03-12-2003, 11:28 | #1 (permalink) |
Junior Member Join Date: Feb 2003 Location: Kiev, UA Age: 53
Member: 20791 Status: Offline Thanks Meter: 0 | Newest flasher+direct patcher+language changing 1) direct patching, 2) own letters in SMS (like as cyrillic), 3) correctly read-write flash & EEPROM Use it! http://www.is.svitonline.com/valeravi/index.htm use www.translate.ru *.crk is a "cracker" format. ftp://ikar.zaural.ru/pub/patches.rar Last edited by Werefox; 03-12-2003 at 11:37. |
03-12-2003, 15:58 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | @Werefox It seems a really good sw. But the menus are in English and the log windows it in russian. Itīs just the pic on the site, or the sw really works this way? Maybe someone could get an english copy and post here the link... |
03-14-2003, 00:35 | #5 (permalink) |
Member: 20791 Status: Offline Thanks Meter: 0 | To use the "General patch page" Original text Code: Add "Send via IrDA ..." options in CardExplorer Firmware: SL45 v56 Author: RizaPN 0x18A3E4 : 28 01 28 01 => 21 02 21 02 (change the text) 0x18A3FE : AE AB => A4 7D (change the function address) Code: 0018A3E4: 28 21 0018A3E5: 01 02 0018A3E6: 28 21 0018A3E7: 01 02 0018A3FE: AE A4 0018A3FF: AB 7D Code: 0018A3E4: 28012801 21022102 0018A3FE: AEAB A47D ADDRESS:space DATA_ORIGINALspaceDATA_CHANGING ONLY 2 SPASES!!! |
03-18-2003, 16:20 | #6 (permalink) |
Member: 20791 Status: Offline Thanks Meter: 0 | The newest versions have appeared http://www.is.svitonline.com/valeravi/index.htm |
03-22-2003, 16:36 | #7 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Kyiv, Ukraine Age: 47
Member: 24687 Status: Offline Thanks Meter: 1 | Also you can use the commens it patches (use ";" before comments): Original text Code: Add "Send via IrDA ..." options in CardExplorer Firmware: SL45 v56 Author: RizaPN 0x18A3E4 : 28 01 28 01 => 21 02 21 02 (change the text) 0x18A3FE : AE AB => A4 7D (change the function address) Code: ;Add "Send via IrDA ..." options in CardExplorer ;Firmware: SL45 v56 ;Author: RizaPN 18A3E4: 28012801 21022102 ;(change the text) 18A3FE: AEAB A47D ;(change the function address) It's mean ;comments ADDRESS: DATA_ORIGINAL DATA_CHANGING ;comments ;comments |
04-19-2003, 21:28 | #8 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | I have made a new version: [GLOW=purple]V_KLay v2.1.0[/GLOW] Whats new ('+ ' mean Added, '*' - fix). v2.1.0 (19.04.2003) + Possibility of disable the confirmation at apply patch and other warnings and messages on successful completion. + Support of other Siemens phones (not all tested - need help). + An auto update of contents of ComboBox lists on tab Flasher to show size FullFlash and EEPROM and their initial addresses. If you pressed down arrow near input fields From, Size, etc. you can see their possible values for selected type of phone. + A field for displaying a flash type and ID of the phone. + Possibility of choice of a transfer rate (baud) on the COM port. + At a text insertion from a clipboard in the window of a patch the text is formatted by one font, instead of that which was in a source code (i.e. in that place from which the text of a patch has been copied). + A pop up menu (on a click of the right mouse button) in the window of the editor of a patch. + At saving the read out block of flash offers a filename of sort "Block_XX.bin", where XX - high 2 digits of the address. * After saving .vkp the file updates his(its) name on caption programs. + Recognition of the command line is added. (Click on the file in the Explorer - and file is opens in V_KLay). + It is added the button "New" patch. + Size of the edited text of a patch up to 2 GB enlarged. + Show the current number of the line and column in the text of patch. You may read more and download program at my webpage http://www.ValeraVi**** |
04-22-2003, 00:13 | #9 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | New version: v2.1.1 - bugs corection *Corrected: error while write to SL45i flash at 0x1f0000 *Corrected in version for Win9x/Me: General Patch tab is displayed now! download new version from: [GLOW=limegreen]http://www.ValeraVi****[/GLOW] |
04-22-2003, 16:42 | #11 (permalink) |
Junior Member Join Date: Apr 2003 Location: Brno, Czech Republic Age: 43
Member: 26101 Status: Offline Thanks Meter: 0 | Great soft, works perfectly, thanx. What about patching the status report to show the name instead of just the phonenumber like on my good old Sagem MW932! |
04-22-2003, 17:37 | #12 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | @vikado77 For removing this bug you must re-install not only Update for Win98, but also and V_KLay for Win2000/XP too!!!. The changes, that fix this bug is in file V_SL4x.ldr, and this file included only in installation pack for WinXP. Sorry... @RAT2 At this moment i busy about V_KLay and not have a time for making patches.... sorry... |
04-22-2003, 20:24 | #13 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | @ValeraVi: No, it isn't workink patching with 1F0000!!! I use WinXP and had uninstalled the old ones, but it still don't working, when i patch 1F0000 ( error I/O COM1 ) What is wrong? |
04-22-2003, 21:13 | #15 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | @vikado77 Its very strange. I recheck all with my SL45i and all working!. Can you describe more about yours hardware and software: what data cable yo use (USB->COM, or original SL45 dock station, or...). Also, is you know program HHD Serial Monitor It will be very great, if you send me a .log file from this program of COM1 while you working with V_KLay on COM1 in case where you get a error. |
Infinity Help-doing Format Fs Language Change. How Can We Change It In English Again | shahi | Infinity-Box | 6 | 11-03-2007 21:59 |
Nokia 6280 Newest Firmware with Chinese Language | nokia6280 | Nokia Base Band 5 ( BB-5 ) | 3 | 12-26-2006 07:43 |
sagem language change and flasher | edazor | ARM9 BASED M62 / M62+ | 0 | 02-19-2004 18:29 |
5303 Flasher with Russian language for sale | Filin | x1x to x45/x50 | 4 | 08-22-2000 22:58 |
C25 flasher in Portuguese language | MisterMister | x1x to x45/x50 | 1 | 03-04-2000 16:13 |
