFFFFFFFF 0000E5004000
7F1084: FFFFFFFFFFFF 0000E6004000
7F108A: FFFFFFFFFFFF 0000E7004000
7F1090: FFFFFFFFFFFF 0000E8004000
7F1096: FFFFFFFFFFFF 0000E9004000
7F109C: FFFFFFFFFFFF 0000EA004000
7F10A2: FFFFFFFFFFFF 0000EB004000
7F10A8: FFFFFFFFFFFF 0000EC004000
7F10AE: FFFFFFFFFFFF 0000ED004000
7F10B4: FFFFFFFFFFFF 0000EE004000
7F10BA: FFFFFFFFFFFF 0000EF004000
7F10C0: FFFFFFFFFFFF 000076004000
7F10C6: FFFFFFFFFFFF 000077004000
7F10CC: FFFFFFFFFFFF 000078004000
7F10D2: FFFFFFFFFFFF 000079004000
7F10D8: FFFFFFFFFFFF 00007C004000
7F10DE: FFFFFFFFFFFF 00007D004000
7F10E4: FFFFFFFFFFFF 00007E004000
7F10EA: FFFFFFFFFFFF 00007F004000
7F10F0: FFFFFFFFFFFF 0000F8004000
7F10F6: FFFFFFFFFFFF 0000F9004000
7F10FC: FFFFFFFFFFFF 0000FA004000
7F1102: FFFFFFFFFFFF 0000FB004000
;T9
7F1108: FFFFFFFFFFFF 00008A004000
7F110E: FFFFFFFFFFFF 00008B004000
;EE_FS
7F1114: FFFFFFFFFFFF 0000BD004000
7F111A: FFFFFFFFFFFF 0000BE004000
;Disk_B
7F1120: FFFFFFFFFFFF 0000AB004000
7F1126: FFFFFFFFFFFF 0000AC004000
7F112C: FFFFFFFFFFFF 0000AD004000
7F1132: FFFFFFFFFFFF 0000AE004000
;PIT
7F1138: FFFFFFFFFFFF 000051004000
7F113E: FFFFFFFFFFFF 000052004000
7F1144: FFFFFFFFFFFF 000053004000
7F114A: FFFFFFFFFFFF 000054004000
;Disk_B
7F1150: FFFFFFFFFFFF 0000A7004000
7F1156: FFFFFFFFFFFF 0000A8004000
7F115C: FFFFFFFFFFFF 0000A9004000
7F1162: FFFFFFFFFFFF 0000AA004000
7F1200: FFFFFFFFFFFF 020000107C02
7F1206: FFFFFFFFFFFF 02000C107C02
7F120C: FFFFFFFFFFFF 020018107C02
7F1212: FFFFFFFFFFFF 020024107C02
7F1218: FFFFFFFFFFFF 020030107C02
7F121E: FFFFFFFFFFFF 02003C107C02
7F1224: FFFFFFFFFFFF 020048107C02
7F122A: FFFFFFFFFFFF 020054107C02
7F1230: FFFFFFFFFFFF 020060107C02
7F1236: FFFFFFFFFFFF 02006C107C02
7F123C: FFFFFFFFFFFF 020078107C02
7F1242: FFFFFFFFFFFF 020084107C02
7F1248: FFFFFFFFFFFF 020090107C02
7F124E: FFFFFFFFFFFF 02009C107C02
7F1254: FFFFFFFFFFFF 0200A8107C02
7F125A: FFFFFFFFFFFF 0200B4107C02
7F1260: FFFFFFFFFFFF 0200C0107C02
7F1266: FFFFFFFFFFFF 0200CC107C02
7F126C: FFFFFFFFFFFF 0200D8107C02
7F1272: FFFFFFFFFFFF 0200E4107C02
7F1278: FFFFFFFFFFFF 0200F0107C02
7F127E: FFFFFFFFFFFF 0200FC107C02
;T9
7F1284: FFFFFFFFFFFF 020008117C02
;EE_FS
7F128A: FFFFFFFFFFFF 020014117C02
;EE_FS
7F1290: FFFFFFFFFFFF 020020117C02
7F1296: FFFFFFFFFFFF 02002C117C02
;PIT
7F129C: FFFFFFFFFFFF 020038117C02
7F12A2: FFFFFFFFFFFF 020044117C02
;Disk_B
7F12A8: FFFFFFFFFFFF 020050117C02
7F12AE: FFFFFFFFFFFF 02005C117C02
#pragma disable warn_no_old_on_apply
B00080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B10080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B20080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B30080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B40080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B50080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B60080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B70080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
B90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BC0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BD0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BE0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C00080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C10080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C20080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C30080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C40080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C50080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C60080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C70080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
C90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CC0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CD0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CE0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
560080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
570080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
580080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
590080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
5C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
5D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
5E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
5F0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
D80080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
D90080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
DA0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
DB0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
;EE_FS
9C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
9D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
9E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
;PIT
310080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
320080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
330080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
340080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
;Disk_B
870080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
880080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
890080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
8A0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
8B0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
8C0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
8D0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
8E0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
; Format new Disk_B
DF0080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
#pragma enable warn_no_old_on_apply
edited and translated by zdob
m55 v10 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 11 12-12-2004 03:41
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 11:32
M55 Graphic Patches iccume x4x, x5x Flashpatching 17 03-06-2004 18:24
m55 v11 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 4 02-27-2004 03:17
dead m55 after freia m55 AMD patch lypen17 E-Gold Based Phones 3 02-27-2004 00:30
Page generated in 0.68721 seconds with 9 queries
