Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 03-11-2004, 08:05   #61 (permalink)
Member: 49917
it's easy:
1. you make a fubu and name "original.bin or original.fls"
2. you make a copy of original fubu and name copy.bin or copy.fls
3. you decompile the lgp file from bin or fls
4. you edit it as you like - and modify AllLangs from header of lgp (2 for 2 languages)
5. you compile the modified lgp to copy.bin( slegd asks for a lgp file - you modified one and a bin file copy.bin - this is where you did wrong) - it should result a file copy.bin - 14 Mb
6.compare the two fubus
7.write patch
enjoy
Old 03-11-2004, 09:57   #62 (permalink)
Member: 49917
i guess i found the problem with 256+ patch - Single patch has no problem(appologises from me), as long as you don't use all the space - the disk b patch can't handle this - acctualy the low space error, so the phone buzz and turn off
maybe chaos or anybody else can confirm me this and fix the patch too
thanks
as long as you live, you learn
Old 03-11-2004, 15:25   #63 (permalink)
Member: 24316
hi,i kill m55 v.11. Please help mee urgent!!!!!
Old 03-11-2004, 18:38   #64 (permalink)
Member: 57012
marcoaq , i did all that, the final patch has 600 kb, i aplied it.what should i do next?how can i use drive B? 10x !
And i have another problem.When I open Mobile from the Siemens Data Suite i see no folders anymore , i see only a file graphcach ... what should I do ?
Old 03-12-2004, 06:00   #65 (permalink)
Member: 49917
you have to create folder Java and subfolder Jam on that drive b:, then put your games in the jam subfolder
set your left softkey as java
if you want to switch from b: to a:, just start games&more from your menu and use the Siemens Data suite after that
Old 03-12-2004, 14:00   #66 (permalink)
Member: 57012
it works !!! thanks very much!!!
Old 03-13-2004, 01:25   #67 (permalink)
Member: 53749
If someone haves a patch to disable aircraft check for version 10, please share it!! If not, can someone transform the patch for v11 shared in the forum to the v10?
Thanks.
Old 03-15-2004, 03:58   #68 (permalink)
Member: 49922
Thanks.
There was a patch to disable aircraft check v10 before, but it doesn't work.
if you want to disable the aircraft check, use Siemens Quick EEPROM Tools v3.2 it works for me now...
Old 03-15-2004, 05:58   #69 (permalink)
Member: 51279
Question Increase Volume M55
Is there any pacth to increase volume on M55 ??
Thanks before
MasWiwid
Old 03-17-2004, 09:27   #70 (permalink)
Member: 53133
You cannot increase the volume on M55, but if you familiar with Cool Edit program you are able to amplify the mid or wave ringtone.
I tried in the wave format and it is working fine.
Old 03-17-2004, 15:29   #71 (permalink)
Member: 49917
why the wave recorder on m55 blocks the phone all the time
maybe is a workaround to this thing or maybe is my phone who did this
please help
thanks
Old 03-18-2004, 05:01   #72 (permalink)
Member: 58706
is there any way to convert those "digital clock during keylock" patches to 12h format?
Old 03-18-2004, 05:42   #73 (permalink)
Member: 49917
the provider->time patch doesn't display the right day - do you know how can this be fixed?
thanks
Old 03-20-2004, 21:52   #74 (permalink)
Member: 58757
Okay, I sort of need a patch that will get rid of the "dialing sound" you hear (m55/v11) when you dial a number. Or at least disable it when "Quiet Environment" profile is enabled. And also, where do I get the patch for drive b for v11? 10x
Old 03-21-2004, 18:29   #75 (permalink)
Member: 57012
I've aplied the digital clock patch for m55 and when i disable the screensaver it doesn't appear.can anybody help me?10x
S55 flash patching(Thread for discussing) zdob x4x, x5x Flashpatching 347 12-09-2006 12:47
X6x Flash patching(THE Thread for discussing) : zdob x6x and x7x Flashpatching 196 09-04-2006 19:12
SL55 flash patching (Thread for discussing) 3aTmr x4x, x5x Flashpatching 29 03-21-2006 19:40
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Page generated in 0.38816 seconds with 9 queries
