Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-28-2005, 03:39   #151 (permalink)
Member: 70080
Thanks Meter: 2
What value we should set? 5 billion??
No. Set 0 =)
Old 02-28-2005, 09:32   #152 (permalink)
trustkill's Avatar
Member: 27745
No. Set 0 =)
Thats what I meant...
Edit: I did try the "zero" value, it doesn´t work !
Old 02-28-2005, 15:09   #153 (permalink)
Member: 60520
Does that have the wanted effect? Because I expect an idle time of zero seconds which means that I have mainscreen again immediately after pressing a key (or at least one second later).
Old 02-28-2005, 16:17   #154 (permalink)
Member: 94448
we should find idle counter address in ram, and reset it every eg. 1 seconds
Old 03-01-2005, 01:03   #155 (permalink)
Member: 9891
Thanks Meter: 2
Disable IDLE Timer :
Just add these 2 lines BEFORE rets from init() part :
calls 0f07fach
calls 0f07ec0h
It works in my BIN file ...
Old 03-01-2005, 15:50   #156 (permalink)
Member: 60520
@rizapn:
Great. Simple additional question: can we re-activate the idle counter? (I know, you give us little finger and we want whole hand It's not that important.
So we have great possibility to create own mainscreen without all the patchwork. Just make a .bin file with all wanted features and execute.
Old 03-01-2005, 23:57   #157 (permalink)
Member: 9891
Thanks Meter: 2
The IDLE timer will be automatically set back to the firmware value after quitting from the BIN file.
Old 03-02-2005, 12:33   #158 (permalink)
Member: 60520
@riza: OK thanks. That's already quite good. So we can run a binary forever.
Another question about doFunc5 (Program handler): can you tell me the difference between run() and init()? Because in your binaries the run()-handler is always set to rets. What if I set run()-pointer to some code? When will it be executed by handler?
Is there already a possibility to start a binary with C166 code (not with card explorer)? I'd like to have a shortcut for some binaries - like midlet shortcut or running midlets through entrypoints. With direct starting from assembler it would be possible.
Old 03-02-2005, 14:01   #159 (permalink)
Member: 9891
Thanks Meter: 2
doFunc5():
Sorry, but I just guess those functions handler (I found it only by "accident", after some trial-and-error, then G-o-d direct me to the drawEasterEgg routines). I did try to put _start routines in run() OR in init(), and both give the same result. What I was thinking when I wrote that run() and init() is : run() function will be called every x ms, and init() is called only once in the 1st time, but I think, that is not the situation. In my trial, both will be executed in the init time (which one is earlier, I did not check yet) ...
Executing Binary File by Command
Yes, of course that is possible. Not a big patch, but I don't have it yet (and actually, I hope somebody else will do that) ...
*) Edited:
OK, I finish the 1st version of EBIN patch, executing bin file through the entry-point ... Just published in the Flash Patches topic
Old 03-09-2005, 04:29   #160 (permalink)
Member: 95401
hi, can you tell me how to find the entry points of the mainMenu() pls...
i'm really confused about that.. i'm using sme45v28,and i'm uneasy with that one, i though it might be the point: ca7c46.
but how can i be sure?
Old 03-09-2005, 06:12   #161 (permalink)
Member: 9891
Thanks Meter: 2
@Trek:
If you want to make sure about your finding, then better if you try it using AT+CGSN patch which has run capability. If you don't have that (AT+CGSN patch), the you can try to use your entry-point with another patch, for example, [RightArrow] patch or any other shortcut patch. Then, you can see what is the result ...
Old 03-10-2005, 14:14   #162 (permalink)
Member: 95401
Originally Posted by rizapn
@Trek:
i don't know how to convert the at+cgsn pach for sme45v28, and when i patch the v04 i've serious problems with phone: after several discharging and charging the battery,there appears some errors in eeprom, and i've to reflash the phone, i don't know why.
i've checked allready if i'm right about the mainMenu(). i just had changed the help in menu with this adress.. but the phone've blocked, no bzzz...no info,just didn't answered my commands.as when you try to run the browser without a simcard...i though that this is probably because of wrong routine or because of the infinity cycle inside memory..but i'm still not shure...
i found a patch for slik45 that makes it to be able read txt files, is there a possibility to convert that patch for sme45v28?
i'm really interested in using my phone without a sim,so that's why i'm asking so much questions
Old 03-11-2005, 14:21   #163 (permalink)
Member: 76708
Don't waste your time with v28!
Upgrade to s45iv4, so all the sme45i patches will be available for you.
The procedure is easy, well documented and absolutely safe (if you've made backups, of course) .
Old 03-11-2005, 14:36   #164 (permalink)
Member: 76708
This patch is NOT converted to S/ME , BUT in sme45iv4 there is:
1. a possibility to read short txt files ( <2000 b)
2. a trick making it possible to read big txt files (well known trick with e-mail client).
Old 03-12-2005, 00:03   #165 (permalink)
Member: 95401
redkin.. as i sad in last thread i wrote.. the problem with v04 is with my eeprom block, after a few charging of battery it's going a mess inside the booth eeproms of the phone...this is 17 blocks that are ****ed up
i don't know why is that,but i thing it's something with battery sensors and values. anyway,the second problem with v04: it's really buggy version, when i flash my phone with it, every 2 days, especially when i turn on the phone there is bzzzz..and nothing's happening...when remove the battery and plug it on once again, everything is fine, but just for a while.. and after a few mounths never helps at all unless reflashing of the eeprom blocks..
BB5 - Technical Discussion adihack Nokia Base Band 5 ( BB-5 ) 220 10-14-2011 06:31
x65 patching technical discussion Acidmrp x6x and x7x Flashpatching 42 10-10-2009 08:06
Iphone 3G Technical Discussion and SP Unlocking theory GraveSlayer iPhone 2 / iPhone 3G / iPhone 3GS 8 11-15-2008 06:04
Technical discussion sharp705sh celluniversal Sharp 0 05-17-2007 18:26
Technical discussion BB5 unlocking twisterfan Nokia Base Band 5 ( BB-5 ) 0 05-16-2007 20:36
Page generated in 0.56280 seconds with 9 queries
