11-02-2005, 12:55 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Somewhere in Poland Age: 36
Member: 143475 Status: Offline Thanks Meter: 0 | FAM v3 i ICD v2.2 Can someone help me? |
11-02-2005, 14:02 | #3 (permalink) | |
Junior Member Join Date: Oct 2005 Location: Ukraine/Kharkov Age: 50
Member: 191727 Status: Offline Thanks Meter: 1 | Quote:
Code: ; ; ICD v2.2/FAM3 Patch2Patch (C)2005 by Rst7/CBSIE ; 0x4456E6: E6F5E400E6F48257DAE4F07F E6FDE400E6FC8257DAE4FC7F | |
11-04-2005, 08:46 | #6 (permalink) | |
When use FAM3.2: For call routine in filesystem context u make a call 0E47FFC with address of your routine in R12:R13. Additional parameters to your routine can be passed throws R14:R15 (when u call 0E47FFC) -> R12:R13 (when filesystem process call your routine) - BFA22 use this feature to pass adress of bin filename without global variable usage. But if patch use other address in FAM2 (not E47FF0) or not use FAM2 at all - u need rewrite all file access | |
11-04-2005, 13:48 | #7 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Ah okay I understand. That's the reason why you your "correction" to ICD is such a few bytes. I compared "Incoming Detail Record" Patch original vs yours... There were 50 or more bytes changed... Does this mean "CDR" used annother method to acess files? |
11-04-2005, 13:57 | #8 (permalink) | |
ICD v2.2 small question | charlielao | Siemens-Benq Flash Patching | 12 | 03-14-2005 11:00 |
