03-11-2004, 09:05 | #61 (permalink) |
Major Poster Join Date: Jan 2004
Member: 49917 Status: Offline Thanks Meter: 0 | 1. you make a fubu and name "original.bin or original.fls" 2. you make a copy of original fubu and name copy.bin or copy.fls 3. you decompile the lgp file from bin or fls 4. you edit it as you like - and modify AllLangs from header of lgp (2 for 2 languages) 5. you compile the modified lgp to copy.bin( slegd asks for a lgp file - you modified one and a bin file copy.bin - this is where you did wrong) - it should result a file copy.bin - 14 Mb 6.compare the two fubus 7.write patch enjoy |
03-11-2004, 10:57 | #62 (permalink) |
Member: 49917 Status: Offline Thanks Meter: 0 | i guess i found the problem with 256+ patch - Single patch has no problem(appologises from me), as long as you don't use all the space - the disk b patch can't handle this - acctualy the low space error, so the phone buzz and turn off maybe chaos or anybody else can confirm me this and fix the patch too thanks as long as you live, you learn |
03-11-2004, 19:38 | #64 (permalink) |
Junior Member Join Date: Mar 2004
Member: 57012 Status: Offline Thanks Meter: 0 | marcoaq , i did all that, the final patch has 600 kb, i aplied it.what should i do next?how can i use drive B? 10x ! And i have another problem.When I open Mobile from the Siemens Data Suite i see no folders anymore , i see only a file graphcach ... what should I do ? Last edited by cristyg; 03-11-2004 at 20:11. |
03-12-2004, 07:00 | #65 (permalink) |
Member: 49917 Status: Offline Thanks Meter: 0 | you have to create folder Java and subfolder Jam on that drive b:, then put your games in the jam subfolder set your left softkey as java if you want to switch from b: to a:, just start games&more from your menu and use the Siemens Data suite after that |
03-13-2004, 02:25 | #67 (permalink) |
Junior Member Join Date: Feb 2004 Age: 44
Member: 53749 Status: Offline Thanks Meter: 0 | If someone haves a patch to disable aircraft check for version 10, please share it!! If not, can someone transform the patch for v11 shared in the forum to the v10? Thanks. |
03-15-2004, 04:58 | #68 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: www.SiemensXP.com Age: 45
Member: 49922 Status: Offline Thanks Meter: 0 | Quote:
if you want to disable the aircraft check, use Siemens Quick EEPROM Tools v3.2 it works for me now... | |
03-17-2004, 10:27 | #70 (permalink) |
Junior Member Join Date: Feb 2004 Age: 49
Member: 53133 Status: Offline Thanks Meter: 0 | You cannot increase the volume on M55, but if you familiar with Cool Edit program you are able to amplify the mid or wave ringtone. I tried in the wave format and it is working fine. |
03-20-2004, 22:52 | #74 (permalink) |
Junior Member Join Date: Mar 2004 Location: Romania Age: 38
Member: 58757 Status: Offline Thanks Meter: 0 | Okay, I sort of need a patch that will get rid of the "dialing sound" you hear (m55/v11) when you dial a number. Or at least disable it when "Quiet Environment" profile is enabled. And also, where do I get the patch for drive b for v11? 10x |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
