Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 09-06-2005, 04:04   #181 (permalink)
KoTsK's Avatar
Member: 17360
; *** RFS. Remove function Select from Startup/Shutdn anim. ***
; Version 0.1 - 20.07.05
; (c)a220
; (p)Antoine[KNet], S55V91
; (p)KoTsK, M55V11/V91
;For using with "remove access to graphcache" (optionable)
;Remove "SELECT" function (RightSoft button) from
;Menu->Setup->Display->Startup/Shutdn anim.
0x05CAF6: 48862D0248873D0E 48862D0148870D0E
Old 09-26-2005, 23:39   #182 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11 with Disk-A patch:
; This will enable you to load a pic from disk as start/end animation picture.
; Do not use -or- undo graphcach patch !!!
4574E2: 42 41
Old 09-26-2005, 23:42   #183 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: Hourly Beep (only)
; (c) ACiD [mrp], SiNgle, RizaPN
; http://www.gsm-dev.com
; Not compatible with:
; Provider->Time Only
; Beep+Light Every Hour
0x0CC3A8: 98809890 DA5550B0
#pragma enable old_equal_ff
0x35B050: 9880
0x35B052: 9890
0x35B054: 88C0
0x35B056: D7400D00
0x35B05A: F2FCFC23
0x35B05E: 46FC0A00
0x35B062: DD0C
0x35B064: D7400D00
0x35B068: F2FCF023
0x35B06C: 48C12D07
0x35B070: E6FC3D00 ; #3Dh => ToneIdx
0x35B074: DAA2AA39
0x35B078: E01C
0x35B07A: 9D01
0x35B07C: E00C
0x35B07E: D7400D00
0x35B082: F6FCF023
0x35B086: 98C0
0x35B088: DB00
#pragma disable old_equal_ff
Old 09-27-2005, 20:30   #184 (permalink)
KoTsK's Avatar
Member: 17360
who need this patch?
; M55V11: Enable Buddist Year toggle menu
; Menu -> Setup -> Clock -> Buddist year
; thx to SiNgle
3BE6CA: 2903 5F05
Old 10-04-2005, 21:11   #185 (permalink)
KoTsK's Avatar
Member: 17360
; M55_ALL: Graphcach for Increased Disk A
; (c)Freeman (i)KoTsK
; re-enable to load startup/shutdown picture
; after increasing disk A.
#pragma disable warn_no_old_on_apply
#pragma disable warn_if_new_exist_on_apply
;If you have M55V10
;45711D: 67726170686361636800
;45714A: 413A5C00
;If you have M55V11
;4574B5: 67726170686361636800
;4574E2: 413A5C00
;If you have M55V91
;457809: 67726170686361636800
;457836: 413A5C00
#pragma enable warn_if_new_exist_on_apply
#pragma enable warn_no_old_on_apply
Old 10-04-2005, 21:14   #186 (permalink)
KoTsK's Avatar
Member: 17360
sorry if this patch is exist....
; M55V11: Change key's layout for calculator
; (c)ValeraVi on S55V20, 2004/01/04
;Set percent on the one press of right softkey and more.
;Layout of keys "*", "#" and right softkey will be:
; calc key layout if [e] and [.] not entered
; .=+-*/±%[memIn][memOut]e --> %.=±e+-*/[memIn][memOut]
45DCF1: 95202E3D2B2D2A2F96319525932223956500 95252E3D963195652B2D2A2F932223952000
; calc key layout if [.] entered
; =+-*/±%[memIn][memOut]e ---> %=±e+-*/[memIn][memOut]
45DCD1: 95203D2B2D2A2F96319525932223956500 95253D963195652B2D2A2F932223952000
; calc key layout if [e] entered
; =+-*/±%[memIn][memOut] --> %=±+-*/[memIn][memOut]
45DCE2: 95203D2B2D2A2F9631952593222300 95253D9631952B2D2A2F2093222300
Old 10-04-2005, 21:18   #187 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11/V91: Long-pressing hotkey1 -> "Mailbox" to another link
; (c) SiNgle - 10/01/04 (p)???????
0DC690: DA209036 DA37422A ; Mailbox -> Wave recording
0DC694: 48423D02 EA0030C7 ; jmpa cc_UC, loc_2DC730
this to change the text of softkey if you apply the "long pressed hotkey-1" patch
0DC2C8: E6FC2403 E6FC???? ; txtId "Mailbox" -> <anything>
;use smelter to see the txtId
Old 10-05-2005, 00:23   #188 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: FLASH SMS DIRRECTLY FROM PHONE (IMPROVED)
; (c)RizaPN, Lava for S/ME45iV04
; (p)KoTsK
; It's possible to send a text message as a flash SMS.
; You need to add a flash symbol (space character) at
; the beginning of message to send it as a flash SMS.
; Otherwise it will send as a normal message.
; Improved:
; - unicode support
; - changeable flash symbol
; - mostly works on any provider!
0x99A814: E6FCB210 DA5510B0
0x35B010: E6F2F020D7506100F3F20510F3F30610
0x35B020: 2D0241252D0441353D06E7F41800D740
0x35B030: 6100F7F4F70FE6FCB210DB00
;to change flash symbol (default is space character)
;0x35B013: 20 ??
;change "??" to any unique standard character, ex.:
;e.g. "!", "#", "$", "%", "?", etc.
;use windows' character map to get the hex code!
Old 10-07-2005, 00:27   #189 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: (just another) Change Minute Beep Delay
;change minutebeep delay in second
;and show call duration info every time it's beeping
004132: 3c ?? ;mov r12, #delaysec
Old 10-08-2005, 10:51   #190 (permalink)
KoTsK's Avatar
Member: 17360
!!! THIS PATCH IS NOT WORK !!!
sorry!
; (p)KoTsK
; Improved:
; - unicode support
;0x35B013: 20 ??
;change &quot;??&quot; to any unique standard character, ex.:
;e.g. &quot;!&quot;, &quot;#&quot;, &quot;$&quot;, &quot;%&quot;, &quot;?&quot;, etc.
;to repair the patch above
0x35B013: 20 5f
0x35B020: 2D02 cc00
0x35B022: 41 61
0x35B026: 41 61
0x35B02a: E7F41800 cc00cc00
Old 10-09-2005, 01:34   #191 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11/V91: Add "Clean up" under "My Menu"
; (c)KoTsK, based on Matr!x Entrypoint
;"Remote sync." -> "Clean up"
3843D6: 55095509550926FE2D00 1A0B1D0B1D0B2AC02500
Old 10-10-2005, 21:29   #192 (permalink)
KoTsK's Avatar
Member: 17360
; M55V11: Hourly Beep (with dynamic light) !!Fixed!!
; (i)KoTsK
; Play beep and dynamic light every hour (hh:00).
; No any patch needed!
; Its compatibility with other patches is not tested at all!
; Not compatible with "Sound+Light every hour" patch!
; If you are using "Date on main screen as Tu 09 Dec" patch,
; please use "Sound+Light every hour" patch instead of this patch!
;call routine at provider
35B050: 9880
35B052: 9890
35B054: 88C0
35B056: D7400D00
35B05A: F2FCFC23
35B05E: 46FC0A00
35B062: DD25
35B064: D7400D00
35B068: F2FCF023
35B06C: 48C1
35B06E: 2D20
35B070: E6FC3D00
35B074: DAA2AA39
35B078: E03C
35B07A: E6FD6400
35B07E: E00E
35B080: DA9F7475
35B084: E03C
35B086: E00D
35B088: E6FE0004
35B08C: DA9F7475
35B090: E01C
35B092: E02C
35B094: E6FD6400
35B098: E00E
35B09A: DA9F7475
35B09E: E02C
35B0A0: E00D
35B0A2: E6FE0004
35B0A6: DA9F7475
35B0AA: E01C
35B0AC: 9D01
35B0AE: E00C
35B0B0: D7400D00
35B0B4: F6FCF023
35B0B8: 98C0
35B0BA: DB00
;to change sound:
;35B072: 3D ?? ; ?? = toneId (hex)
;35B072: 3D 00 ; turn off sound
;to disable dynamic light:
;35B078: E03C 0D18
Old 10-11-2005, 16:32   #193 (permalink)
dnn
Member: 144761
Patches for M55 v91
Patches for M55 v91 at http://d-n-n.narod.ru.
See description list: http://d-n-n.narod.ru/PatchesCurrList.htm
Alerts, HourBeep, AutoProfileSelection, CallsLog, DigiClockSS, OwnMel++, Dynamic ProviderName, SimEmu+SimEmuAutoSIM, View missed calls and SMS @keylock mode . What are you waiting for?
Old 10-20-2006, 14:02   #194 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 352
I need to change IMEI . Where to find the patch ?
Thanx !
Old 01-28-2007, 17:40   #195 (permalink)
Member: 441069
Who can make a white-list patch?
Big thanks for all who can...
m55 v10 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 11 12-12-2004 03:41
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 11:32
M55 Graphic Patches iccume x4x, x5x Flashpatching 17 03-06-2004 18:24
m55 v11 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 4 02-27-2004 03:17
dead m55 after freia m55 AMD patch lypen17 E-Gold Based Phones 3 02-27-2004 00:30
Page generated in 0.41012 seconds with 9 queries
