Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-26-2004, 11:19   #1 (permalink)
Member: 91950
Exclamation ME45 Troubles
I recently got a ME45 which seems to be a great mobile phone, and I'm thinking of keeping it, but I have some problems with it.
First of all it works great, the menu acessing is fast, smooth there are no network problems whatsoever. The thing that bugs me is that after I format the drive the drive info says : Size 348 Kb, Free 347 Kb. Why is that??
And Second I've been having problems flashing it with patches or even fullflash, the software just does'nt upload. I had luck with S45i_040315.exe (WinSwup) which finishes with no error, but then I can't activate the crc patches, and the s/me crc - so I cant turn the phone on! After I loaded the new software I was able to turn on the crc's (with SMEactivation tools), but I cant upload any of the other patches??
I don't know what the problem with my phone is and should I try to flash it again??? If some1 can answer these questions for me I'd be very thankful!!
Old 11-26-2004, 14:39   #2 (permalink)
genetic1's Avatar
Member: 70990
First of all...do you have a fubu (fullflash) of your old data (before applying S45i_040315.exe) and eeprom data??? I hope you have!? If not - so now it's to late.
Next step:
After applying S45i_040315 use S45iv04 Activator by ACiD
Download: http://www.gsmdev.de/index.php?c=viewprojektinfo&id=13
Using this very good tool for patching CRC and others. If you've done this successful you can turn on mobile. (if you get message "Wrong Software", please "Unlock" phone by using SME45Tools for example).
For applying (many) other patches, please use V_klay:
Download: http://www.vi-soft.com.ua/
Please apply this patch with V_klay and format flex memory. It works 100%.
;Increased FlexMemory (393,51kb)
; (probably by Jaelenicu)
;You should backup your whole contents of Flexmem using one of those
;applications to backup directly. Or you can use Data Exchange (for
;Flexmem files) and VisSie / Mobile Navigator (for Addressbook) to
;backup indirectly.
;after format is still increased
02BBF6: 0002 8000
3A5526: 66 E6
3A5528: FF 0C
3A554E: D4E00A00 E6FE2003
3A5771: 2C 1C
3A5796: D4C00200 E6FC2003
3A58D9: 2060 005A
Good luck
genetic1
Old 11-30-2004, 08:21   #3 (permalink)
Member: 91950
I have done everything you have described above, have been doing it from the start, but that is not the case here!!!
I can't restore my original FUBU, so is there a way to format/erase the complete memory range, and then to upload the FUBU or smthing???
because I'm scared that if I just try to flash it again it might not work???
Old 11-30-2004, 13:57   #4 (permalink)
genetic1's Avatar
Member: 70990
If you have your (working) orig. Fubu you haven't to be "scared"!
One reason,that your upgrade doesn't work, could be your chipset...BA20 Chip is a little bit more difficult as CE20, C289 or C489 Chip.
Use this link and download SME45Tools:
http://gsmfree.vipserver.ru/Siemens/sme45_sme45i.htm
There is also a manual, how to update SME45 to SME45i (but only in german!)
In your case...select register "Write flash"..."Read from file" (here you must select your orig. Fubu)..."Write to flash" (short pression red button) - READY!
Now your orig. Fubu will be restored.
It works 100%.
Please search forum, too. There are "hundreds" of posts about this topic...
Example:Dead ME45 !!!
BTW: (Hope you use an non-original-datacable)!!! Have you charged your battery to max. before you made your fubu? So before restore your fubu, you have to charge your battery to max. again!
genetic1
Old 12-01-2004, 08:08   #5 (permalink)
Member: 91950
Thanx for all your help, I'll look into what you say and I should check about the cable, it is suposed to be a patched SL45 cable but I'm not sure
And again thank you!!!
me45 unloking mcc x1x to x45/x50 0 10-25-2001 18:41
searching for me45 upgrade 07 lg1 !! Proggy x1x to x45/x50 10 10-16-2001 23:30
Flash for ME45 daro x1x to x45/x50 5 10-09-2001 23:17
Experience new ME45 Swen x1x to x45/x50 1 09-20-2001 13:12
Soft for S/ME45 Vasuk x1x to x45/x50 1 09-20-2001 12:34
Page generated in 0.29331 seconds with 8 queries
