01-13-2005, 09:33 | #211 (permalink) |
Junior Member Join Date: Oct 2004 Age: 54
Member: 89010 Status: Offline Thanks Meter: 0 | SHT 1.1 ScreenShot ; Firmware : S45iv4 ; Author: fcotrina ; Created: 12.01.2005 ; Based in Windows ScreenShot and patch CL=CallLogging ; With some ideas taken from lalo.lerry and RizaPN ; Big thanks to Redkin and NCTN. ; How to run it? Follow these steps: ; Press 'left sidekey', to take the screenshot ; Open any file in explorer. ; A new file named scr????.BMP has been created in A:\ ; You can view it, send it, or transfer to a computer ; Every time a new file is created with a random secuence number ; Rename the file if you want to keep it. Otherwise it might get overwritten ; known bugs: ; -The picture is taken after the key has been pressed, so the picture ; might change due to that key press ; -You need to open another file in between. I had to delay creating the ; file because S45i allows to create file only in some specific routines ; -If the random name is already an existing file, data is appended. Probably ; I should use a secuential number, or 2 random numbers, or date_time ; -If you take several screenshots, only saves the last one, unless you ; open any file in between. This is not a bug. I want it to be like this ; -it uses free RAM from 0000:1000 . If any other patch uses it, they collide #include C166.inc base 0A00000h org 0CCB2D4h ; original code called when a key is pressed ;CCB2D4: D7 40 03 02 : extp #203h, #1 ;CCB2D8: D4 FE 5E 2E : mov r15, [r14+#2E5Eh] calls new_key_pressed ; my new code nop ; I replace 4 instructions: 8 bytes nop org 0DA2C98h ; original code called when a file is open ; DA2C98: 88 90 : mov [-r0], r9 ; DA2C9A: 88 80 : mov [-r0], r8 calls new_file_open ; my new code after_open_file: ; need to know where to jump back. ;****************************** ; When key 'left sidekey' is pressed, copy screen into 00:1000 ; That key is on the left part of the screen. Yes, that long key. ; Press the top part of it. org 0AEB000h ; there is unused ROM here. If not, use 0C94F0 or 5EFA00 new_key_pressed: mov [-r0], r5 mov [-r0], r11 mov [-r0], r12 mov [-r0], r14 mov r5, r12 ; pressed key is stored in r12 cmp r5, #000Eh ; is left_sidekey? jmpr cc_NZ, exit_no_left_sidekey mov r14, #1FD4h ; screen is taken from 0041:1FD4 mov r12, #q(free_RAM_screen) ; target mov r11, #0410h ; size ; copy 410h bytes from 0041:1FD4 to 0000:1000 ; probably there is a memcpy routine somewhere, but I don't know where another_r11: extp #41h, #1h mov r5, [r14] ; can be check with at+cgsn:00,1000 at+cgsn:01,1FD4 add r14, #02h extp #0h, #1h mov [r12] , r5 add r12, #02h sub r11, #02h jmpr cc_NZ, another_r11 ; flag that there is a file pending to be saved mov r5, #'A:' extp #0h, #1h mov q(free_RAM_name), r5 exit_no_left_sidekey: mov r14, [r0+] mov r12, [r0+] mov r11, [r0+] mov r5, [r0+] ; do now the original code extp #203h, #1 mov r15, [r14+#2E5Eh] rets ;****************************** new_file_open: mov [-r0], r9 ; original code in 0DA2C98h mov [-r0], r8 ; also original ;base 0100000h ;org 0100900h save_screen: mov [-r0], r4 mov [-r0], r6 mov [-r0], r12 mov [-r0], r13 mov [-r0], r14 mov [-r0], r15 extp #0h, #1h mov r4, q(free_RAM_name) cmp r4, #'A:' jmpr cc_NZ, exit ; no screenshot taken yet ; copy file name to 0000:1000 and give it a unique name mov r15, #p(file_name) ; file name segment mov r14, #q(file_name) ; file name offset mov r13, #0h mov r12, #q(free_RAM_name) calls 0FF40A0h ; copy string r15:r14 -> r13:r12 ; take random value extp #2h, #2h mov r13, 03FDAh ; this stores the seconds (in internal format) mov r14, 03FDCh ; and this stores the minute (more or less) ; convert to 4 letters and r14, #0F0Fh add r14, #04141h ; that is , 'A' 2 times and r13, #0F0Fh add r13, #04141h ; that is , 'A' 2 times extp #0, #2h mov q(free_RAM_name)+06h, r14 ; set it in the middle of file name offset. mov q(free_RAM_name)+08h, r13 ; set it at the end of file name offset. ; open file for write mov r14, #10Ah ; always fixed value #10Ah mov r13, #0h ; file name segment mov r12, #q(free_RAM_name) ; file name offset mov r15, #0100h ; always fixed value #100h mov [-r0], r9 ; emulate original code in 0DA2C98h mov [-r0], r8 calls after_open_file cmp r4, #0FFFFh ; check if opening was correct jmpr cc_Z, exit ; something wrong mov [-r0], r4 ; save file handler mov r12, r4 ; file handler mov r13, #q(header) ; header data offset mov r14, #p(header) ; header data segment mov r15, #62 ; data size: 16+16+16+14 , in decimal ! calls 0DA3642h ; write header mov r12, [r0+] ; retrieve handler ; screen starts in 5FD4 and ends in 63E4 , that is, 0x0410 bytes ; although I have copied in 001000h, that is, 0000:1000 mov r6, #050h ; number of lines: 80 ;mov r13, #023D7h ; address of the last line mov r13, #q(free_RAM_screen)+0403h ; address of the last line, when screenshot starts from 0000:1000 loop_r6: mov [-r0], r6 mov [-r0], r13 mov [-r0], r12 ; save handler ;mov r14, #41h ; segment address of current line mov r14, #0h ; segment address of current line, starting from 0000:1000 mov r15, #010h ; line size in bytes: 16 (although width=101, almost 13*8) calls 0DA3642h ; write to file this screen line r13:r6 mov r12, [r0+] ; retrieve file handler mov r13, [r0+] sub r13, #0Dh ; jump to previous screen line mov r6, [r0+] sub r6, #01h ; if this is not the first line, continue ;cmp r6, #0h ; not needed because sub also set flags jmpr cc_NZ, loop_r6 close: calls 0DA4AB4h ; close file exit: mov r4, #0FFFFh extp #0h, #1h mov q(free_RAM_name), r4 ; flag that it has been processed mov r15, [r0+] mov r14, [r0+] mov r13, [r0+] mov r12, [r0+] mov r6, [r0+] mov r4, [r0+] rets ;org 0100990h file_name: ; file name db 'A:\scr' unique_name: db '0000.' header: ; header of a BMP file, black+white, 101x80 db 42h, 4Dh, 50h, 00h, 00h, 00h, 00h, 00h, 00h, 00h, 3Eh, 00h, 00h, 00h, 28h, 00h db 00h, 00h, 65h, 00h, 00h, 00h, 50h, 00h, 00h, 00h, 01h, 00h, 01h, 00h, 00h, 00h db 00h, 00h, 00h, 05h, 00h, 00h, 0C4h, 0Eh, 00h, 00h, 0C4h, 0Eh, 00h, 00h, 00h, 00h db 00h, 00h, 00h, 00h, 00h, 00h, 0FFh, 0FFh, 0FFh, 00h, 00h, 00h, 00h, 00h ; this part is only for the compiler. It does not go into the patch, because it takes RAM, not ROM base 0000000h org 001000h free_RAM_name: db 'A:\scr????.BMP', 0h, 0h ; must be multiple of 2 free_RAM_screen: ; end of source code ; this is the binary patch 0x3A2C98: DA0E4EB0 88908880 0x2CB2D4: D7400302D4FE5E2E DA0E00B0CC00CC00 0x0EB000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088B088C088E0F05C46F50E003D16 0x0EB010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FED41FE6FC1010E6FB1004D7404100 0x0EB020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A85E08E2D7400000B85C08C228B23DF6 0x0EB030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F5413AD7400000F6F5001098E098C0 0x0EB040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98B09850D7400302D4FE5E2EDB008890 0x0EB050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88808840886088C088D088E088F0D740 0x0EB060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000F2F4001046F4413A3D4BE6FFBA02 0x0EB070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE1C31E00DE6FC0010DAFFA040D750 0x0EB080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0200F2FDDA3FF2FEDC3F66FE0F0F06FE 0x0EB090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 414166FD0F0F06FD4141D7500000F6FE 0x0EB0A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0610F6FD0810E6FE0A01E00DE6FC0010 0x0EB0B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FF000188908880DADA9C2C46F4FFFF 0x0EB0C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D208840F0C4E6FD2731E6FEBA02E6FF 0x0EB0D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3E00DADA423698C0E6F65000E6FD1314 0x0EB0E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 886088D088C0E00EE6FF1000DADA4236 0x0EB0F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C098D026FD0D00986028613DF1DADA 0x0EB100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B44AE6F4FFFFD7400000F6F4001098F0 0x0EB110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98E098D098C098609840DB00413A5C73 0x0EB120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6372303030302E424D50000000000000 0x0EB130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 003E0000002800000065000000500000 0x0EB140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00010001000000000000050000C40E00 0x0EB150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00C40E00000000000000000000FFFFFF 0x0EB160: FFFFFFFFFF 0000000000 |
01-15-2005, 08:43 | #212 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** BLR. Blinking Light when Ringing *** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Release : 08.01.05 - v1 ;Update : 15.01.05 - v2 ;This patch makes retroillumination blinking when phone is ringing for an incoming call ;and tone are setted to off or beep. ;Morover, it corrects retroillumination fading even if phone is still ringing when tones are on. ;Improuvments v2: ;one blink per second (=speed x2) ;stop blinking if a key is pressed ;customization options added 5631E6: FACAD69A FA87E0DF 563316: DACBF02C DA8780E0 07DFE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAF71AD448402D27DACD0CDD48402D0D 07DFF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAE50E11E6004400CC0048432D03F68E 07E000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20370D03C2F120372D03DACC08DF0D13 07E010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F3F421370821F7F4213747F40600FD0B 07E020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA873AE0E6F42437E6F5FA00E6FD3AE0 07E030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE8700BB17FACAD69AD7404400C2F1 07E040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20373D0FDAE50E1148433D0BDACCD0DF 07E050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F42837E6F53200E6FDDCDEE6FECC00 07E060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB01DB0088E088D0F0C4E6FD4400F0E5 07E070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00FDACCE2960804CB00A9204C616C6F 07E080: FFFFFFFFFFFFFFFFFFFFFFFFFFFF E014D7404400F7F82037FACBF02C ;CUSTOMIZATION: ;Enable blinking retroillumination setting indipendent: ;07DFE0: DAF7 0D03 ;Enable blinking retroillumination always (also when tone are on): ;07DFE8: DACD 0D03 ;Add a beginning blinking retroillumination delay: ;07E01C: 06 xx ;where xx is a hex value >06, each unit is about 2 second delay ;Change light off time: ;07E056: 32 xx ;where xx is time in ms/0,25 in hex swapped bytes ;default= 32hex = 50dec : 0,25 =200ms ;Enjoy it! ;© Lalo 2005 Luki's Siemens Modding Forum |
01-17-2005, 05:25 | #213 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** ISP. Improuved Screensaver Pop-up *** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Thanks to ntcn for accessories state RAM location ;Release : 17.01.05 - v1 ;This patch limits screensaver pop-up: ;it will not pop-up if a charger, data cable or tracer cable is connected to phone. 5605FA: DAF87CE5 FA8760E2 7E260: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7404300C2F4DE2148472D0A46F49800 7E270: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0746F499002D04DAF87CE5DAF6FE05 7E280: FFFF DB00 ;CUSTOMIZATION: ;Don't check tracer cable connection (uncomment): ;7E26C: 46F4 0D02 ;Don't check data cable connection (uncomment): ;7E272: 46F4 0D02 ;Enjoy it, Genetic! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 01-17-2005 at 07:42. |
01-17-2005, 05:57 | #214 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** MES. Missed Events String in Idle/Screensaver *** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Release : 17.01.05 - v1 ;This patch changes second line operator name in idle or operator name in screensaver mode ;to became a missed events info string, ;if a missed event is present and if phone is in normal state (e.g. not in "Net searching mode", etc...). ;Missed event/s (calls, SMSes, voice messages, appointments, memos and alarm clock) ;and its/their number is displayed in string. ;NOTE: Missed voice messages number is setted to 1 by default, even if they are more than one. ;This is because my operator (or I?) don't use voice messages, ;so I couldn't check out their missed number RAM location. ;If anyone knows it, please let me know and I will complete the patch . 561130: DACBF86E FA8700E1 ;if you don't have Operator Name in Screensaver patch applied apply the following line: 58D764: DAC44488 FA8722E1 ;if you have it, comment the above line and uncomment this one: ;58D764: FA87C0DD FA8722E1 7E100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA8750E148A03D04DACBF86EFAF63411 7E110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E016DACA709EE6FE3037E6FF4400FAF6 7E120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7411DA8750E148A03D04DAC44488FAF8 7E130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 68D7E09CDACA08A0E6FE3037E6FF4400 7E140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAF8D2F0FAF8B2D7FFFFA9204C616C6F 7E150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACBB208E6F83037E6F94400E00ADAC4 7E160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70C7F0640065DAC4B2C7004600454840 7E170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D03E6F69301BB41D7403A00C2F4A012 7E180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D03E6F6930DBB39D7405700C2FCC221 7E190: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FC0F0046FC0A002D11D7405700F3F2 7E1A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C221DACCA85A2D0AD7405700F3F2D925 7E1B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8AF10830DAC5AAE648402D04E014E6F6 7E1C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9314BB1BE6FCA4CCE6FDF700DAF6BADA 7E1D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D03E6F6932DBB10E02CDAF1FEA1 7E1E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D04E014E6F69303BB0748A02D03 7E1F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E001DC49B928FACAAC9748A02D09E6F1 7E200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9595E6F22C20DC59B818C42802000884 7E210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C4E7F23000DC49B928DC47DACBD01F 7E220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAFFC03F0882E6F19520DC49B8180882 7E230: FFFFFFFFFFFFFFFFFFFFFFFF F016DC49B818088208A1CB00 ;CUSTOMIZATION: ;If you have Operator Name in Screensaver patch applied, apply also this line (uncomment): ;07E12A: DAC44488 FA87C0DD ;Overwrite first line operator name, not the second, in idle (uncomment): ;07E111: 16 06 ;Remove leading 0 in 00-09 missed events numbers (uncomment): ;07E214: 30 91 ;Enjoy my (very) last gift, Genetic! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 01-17-2005 at 14:52. |
01-17-2005, 09:35 | #215 (permalink) |
Member: 89010 Status: Offline Thanks Meter: 0 | TRO1.0 set breakpoints at Output points and trace them ; TRO1.0 set breakpoints at Output points and trace them ; Firmware : S45iv4 ; Author: fcotrina ; Created: 16.01.2005 ; Based in patch DAR=Dump_All_Registers_v2 by RizaPN ; With some ideas taken from lalo.lerry and RizaPN ; Big thanks to Redkin and NCTN and all patchers out there ; ; This patch is related to TRI ; This patch is useful for patch programmers. If you ; find some code in ROM and want to know who calls it, just ; change any instruction "rets" with "trap #4Ah", that is: ; 0xYYYYYY: DB00 9B94 ; After patching the ROM with new traps, start the phone. If it ; crashes, undo the trap, as this is not a traceable routine. ; Then, using CGSN patch, set the debug level in 0040:0802 ; at+cgsn*40,0802,0000 not debug anything ; at+cgsn*40,0802,FFFF not debug anything ; at+cgsn*40,0802,7777 call procedure 0100700h before anything else ; at+cgsn*40,0802,6666 call procedure 0100600h after debugging ; at+cgsn*40,0802,1111 print the routine that is hitted and its caller ; Any other value will print the routine that is hitted and 12 entries in stack. ; for example, at+cgsn*40,0802,2222 will do that. This is what I normaly use. ; When I say "print", I mean that the information it output to the first ; serial port COM1 . Use Hyperterminal or similar to see the data. ; ; For example, apply this patch: ; 0x53B940: DB00 9B94 ; then, at+cgsn*40,0802,2222 ; and when you start the game RaceAce , it shows: ; 00F3B940<00FA61C8-0800.BF7E.00FC.BB34.00FC.B50A.00FC.FED2.00F4.64F2. 00CC.E6C6. ; The first value is the routine that was intercepted. Almost sure, this is the ; place where you have set your breakpoint: 0xF3B940 ; The second value, after the '<', is the routine that called it. Let's call it S1 ; In this case, FA61C8 is "calls 0E2FFFAh" (a.k.a. callR5R4) with r5=03E9 and r4=21C8, ; what converts to 03E9:21C8=0FA61C8h ; Later, after the '-', it dumps the stack: ; Usually, the first value is the flags register PSW , 0800 in this case ; Then, it usually follows the routine S2 that called S1, But remember that S1 might ; store information in the stack, so this word can be anything else. ; in this case, it is BF7E.00FC , that means 0FCBF7Eh ; Following, the routine S3 that called S2, with same warning as above: 0FCBB34h ; If nothing messes up with the stack, it is possible to back-trace 2+5 routines. ; ; limitations: ; -the patch sets up a new handler for trap #4Ah. This is done ; quite early in the mobile initialization, but may not early enough. ; That means that not all "rets" can be substituted, because ; the trap might had not been set yet. ; -too many breakpoints might print too much data, and crash the phone ; -only work with "rets" . Instruction "ret" can not be traced because ; CSP is not stored, and it is tricky to know it. ; -if another trap is being processed, the breakpoint might not be processsed. ; This depends on the priority of the processed trap and the processor mode ; -if to terminal is connected, the patch tries to send the information ; -I know there are routines to output characters to serial port. I did not ; use them because they use new processes/multitasking, and this modifies ; the values and timings ; -this patch might confuse aplications like SiemensDebugger. Set debug_level ; to 0000 before using SiemensDebugger, ex: at+cgsn*40,0802,0000 base 0A00000h #include C166.inc org 0CEE650h ; this is the end of the original routine that sets any trap handler jmps set_my_trap_4A ; originaly: ; 2EE650: FC00 ; pop DPP0 ; 2EE642: DB00 ; rets org 0FEF100h ; just some freee space in ROM ;****************************************** ; Set the new handler for trap #4A set_my_trap_4A: mov r1, #s(my_trap_4A) movb rh1, rl1 movb rl1, #0FAh ; code for "JMPS" mov r12, #0128h ; trap 4A jumps to 4A*4=128h. This is in C166 manual mov [r12], r1 ; set the segment to jump to mov r1, #o(my_trap_4A) add r12, #2 mov [r12], r1 ; set the offset to jump to. ; in other words: put in 0000:0128 the intruction "jmps my_trap_4A" pop DPP0 ; this was in the original code rets ;****************************************** ; this is where "trap #4Ah" will jump to my_trap_4A: mov [-r0], r6 mov [-r0], r5 mov [-r0], r4 mov [-r0], r3 extp #40h, #1h ; read debug_level mov r4, 0802h cmp r4, #7777h ; if 7777h, call subrutine jmpr cc_NZ, continue_process ; if not, continue calls 0100700h continue_process: pop r6 ; a trap always sets PSW-CSP-IP. As I come from pop r3 ; a "rets" substituted by "trap #4Ah" , therefore ; ; IP is the last data in stack, and CSP is the previous callr output_r3 ; output CSP mov r3, r6 ; and then IP. To make it better, show the address that sub r3, #02h ; called the trap, not the address where I should return to callr output_r3 movb rl4, #'<' ; print a separator callr output_rl4_char pop r6 ; get PSW from stack. Can not be modified pop r5 ; stack holds IP of the address that called pop r3 ; stack holds CSP push r6 ; insert PSW again, because we'll return with reti push r3 ; insert CSP again. Remember that reti extracts PSW-CSP-IP push r5 ; insert IP again. Now we could return callr output_r3 ; print who called, that is, where we come from. First CSP mov r3, r5 ; and later IP. As this is a "calls ..." instruction, takes 4 bytes sub r3, #04h callr output_r3 ; after printing the current address and the calling address, dump some stack extp #40h, #1h mov r5, 0802h ; but only if debug_level tells us so. cmp r5, #1111h ; if #1111h , short listing. jmpr cc_Z, check_post_routine ; long listing movb rl4, #'-' ; initial separator callr output_rl4_char mov r5, SP add r5, #04h ; the first 4 bytes have already been printed mov r6, #0Ch ; dump 12 words another_stack: mov r3, [r5+] callr output_r3 movb rl4, #'.' ; separator in between stack words callr output_rl4_char sub r6, #01h cmp r6, #0h jmpr cc_NZ, another_stack ; output a line_feed and see if need to call a post-process-routine check_post_routine: movb rl4, #0Dh callr output_rl4_char movb rl4, #0Ah callr output_rl4_char extp #40h, #1h mov r5, 0802h ; read debug_level cmp r5, #6666h ; if 6666h, call routine at 100600 jmpr cc_NZ, end_my_trap_4A calls 0100600h end_my_trap_4A: mov r3, [r0+] mov r4, [r0+] mov r5, [r0+] mov r6, [r0+] reti ; this pops IP, CSP, PSW, and then rets ;************** ; if r3 is a word with value #1234h, outputs 1, 2, 3, 4 ; this is not a trivial as it looks, because of little indian output_r3: mov r4,r3 shr r4, #0Ch ; get left-most nibble: 1 callr output_rl4_numeric mov r4,r3 shr r4, #08h ; get second-left-most nibble: 2 callr output_rl4_numeric mov r4,r3 shr r4, #04h ; get second-right-most nibble: 3 callr output_rl4_numeric mov r4,r3 ; get right-most nibble: 4 callr output_rl4_numeric ret ; it is a relative routine. ; **************** output_rl4_char: mov [-r0], r5 jmpr cc_UC, numeric output_rl4_numeric: ; outputs a number. Basically, adds '0' to it mov [-r0], r5 and r4, #000Fh add r4, #30h cmp r4, #3Ah jmpr cc_ULT, numeric ; although if it is in range 0Ah to 0Fh, needs add r4, #07h ; to add 'A'-'0' numeric: extp #40h, #1h mov r5, 0802h ; read debug_level cmp r5, #0h ; if 0 of FFFF, do not output anything jmpr cc_Z, exit_output_rl4 cmp r5, #0FFFFh jmpr cc_Z, exit_output_rl4 movb S0TBUF, rl4 mov r4, r5 bclr S0TIR ; send to COM1 serial port not_sent_yet: jb S0TIR, exit_output_rl4 ; if sent, exit sub r4, #01h ; if not sent, try again, as many times as debug_level jmpr cc_NZ, not_sent_yet exit_output_rl4: mov r5, [r0+] ret end ; I am not releasing the binary code because I assume that ; you need (and you know how) to compile yourself |
01-17-2005, 09:36 | #216 (permalink) |
Member: 89010 Status: Offline Thanks Meter: 0 | TRI1.0 set breakpoints at Input points and trace them ; TRI1.0 set breakpoints at Input points and trace them ; Firmware : S45iv4 ; Author: fcotrina ; Created: 16.01.2005 ; Based in patch DAR=Dump_All_Registers_v2 by RizaPN ; With some ideas taken from lalo.lerry and RizaPN ; Big thanks to Redkin and NCTN and all patchers out there ; ; This patch is related to TRO ; This patch is useful for patch programmers. If you want ; to know the value of the registers, just change any ; instruction "mov [-r0], r15" and "mov [-r0], r14" with ; a call to this patch (debug_r15_r14), that is: ; 0xYYYYYY: 88F088E0 DAFE00FA ; Then, using CGSN patch, set the debug level in 0040:0802 ; at+cgsn*40,0802,0000 not debug anything ; at+cgsn*40,0802,FFFF not debug anything ; Any other value will print the routine that is hitted and 12 entries in stack. ; for example, at+cgsn*40,0802,2222 will do that. This is what I normaly use. ; When I say "print", I mean that the information it output to the first ; serial port COM1 . Use Hyperterminal or similar to see the data. ; Also, you need to specify which routines you want to trace. ; For that, set the address in 0040:0840 ; For example, suppose you are interested in the register values at 0xC83B88 ; Remember that C83B88 = 283B88 ; Apply this patch: ; 0x283B88: 88F088E0 DAFE00FA ; And start the phone. ; then, do at+cgsn*40,0840,00C83B88 to enable the breakpoint ; and at+cgsn*40,0802,2222 to see the results in Hyperterminal ; ; If you want to debug a routine that does ; not use "mov [-r0], r15" and "mov [-r0], r14" ; but uses "mov [-r0], r09" and "mov [-r0], r08" instead, just call debug_r09_r08 ; In this case, patch the ROM with: ; 0xYYYYYY: 88908880 DAFE18FA ; for example, 0x280788: 88908880 DAFE18FA ; and enable the breakpoint with at+cgsn*40,0840,00C80788 ; ; You can enable several breakpoints just putting them together: ; at+cgsn*40,0840,00C83B8800C80788 ; Even more, you can enable all breakpoints in the same page using FFFF as the offset: ; at+cgsn*40,0840,00C8FFFF will enable C80456 and also C804DE and C8054A ... ; But remember that first you need to path ROM: ; 0x280456: 88F088E0 DAFE00FA ; 0x2804DE: 88F088E0 DAFE00FA ; 0x28054A: 88F088E0 DAFE00FA ; ; limitations: ; -you can trace 8 breakpoints. Modify the program if you need more ; -only 6 combinations "mov [-r0], rX" + "mov [-r0], rY" are supported ; it is really easy to add more, but those 6 combinations appear: ; r15_r14 = 88 F0 88 E0 -> 2474 times ; r14_r13 = 88 E0 88 D0 -> 1414 times ; r13_r12 = 88 D0 88 C0 -> 4544 times ; r09_r08 = 88 90 88 80 -> 5425 times ; r08_r07 = 88 80 88 70 -> 1840 times ; r08_r07 = 88 70 88 60 -> 2498 times ; That is, about 15.000 routines ; -It is a good idea to patch as much ROM as you can, and then enable only ; those breakpoints you are interested on. If you enable too much, for ; example with at+cgsn*40,0840,00C8FFFF500F7FFFF00F9FFFF00FAFFFF ; then the data will be huge. Apart from that, if you do NOT output ; data, that is, at+cgsn*40,0802,0000 , then the mobile will run ; just a bit slower than usual ; -do not breakpoint this patch in routine debug_rX_rY, or it will ; go into an infinite loop ; base 0A00000h #include C166.inc org 0FEFA00h ; just some freee space in ROM ; These are all entry points. They can be called from anywhere in ROM debug_r15_r14: mov [-r0], r15 mov [-r0], r14 jmps do_debug debug_r14_r13: mov [-r0], r14 mov [-r0], r13 jmps do_debug debug_r13_r12: mov [-r0], r13 mov [-r0], r12 jmps do_debug debug_r09_r08: mov [-r0], r09 mov [-r0], r08 jmps do_debug debug_r08_r07: mov [-r0], r08 mov [-r0], r07 jmps do_debug debug_r07_r06: mov [-r0], r07 mov [-r0], r06 jmps do_debug ;****************************** ; Do the processing do_debug: ; save flags. This is required as it will be very bad if I modify it push PSW ; save all registers. That will make it easier to print them mov [-r0], r15 mov [-r0], r14 mov [-r0], r13 mov [-r0], r12 mov [-r0], r11 mov [-r0], r10 mov [-r0], r9 mov [-r0], r8 mov [-r0], r7 mov [-r0], r6 mov [-r0], r5 mov [-r0], r4 mov [-r0], r3 mov [-r0], r2 mov [-r0], r1 mov [-r0], r0 continue_process: ; first thing is to print where we are. As we come from "calls ...", the CSP-IP ; is stored complete in the stack pop r6 ; get PSW, because I have stored it previously. As long as it stays in r6, it is safe pop r14 ; get IP pop r15 ; stack holds CSP push r15 ; insert CSP again push r14 ; insert IP again. Now we could return push r6 ; need to push flags again because it is extracted at the very end sub r14, #04h ; the stack doesn't have the address that called, but the address just after that ; find if this address has an enabled breakpoint: ; search r15:r14 from 0040:0840 until 0040:0860, that is, 8 times and r6, #00FFh mov r12, #0840h mov r11, #8 ; times to search search_again: extp #40h, #2h mov r3, [r12+] ; get CSP that is breakpointed. This is stored as a page, not a segment mov r2, [r12+] ; get IP movb rl3, rh3 ; change little_indian to big_indian and r3, #00FFh ; only pages in the first 16Mg (are there pages outside this? answer:NO) cmp r3, r15 ; check page jmpr cc_NZ, not_coincidence movb rl3, rh2 ; change little_indian to big_indian movb rh3, rl2 cmp r3, r14 ; check offset jmpr cc_Z, coincidence cmp r3, #0FFFFh ; if offset is FFFF, also debug. This is like a mask for page:**** jmpr cc_Z, coincidence not_coincidence: sub r11, #1h jmpr cc_NZ, search_again jmpr cc_UC, end_do_debug ; not in list coincidence: ; first print stack mov r3, r15 callr output_r3 ; print who called, that is, where we come from. First CSP mov r3, r14 ; and later IP. As this is a "calls ..." instruction, takes 4 bytes callr output_r3 ; long listing of stack movb rl4, #'-' ; initial separator callr output_rl4_char mov r5, SP add r5, #06h ; PSW-IP-CSP have already been printed. Each one takes 2 bytes mov r6, #0Eh ; dump 12 words from stack another_stack: mov r3, [r5+] callr output_r3 movb rl4, #'.' ; separator between stack words callr output_rl4_char sub r6, #01h jmpr cc_NZ, another_stack callr output_CR_LF ; dump all 15 registers : | r0 | r1 | r2 | r3 | ... | r13 | r14 | r15 mov r15, r0 ; see where I stored them mov r14, #10h ; number of words to output another_register: movb rl4, #'|' ; separator between registers callr output_rl4_char mov r3, [r15+] callr output_r3 sub r14, #1h jmpr cc_NZ, another_register callr output_CR_LF end_do_debug: mov r1, [r0+] ; I stored r0, but don't want to retrieve it mov r1, [r0+] mov r2, [r0+] mov r3, [r0+] mov r4, [r0+] mov r5, [r0+] mov r6, [r0+] mov r7, [r0+] mov r8, [r0+] mov r9, [r0+] mov r10, [r0+] mov r11, [r0+] mov r12, [r0+] mov r13, [r0+] mov r14, [r0+] mov r15, [r0+] pop PSW rets output_CR_LF: ; output a line_feed movb rl4, #0Dh callr output_rl4_char movb rl4, #0Ah callr output_rl4_char ret ;************** ; if r3 is a word with value #1234h, outputs 1, 2, 3, 4 ; this is not a trivial as it looks, because of little indian output_r3: mov [-r0], r4 mov r4,r3 shr r4, #0Ch ; get left-most nibble: 1 callr output_rl4_numeric mov r4,r3 shr r4, #08h ; get second-left-most nibble: 2 callr output_rl4_numeric mov r4,r3 shr r4, #04h ; get second-right-most nibble: 3 callr output_rl4_numeric mov r4,r3 ; get right-most nibble: 4 callr output_rl4_numeric mov r4, [r0+] ret ; it is a relative routine. ; **************** output_rl4_char: mov [-r0], r5 jmpr cc_UC, numeric output_rl4_numeric: ; outputs a number. Basically, adds '0' to it mov [-r0], r5 and r4, #000Fh add r4, #30h cmp r4, #3Ah jmpr cc_ULT, numeric ; although if it is in range 0Ah to 0Fh, needs add r4, #07h ; to add 'A'-'0' numeric: extp #40h, #1h mov r5, 0802h ; read debug_level cmp r5, #0h ; if 0 of FFFF, do not output anything jmpr cc_Z, exit_output_rl4 cmp r5, #0FFFFh jmpr cc_Z, exit_output_rl4 movb S0TBUF, rl4 mov r4, r5 bclr S0TIR ; send to COM1 serial port not_sent_yet: jb S0TIR, exit_output_rl4 ; if sent, exit sub r4, #01h ; if not sent, try again, as many times as debug_level jmpr cc_NZ, not_sent_yet exit_output_rl4: mov r5, [r0+] ret end ; I am not releasing the binary code because I assume that ; you need (and you know how) to compile yourself |
01-19-2005, 05:28 | #217 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** ISP. Improuved Screensaver Pop-up *** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Thanks to ntcn for accessories state RAM location ;Release : 17.01.05 - v1 ;Update : 19.01.05 - v1.1 - little relocated - ;This patch limits screensaver pop-up: ;it will not pop-up if a charger, data cable or tracer cable is connected to phone. ;NOTE: tracer cable is a data+charger cable. 5605FA: DAF87CE5 FA87D0E2 7E2D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7404300C2F4DE2148472D0A46F49800 7E2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0746F499002D04DAF87CE5DAF6FE05 7E2F0: FFFF DB00 ;CUSTOMIZATION: ;Don't check tracer cable connection (uncomment): ;7E2DC: 46F4 0D02 ;Don't check data cable connection (uncomment): ;7E2E2: 46F4 0D02 ;Enjoy it, Genetic! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 01-19-2005 at 07:48. |
01-19-2005, 05:39 | #218 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** MES. Missed Events String in Idle/Screensaver *** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Release : 17.01.05 - v1 ;Update : 19.01.05 - v4 - option added ;This patch changes second line operator name and/or date in date&time string in idle ;and/or operator name in screensaver mode, to became a missed events info string, ;if a missed event is present and if phone is in normal state (e.g. not in "Net searching mode", etc...). ;Missed event/s (calls, SMSes, voice messages, appointments, memos and alarm clock) ;and its/their number is displayed in string. ;NOTE: ;1. Missed voice messages number is setted to 1 by default, even if they are more than 1. ;This is because my operator (or I?) don't use voice messages, ;so I couldn't check out their missed number RAM location. ;If anyone knows it, please let me know and I will complete the patch. ;2. If missed events are 4 or + in data&time string, they "collides" with time and this one disappear. ;It will reappear as soon as missed events number will be less than 4. ;UNINSTALL any previously applied version, first! ;Improuvments v4: ;missed event string instead of date support added ;dinamic use of string spaces and characters ;space saved ;small/big font type string option added ;patch routine: 7E100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E003BB2B48403D04DACBF86EFAF63411 7E110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E013BB1FE016DACA709EFAF67411E003 7E120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB1C48403D04DAC44488FAF868D7E013 7E130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB10E09CDACA08A0DAF8D2F0FAF8B2D7 7E140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E003BB0B48403D02FAC66439E033BB05 7E150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DB00E6FE3037E6FF4400DACAB89CDA87 7E160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70E1DACA629CCB00FFFFA9204C616C6F 7E170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACBB208E007DAC470C7F0640065DAC4 7E180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B2C70046004548402D03E6F69301BB47 7E190: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403A00C2F4A0122D03E6F6930DBB3F 7E1A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405700C2FCC22166FC0F0046FC0A00 7E1B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D11D7405700F3F2C221DACCA85A2D0A 7E1C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405700F3F2D9258AF10830DAC5AAE6 7E1D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D04E014E6F69314BB21E6FCA4CC 7E1E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FDF700DAF6BADA48402D07E6F6932D 7E1F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48312D02E6F6930ABB12E02CDAF1FEA1 7E200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D04E014E6F69303BB0948302D03 7E210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E102DC49B928F047F0B7FACAAC974830 7E220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D3048B13D0848333D06E6F19520BB2B 7E230: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F12020BB2848702D0EE6F19595BB23 7E240: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F12C9148333D0248B39D0448B49D02 7E250: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F12C20BB18F0C4E7F23000DC49B928 7E260: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC47DACBD01FDAFFC03F088248333D02 7E270: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48B29D0548B39D03E6F19520BB04F016 7E280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB020871CB00DC49B8180882CB00FFFF ;patch starting points: ;Missed events string in operator name second line space in idle (uncomment): ;561130: DACBF86E FA8700E1 ;Missed events string in operator name space in screensaver (uncomment): ;if you don't have Operator Name in Screensaver applied use this line: ;58D764: DAC44488 FA871EE1 ;if you have Operator Name in Screensaver applied: ;if you choose to delete operator name use this lines: ;58D764: 0D424488 FA871EE1 ;07E126: DAC44488 FAF8EAD7 ;if you choose to alternate operator - profile names use these lines: ;58D764: FA87C0DD FA871EE1 ;07E126: DAC44488 FA87C0DD ;Missed events string in date space in idle (uncomment): ;if you don't have any "data patch" applied use this line: ;560506: DAC66439 DA8740E1 ;if you have "DD dd mmm" date patch applied use these lines: ;560506: DA8740DA DA8740E1 ;07E148: FAC66439 FA8740DA ;if you have temperature instead of DATE patch or both date patches applied use these lines: ;560506: DA8730CE DA8740E1 ;07E148: FAC66439 FA8730CE ;CUSTOMIZATION: ;Memos small icon font is missing in orginal fw, so, if you have changed operator font type to a small font (06,07), ;use this line to use small bell as icon font for missed appointments (uncomment): ;07E111: 13 23 ;in idle ;07E12F: 13 23 ;in screensaver ;Overwrite first line operator name, not the second, in idle (uncomment): ;07E115: 16 06 ;Remove leading 0 in 00-09 missed events numbers (uncomment): ;07E25A: 30 91 ;delete missed events arrow in screensaver: ;58D9A8: F084 E008 ;NOTE: missing event arrows pops up for more missed events ;(but less important, IMHO, like bitmap or ringtone recieved) than missing events string. ;That's the very last end (I HOPE)! ;Enjoy it! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 01-20-2005 at 09:08. |
01-26-2005, 20:09 | #219 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | Sorry, I really couldn't avoid to make it ;*** MSC. More Shortcut *** ;Firmware : S-ME45i v04 ;Author : RizaPN, Lalo ;Release : December 16, 2003 - v1 ;Updated : December 19, 2003 - v2 ;Updated : Jenuary 26, 2005 - v3 - bugs corrected ;This patch adds 13 more fixed shortcut in idle, ;by pressing button 0-9,*,+,# followed by LeftSoftKey. ;Assign your favourites function to them by patch customization ... ;Improuvements v3 - bug fixed: ;correct display of "clear" text in left softkey after having used the shortcut ;no more strange patch auto-disablements ;no shortcut if call in progress (you can't cancel the pressed digit by red button if call is in progress) ;some TAG text corrected 27F966: F0D65C2D DA8770CC 55DA78: 46FF0B00 DA87B6CC 5611DC: FACAAC97 FA872ACD 7CC70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48603D1E46FC2A013D1B88C0DAC46AAC 7CC80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C048412D15D7405B00F3F45C243D10 7CC90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7404400F3F4FF373D0BBB30D7501F02 7CCA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9932A922F0C1E114D7405B00F7F45C24 7CCB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0D65C2DDB0046FF0B003D1388C0DAC4 7CCC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6AAC98C048412D0DF04CD7404400F3F4 7CCD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF373D0248412D062841D7404400F7F8 7CCE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF37DB00BB0B0822E005D7601F0299A2 7CCF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9992A982DAE2FAFFE00CDB00D7405B00 7CD00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F3F45B2427F430009D0607F40D003D02 7CD10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E1C40D01094347F40C00EDFAC042F012 7CD20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C21002106F2380DCB00E108D7404400 7CD30: FFFFFFFFFFFFFFFF F7F8FF37FACAAC97 CUSTOMIZATION: ;Choose shortcuts: ;Modify this list as you like. ;The first 2 byte is text code for LeftSoftKey ;and the last 3 byte is function entry-point ;Example: 01EC is "Calc.", and F65D38 is its entry-point 7CD38: FFFFFFFFFF 01ECF65D38 ; 0.Calculator 7CD3D: FFFFFFFFFF 074CE994CA ; 1.Inbox 7CD42: FFFFFFFFFF 0749E99466 ; 2.SMS 7CD47: FFFFFFFFFF 074DE99508 ; 3.Outbox 7CD4C: FFFFFFFFFF 02F1E99548 ; 4.Archive 7CD51: FFFFFFFFFF 0099E99624 ; 5.New email 7CD56: FFFFFFFFFF 0102F5E37A ; 6.IrDA 7CD5B: FFFFFFFFFF 01FEF65D50 ; 7.Appointment 7CD60: FFFFFFFFFF 010BF65D44 ; 8.Calendar 7CD65: FFFFFFFFFF 0288F65DAA ; 9.Internet 7CD6A: FFFFFFFFFF 01C1F65D1C ; *.Games 7CD6F: FFFFFFFFFF 04A9F5E368 ; +.GPRS 7CD74: FFFFFFFFFF 08B2F65D64 ; #.Explorer ;Enable shortcuts in call in progress (uncomment): ;07CC7A: 88C0 0D05 ;07CCBC: 88C0 0D05 ;Enjoy it! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 01-26-2005 at 21:21. |
02-03-2005, 01:39 | #220 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** NAM. New "Applications" Menu v3*** ;Firmware : S-ME45i v04 ;Author : Lalo ;Luki's - Siemens Modding Forum ;Based on RizaPN SL45i patch (thanks Master for your source asm) ;Release : 03.02.05 ;Updated: 04.02.05 - v3.1 - autosize improuved, rilocated, pictures changed, space saved - ;This patch replaces unusefull (IMHO) "Help on line" item with a new "Applications" item in main menu. ;The new Application menu consists of 5 profiles, ;and each profile controls 16 patches functions (tot. 80 voices max), ;and has the capability to "autosize" itself (this means that only used voices are displayed) ;Old NAM menu is totally implemented in first profile menu of new NAM. ;UNINSTALL the first NAM version before apply this one. 5A9B4: 3E60F6 00E387 5AB20: 06020502 1A0C1A0C 0x7C9D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 40010000C7000000AD01000077020000 0x7C9E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D0091F021A0CFF7F 0x7C9F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00000000000000000000000000000000 0x7CA00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08091A02FE081A028002000000000000 0x7CA10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 123844006C3844000500FFFFFFFFFFFF 0x7CA20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D4091F028D0AFF7F 0x7CA30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D4091F028E0AFF7F 0x7CA40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D4091F028F0AFF7F 0x7CA50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D4091F02900AFF7F 0x7CA60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000000065000C00D4091F02910AFF7F 0x7CA70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00000000000000000000000000000000 0x7CA80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0C091A02FE081A028102000010E48700 0x7CA90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 80384400A03944001000FFFFFFFFFFFF 0x7E300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6004400E6F12438E6F28038E6F3E024 0x7E310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F426E3E045E006E017BB35E6FAE009 0x7E320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FBF0090D21E00C0D07E01C0D05E02C 0x7E330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D03E03C0D01E04CE6004400F6FC1038 0x7E340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F03C5C53E6F19238E6F2E03906F3F024 0x7E350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F426E4E0F5E026E027BB15F0AC5C4A 0x7E360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FA200AE6FB700AF0CEF0DFE00E88E0 0x7E370: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0FAE6F11F02881088F0F0EBF0F1DAFA 0x7E380: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A8470806DB00EC00D7401F029893BB0D 0x7E390: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FA870088A2F0A55C2A00A488A206F1 0x7E3A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2400A0053DF1FC00CB0048702D16E6FA 0x7E3B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 050248713D0FE6FB7025F0D55C5D20BD 0x7E3C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E008D7401F0298DB46FDFFFF3D0680F8 0x7E3D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8DF80D0546F9FFFF2D02E6FA590588A1 0x7E3E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E03A88A1E00A88A188A188A146F9FFFF 0x7E3F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02E6F922038891889148603D0288A1 0x7E400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D05E6FA1A0288A1E6FA300988A1CB00 0x7E410: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E02BF02EBB4C60212D01E01B88B0DAFA 0x7E420: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3A2B0802DB00E00C0D1DE01C0D1BE02C 0x7E430: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D19E03C0D17E04C0D15E05C0D13E06C 0x7E440: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D11E07C0D0FE08C0D0DE09C0D0BE0AC 0x7E450: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D09E0BC0D07E0CC0D05E0DC0D03E0EC 0x7E460: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D01E0FCF02CBB235021DC45B82448C0 0x7E470: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02E0020D0EE6F19038E002D7404400 0x7E480: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A84146F405022D01082106F1120028C1 0x7E490: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF5F0C8F0D9F0E2E00FDAFA1827F0C8 0x7E4A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0D9DAFA822EDACA7AB2FAFADC35E6F4 0x7E4B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C3FE6F54200E0114C12D7404400F2F3 0x7E4C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 10382D07E6F4602EE6F55B0028315C13 0x7E4D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0043DC45A824CB00FFFFA9204C616C6F ;These are the Application menu items names, stored by thier hex byte swapped string IDs: 0x7E4E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D0A8E0A8F0A900A910AFFFFFFFFFFFF ;These are the Profile 1 menu items names, stored by thier hex byte swapped string IDs: 0x7E4F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AA062E018503B6023800A3042B022B06 0x7E500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 03008D006607290663007F0275009A02 ;Here must be placed the Profile 2 menu items names, stored by thier hex byte swapped string IDs: ;0x7E510-0x7E52F: empty by now, each word correspond to an item in profile 2 menu ;Here must be placed the Profile 3 menu items names, stored by thier hex byte swapped string IDs: ;0x7E530-0x7E54F: empty by now, each word correspond to an item in profile 3 menu ;Here must be placed the Profile 4 menu items names, stored by thier hex byte swapped string IDs: ;0x7E550-0x7E56F: empty by now, each word correspond to an item in profile 4 menu ;Here must be placed the Profile 5 menu items names, stored by thier hex byte swapped string IDs: ;0x7E570-0x7E58F: empty by now, each word correspond to an item in profile 5 menu ;First profile menu voices (=old NAM menu voices): ;voice 1 = Black = FD. Funny Display: invert colors option ;voice 2 = Swap = FD. Funny Display: turn display on orizzontal ax option ;voice 3 = Reversi = FD. Funny Display: turn display on vertical ax option ;voice 4 = Clock = DC. Digital Clock ;voice 5 = Animation = ? AOL. Animated Operator Logo ;voice 6 = Screensaver = BLANK. Blank Screen when Keylocked ;voice 7 = Alarm clock = HB.Hourly Beep or ACP.Automatically change the phone's profiles ;voice 8 = Temperature = SCT. Show Current Temperature instead of time or date ;voice 9 = 12 Hours = HFI. 12AM-PM Hours Format in Idle screen ;voice 10 = Format date = DFI. dd NN mmm Date Format in Idle screen ;voice 11 = SMS as text = CL.Call Logging: save SMS text option ;voice 12 = Save data = CL.Call Logging ;voice 13 = Auto Answer = BL.Black List: autoanswer option for unknown ID calls ;voice 14 = Reject = BL.Black List: reject option for unknown ID calls ;voice 15 = Busy = BL.Black List: busy option for unknown ID calls ;voice 16 = Silent = AAA. Assign Any ringtone to Any number: silent option for unknown ID calls ;if you don't use some of them and want to delete them, just fill the related word of FFFF ;e.g.: delete Reversi menu item: ;0x7E4F4: 8503 FFFF ;CUSTOMIZATION: ;Disable autosize menu feature: ;0x7E319: 17 07 ;show always all profiles in application menu (also "empty" profiles) ;0x7E359: 27 07 ;show allways all items in profiles menu (also "empty" voices) ;(continues in following post) Last edited by lalo.lerry; 02-04-2005 at 03:15. Reason: new version released |
02-03-2005, 03:00 | #221 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;(continues from previous post) ;PICTURES: ;Change "Help on Line" pictures to "Applications" pictures in main menu animations (pictures nn.578-584): ; ##### Picture 578 ##### ; Picture Data 0DAAE8: 00000F00000F00000F1FFFCF1F87CF1F 00400F00400F00E00F00E00F00E00F01 0DAAF8: 03CF1E31CF1E79CF27F9CF1FF1CF1FE3 F00F01F00F7FFFCF3FFF8F1FFF0F07FC 0DAB08: CF1FC7CF1FCFCF1FCFCF1FFFCF1FCFCF 0F03F80F07FC0F07FC0F07BC0F0F1E0F 0DAB18: 27CFCF1FFFCF 0C060F18030F ; ##### Picture 579 ##### ; Picture Data 0DAB1E: 07E00F0FE00F1EE00F3C7FCF3B604F3B 00400F00600F00600F00E00F00F00F00 0DAB2E: 604F3E604F3EE04F4CE04F3DE04F3FE0 F00F01F00F3FFF8F1FFF0F0FFE0F07FC 0DAB3E: 4F3EE04F3CC04F3FA04F3F404F3E804F 0F03F80F03F80F03FC0F07FC0F07BC0F 0DAB4E: 4D004F3A004F 071C0F06040F ; ##### Picture 580 ##### ; Picture Data 0DAB54: 1C000F1C000F3C000F3FFFCF3C004F3C 00100F00100F00380F00380F00780F00 0DAB64: 004F3C304F3C304F4C004F3C704F3C70 780F0FFF0F07FF0F03FE0F01FC0F00FC 0DAB74: 4F3C304F3C304F3C304F3C784F3C784F 0F00FC0F00FC0F01FC0F01DC0F01CC0F 0DAB84: 48004F38004F 01840F01000F ; ##### Picture 581 ##### ; Picture Data 0DAB8A: 60000F60000F60000F7FFFCF60004F60 00400F00400F00400F00600F00600F00 0DAB9A: 004F60304F60304F58004F60704F6070 600F00E00F00F00F00F00F00700F0060 0DABAA: 4F60304F60304F60304F60784F60784F 0F00600F00600F00E00F00E00F00A00F 0DABBA: 58004F60004F 00B00F00100F ; ##### Picture 582 ##### ; Picture Data 0DABC0: 80000FC0000FE0000FFFFFCFE0004FE0 00200F00200F00200F00600F00600F00 0DABD0: 004FE0004FE1FE4FD9FE4FE0004FE000 600F00700F00F00F00F00F00E00F0060 0DABE0: 4FE1FE4FE0004FE0004FE0004FE0004F 0F00600F00600F00700F00700F00500F 0DABF0: D8004FE0004F 00D00F00800F ; ##### Picture 583 ##### ; Picture Data 0DABF6: 00000F80000FC0000FFFFFCFE0004FE0 00800F00800F01C00F01C00F01E00F01 0DAC06: 004FE0004FE1FE4FD8004FE0004FE1FE E00F0FFF0F0FFE0F07FC0F03F80F03F0 0DAC16: 4FE1FE4FE0004FE0004FE1FE4FE0004F 0F03F00F03F00F03F80F03B80F03380F 0DAC26: D8004FE0004F 02180F00080F ; ##### Picture 584 ##### ; Picture Data 0DAC2C: 00000F00000F00000FFFFFCFE0004FE0 00200F00600F00600F00700F00F00F00 0DAC3C: 004FE0004FE1FE4FD8004FE0004FE1FE F00F00F80F1FFFCF0FFF8F07FF0F03FE 0DAC4C: 4FE0004FE0004FE1FE4FE1FE4FE0004F 0F01FC0F01FC0F03FC0F03FE0F03DE0F 0DAC5C: D8004FE1FE4F 038E0F02060F ;Change unused (I hope!) picture n.320 to become the new menu icon: ; ##### Picture 320 ##### ; Picture Table Index 0DE930: 1A280100 0F0B0100 ; Picture Data 0D6CD9: 0050003F0028003F0C50003F1EA0003F 01010101038103813FF90FE107C107C1 0D6CE9: 1F70003F1FFD003F0EFE803F15FF803F 0EE1082100010F0F0F0F0F0F0F0F0F0F 0D6CF9: AFD1803F5F90803FAF18403F4E11403F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D09: 0FE2403F0E44403F0E00803F0615003F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D19: 0B23003F07CF803F01F3803F03FF803F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D29: 03FF803F07FF803F07FFC03F0FFFC03F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D39: 0FFFC03F13FFF03F1CFFE83F0B3FE83F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D49: 08FC283F0883F03F0CFFE03F07FFF03F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D59: 007DF03F007DF83F007CF83F007CFC3F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F 0D6D69: 007CFFBF00E4FE7F0104C07F01F8FFBF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F ;FOR PATCH MASTERS: ;These are the EEFULL RAM locations used by this patch (for any selectable patches), ;1st Profile => 0042:3F3Ch (old one used in the first NAM patch), ;2nd Profile => 005B:2E60h (unused? profile setting data) ;3rd Profile => 005B:2E62h (unused? profile setting data) ;4nd Profile => 005B:2E64h (unused? profile setting data) ;5rd Profile => 005B:2E66h (unused? profile setting data) ;new item names must be placed in NAMv3 menu names area (0x7E510-0X7E58F) ;REMEMBER not to place any new patch there! ;I hope a lot of new selectable patches will come! ;Enjoy it! ;© Lalo 2005 Luki's - Siemens Modding Forum Last edited by lalo.lerry; 02-03-2005 at 19:43. Reason: new version released |
02-04-2005, 21:07 | #222 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** CLS. Change Log-in and Log-off Sounds *** ;Firmware : S-ME45i v04 ;Author : Lalo ;luki's Siemens Modding Forum ;Adapted and modified from a SL45 Trustkill's and Abomin's patches ;Release : 06.09.04 - v1 ;Updated: 04.02.05 - v1.1 - new NAMv3 integration - ;This patch changes the startup and/or shutdown sound in any other phone one, ;according to extended info tone flag in profile's menu ;and selectable through my NAMv3, profile 2, item 1. ;UNDO the previouly version if applied! 557357:CD3EDB 8710DA 591173:CD3EDB 8724DA 7DA10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405B00F2F4602E9AF40200E6FC5100 7DA20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FACD3EDBD7405B00F2F4602E9AF40200 7DA30: FFFFFFFFFFFFFFFF E6FC5600FACD3EDB ;CUSTOMIZATION: ;change log-in sound: ;7DA1E: 51 xx ;change log-off sound: ;7DA32: 56 xx ;where xx is sound number according to word list sound ;Selection throught NAMv3 (you must have NAM patch applied): ;defoult = profile 2, item 1 (own sounds) ;7E510: FFFF 5309 ;assign 2.1 item to CLS patch (uncomment) ;Enjoy it, Genetic! ;© Lalo 2005 Luki's Siemens Modding Forum |
02-09-2005, 00:10 | #223 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** NNC. Name and Number in Incoming/Outgoing Calls *** ;Firmware : S-ME45i v04 ;Author : Lalo ;luki's Siemens Modding Forum ;Partly based on RizaPN SL45i patch ;Release : 08.02.05 - v1 ;Updated: 10.02.05 - v1.1 - option added ;This patch adds a new line with number just under name in incoming and/or outgoing call screen. ;The number will be shown only if avable and if not yet shown in "name" string. ;show number in incoming calls (comment if you don't want it): 5631B6: DACB6264 DA87A0E5 5631BC: FA3FE6FF1502 6037E6FF4400 ;show number in outgoing calls (comment if you don't want it): 55CA1C: DACA709E DA87A6E5 55CA22: E43FE6FF1502 6037E6FF4400 ;show number in outgoing calls if handfree on (comment if you don't want it): 55CAB4: DAF76CD3 DA8710E6 55CAD0: DACAA8B2 DA87ACE5 55CAD6: E43FE6FF1502 6037E6FF4400 7E5A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACB62640D05DACA709E0D02DACAA8B2 7E5B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACAF097E6F63E27E6F77521E6F86037 7E5C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F94400E6003C00A9862D120862A986 7E5D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0F0D0447F893003D030D01BB110871 7E5E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9927F041BB092D04F0147C41BB053DF8 7E5F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E102BB08FAC6E23AE1F3612341232D05 7E600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 07F23000DC49B9280881CB00FFFFFFFF 7E610: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAE50E1148443D02FAF76CD3E004DB00 ;CUSTOMIZATION: ;Delete your country international prefix in shown number (uncomment): ;7E5D2: 0D04 A987 ;7E5D6: 93 xx ;where xx is you country international prefix with swapped numbers ;e.g.: Germany: prefix = +49, xx = 94 ;and write a "0" instead of it (uncomment if you want it): ;7E5DA: 0D01 E102 ;Move name and number string in incoming call to fit it properly in screen (comment if you don't want it): 59E39: 2E02 2B02 ;name string: y and font type 59E45: 0001 3806 ;number string: y and font type ;Enjoy it, Maulwurf! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 02-10-2005 at 02:48. |
02-11-2005, 02:11 | #224 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** PLK. PTT Button Long in Keylock Screen *** ;Firmware : S-ME45i v04 ;Author : Lalo ;luki's Siemens Modding Forum ;Release : 11.02.05 - v1 ;This patch invertes PTT button pression behaviour when keylocked to avoid unwanted shortcut: ;short pression: no effect ;long pression: start voicedialling function 560D3C: DAFD66D6 DA87A0E2 7E2A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACAB6F1DACB0647DACCD25C46F6EB00 7E2B0: FFFFFFFFFFFFFFFFFFFF 3D02FAFD66D6E004DB00 ;Enjoy it, Lalo! ;(Finally I can enjoy my Siemens mp3 player without unwanted music stops! ) ;© Lalo 2005 Luki's Siemens Modding Forum |
02-11-2005, 02:18 | #225 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** UWS. Unsent SMS Waring Sound *** ;Firmware : S-ME45i v04 ;Author : Lalo ;luki's Siemens Modding Forum ;Release : 11.02.05 - v1 ;Updated : 12.02.05 - v2 - more situations included ;This patch changes "SMS not sent" MessageBox beep with a warning sound, ;if the SMS has not been (or only partly if multiSMS) sent. 4A3496: DACA4E9A DA8770F1 4A38A8: DAFAD84C DA8776F1 4A4070: DACC5C1A DA877CF1 4A437A: DACA5EA0 DA8782F1 7F170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DACA4E9A0D08DAFAD84C0D05DACC5C1A 7F180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D02DACA5EA0DACAB89CE6FC6700DACD 7F190: FFFFFFFFFFFF 3EDBFACA629C ;CUSTOMIZATION: ;Change warning sound type (uncomment): ;7E18C: 67 xx ;where xx is a sound taken from word sounds list ;NOTE: If you find some other situations in which SMS in not sent but there is no waring sound, ;please report to me and I'll try to add them. ;Enjoy it, ElPossa! ;© Lalo 2005 Luki's Siemens Modding Forum Last edited by lalo.lerry; 02-12-2005 at 01:23. |
S/ME45i-v04: Flash Patching ... | rizapn | x4x, x5x Flashpatching | 1282 | 07-05-2015 12:16 |
821sc flash patch cid3 dead after flash | cetech | Z3X-Team Products | 26 | 07-17-2009 12:12 |
L760 flashing patched flash problem | Steph | NSPRO | 4 | 12-05-2008 11:04 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Need flash patched with Spanish lang for Neptune ! | Kilowat | Mitsubishi | 4 | 05-21-2002 07:24 |
