02-09-2005, 17:38 | #17 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | @Student Charlie: "mov r12, mem_3BA42" As I told you, this is a EXTP command sequence and needs the Page (and number of affected instruction) to be specified by extp command. You need two commands, and the correct writing mode is: extp #0Eh, #1 ;0E=Page 1=following 1 instruction affected mov r12, 3A42h ;3A42=Offset ;where P:Off=unread SMS RAM location "jnb r9.7, loc_12345" here the error is that SFE don't know where you will put your patch, so you cannot insert a absolute address. You have to create a subroutine label and point to that. E.G.: try: jnb r4.11, exit1 exit1: rets Errors: 88 C0 : mov [-r0], r12 88 D0 : mov [-r0], r13 88 90 : mov [-r0], r9 D7 40 0E 00 : extp #0Eh, #1 F2 F9 42 3A : mov r9, mem_3A42 9A F9 10 70 : jnb r9.7, loc_xxxxx ;already explained you this error D7 40 36 00 : extp #36h, #1 F2 FC 6C 09 : mov r12, mem_D896C <=store word value of RAM loc 0036:096C; APP Profile 2 D7 40 0D 00 : extp #0Dh, #1 ;Extp command needed! F2 FD DE 25 : mov r13, mem_25DE ;0D:25DE= RAM time hours 46 FD 11 00 : cmp r13, #11h ; compare r13=hours, with #11h=17:00 8D 07 : jmpr cc_C, loc_xxxxx ;if hour < or = 17:00 jump to loc_xxxxx (i dont know how to type this in sfe assembler) ;already explained you this error 2F 00 : bset r12.2 <= to set flag of APP Profile2 Function 3 Error: correct is 2F FC D7 40 0D 00 : extp #36h, #1 F6 FC 6C 09 : mem_D896C, mov r12 ;Needed to store back the modfied NAM profile 2 word 98 90 : mov r9, [r0+] ; this is located at loc_xxxxx ;already explained you this error 98 D0 : mov r13, [r0+] 98 C0 : mov r12, [r0+] ;CB 00 : ret ; need rets(DB00): it's a return from intersegment routine! Note: each one of these error make phone to crash (or at least patch not to work) I applied trustkill's moving and changing operator name location which is this: 18E692: 09 f8; y-pos of operator name string (normal mode) If i use Winhex, 18E692: F8 and 18E672: F8. But if i use sfe disasm this comes up: 18E690: 01 00 : addb rl0, rl0 18E694: 00 00 : add r0, r0 18E696: 00 00 : add r0, r0 How come 18E692 isnt shown? ??? Anyway, those are datas, not asm commands. It's useless disasm them (as menus datas, pictures datas, ringtones etc...)! You need "just" to understand how it works There are some patches i didn't use on my sl45, but i want to disassemble them. How can i do that without having to patch them on my phone? Apply them on a free (BIG) Fubu, with V-klay offline mode. Than disasm them! I saw this on S45 patches. Can you do it for sl45v56 Professor? HFI. 12AM-PM Hours Format in Idle screen AGGGGGGHH... really no time now. Maybe in future (or you can do it ) END OF LESSION N°6! Bye Lalo Last edited by lalo.lerry; 02-09-2005 at 21:21. |
02-10-2005, 01:03 | #18 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | About sfe : - we can try sfe a "jnb r9.7, 10" which mean : jump to the address 10 (inline assembler is always use starting address 0) if bit r9.7 is not set - we can disassembly patch file directly from the file using "sfe d" command, for example : sfe d patchfile.vkp,3b0000,100 ... disasm patchfile.vkp starting from address 3b0000 for the next 100 bytes. No need to apply it anywhere ... Also, sfe has a simple debugger which is usefull to test some C166 command impact and result. Check the last part of sfe_help.txt file to get more info ... Example debugger usage : sfe r sl45v56.bin ,ri sl45v56.bin is an SL45 FUBU file... rizapn |
02-10-2005, 02:20 | #19 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @MASTER: It's always a pleasure to read your post. About SFE capabilities: ALWAYS MORE AMAZING! Even if I'm using it every day, I didn't know it has also these features (and I read the help file!) Can you please write some more info about sfe interactive assembler usage? Thanks Lalo Last edited by lalo.lerry; 02-10-2005 at 02:34. |
02-10-2005, 02:53 | #20 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | @Prof Lalo: On my previous post ( 1st exam) i failed hehehe. more than 50% was wrong. Please have a look at this and recheck my 1st exam Professor. 5FFB80: 88 C0 : mov [-r0], r12 5FFB82: 88 D0 : mov [-r0], r13 5FFB84: 88 90 : mov [-r0], r9 5FFB86: D7 40 0E 00 : extp #0Eh, #1 5FFB8A: F2 F9 42 3A : mov r9, mem_3A42 5FFB8E: 9A F9 10 70 : jnb r9.7, loc_5FFBB2 5FFB92: D7 40 36 00 : extp #36h, #1 5FFB96: F2 FC 6C 09 : mov r12, mem_D896C <=store word value of RAM loc 0036:096C; APP Profile 2 5FFB9A: D7 40 0D 00 : extp #0Dh, #1 ;Extp command needed! 5FFB9E: F2 FD DE 25 : mov r13, mem_25DE ;0D:25DE= RAM time hours 5FFBA2: 46 FD 11 00 : cmp r13, #11h ; compare r13=hours, with #11h=17:00 5FFBA6: 8D 01 : jmpr cc_C, 5 (i did what Master Rizapn said ) 5FFBA8: 2F FC : bset r12.2 <= to set flag of APP Profile2 Function 3 5FFBAA: D7 40 0D 00 : EXTP #36H, #1 5FFBAE: F6 FC 6C 09 : mem_D896C, mov r12 5FFBB2: 98 90 : mov r9, [r0+] 5FFBB4: 98 D0 : mov r13, [r0+] 5FFBB6: 98 C0 : mov r12, [r0+] 5FFBB8: DB 00 : ret @ Master Rizapn: Belated Happy Islamic Lunar New Year Thank you for your post also. |
02-10-2005, 03:06 | #23 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @Stud Charlie: 5FFB80: 88 C0 : mov [-r0], r12 5FFB82: 88 D0 : mov [-r0], r13 5FFB84: 88 90 : mov [-r0], r9 5FFB86: D7 40 0E 00 : extp #0Eh, #1 5FFB8A: F2 F9 42 3A : mov r9, mem_3A42 5FFB8E: 9A F9 10 70 : jnb r9.7, loc_5FFBB2 5FFB92: D7 40 36 00 : extp #36h, #1 5FFB96: F2 FC 6C 09 : mov r12, mem_D896C <=store word value of RAM loc 0036:096C; APP Profile 2 5FFB9A: D7 40 0D 00 : extp #0Dh, #1 ;Extp command needed! 5FFB9E: F2 FD DE 25 : mov r13, mem_25DE ;0D:25DE= RAM time hours 5FFBA2: 46 FD 11 00 : cmp r13, #11h ; compare r13=hours, with #11h=17:00 5FFBA6: 8D 01 : jmpr cc_C, 5 (i did what Master Rizapn said ) ;I prefer 8D 05 5FFBA8: 2F FC : bset r12.2 <= to set flag of APP Profile2 Function 3 5FFBAA: D7 40 0D 00 : EXTP #36H, #1 5FFBAE: F6 FC 6C 09 : mem_D896C, mov r12 5FFBB2: 98 90 : mov r9, [r0+] 5FFBB4: 98 D0 : mov r13, [r0+] 5FFBB6: 98 C0 : mov r12, [r0+] 5FFBB8: DB 00 : ret Right, but I prefer a longer jump. BTW, I'm online on ICQ now (and for more 10 min), but where are you? Last edited by lalo.lerry; 02-10-2005 at 03:44. |
02-10-2005, 03:12 | #24 (permalink) | |
Member: 66040 Status: Offline Thanks Meter: 14 | Quote:
Im on MSN Prof. I uninstalled my ICQ | |
02-10-2005, 09:00 | #26 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | @Prof Lalo: I patched my phone with the one posted on #23 but the Profile2,Function3 still isnt SET at 17:00. Also, when i try to call my phone, it automatically asnwers but doesnt start tne ANM message. Then when i UNDO the patch, the phone detects some hex values where previously the old data before patching was FF FF .. .. I also tried this other version i made and result was the same. 5FFB80: FFFF 88C0 5FFB82: FFFF 88D0 5FFB84: FFFF 8890 5FFB86: FFFFFFFF D7403600 5FFB8A: FFFFFFFF F2F96C09 5FFB8E: FFFFFFFF 9AF91210 5FFB92: FFFFFFFF D7403600 5FFB96: FFFFFFFF F2FC6C09 5FFB9A: FFFF 2EFC 5FFB9C: FFFFFFFF D7400D00 5FFBA0: FFFFFFFF F2FDDE25 5FFBA4: FFFFFFFF 46FD1100 5FFBA8: FFFF 8D06 5FFBAA: FFFF 9D05 5FFBAC: FFFF 2FFC 5FFBAE: FFFFFFFF D7400D00 5FFBB2: FFFFFFFF F6FC6C09 5FFBB6: FFFF 9890 5FFBB8: FFFF 98D0 5FFBBA: FFFF 98C0 5FFBBC: FFFF DB00 Help sir If i have a patch and want to test if it has an error, how do i do it aside from patching my phone and testing it? I dont understand how to use the assembler functions of sfe. The only thing i know how to use is the inline assembler. Last edited by charlielao; 02-10-2005 at 09:50. |
02-10-2005, 11:51 | #27 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | About sfe interractive debugger: Just an example ... Turn on the engine : sfe r sl45v56.bin ,ri A00000> a 37:3700 Inline assembler ... 0x0DF700: mov r12, #7Bh 0x0DF704: mov r13, #100 0x0DF708: add r13, r12 0x0DF70A: cmp r13, #200 0x0DF70E: jmpr cc_NZ, 6 0x0DF710: add r12, #100 0x0DF714: add r12, #100 0x0DF718: rets 0x0DF71A: 0DF71A> g 37:3700 0DF700> r 0DF704> r 0DF708> r 0DF70A> d r 0DF70A> ... r : run 1 command d r : display/dump registers value g : goto address a : inline assembler rizapn |
02-10-2005, 16:55 | #28 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | @Student: Possible motivation not working for v. in post #23: 1.you forgot to patch a starting point (where to call patch routine) in fw 2.you forgot to flag profile 1 item 8 (ex autoswap profile) 3. ANM isn't controlled by profile 2 item 3 Possible motivation not working for v. in post #26: Above motivation + 5FFBA8: FFFF 8D06 5FFBAA: FFFF 9D05 1. You cannot use 2 CC one after the other in this way, you have to repeat the cmp 2. These two CC complement each others: in both situatione only possibility is to jump to exit @MASTER: Thanks for explanation, I used Acid's Debugger for these tasks since now, but I'll certainly try SFE |
02-11-2005, 00:45 | #29 (permalink) | ||
Member: 66040 Status: Offline Thanks Meter: 14 | @Prof: Quote:
number 2 and 3 im sure they are OK. Quote:
02-11-2005, 01:30 | #30 (permalink) | ||
Member: 50673 Status: Offline Thanks Meter: 2 | @Student: Quote:
You have to insert it on a fw routine that is called costantly... Quote:
how to Add profile logo font like this picture ? | blazefr | Siemens-Benq Flash Patching | 12 | 06-05-2005 09:01 |
NEWEST profile logo patch - SME45iv04 | genetic1 | Siemens-Benq Flash Patching | 0 | 11-01-2004 23:19 |
SOL Selectable Operator Logo Patch | Kromonos | Siemens-Benq Flash Patching | 8 | 12-24-2003 11:30 |
selectable operator logo patch | Shibby86 | Siemens-Benq Flash Patching | 4 | 06-18-2003 16:06 |
Selectable Operator Logo patch problem | wong | Siemens-Benq Flash Patching | 0 | 06-17-2003 16:57 |
