04-23-2003, 06:50 | #16 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | http://mitglied.lycos.de/spcgroup/ABTS.zip if i patch it, vklay read tthe adresses 1F0000 and 4B0000, the error comes, if vklay want to write 1F0000. Vklay showes first "write 1F0000", then "write1F2000", then "write1F4000" and then the error message comes! I use an original data-cable, system WinXP. i will send you my serial-log-file! i hope, you can help me! |
04-23-2003, 15:17 | #18 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | @ValeraVi: I've an idea, to make your great vklay better. If you start a patch, then vklay read a part of the flash of the mobile phone (1F0000 f. e.), then it control, if this bit are the same of the undo-ones, if not, than you get a message: i think, it would be better, if you can save the readed bits, before vklay write the patch. Because if you use a lot of patches, than you have not the original flash, so you can not use the undo-function. But if you could save the old readed parts, than you have always a undo-function. Is it possible? |
04-23-2003, 21:19 | #19 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Kyiv, Ukraine Age: 47
Member: 24687 Status: Offline Thanks Meter: 1 | This is possilbe. But this method have no sence, because if you use patch on non original firmware the developer of that patch CAN NOT guaranty that this patch will be working fine!! This is why RizaPN and other make almost each next patch in adresses, where older patches not changing anything... And if hi make new version of patch hi ask you to uninstal previous (replase prev. patch with ORIGINAL values for ORIGINAL firmware) patch. ____________ ValeraVi, [GLOW=limegreen]http://www.ValeraVi****[/GLOW] |
04-24-2003, 08:40 | #21 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | oh yes, but this is a special case... may be solution is - make a vkp with original pictures, and then upload his if you want a original picture... Ok, may be in future versions, thanks for idea... |
04-24-2003, 17:53 | #23 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | BIG THANKS! I fix it: Update .exe file to V_KLay v2.1.2 [GLOW=limegreen]http://www.ValeraVi****[/GLOW] If after update you got a error Bad .ldr format you must use new ldr files. This files exist only in latest install package for WinXp on my web mage http://www.valeravi**** - download, reinsatll the program, then overwrite exe in insalled forder with that v2.1.2... |
04-25-2003, 11:50 | #27 (permalink) |
Insane Poster Join Date: Mar 2003 Location: Roma (Italy)
Member: 24322 Status: Offline Thanks Meter: 0 | Just a question: it would be possible comparing my "normal" flash with my "modded" one to find all modified data and create a VKP patch file with all patches that i applied to my firmware? This file would be quite useful to apply in just one passage all patches to a normal flash. |
04-25-2003, 13:23 | #28 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | You can use program from this post: http://forum.gsmhosting.com/vbb/show...190#post353190 http://users.i.com.ua/~dmitry_z/slfc.exe |
Infinity Help-doing Format Fs Language Change. How Can We Change It In English Again | shahi | Infinity-Box | 6 | 11-03-2007 21:59 |
Nokia 6280 Newest Firmware with Chinese Language | nokia6280 | Nokia Base Band 5 ( BB-5 ) | 3 | 12-26-2006 07:43 |
sagem language change and flasher | edazor | ARM9 BASED M62 / M62+ | 0 | 02-19-2004 18:29 |
5303 Flasher with Russian language for sale | Filin | x1x to x45/x50 | 4 | 08-22-2000 22:58 |
C25 flasher in Portuguese language | MisterMister | x1x to x45/x50 | 1 | 03-04-2000 16:13 |
