12-09-2004, 02:38 | #121 (permalink) |
No Life Poster Join Date: May 2004 Location: Colombia Age: 34
Member: 64398 Status: Offline Thanks Meter: 153 | 1. A inverse patch of the Black List patch (auto start incoming calls of last group) 2. Call to a specify number when is activated a profile or alarm I post it in Patch ideas forum but i want to try make it and i need some help: Address of funtion for accept a incoming call: Accept_Incoming_Call() Address of funtion for make a call and how to use this: Make_Outgoing_Call() The rest of patch is easy to make using the source of other patches |
12-09-2004, 09:59 | #122 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | @Tr0: SL45iv56 A2DE24 : AnswerCall () MakeCall () function don't use a simply EP, it needs some registers to be setted. I don't know it for SL45, sorry. @all: how can I insert a delay in a routine? I've seen in SL45 there is function DAFC68 InsertDelay (), that was used by MASTER's in Blinking When Ringing Patch, but in S45i there insn't such a function (or better, there is but is unused and don't work). If I create a loop just for wasting time (100ms), it's a good workarroud? There will be any problem is CPU waste resources it this stupid way? Thanks |
12-16-2004, 10:52 | #124 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 48
Member: 27745 Status: Offline Thanks Meter: 0 | About the delay: In a early version of the supernet-patch for SL45v56 was a routine : Code: ;------------------------------------------------------safety ;If supernet is selected during start of phone, run this 23h x extp #6h, #1 mov r14, 0200h cmp r14, #0Ah jmpr cc_UGE, safe add r14, #1h extp #6h, #1 mov 0200h, r14 jmpr cc_UC, exitB safe: ;-----------------------------------------------------/safety |
12-16-2004, 21:56 | #125 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 50
Member: 48199 Status: Offline Thanks Meter: 0 | Hi Lalo! This subroutine is from SLIK fw. I think, it`s RE-calls itself by timer. Code: csegDA:FC46 sub_DAFC46: csegDA:FC46 csegDA:FC46 DC 5D extp r13, #2 csegDA:FC48 98 EC mov r14, [r12+] csegDA:FC4A A8 FC mov r15, [r12] csegDA:FC4C F0 CE mov r12, r14 csegDA:FC4E F0 DF mov r13, r15 csegDA:FC50 06 FC 64 00 add r12, #64h ; 'd' csegDA:FC54 E0 0E mov r14, #0 csegDA:FC56 DA E6 B2 FA calls 0E6h, drawSomeImages csegDA:FC5A E6 FC 20 03 mov r12, #320h ;r12:r13 - delay? csegDA:FC5E E0 0D mov r13, #0 csegDA:FC60 E6 FE 46 FC mov r14, #sub_DAFC46 ;r15:r14 - address of subroutine, csegDA:FC64 E6 FF DA 00 mov r15, #0DAh ;that calls after delay csegDA:FC68 DA D6 6C 02 calls 0D6h, onTimer csegDA:FC6C E0 14 mov r4, #1 csegDA:FC6E DB 00 rets csegDA:FC6E ; End of function sub_DAFC46 Code: ROM:E12650 sub_E12650: ROM:E12650 DA 91 30 F5 calls 91h, AcquireGbsLock ROM:E12654 D7 40 03 00 extp #3, #1 ROM:E12658 F2 F4 24 3D mov r4, word_FD24 ROM:E1265C 67 F9 08 00 andb rh4, #8 ROM:E12660 3D 1F jmpr cc_NZ, loc_E126A0 ROM:E12662 DA CF 4A EE calls 0CFh, sub_CFEE4A ROM:E12666 48 40 cmp r4, #0 ROM:E12668 3D 17 jmpr cc_NZ, loc_E12698 ; Notes ROM:E1266A DA C5 08 E4 calls 0C5h, sub_C5E408 ROM:E1266E 48 40 cmp r4, #0 ROM:E12670 3D 13 jmpr cc_NZ, loc_E12698 ; Alarm ROM:E12672 D7 40 56 00 extp #56h, #1 ; 'V' ROM:E12676 F3 F2 0E 13 movb rl1, byte_15930E ROM:E1267A 9A F1 05 60 jnb r1.6, loc_E12688 ROM:E1267E DA CC 0A 9C calls 0CCh, sub_CC9C0A ROM:E12682 28 41 sub r4, #1 ROM:E12684 48 43 cmp r4, #3 ROM:E12686 FD 08 jmpr cc_ULE, loc_E12698 ; SMS ROM:E12688 ROM:E12688 loc_E12688: ROM:E12688 DA 83 A8 B4 calls 83h, sub_83B4A8 ROM:E1268C 70 45 or r4, r5 ROM:E1268E 3D 04 jmpr cc_NZ, loc_E12698 ROM:E12690 DA 83 84 B4 calls 83h, get_missing_calls_count ROM:E12694 70 45 or r4, r5 ROM:E12696 2D 04 jmpr cc_Z, loc_E126A0 ROM:E12698 ROM:E12698 loc_E12698: ROM:E12698 ROM:E12698 E6 FC 3B 00 mov r12, #3Bh ; ';' ROM:E1269C DA 94 08 91 calls 94h, beep? ROM:E126A0 ROM:E126A0 loc_E126A0: ROM:E126A0 ROM:E126A0 E6 FC 50 26 mov r12, sub_E12650 ROM:E126A4 E6 FD E1 00 mov r13, #0E1h ; '?' ROM:E126A8 88 D0 mov [-r0], r13 ROM:E126AA 88 C0 mov [-r0], r12 ROM:E126AC E0 0E mov r14, #0 ROM:E126AE 88 E0 mov [-r0], r14 ROM:E126B0 E6 FC F0 03 mov r12, #3F0h ROM:E126B4 E0 0D mov r13, #0 ROM:E126B6 E6 FE 3B 04 mov r14, #43Bh ROM:E126BA E6 FF 00 00 mov r15, #0 ROM:E126BE DA 92 D6 2E calls 92h, InternalStartTimer ROM:E126C2 08 06 add r0, #6 ROM:E126C4 FA 91 3A F5 jmps 91h, FreeGbsLock ROM:E126C8 ; --------------------------------------------------------------------------- ROM:E126C8 This is starting address of patch ROM:E126C8 F7 8E 3A F6 movb byte_F63A, ZEROS ROM:E126CC DA 91 30 F5 calls 91h, AcquireGbsLock ROM:E126D0 0D E7 jmpr cc_UC, loc_E126A0 ROM:E126D0 ; End of function sub_E12650 |
12-16-2004, 22:31 | #126 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @fcortina: Yes, I know that the waste routine works. I had already made my patch (Improuved Blinking when Ringing). I only dont' like this workarround. My waste routine works also without IDLE command, do you think I mast add it? OT: Compliment for your very good patch! @TrustKill: It's very similar to the routine I've inserted in my patch, my problem is is that I had to waste about 100ms, so I have to make it at least 65655*4 loops... @Abomin: very good starting points. The SL45 routine I already know it, as I wrote in my asking post, but it doesn't work (or probably use it in a bad way) The second is very intresting. OT: how is going your handfree patch? @all: WOW! I really appreciate you help. I'll study them and make some experiments. Thank you very much Lalo |
01-12-2005, 21:16 | #127 (permalink) |
Member: 48199 Status: Offline Thanks Meter: 0 | Hello people! Some SLIK subroutines: C24780 - is calling when handsfree is connected C2478C - is calling when dockstation is connected C24758 - is calling when car kit is connected C2474E - is calling when handsfree or car kit is unplugged |
01-12-2005, 21:47 | #129 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Ankara, Turkey Age: 50
Member: 69110 Status: Offline Thanks Meter: 0 | @abomin: thank you very much i will employ some of these entry points in order to make SL45 as a simple alarm system as it is the case with C45 by Sabodyn. |
01-19-2005, 21:03 | #130 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | @adomin: One thing I dont understand: 224750: DAC21E48 DAE0D4C7 ; unplug HF - profile 0 224782: DAC21E48 DAE0C0C7 ; connect HF - profile 1 C24780 - is calling when handsfree is connected C2474E - is calling when handsfree or car kit is unplugged See the bold text, I cant see the cohernece between this too adresses |
01-20-2005, 00:33 | #131 (permalink) |
Member: 48199 Status: Offline Thanks Meter: 0 | Look: Code: csegC2:474E SomeAccessoryWasUnplugged: csegC2:474E csegC2:474E E0 0C mov r12, #0 csegC2:4750 DA C2 1E 48 calls 0C2h, sub_C2481E csegC2:4754 FA C2 EA 46 jmps 0C2h, loc_C246EA csegC2:4754 ; End of function SomeAccessoryWasUnplugged csegC2:4758 CarKitIsConnected: csegC2:4758 csegC2:4758 E0 1C mov r12, #1 csegC2:475A DA C2 1E 48 calls 0C2h, sub_C2481E csegC2:475E FA C2 EA 46 jmps 0C2h, loc_C246EA csegC2:475E ; End of function CarKitIsConnected csegC2:4780 HFIsConnected: csegC2:4780 csegC2:4780 E0 2C mov r12, #2 csegC2:4782 DA C2 1E 48 calls 0C2h, sub_C2481E csegC2:4786 FA C2 EA 46 jmps 0C2h, loc_C246EA csegC2:4786 ; End of function HFIsConnected csegC2:481E sub_C2481E: csegC2:481E csegC2:481E E6 00 0E 00 mov DPP0, #0Eh csegC2:4822 CC 00 nop csegC2:4824 F2 FD 56 3F mov r13, NowConnectedAccessory ; 1-CarKit csegC2:4824 ; 2-Hands Free Head Set csegC2:4824 ; 3- ... csegC2:4828 F6 FD 58 3F mov AccessoryWasConnectedBefore, r13 ; 1-CarKit csegC2:4828 ; 2-Hands Free Head Set csegC2:4828 ; 3- ... csegC2:482C F6 FC 56 3F mov NowConnectedAccessory, r12 ; 1-CarKit csegC2:482C ; 2-Hands Free Head Set csegC2:482C ; 3- ... csegC2:4830 DB 00 rets csegC2:4830 ; End of function sub_C2481E csegC2:4846 WhatIsConnectedToPhone?: csegC2:4846 csegC2:4846 E6 00 0E 00 mov DPP0, #0Eh csegC2:484A CC 00 nop csegC2:484C F2 F4 56 3F mov r4, NowConnectedAccessory ; 1-CarKit csegC2:484C ; 2-Hands Free Head Set csegC2:484C ; 3- ... csegC2:4850 DB 00 rets csegC2:4850 ; End of function WhatIsConnectedToPhone? |
01-20-2005, 00:39 | #132 (permalink) |
Member: 70990 Status: Offline Thanks Meter: 1 | SME45iv04: I need help for this topic: http://forum.gsmhosting.com/vbb/showthread.php?t=183549 Could anybody support me? Thanks in advance. genetic1 |
01-20-2005, 20:43 | #134 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | @abomin: What I´m trying to do is to enable voice-dialling when connected to a car-kit... So I changed "plug carkit" to "plug handsfree": Code: ; change connect carkit to connect handsfree - trial 1 0x224758: E01C E02C ; mov r12, #2 So, if I try to push "voice-dial" there is always error "Not available in car-kit"... Any other ideas ? |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
