01-14-2004, 16:37 | #20 (permalink) |
Insane Poster Join Date: May 2003
Member: 29842 Status: Offline Thanks Meter: 0 | single you can help me: i ve made everything with that walkthrough that polk posted,but when the mobile finds the operator shuts down.The only thing i can do after is to reflash so i can work the phone. why? |
01-14-2004, 18:48 | #21 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | Quote:
Thanks. @all, No1 say nothing about applying more than one patch on same phone, so be carefull - look at adresses used by patch in V_Klay and be sure that patch you want to apply doesnt make conflict with other patches you have already in phone. Last edited by XisiX; 01-14-2004 at 18:53. | |
01-15-2004, 14:53 | #22 (permalink) |
Junior Member Join Date: May 2003 Location: Hungary / Budapest
Member: 29152 Status: Offline Thanks Meter: 0 | Don't forget in original.lgp file ; Header info ; PhoneType M55_10, 5A0000, 40000,6,8,a,c,e,10,12,16,2a,3c,43,0 AllLangs 6, or 7, or something to 2 change!! |
01-16-2004, 00:53 | #23 (permalink) |
Junior Member Join Date: Jan 2004
Member: 49500 Status: Offline Thanks Meter: 0 | tried to extract the language pack from a flash(v.10) i read from my phone with M55 tool.. but it says 'unknown phone flash'.. is there a specific part of the flash that needs to be extracted from the phone? |
01-16-2004, 17:47 | #26 (permalink) |
Member: 49500 Status: Offline Thanks Meter: 0 | nevermind that.. i managed to squeeze ~1.3MB onit.. 'capacity' shows available space on drive a: here's a link to a patched flash with english and russian.. but the server won't be up 24/7 so if someone has an account on a server with more uptime.. please put it there. thx SiNgle m55_fubu_drivepatch |
01-17-2004, 13:34 | #29 (permalink) |
Junior Member Join Date: Jan 2004 Location: http://nec.intact.pl Age: 40
Member: 49004 Status: Offline Thanks Meter: 0 | First: Since U use Java Disk b: DES show only it. If U want to have acces to a: then simply turn your phone off and turn it on again. Second: U should decompile LangPack from your actual flash. It should have 2.02 MB sometimes it is 6 MB i don't know Y but probably because flash patches. IF U READ & understand MY TUTORIAL http://www.glucholazy.net/Tutorial_Java.txt Than everything should be OK. LINKS TO SOFTWARE ARE ON 1 SITE OF THIS TOPIC IF YOU HAVE SOME PROBLEMS WHILE PATCHING COPY ALL FOLDERS TO YOUR HDD AND FLASH IT BY REPAIR FLASH AND THAN UPDATE FLASH FROM MY-SIEMENS.COM. THAN BACKUP YOUR FILES. THIS PATCH WORKS ON M55 WITH FLASH VERSION 10 !!!! AND IT REALLY WORKS |
Graphic Patches and links of them for M55 | El Unix | x4x, x5x Flashpatching | 3 | 08-09-2004 09:47 |
ideas for m55 v11 patches | prp | E-Gold Based Phones | 1 | 08-05-2004 20:38 |
Freia Patched for M55 !!! | Drug_Store | Siemens-Benq RingTones and WallPapers | 56 | 03-22-2004 06:31 |
Finally Nokias Network indicator patch for M55 v10!!! | leoaamro | E-Gold Based Phones | 0 | 03-18-2004 07:05 |
Patch For M55 | fabio911 | E-Gold Based Phones | 6 | 10-19-2003 20:40 |
