04-27-2005, 11:23 | #211 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | I don't know fully, what you're doing, but it sounds very effective and brings much information about SL45 to the world. Fine job! :-) What do you mean with "overview of all registers,..."? Can you give some advices what that is good for? Because (in my eyes) an important thing for patching is to know how the routines are working (parameters, return values) and where they are. For example "SendMessage(PDU)" would be quite a useful routine. If you find some of those very interesting things... Can you give us a list for the content and its meaning you found in memory? If you need webspace or similar I could help. I appreciate your work. Perhaps in the future we'll have an even better SL45 because of your help. |
04-27-2005, 14:47 | #212 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | @jash: If you want a confortable shell for SL45 Debugging by patches, you can use: Riza's (and others) AT+CGSN patch + ACiD's AT+CGSN Debugger or KonstanT's CGSN Debugger Sinclair's Open BFB patch + ACiD's Siemens Debugger I prefer the second one. BTW, you work looks very interesting! Waiting for your new IDA db (hoping it work also with my IDA v4.5), when you will be ready to pubbish it Lalo |
04-28-2005, 13:16 | #213 (permalink) |
Junior Member Join Date: Apr 2005 Age: 53
Member: 134505 Status: Offline Thanks Meter: 0 | All, Thanks guy for the positive responce, Ill have a look at the debug shells you pointed out. With Registers I mean memory locations used for controlling hardware and Shared memory for intra-hardware communications, HF control etc. Just ask if you need info OK? but do remember I do not anything yet about the menustructures, and all the other Firmware options. I´m approaching this issue bottum up. In the mean time I´ll keep entering info in my IDA DB, which is a lot of work, believe me. For the same reason I started the documentation thread Jash Joke of the day : paper cannot be uploaded to anything else than a shredder or, more usefull, my brain Last edited by jash; 04-28-2005 at 17:49. |
05-15-2005, 05:24 | #214 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | @ Riza: Does it possible to playback voice dialing record from EPROM? If yes then we can play different records for different calling people in the headset (when connected) and don`t use MMC. |
05-15-2005, 09:37 | #215 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @abomin: - as I know, the standard (firmware) playVMO() function takes a VMO filename as a parameter. Unless we modify it (or somebody found the playRawVMO or playVMOBuff functions), then it is NOT possible to use THAT known routines to play VMO data from EEPROM area. |
05-17-2005, 00:45 | #216 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | About File Access: (sc0ty's question) I'm sorry for any "I don't know" answer, because there are many thing which is not discovered yet... Code: mov r14, #010Ah mov r13, #pag(cdr_filename) mov r12, #pof(cdr_filename) mov r15, #0100h calls fileOpen r15 is dunno, but most fileopen in the firmware use 0100 for this register. The output is r4=fileHandle, 0FFFF for error, otherwise = fileHandle (need for othe file access funcs, such as fileRead, fileWrite and fileClose). rizapn |
05-18-2005, 05:53 | #217 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | @Master: How will i know the #pag and #pof of a filename in mmc? EDIT Thanks for the answer below Master. Looking into your CDR and the mini gps patch, do we "assign" the RAM loc for the txt file we want to use in an unused area? Last edited by charlielao; 05-18-2005 at 08:58. |
05-18-2005, 07:04 | #218 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @charlie: - maybe this can give you more info ... Code: mov r14, #010Ah mov r13, #pag(stfilename1) mov r12, #pof(stfilename1) mov r15, #0100h calls fileOpen stfilename1: db 'a:/misc/mydata.txt',0 |
05-19-2005, 07:30 | #219 (permalink) | |
Junior Member Join Date: Aug 2004 Age: 51
Member: 76708 Status: Offline Thanks Meter: 0 | Quote:
Code: int _open( const char *filename, int oflag [, int pmode] ); oflag is an Integer constant combinations defined in FCNTL.H: #define _O_RDONLY 0x0000 /* open for reading only */ #define _O_WRONLY 0x0001 /* open for writing only */ #define _O_RDWR 0x0002 /* open for reading and writing */ #define _O_APPEND 0x0008 /* writes done at eof */ #define _O_CREAT 0x0100 /* create and open file */ #define _O_TRUNC 0x0200 /* open and truncate */ #define _O_EXCL 0x0400 /* open only if file doesn't already exist */ #define _O_TEXT 0x4000 /* file mode is text (translated) */ #define _O_BINARY 0x8000 /* file mode is binary (untranslated) */ #define _O_NOINHERIT 0x0080 /* child process doesn't inherit file */ #define _O_TEMPORARY 0x0040 /* temporary file bit */ #define _O_SHORT_LIVED 0x1000 /* temporary storage file, try not to flush */ #define _O_SEQUENTIAL 0x0020 /* file access is primarily sequential */ #define _O_RANDOM 0x0010 /* file access is primarily random */ The pmode argument is required only when _O_CREAT is specified. If the file already exists, pmode is ignored. Otherwise, pmode specifies the file permission settings, which are set when the new file is closed the first time. #define _S_IREAD 0000400 /* read permission, owner */ #define _S_IWRITE 0000200 /* write permission, owner */ #define _S_IEXEC 0000100 /* execute/search permission, owner */ | |
06-30-2005, 09:43 | #224 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | any body know, how found place in RM where incoming SMS are placed? i found only this info: SMS placed in pag 35h and started from marker 04E4h, his in unicode format. but i not found how know lenght of incoming SMS. |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
