05-02-2003, 09:32 | #36 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Kyiv, Ukraine Age: 47
Member: 24687 Status: Offline Thanks Meter: 1 | Newest version of V_KLay is v2.1.4. History: v2.1.4 (2.05.2003) + Commands of handle by the program from the command line are added. + Support of phones S/ME45 with flash type CE20, BA20 is added. v2.1.3 (29.04.2003) + The algorithm of reading / writting of memory of phone is improved: • it is used much less productivity of the processor, • repetition of the operation with memory at failure. + Are added INI files for change the main layout of phones C45fw350315, C45fw500315, ME45fw280315, S45ifw040315 (this is only phones for what i found FullFlashes in Internet. If want support of your phone - give me it FullFlash (for phones of model xx45 and higer)). The symbols is changed in English and Russian layout. Other layouts is destoyed! Do not use v_klay if you use other than Eng or Rus layouts in the phone!!! + Has added a support of phones S/S/M35 with flash type CE20, BA20. (i found allboot.bin http://forum.siemens-club.ru) Last edited by ValeraVi; 05-02-2003 at 09:38. |
05-10-2003, 12:26 | #37 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | Newest version of V_KLay is v2.1.5. History: v2.1.5 (6.05.2003) + Support of multilanguage comments is added. Characters of all languages installed in the system (look " Control Panel-> Regional And Language Options-> Languages-> Supplemental language support " and " Control Panel-> Regional And Language Options-> Advanced-> Codepage conversion tables ") are displayed. * Many fine corrections. [glow=sandy brown]Instruction of how to use "Flasher" tab:[/glow] Flasher tab is intended for writing / reading of memory of phone. Generally the order operation such: - Select a functional mode: Set "Work with" "Phone". Select Com port where your phone is connected and select the baud rate (default: 115200). - Go to the tab "Flasher". - In section "Memory of the phone" set the initial address ("From Address") and a block length ("Size") of memory of phone with which we shall work. Reading of memory of phone. - Press "Read Memory" to read the data from memory of phone in the buffer of the program. - Press "Save File..." to save the programs given from the buffer in the file. Writing of memory of phone. - Press "Open File..." to load the data from the file in the buffer of the program. - Press "Write Memory" to write the data from the buffer to the memory (flash) of phone. This operation is influenced with the number written in field "Offset" of the section "Buffer of the program". This number specifies the address in the buffer with which to start to read the data from the buffer for writing in phone. For example. Is present full flash (the size 0x600000) from which needs to be written in phone only the data for eeprom. It is necessary for this purpose: • load this full flash in the buffer (press " Open File..."); • write in field "Offset" the address of the data for eeprom in the loaded file - 0x5f0000; • write in field "From Adress" of the section "Memory of phone" eeprom address in phone - 0x5f0000; • write in field "Size" of the section "Memory of phone" a size eeprom in phone - 0x010000; • press "Write Memory" to write the data from the buffer of program to the eeprom in the phone. Thus will be written only data from the file from 0x5f0000 (that is indicated in field "Offset") size 0x010000 (that is indicated in field "Size" of the section "Memory of the phone"), rest data of the file will not be written. On other operations the number in field "Offset" does not influence. In Flasher the buffer one for all - in him it is possible to read out the file or the data from phone, from him it is possible to write in the file or in phone. E.g. it is possible to write a piece of flash from one phone to another without need to save it to file. Only before disconnecting each phone it is necessarily press "Turn ON". Whitout this you phone do not turned ON until you do not make disconnecting, then connecting phones battery. If you have selected a functional mode "File with part of Flash" - and if you select for this a fullflash. Then by means of tab "Flasher" you may get from it a pieces or write to him other pieces of another flash file (that is loadded in the buffer by mean of button "Read file..." in the "Flasher" tab. ____________ ValeraVi, [GLOW=limegreen]http://www.ValeraVi****[/GLOW] |
05-10-2003, 13:25 | #39 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | The old data is exist in the patch! It is no need to read and save his. If old data from patch is not exist in phone you MUST DO NOT APPLY THE PATCH!! (read forum and you see that if some people ignore this error hi has A BIG TROUBLE!!!) May be if future version i disable possibility of write new data if old if not found AT ALL. If you want to apply new patch over old - FIRST UNDO OLD PATCH! If you have a many patch in you phone - you MUST remember all what you apply (create a separate folder on your HDD and save to his all paches that currently you have in you phone), and if you want to aplly new patch - undo previous!!! |
05-10-2003, 13:57 | #40 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | no, you don'T undersatand me. If i will try out a new patch weith no old data in it! f. e. in the adress 2700000 than i must save it (270000 size 10000)before i try the new patch, to have a backup. But it is complicated. I tkink it would be better, if i can save this while the reading bofore writing the new patch! |
05-10-2003, 16:51 | #41 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | This function is interesting only for developers of patches. Because most complete patch has a old data in it. What you said i remember and may be in a future, when i will have more free time i implement some functions for developers... But at this time you may use utility from Chaos (see prev. pages of thread) for comparing .bin files and making a .vkp from result of this comparing.... |
05-11-2003, 15:53 | #42 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | !!! To everyone, who using v2.1.3 - v2.1.5!!! Download upgrade to v2.1.5.1 Is corrected the error arising at reading flash after glitch of the previous attempt of reading (when flash it started to be read not by the big pieces (0x010000) but smaller (0x008000, 0x004000, etc.). Install package I shall make soon... |
05-12-2003, 04:16 | #43 (permalink) |
Insane Poster Join Date: Sep 2002 Location: Indonesia Age: 49
Member: 15723 Status: Offline Thanks Meter: 0 | @ValeraVi Hi! I've tried ur program on my ME45 and works great. I just wonder... I made a program called "SieFlash" and sometimes it's unstabil for writing flash. I used TComPort 2.64 component for Delphi. If I may know... what component did u use for V_Klay ? Regards |
05-12-2003, 09:32 | #44 (permalink) |
Member: 24687 Status: Offline Thanks Meter: 1 | @army Hello! Thanks for good words about my prog. I know your "SieFash", it support many types of phones... V_KLay i wrote in MS Visual C++ 7.0. I do not use any component and wrote my own class for access to the phone. This class use general Win32 function in overlapped mode for COM port. If you interesting in it - say. Also for CBuilder and Delphi in my other projects i use TurboPower Async Professional v4. And i do not found any problem with it. But, officially, its not free |
05-17-2003, 17:36 | #45 (permalink) | |
Member: 24687 Status: Offline Thanks Meter: 1 | Quote:
Infinity Help-doing Format Fs Language Change. How Can We Change It In English Again | shahi | Infinity-Box | 6 | 11-03-2007 21:59 |
Nokia 6280 Newest Firmware with Chinese Language | nokia6280 | Nokia Base Band 5 ( BB-5 ) | 3 | 12-26-2006 07:43 |
sagem language change and flasher | edazor | ARM9 BASED M62 / M62+ | 0 | 02-19-2004 18:29 |
5303 Flasher with Russian language for sale | Filin | x1x to x45/x50 | 4 | 08-22-2000 22:58 |
C25 flasher in Portuguese language | MisterMister | x1x to x45/x50 | 1 | 03-04-2000 16:13 |
