Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 08-13-2004, 08:14   #121 (permalink)
KoTsK's Avatar
Member: 17360
; M55v91 - Don't show dial of analog clock in screensaver
; Useful if you use Big Digital Clock in screensaver mode
; (c) avkiev for S55V20
; (p) KoTsK for M55V91
384d06: E4 00
Old 08-13-2004, 10:08   #122 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: CHANGE DATE FORMAT ON MAIN SCREEN
; (c)dspmobile for S55V20
; (p)KoTsK for M55V91
;!!! do not use "Date on Main Screen as Tu 09 Dec" patch !!!
;plz select one of these four options:
;1) shown as "dd.mm.yy" or "mm/dd/yy"
0D58D0: 0D01E0FCF07CF0C8F0D9F0E7F0F6 0D01E07CF07CF0C8F0D9F0E7F0F6
;2) shown as "dd/mm/yy"
;0D58D0: 0D01E0FCF07CF0C8F0D9F0E7F0F6 0D01E0FCF07CF0C8F0D9E07EE03F
;3) shown as "dd/mm/yyyy"
;0D58D0: 0D01E0FCF07CF0C8F0D9F0E7F0F6 0D01E0FCF07CF0C8F0D9E0FEE03F
;4) shown as "yyyy.mm.dd"
;0D58D0: 0D01E0FCF07CF0C8F0D9F0E7F0F6 0D01E0FCF07CF0C8F0D9E0FEE04F
Old 08-13-2004, 16:51   #123 (permalink)
Member: 32993
;Increase discA to 4,278,191bytes (4.08MB)
;M55v10
;(c)Sep. greeting to all creators of original patch
;thnks to kay_man & [ZZToP] for help
download
T9 working.
Compatible with all patches FW10, but need to install to clear FF.
Uncompatible with graphic patches and patches that change string in original langpack.
If graphic patch was installed - it will be saved.
Change pictures after install this patch you can by PicPac using included free.ini.
There only one PIT left in phone.
Voicedialling, java, sms - all tested and works.
You need a PicPac to use this pach.
PS i have also a 4.14 patch with working sms send, t9 etc But it's uncompatible with all patches, which are use 35block. If you need that patch - ask me ICQ#6333555
Old 08-16-2004, 03:30   #124 (permalink)
Member: 49922
; Remove increase of Loudness when Sound plays © Sinclair
;ported for M55v11 by kay
;Many Thanks LeLLik
;zzt121 for M55v10
172D8C: E6FD2E00 E6FD2D00 ;calls
172D94: E6FD4500 E6FD4400 ;family
172D9C: E6FD4700 E6FD4600 ;friends
172DA4: E6FD4900 E6FD4800 ;office
172DAC: E6FD4B00 E6FD4A00 ;vip
172DB4: E6FD4D00 E6FD4C00 ;leasure
172DBA: E6FD4F00 E6FD4E00 ;private
172DC0: E6FD5100 E6FD5000 ;business
172DC6: E6FD5300 E6FD5200 ;received
172E14: E06D 0DF3 ;other calls
172DD2: E6FD3200 E6FD3300 ;reminders
172DD8: E6FD3400 E6FD3300 ;an alarm clock
172DEA: E6FD3700 E6FD3600 ;sms (to put short; does not interrupt)
172DF0: E6FD3900 E6FD3800 ;inf.uslugi
172DF6: E6FD5700 E6FD5200 ;mel.pri ON (to put short; does not interrupt)
172DFC: E6FD5900 E6FD1500 ;mel.pri vykl.
* I'm Not tested it yet & Sorry I can't found a perfect translator...
Old 08-18-2004, 03:32   #125 (permalink)
Member: 49922
; Protect INBOX & OUTBOX Messages with Phonecode
; © ACiD[mrp], ported to V11 by AlexSid
; M55 v91
;outbox
0A003F: 2A7410 559071
0A004B: 2A7410 559071
0A10B3: 2A7410 559071
#pragma enable old_equal_ff
357178: 000000000600D49E
357180: 2E00E00008FE21004E280A009C715500
357190: E6FC7871E6FD5501FA2E06F2E00CE00D
3571A0: E00EE00FFA2A7410
#pragma disable old_equal_ff
;inbox
0A0009: 2AD60C 556071
0A001B: 2AD60C 556071
0A0D23: 2AD60C 556071
357148: 000000000600D49E
357150: 2E00E00008FE21004E280A006C715500
357160: E6FC4871E6FD5501FA2E06F2E00CE00D
357170: E00EE00FFA2AD60C
; Change Colour of Disabled Softkey
; (c) Matr!x, Braindead (S55)
; M55 v91
775718: AA FF
;FF = invisible
;00 = filled with the color
;C0, F0 = the wave
;DD = the ripples
; REMOVE PROVIDER NAME FROM MAIN SCREEN
; (C)Matr!x, converted to M55V11 by KoTsK
; M55 v91
0CC274: 8890 DB00
Old 08-20-2004, 21:31   #126 (permalink)
KoTsK's Avatar
Member: 17360
Wink
; M55V11/V91: MULTI-INDICATOR
; (C)ZH-Soft, ACiD (P)AlexSid, !Freeman!, lalo.lerry (I)KoTsK
; + NETWORK PEAK LEVEL (dB)
; + BATTERY LEVEL (%)
; + ENVIRONMENT TEMPERATURE (°C)
; + VIBRA INDICATOR
; + PROFILE INDICATOR
; !!! Need patch: GFX KOTSK.VKP (attached) !!!
0DDAD6: DA2DB2D2 DA9F9008
7F0890: DA2DB2D2D7400900F2F1663AE103F6F1
7F08A0: 0EFEE6FF64005BFFF2FE0EFEF2FF0CFE
7F08B0: E04CE0AD06FE190088F0DA2DB2D298F0
7F08C0: F6FF0EFEE0AF5BFFF2FE0EFEF2FF0CFE
7F08D0: E08CE0AD06FE190088F0DA2DB2D298E0
7F08E0: E0CCE0AD06FE1900DA2DB2D2E00CE0AD
7F08F0: E6FE2500DA2DB2D2FA9F0009
7F0900: DA2DB2D2D7401300F2F1EC27F6F10EFE
7F0910: E6FF64005BFFF2FE0EFEF2FF0CFEE6FC
7F0920: 4A00E6FD000006FE290088F0DA2DB2D2
7F0930: 98F0F6FF0EFEE0AF5BFFF2FE0EFEF2FF
7F0940: 0CFEE6FC5000E6FD000006FE290088F0
7F0950: DA2DB2D298F0F0EFE6FC5600E6FD0000
7F0960: 06FE2900DA2DB2D2FA9F9209
7F0992: DA2DB2D2D7401100F2F11E2126F1
7F09A0: AA0AF6F10EFEE6F164005B11F2FE0EFE
7F09B0: F2FF0CFEE0ADE6FC500006FE190088F0
7F09C0: DA2DB2D298F0F6FF0EFEE0AF5BFFF2FE
7F09D0: 0EFEF2FF0CFEE0ADE6FC540006FE1900
7F09E0: 88F0DA2DB2D2E6FC5800E0ADE6FE2300
7F09F0: DA2DB2D298E0E0ADE6FC5A0006FE1900
7F0A00: DA2DB2D2E6FE2400E0ADE6FC5E00DA2D
7F0A10: B2D2FA9F200A
7F0A20: DA2DB2D20FF1D7400C00F6F100000D05
7F0A30: 0EF1D7400C00F6F10000D7400C00F2FF
7F0A40: F63F9AFF03F0
7F0A46: E6FEAF01 ;#1AFh ---> FirstPictureNumber.VibraOn
7F0A4A: 0D02
7F0A4C: E6FEB001 ;#1B0h ---> FirstPictureNumber.VibraOff
7F0A50: E6FC3600 ;#036h ---> Xpos.Vibra
7F0A54: E0AD ;#00Ah ---> Ypos.Vibra
7F0A56: DA2DB2D2FA9F800A
7F0A80: DA2DB2D2DA8C0ECAC08CF0EC
7F0A8C: E6FC3300 ;#33h ---> FirstPictureNumber.Profile
7F0A90: 00EC
7F0A92: E6FC1600 ;#16h ---> Xpos.Profile
7F0A96: E0AD ;#0Ah ---> Ypos.Profile
7F0A98: DA2DB2D2DB00
;For M55V11, enable this line:
;7F090A: EC EA
23/08/2004 - !!! gfx kotsk.vkp is updated !!!
- 025..040 = small font 0..9, ., °C, -, K, M, %
- 041..050 = battery digit 0..9
- 051..057 = profile indicators
- 058..070 = digital clock 2-bit
- 228 = full screen blank-in-black analog clock
- 323..329 = profile indicators 2-bit
- 332..344 = digital clock 1-bit
- 351..356 = net signal 1 (numeric)
- 357..362 = net signal 2 (numeric)
- 364..379 = battery icons (charging pictures fixed!)
- 431..432 = vibra indicators
- 448..453 = net signal (numeric)
- PIT-tables fixed!
Old 08-21-2004, 15:52   #127 (permalink)
toroloco73's Avatar
Member: 24287
Talking from an italian friend of mine
;*** CBI. CB message in Idle screen ***
;Firmware : M55v10 - M55v11
;Author : Lalo
;luki's Siemens Modding Forum
;Release : 14.08.04 - v1
;This patch changes CB message display mode in idle screen.
;M55v10:
;CB message flashes:
;0D9724: 8E 8F
;CB message always on:
;0D9722: E6FC 0D06
;M55v11:
;0DA4FC: 92 93
;0DA4FA: E6FC 0D06
;M55v10
;CB message alwayson v2:
0D96FF: 09 18
0D9707: 05 14
or if you want his personal CB message
;M55v10
;Lalo
45DAB0: 952D2D2D2D2D2D2D2D2D2D2D2D2D2D2D 952D206C616C6F206973207468652062
45DAC0: 2D2D2D2D2D2D2D2D2D00 657374203B29202D9500
Old 08-21-2004, 22:53   #128 (permalink)
KoTsK's Avatar
Member: 17360
; M55V91: SETUP ILLUMINATION BY 5%
; (c) SiNgle (p)KoTsK
41F680: 0003080C121E2B384451 000103081012161E242B
41F68A: 7F 30
41F68B: 0003080C121E2B384451 34384044485054586064
05CF80: 06FC0A00 06FC0500
05CFB6: 26FC0A00 26FC0500
7F75DA: E0AE E05E
7F7640: E0AE E05E
7F75EE: 8B 80
Old 08-22-2004, 11:40   #129 (permalink)
KoTsK's Avatar
Member: 17360
/* not tested yet b'coz this menu's already exist on my phone */
; M55V91: ENABLE BAND SELECTION MENU
; ©RizaPN on SL45i
; Converted by KoTsK
; Menu > Setup > Network > Band selection
381338: 0502 FA01
Old 08-22-2004, 20:43   #130 (permalink)
Member: 32993
i remake ;*** www.Voltage_on_akkum_in_mV_and_temperature_in_`С *** © ZH-Soft
Now instead voltage - percent of akkum is shown. Setup are placed below, because i use extended PIT and pics 5x7
;*** www.Percentage_of_akkum_and_temperature_in_`С_with_setup *** © ZH-Soft
;Changed by Sep.
;M55v10
;Shown above original indicator
;Pics by default: 25-34digits, 35-dot, 36-grad, 37-%
;Places by default for 3х5 pics
0DCCF1: 2DCCC4 9F0009
7F0900: DA2DCCC4D7400C00F2F100009AF13B00
7F0910: DA2DCCC4D7401300F2F1EA27F6F10EFE
7F0920: E6FF64005BFFF2FE0EFEF2FF0CFEE02D
7F0930: E6FC4C0048E02D0606FE190088F0DA2D
7F0940: CCC498F0F6FF0EFEE0AF5BFFF2FE0EFE
7F0950: F2FF0CFEE02DE6FC510006FE190088F0
7F0960: DA2DCCC498F0F0EFE02DE6FC560006FE
7F0970: 1900DA2DCCC4E6FC5B00E02DE6FE2500
7F0980: DA2DCCC40D44D7401100F2F1E22026F1
7F0990: AA0AF6F10EFEE6F164005B11F2FE0EFE
7F09A0: F2FF0CFEE02DE6FC4F0006FE190088F0
7F09B0: DA2DCCC498F0F6FF0EFEE0AF5BFFF2FE
7F09C0: 0EFEF2FF0CFEE02DE6FC530006FE1900
7F09D0: 88F0DA2DCCC4E6FC5600E02DE6FE2300
7F09E0: DA2DCCC498E0E02DE6FC5A0006FE1900
7F09F0: DA2DCCC4E6FE2400E02DE6FC5E00DA2D
7F0A00: CCC40FF1D7400C00F6F10000DB000EF1
7F0A10: D7400C00F6F10000DB00
;Setup
;example of num: 0x0D03=30Dh=781
;'y' counts from left corner
;example of move pics to  781-790-digits, 791-dot, 792-grad, 793-%
;akkum
;7F093A: 1900 0d03 ;first digit of akkum
;7F0932: 4C ;y1
;7F095C: 1900 0d03 ;second
;7F0950: 51 ;y2
;7F0970: 1900 0d03 ;third
;7F096C: 56 ;y3
;7F097E: 2500 1903; '%'
;7F0978: 5B ;y4
;graduses
;7F09AC: 1900 0D03 ;first digit of grad.
;7F09A8: 4F ;y1
;7F09CE: 1900 0D03 ;etc
;7F09CA: 53 ;y2
;7F09EE: 1900 0D03
;7F09EA: 5A ;y3
;7F09DE: 2300 1703 ;dot
;7F09DA: 56 ;y4
;7F09F6: 2400 1803 ;grad
;7F09FC: 5E ;y5
Old 08-23-2004, 08:01   #131 (permalink)
anuroj_007's Avatar
Member: 66180
;Show your name or logo on main screen and screen saver(save mode or analog clock)all time
;modified from
; Provider Name -> Profil Logo Working on all phones
; Author: ACiD [mrp] & SiNgle
; Loader: V-Klay 2.4+ / M55
0CB5C0: 66FEFF3FF2FF02FE DA43EC74CC00CC00
2374EC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FF0D01D7401300F3FC222648603D03
2374FC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE6034DB0048613D03E6FE7434DB00
23750C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48623D03E6FE8834DB0048633D03E6FE
23751C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9C34DB0048643D03E6FEB034DB004865
23752C: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D03E6FEC434DB00E6FED834DB00
237460: FFFFFFFFFFFFFF xxxxxxxxxxxx00 ; = "XXXXXX" ; change to your name/logo * You can create any text info as you wish in Hex code (as long as not more than free space limit - 00)*
237474: FFFFFFFFFFFF 4c6569736500 ; = "Leise"
237488: FFFFFFFFFF 4c61757400 ; = "Laut"
23749C: FFFFFFFFFFFFFFFF 436172204B697400 ; = "Car Kit"
2374B0: FFFFFFFFFFFFFFFF 4865616473657400 ; = "Headset"
2374C4: FFFFFFFFFFFF 4e6163687400 ; = "Nacht"
2374D8: FFFFFFFFFFFFFF 41726265697400 ; = "Arbeit"
select the line show profil that you always use
You can see the HEX code for any letter here
http://www.asciitable.com/ascii2.html
Old 08-23-2004, 13:40   #132 (permalink)
Member: 32993
Some remake of *** www.Change_time_of_minute_signal *** © SiNgle, RizaPN, respect to its authors. To all speaking by free limit of 5sec =)
;*** www.Cancel_call_by_time *** ©  Sep.
;M55v10
;uncompatible with *** www.Change_time_of_minute_signal *** © SiNgle, RizaPN
;on/off by menu->927
00413C: F2F40CFE DA6800BD
48BD00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F40CFE46F405003D02DA22CA0CDB00
48BD06: 05 04 ; seconds
Old 08-23-2004, 14:50   #133 (permalink)
anuroj_007's Avatar
Member: 66180
;Modified Vibra logo
;Source from
;Vibra logo m55 v10
;©ZH-Soft
;And pictures from KoTsk
;compatible to
;M55V10: Show Profile Logo + Temperature
;Original sources are © ACiD, ZHpaul and improve by KoTsK
;Change logo position to be between profil logo and temp and new logo pictures
7F05D2: DA2DCCC4 DA9F8A0A
7F0A8A: FFFFFFFFFFFF DA2DCCC4D740
7F0A90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D00F2FEEE1C9AFE03F0E6FEAF010D02
7F0AA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FEB001E6FC2800E6FD0A00DA2DCCC4 ;x-position=2800,y-position=0A00
7F0AB0: FFFF DB00
; ##### Picture 431 #####
; Picture Data
2EDC4A: C0C0C0FFFFFFFFFFC0C0C0C0C0C0C0C0 00000000000000000000000000000000
2EDC5A: C0C0C0C0C0C0C0C0FF000000FFFFFFFF 000000000000F1F1F100F100F100F1F1
2EDC6A: FFFFFFFFFFFFFFC0C0C0C0C0C0FF00B6 F100F1F1F100F100F10000F1000000F1
2EDC7A: E000FFFF00FFFF00FFFF00FFFFC0C0C0 00F100F100F100F100F100F100F10000
2EDC8A: C0C0FF00B6E0B600FFFF00FFFF00FFFF F1F1F100F1F1F100F100F100F1000000
2EDC9A: 00FFC0C0C0C0C0FF00B6E0B600FFFF00 F1F10000000000F100F100F100F100F1
2EDCAA: FFFF00FFFF00FFC0C0C0C0C0FF00B6E0 00F100F100F100F10000F1F1F100F100
2EDCBA: B600FFFF00FFFF00FFFF00FFC0C0C0C0 F100F1F1F100F1F1F100F100F1000000
2EDCCA: C0FF00B6E000FFFF00FFFF00FFFF00FF 00000000000000000000000000000000
2EDCDA: FFC0C0C0C0C0FF000000FFFFFFFFFFFF 000000C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDCEA: FFFFFFFFFFC0C0C0C0C0C0FFFFFFFFFF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDCFA: C0C0C0C0C0C0C0C0C0C0C0C0C0 C0C0C0C0C0C0C0C0C0C0C0C0C0
; ##### Picture 432 #####
; Picture Data
2EDD07: C0C0C0C0C0FFFFFFFFFFC0C0FFFFFFC0 C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD17: C0C0C0C0C0C0C0C0C0C0FF000000FFFF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD27: FFFF00FFC0C0C0C0C0C0C0C0C0C0C0FF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD37: 00B6E000FFFF00FFFFC0C0C0C0C0C0C0 C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD47: C0C0C0C0FF00B6E0B600FFFFFFFFFFFF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD57: C0C0C0C0C0C0C0C0C0FF00B6E0B600FF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD67: FF000000FFC0C0C0C0C0C0C0C0C0FF00 C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD77: B6E0B600FFFFFFFFFFFFC0C0C0C0C0C0 C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD87: C0C0C0FF00B6E000FFFF00FFFFC0C0C0 C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDD97: C0C0C0C0C0C0C0C0FF000000FFFFFFFF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDDA7: 00FFC0C0C0C0C0C0C0C0C0C0C0FFFFFF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
2EDDB7: FFFFC0C0FFFFFFC0C0C0C0C0C0 C0C0C0C0C0C0C0C0C0C0C0C0C0
I had test on my baby M55 v10 its all OK
Thank to all for this small success
Old 08-23-2004, 17:49   #134 (permalink)
KoTsK's Avatar
Member: 17360
... remade ...
; M55V11/V91: INCOMING CALL INDICATOR V2.0
; "Unknown/Home/Office/Mobile/Fax/Fax2"
; ©Matr!x, AlexSid, kay - 23/08/04
; The phone numbers should be written in international format,
; e.g. 081234567 must be written as +6281234567 ...
; otherwise it will shown as "unknown".
01B6AC: FA216AB8 FA2164B7
01B8C4: DA2164B7 DA21A0B6
0DA9F6: DA9AF2C7 DA7510DD
45DC07: 954964656100954B 9595959595009595
45DC0F: 6973730095486F6C 9595950095959595
45DC17: 696461790095466C 9595959500959595
45DC1F: 6F77657273009548 9595959595009595
45DC27: 6561727400954865 9595959500959595
45DC2F: 6172746163686500 9595959595959500
55DD10: D7400700F2FBBA3C88B048B02D0B48B1
55DD20: 2D0F48B22D1348B32D1748B42D1B48B5
55DD30: 2D1FDB00E6FEAE11DA9AF2C7FA757CDD
55DD40: E6FEAD11DA9AF2C7FA757CDDE6FEAC11
55DD50: DA9AF2C7FA757CDDE6FEAB11DA9AF2C7
55DD60: FA757CDDE6FEAA11DA9AF2C7FA757CDD
55DD70: E6FEA911DA9AF2C7FA757CDD98E006FE
55DD80: 4700E6FC1300E6FD0100DA2DB2D2DB00
*** GFX KOTSK.VKP is updated! ***
- added incoming call indicator pictures
File Type: gif incoming_call.gif (839 Bytes, 48 views)
Old 08-25-2004, 20:56   #135 (permalink)
KoTsK's Avatar
Member: 17360
.... if this patch is useful ....
; M55V11: Disable backlight during incoming call © AlexSid, kay
01B6A6: DA21F2EE DA7500DD
55DD00: DA2160EEE03CE6FD
55DD08: FF7FDAA036D2DB00
; M55V91: Disable backlight during incoming call © AlexSid, kay ® KoTsK
55DD08: FF7FDAA0AED2DB00
m55 v10 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 11 12-12-2004 03:41
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 11:32
M55 Graphic Patches iccume x4x, x5x Flashpatching 17 03-06-2004 18:24
m55 v11 patches (some new, some old) |FeRRaRi| E-Gold Based Phones 4 02-27-2004 03:17
dead m55 after freia m55 AMD patch lypen17 E-Gold Based Phones 3 02-27-2004 00:30
Page generated in 0.66387 seconds with 9 queries
