03-31-2004, 15:04 | #92 (permalink) | |
Junior Member Join Date: Mar 2004 Age: 46
Member: 56901 Status: Offline Thanks Meter: 0 | Quote:
http://www.lcard.ru/~gorinov/xsiemens.html | |
03-31-2004, 22:06 | #93 (permalink) |
Junior Member Join Date: Mar 2004 Age: 41
Member: 57087 Status: Offline Thanks Meter: 0 | ;"LCW" LeftSoftKey -> Camera -> WAV recording ;(C) SiNgle ;M55v10 ;Released 20.12.03 0D2EFA: DA302A55 da37441a ----------- There is a bug, after I use the wav recorder and then I try to read some text files from my phone from file system it doesn't read them anymore. I have to shut down the phone and restart it in order to read them. |
04-02-2004, 12:05 | #94 (permalink) |
Junior Member Join Date: Apr 2004
Member: 60890 Status: Offline Thanks Meter: 0 | digiclock Hi All Can I ask you something? I applied the "digiclock in keylocked mode" patch to my m55 v10. I had a lot of trouble in trying to change the images from 332 to 342. In fact, if I try to make bitmap images with more than 8 bit color depth (16-24-32), the patch doesn't work, I mean there must be some overlap with digiclock patch, because in that case, If I apply digiclock patch I can't apply the images patch and vice-versa. But no problem If I use 8-but bmp images. The only strange thing is that, whatever is the image I substitute to the original, when I load it, in SPC2 appear 0x?????? in place of the real address of the original image. Besides, when I save the patch, the first image begin always from address 000000. Is that normal? Thanks Federico |
04-05-2004, 17:00 | #95 (permalink) | |
Junior Member Join Date: Jan 2004
Member: 49868 Status: Offline Thanks Meter: 0 | Quote:
Code: ; Provider Name -> Time, Environment Temperature ; Format: 10:01 - 24,5'C ; ; M55 v10 ; ; 2004 by ACiD[mrp] ; GSM Development Crew www.gsm-dev.com ; Mobiletuning www.mobiletuning.de ; ; ; If you already applyed the ProviderTime Patch please ; undo this first. ; ; Sorry, there's no ° available so I've used an ' 0CB5BC: E04E00E0 E6FE2001 0CB5C0: 66FEFF3F E6FF0300 0CB5C4: F2FF02FE DA500898 0CB570: E04E00E0 E6FE2001 0CB574: 66FEFF3F E6FF0300 0CB578: F2FF02FE DA500898 309808: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88608870888088C088D0D7400D00F3FE 309818: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CE63F0C7BB6ED7400300F7FE20C1F078 309828: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE21C1E7FE3A00D7400300 309838: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE22C1D7400D00F3FECC63F0C7BB59 309848: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE23C1F078D7400300F7FE 309858: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 24C1E7FE2000D7400300F7FE25C1E7FE 309868: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D00D7400300F7FE26C1E7FE2000D740 309878: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0300F7FE27C1D7401100F2FCE460E6FD 309888: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AA0A20CDF6FC0EFEE0AD4BDDF2FC0EFE 309898: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD0CFEBB2ED7400300F7FE28C1F078 3098A8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400300F7FE29C1E7FE2C00D7400300 3098B8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE2AC1F0CDBB1DF078D7400300F7FE 3098C8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2BC1E7FE2700D7400300F7FE2CC1E7FE 3098D8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4300D7400300F7FE2DC1E10ED7400300 3098E8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F7FE2EC198D098C0988098709860BB01 3098F8: FFFF DB00 3098FA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F6FC0EFEE0A65B66F2F70EFEF2F80CFE 30990A: FFFFFFFFFFFFFFFFFFFF 06F7300006F83000CB00 Last edited by Eza; 04-06-2004 at 10:14. | |
04-05-2004, 18:18 | #96 (permalink) |
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | is there a patch for disable aircraft check for M55V10? i have search the whole forum and got nothing. and what the best for patching, ppl? M55v10 or M55v11?? |
04-06-2004, 10:16 | #98 (permalink) | |
I prefer 10. | |
04-07-2004, 08:09 | #102 (permalink) |
Crazy Poster Join Date: Feb 2004 Location: Australia Age: 43
Member: 55381 Status: Offline Thanks Meter: 0 | ;FlashSMS Sender ;© SiNgle ;M55v10 ;Released 14.03.04 ;Ver 1.0 ; neues SMS Profil erstellen ; - Gültigkeit 1 Woche ; - alles andere beliebig ; SMS schreiben ; Optionen -> Senden Via ... ; Flash SMS wählen 6582B8: E6FE043E FA505271 00307152: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8880E6F85C3DD7400C00F448010047F4 00307162: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AD003D10D7400C00A94847F408002D08 00307172: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F4F00006F8B600D7400C00B9480D18 00307182: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4FF20DF8D7400C00F448020047F4AD00 00307192: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0FD7400C00F448010047F408002D0D 003071A2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F4F00006F8B600D7400C00E4480100 003071B2: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 9880E6FE043EFA85BC824FF20DF3 |
04-07-2004, 09:14 | #103 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: www.SiemensXP.com Age: 45
Member: 49922 Status: Offline Thanks Meter: 0 | Quote:
but what the quote words mean? is there any setting I have to do to sent SMS as FlashSMS? | |
04-07-2004, 11:38 | #104 (permalink) |
Member: 55381 Status: Offline Thanks Meter: 0 | the quotes are in german, which say: 1. create a new sms message profile in menu>messages>msg. setup>sms, you can name it anything. i named it "Flash SMS" 2. set the settings for that profile as required, i.e. ur provider number etc etc, but you HAVE to select validity period as "1 week", the rest of the settings you can put anything. then when you've got the profile, type ur new message and then goto options>send via... and select your "Flash SMS" profile and send away! |
04-08-2004, 02:47 | #105 (permalink) | |
Thanks again |FeRRaRi| ... | |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
