Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 04-03-2005, 15:56   #871 (permalink)
Member: 75064
Thanks Meter: 6
That's a good question i have that fw too.
Old 05-03-2005, 16:58   #872 (permalink)
Member: 74486
Hi all!
I was wondering if anyone might have the same problem and/or might know how to solve it.
My phone (m55) is (or rather was T-Mobile. While learning of patching and everything, I changed the annoying t-mobile pictures (and the siemens ones too, but one thing remains:
The menu structure:
1 Games and more
1.1 wap link
1.2 wap link
1.3 games and more=> java/jam folder
2 Pictures=>
2.1 Wap link
2.2 My pictures=> pictures folder
3 Sounds=>
3.1 Wap link
3.2 Wap link
3.3 My sounds=> sounds folder
And so on. Really annoying to have to press 9 buttons to get to ringtones! And no way to see the hidden folders, but to open a picture and exit to the menu, then I get to the "normal menu".
So the big question is: how can I get the normal siemens card explorer?!?!?!
If noone has any better ideas, could you at least post me you clean backed up FF? I'll flash it and reaply the hundred something patches I have installed
THNX in advance!
Old 05-25-2005, 13:05   #873 (permalink)
Member: 74486
Oh, never mind! I found a sollution:
It's done by remapping the phone, or, as I've done, simply overwriting the
5381 (Unknown)
5360-5364 (magic Bookmarks)
blocks of the eeprom with original ones. (With SIEMENS EEPROM TOOL)
Old 10-04-2005, 15:56   #874 (permalink)
Member: 65316
Hi ALL,
Could someone ports the following patch to M55 FW91 ?
(That would be better if the RESET funcion is on the camera hotkey.)
;*** software RESET on Left_Key ***
;the Handy peels when pressing CURSOR_LEFT _ _ immediately out ; store (without EEPROM...)
; Firmware: S55 v20
; Author: AC ID [ mrp ]
; Homepage: www.gsm dev.com
32499C: DA7106B8 B748B7B7; srst (software RESET)
Thanks in advance,
Jimmy
Old 10-04-2005, 20:09   #875 (permalink)
KoTsK's Avatar
Member: 17360
@anyone asking about disk-a patch
i think that patch has been posted long time ago. check it on m55's pacth section.
it's better to set the phone to fact. settings and do backup before applying patch.
read carefully the instruction written inside vkp file.
@jimkz
use instruction of B748B7B7 as an "entrypoint" to anywhere you want, e.g. on clicking left-arrow key, etc.
Old 09-23-2006, 00:02   #876 (permalink)
Member: 241198
hi there,
I'm searching for a patch for m55 vers 11 that can remove the acoustic shock protection. Does anyone can help me?
thanks
Old 09-23-2006, 00:16   #877 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@wile:
Hi mate! Nice to see you here...
Good searching
Old 09-24-2006, 08:00   #878 (permalink)
Member: 89854
I still love my siemens m55.
Old 05-01-2009, 10:03   #879 (permalink)
Member: 1006060
can someone pls guide me how to use these patches??..
Old 05-01-2009, 10:27   #880 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 397
...you need to use the V-Klay software. Install it, set comm port and baudrate to 115200,connect your phone with serial cable (service cable, not data cable). Your phone needed to be off. Double click to the patch, vklay software is started, short push to the phone power button (red button). After starting connection, v-klay make the flash backup (only one time). After macking backup (and saved on the local drive), v-klay compair address writed on the patch to the addres from phone and if everyhing is OK, write modification on phone. Is easy, but not for begginers! Possible to damage eeprom fields and your phone crash...
BTW. you need to make testpoint (cut one track). Otherwise, not working connection.
dagos
Old 01-25-2010, 04:37   #881 (permalink)
kalitirto's Avatar
Member: 930245
Thanks Meter: 22
a very good explanation at all... thanks
S55 flash patching(Thread for discussing) zdob x4x, x5x Flashpatching 347 12-09-2006 12:47
X6x Flash patching(THE Thread for discussing) : zdob x6x and x7x Flashpatching 196 09-04-2006 19:12
SL55 flash patching (Thread for discussing) 3aTmr x4x, x5x Flashpatching 29 03-21-2006 19:40
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Page generated in 0.37291 seconds with 9 queries
