Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 12-12-2003, 18:37   #31 (permalink)
Member: 46164
;*** DKM. Disable_Keylocked_Message ***
;Firmware : SME45iv04
;Author : RizaPN
0x55D84A: DAF6 0D01
Old 12-12-2003, 18:38   #32 (permalink)
Member: 46164
;*** KTM. Keylocked_auto_TimeOut_Modification ***
;Author : RizaPN
;Release : December 11, 2003
0x560DD0: 60EA 3075
;The value is representing time before auto keylocked in milisecond
;(original = EA60 = 60000 ms). Modify with your own value.
Old 12-12-2003, 18:40   #33 (permalink)
Member: 46164
;*** ISK. Invert Softkey Display ***
;Author : RizaPN
;This patch will invert the soft key display
;black text with white background
0x27F557: 60 00
0x27F65F: 97 07
Old 12-12-2003, 18:41   #34 (permalink)
Member: 46164
;*** AAA. Assign Any ringtone to Any number ***
;Author : RizaPN
;This patch is work based on Addressbook data.
;Use 2 digit "Post code" as a ringtone ID, for example:
;01 is for ringtone no.1, etc...
0x2DDAB8: DAF9FA79 DA8780C9
0x07C980: FFFFFFFFFFFFFFFF E002D7503C00F2F1
0x07C988: FFFFFFFFFFFFFFFF 262BF6F2262B27F2
0x07C990: FFFFFFFFFFFFFFFF 30008D0B27F33000
0x07C998: FFFFFFFFFFFFFFFF 8D08C02D5C3D00D1
0x07C9A0: FFFFFFFFFFFFFFFF 00D1C03100D166FD
0x07C9A8: FFFFFFFFFFFFFFFF 3F00FAF9FA79FFFF
Old 12-12-2003, 18:42   #35 (permalink)
Member: 46164
;*** BEW. Modify Battery Empty Warning Sound ***
;Author : RizaPN
0x25FFB9: 3C 0C ; no sound
;0x25FFB9: 3C 1C ; tut-tut-tut sound
;0x25FFB9: 3C 2C ; high "tit" sound
;0x25FFB9: 3C 4C ; "click"
;0x25FFB9: 3C 5C ; "tit" sound
;8C = "tuuuuuuuuuuuuuuuuuuuut"
;9C = "tu-tu-tu-tu"
;AC = "tu-tu-tu-tu"
;BC = "tut"
;CC = "tu-tu-tu"
;DC = "tu-tu-tu"x3
;EC = "tu--tu"
Old 12-12-2003, 18:44   #36 (permalink)
Member: 46164
;*** NAM. Add New "Application" Menu ***
;Author : RizaPN
;Release : December 12, 2003
;This patch will create a new "Application" menu under the
;Setup menu to provide the ability to enable/disable some
;function provided by patches.
;After applying this patch, you need to REAPPLY the Digital
;Clock patch with the latest version.
0x05B9CC: 810AEF04 1A0C1A0C
0x05B9F6: 7284F600 D0C98700
0x07C9D0: FFFFFFFFFFFFFFFF E6F32200EC00E600
0x07C9D8: FFFFFFFFFFFFFFFF 4400E6F11638E6F2
0x07C9E0: FFFFFFFFFFFFFFFF 8839D7401F02D4C3
0x07C9E8: FFFFFFFFFFFFFFFF E00AE6F459058841
0x07C9F0: FFFFFFFFFFFFFFFF E0348841E0048841
0x07C9F8: FFFFFFFFFFFFFFFF 8841884188C188C1
0x07CA00: FFFFFFFFFFFFFFFF E6F41A028841E6F4
0x07CA08: FFFFFFFFFFFFFFFF 30098841E6F48700
0x07CA10: FFFFFFFFFFFFFFFF 8842E6F480CA8842
0x07CA18: FFFFFFFFFFFFFFFF 06F124002832ADE1
0x07CA20: FFFFFFFFFFFFFFFF 0824E6F4F6008842
0x07CA28: FFFFFFFFFFFFFFFF E6F472848842FC00
0x07CA30: FFFFFFFFFFFFFFFF F0CEF0DFE00E88E0
0x07CA38: FFFFFFFFFFFFFFFF E6FFA40AE6F11F02
0x07CA40: FFFFFFFFFFFFFFFF 881088F0E6FEB40A
0x07CA48: FFFFFFFFFFFFFFFF F0F1DAFAA8470806
0x07CA50: FFFFFFFFFFFFFFFF DB00E00348E02D07
0x07CA58: FFFFFFFFFFFFFFFF F02EBB0A60212D02
0x07CA60: FFFFFFFFFFFFFFFF E0130D01E0238830
0x07CA68: FFFFFFFFFFFFFFFF DAFA3A2B0802DB00
0x07CA70: FFFFFFFFFFFFFFFF E01128214C12D740
0x07CA78: FFFFFFFFFFFFFFFF 4200F2F23C3FCB00
0x07CA80: FFFFFFFFFFFFFFFF 88C088D0DAFAE42B
0x07CA88: FFFFFFFFFFFFFFFF F024BBF25021D740
0x07CA90: FFFFFFFFFFFFFFFF 4200F6F23C3F98D0
0x07CA98: FFFFFFFFFFFFFFFF 98C0E6FE1100E00F
0x07CAA0: FFFFFFFFFFFFFFFF FAFADC3500000000
0x07CAA8: FFFFFFFFFFFFFFFF 65000C00243A1602
0x07CAB0: FFFFFFFFFFFFFFFF 1A0CFF7F00000000
0x07CAB8: FFFFFFFFFFFFFFFF 0000000000000000
0x07CAC0: FFFFFFFFFFFFFFFF 0000000008091A02
0x07CAC8: FFFFFFFFFFFFFFFF FE081A0281020000
0x07CAD0: FFFFFFFFFFFFFFFF 52CA870004384400
0x07CAD8: FFFFFFFFFFFFFFFF 4439440011008002
0x07CAE0: FFFFFFFFFFFFFFFF 0000220322032203
0x07CAE8: FFFFFFFFFFFFFFFF 2203220322032203
0x07CAF0: FFFFFFFFFFFFFFFF 220322032B02A304
0x07CAF8: FFFFFFFFFFFFFFFF 3800B60285032E01
0x07CB00: FFFFFFFFFFFFFFFF AA06EF04FFFFFFFF
Old 12-16-2003, 01:53   #37 (permalink)
Member: 46164
FLS. Flash SMS Directly from the Phone (vs Unicode)
;*** FLS. Flash SMS Directly from the Phone ***
;Author : RizaPN,$Lava
;Release : December 15, 2003
;Updated : December 17, 2003 (v3.1)
;Give a possibility to send a Flash SMS directly from the phone
;Add 1 space in the beginning of the message to send it as a flash
;SMS, otherwise it will send as a normal ones.
;Added Unicode support and possibility to change "Flash" symbol
0x4904A6: E6FCFA39 DA87D0CB
0x07CBD0: FFFFFFFFFFFFFFFF E6F2F020D7505700
0x07CBD8: FFFFFFFFFFFFFFFF F3F34E39F3F24D39
0x07CBE0: FFFFFFFFFFFFFFFF 2D0241252D044135
0x07CBE8: FFFFFFFFFFFFFFFF 3D06E7F41800D740
0x07CBF0: FFFFFFFFFFFFFFFF 5700F7F43F39E6FC
0x07CBF8: FFFFFFFF FA39DB00
;change "Flash" symbol
;0x07CBD3: 20 21 ; '!'
;0x07CBD3: 20 23 ; '#'
;0x07CBD3: 20 24 ; '$'
;0x07CBD3: 20 25 ; '%'
;0x07CBD3: 20 3A ; ':'
;0x07CBD3: 20 3F ; '?'
Old 12-16-2003, 01:58   #38 (permalink)
Member: 46164
;*** RKL. RED Longpressed Key Light ***
;Author : RizaPN
;Enable illumination flag for RED longpressed key light when key
;is locked. After applying this patch, the light after pressing
;RED key when the key is locked, is only turn ON if the Illumination
;is enabled (normally, the light is always ON).
0x2CDF28: 9A09 0DF3
Old 12-16-2003, 02:04   #39 (permalink)
Member: 46164
;*** BLANK. Blank Screen when Keylocked ***
;Author : RizaPN
;Need 'RKL' patch ...
;Function is selectable from Setup->Application->Screensaver menu
;Display will be blanked if the key is locked,
;by long-pressing # button or by auto-keylock function.
;Dispaly will become normal if the key is unlocked,
;or call/message/appointment arrived, or RED button is
;long-pressed.
0x24FDEE: FACC82DF FA8734CC
0x57D41E: F3F2AF2E DA8710CC
0x07CC10: FFFFFFFFFFFFFFFF D7504500C2F40036
0x07CC18: FFFFFFFFFFFFFFFF F7F9003641892D05
0x07CC20: FFFFFFFFFFFFFFFF DACAC633C08CDACA
0x07CC28: FFFFFFFFFFFFFFFF 327DD7405B00F3F2
0x07CC30: FFFFFFFFFFFFFFFF AF2EDB00D7404200
0x07CC38: FFFFFFFFFFFFFFFF F3F83C3F9AF40850
0x07CC40: FFFFFFFFFFFFFFFF E00CDACA327DE014
0x07CC48: FFFFFFFFFFFFFFFF D7404500F7F80036
0x07CC50: FFFFFFFFFFFFFFFF FACC82DFFFFFFFFF
Old 12-16-2003, 16:11   #40 (permalink)
Member: 46590
in this patch I found bad adress:
;Author : RizaPN (corrected by CooKee)
0x27F556: 60 00
0x27F65F: 97 07
and now it works
Old 12-17-2003, 18:06   #41 (permalink)
Member: 30734
;** ANIMATED OPERATOR LOGO AND DIGITAL CLOCK **
;Corrected. It works well seems to be but some address are overlapped with other patches like:
;**NAM.Add New Application menu**, **FLS.FLASH SMS**, **BLANK.Blank screen when keylocked**, ;perhaps with more...
;Enjoy it!!.
;eaXier
;Firmware: S/ME45i 040315
;Version 0.3
;Modified: 11.12.03
;*** Original patch for SL45 (C) by RizaPN *****
; Adaptation for S/ME45i (C) by REDKIN
; Instructions:
; 1. Undo Other Animated Logo Patches (don't forget to UNDO pictures!).
; 2. Apply this patch to phone AND to prevoiusly downloaded fullflash (or
; download FF after applying this patch).
; 3. AFTER that change in SiemensPictureChange pictures 310-321 for
; digital clock and 320-333 for animated logo (or see comments below ).
; 4. Save patch in SPC. Open it in V_Klay. Delete unwanted CRC check. Apply it.
; 5. If Operator Logo is disabled - enable it!
; Menu-Setup-Phone-Display-Bitmap Viewer-Load.
; 6. Enjoy!
; COMMENTS:
; - Alpha version! Bugs may vary. Report to [email protected]
; - WARNING! DON'T INCREASE in SPC picture sizes (i mean this patch only)!!! Results
; could be realy bad.
; - You can use Pictures from original Patch for SL45. Try to look here:
; http://www.calver.cz/luke/index.htm
; OR you can use created by me .vkp file:
; http://dredkin.narod.ru/siemens/digclock/digits.rar
; and this animation:
; http://dredkin.narod.ru/siemens/digclock/globus.rar
; in this case, you can skip step 3 of instruction
;- your comments and bug reports on e-mail above are very appreciated.
;- See patch customization below.
005610A6: DACBF86E DA8700CB
005607E0: 46FC2300 DA8710CB
0055C8F8: D7405B00F2F65224 DA8724CBCC00CC00
00565096: DAC40AFE DA872ECB
0007CB00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E016D7405B00F7FC8A1FDACBF86EDB00
0007CB10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48C1FD05E004D7405B00F7F88A1F46FC
0007CB20: FFFFFFFF 2300DB00
0007CB24: FFFFFFFFFFFFFFFFFFFF D7405B00F2F652240DF3
0007CB2E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC40AFEF094E01448902D02DAF4F400
0007CB3E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D010D02BB040D01BB1EF049DB00
0007CB4E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405B00F3F48A1F49402D15D7405B00
0007CB5E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE881F08E146FE0A008D01E00ED740
0007CB6E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5B00F6FE881F06FE4201E6FC0000E6FD
0007CB7E: FFFFFFFFFFFFFFFF 0900DAC89C43CB00
0007CB86: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405B00F3F88A1F2D33E00CE0BEBB27
0007CB96: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7503C00F2F1503DF2F24E3D8820
0007CBA6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB28E6FEFFFFD7405B0054FE881FDD03
0007CBB6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FC0D000D04E0AEBB1226FC09009810
0007CBC6: FFFFFFFF BB01CB00
0007CBCA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE
0007CBDA: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00
0007CBE4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE3601E09DDAC89C4398C006FC
0007CBF4: FFFFFFFF 1600CB00
0007CBF8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE
0007CC08: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFE48E02D02BBEA0D0206FC160098E0
0007CC18: FFFFFFFF BBE5CB00
; Changes in picture table (pictures itself come separately):
000DE8E0: 21230100D62735021C1D010085283502 162F0100AC282902162F010039292902
000DE8F0: 1B1F0100F92835021B28010075293502 162F0100C6292902162F0100532A2902
000DE900: 15270100152A35021A2701008A2A3502 162F0100E02A2902162F01006D2B2902
000DE910: 17230100262B3502182601008F2B3502 162F0100FA2B2902162F0100872C2902
000DE920: 15270100012C350215210100762C3502 162F0100142D2902162F0100A12D2902
000DE930: 1A280100D92C350213280100792D3502 0D2F01002E2E2902652F01008C2E2902
000DE940: 16260100F12D350228160100632E3502 652E010050112902652E0100A6132902
000DE950: 15270100D12E35021B250100462F3502 652E0100FC152902652E010052182902
000DE960: 18230100DA2F35021326010043303502 652E0100A81A2902652E0100FE1C2902
000DE970: 1B220100B53035021D2101003D313502 652E0100541F2902652E0100AA212902
000DE980: 23200100C13135021723010061323502 652E010000242902652E010056262902
; Patch Customizaton
; 0007CB66: 0A 0X ; X - number of frames in animation. Max. 10 frames.
; 0007CB41: 01 XX ;What is drawn when keys are UNLOCKED:
; 04 - Default Logo
; 03 - Digital Clock
; 01 - Animated Logo
; 0007CB43: 02 XX ;What is drawn when keys are LOCKED:
; 03 - Default Logo
; 02 - Digital Clock
; 00 - Animated Logo
Old 12-18-2003, 09:53   #42 (permalink)
Member: 9891
Thanks Meter: 2
;*** CLST. Call List via GREEN button (SME45) ***
;Author : RizaPN
;Release : December 18, 2003
;Use GREEN button to access ALL Call List.
;1st access will go to Calls Dialled,
;2nd will go to Calls Received, and the last for Call Missed.
0x5609B8: DAF8220D DA87B0CD
0x07CDB0: FFFFFFFFFFFFFFFF D7404400F3F2FE37
0x07CDB8: FFFFFFFFFFFFFFFF 092149238D01E102
0x07CDC0: FFFFFFFFFFFFFFFF D7404400F7F2FE37
0x07CDC8: FFFFFFFFFFFFFFFF 3D02FAF8D20D4921
0x07CDD0: FFFFFFFFFFFFFFFF 3D02FAF8020DFAF8
0x07CDD8: FFFFFFFFFFFFFFFF 260DFFFFFFFFFFFF
RizaPN, Jakarta - Indonesia
Old 12-18-2003, 09:58   #43 (permalink)
Member: 9891
Thanks Meter: 2
;*** MSC. More Shortcut ***
;Author : RizaPN
;Release : December 16, 2003
;Get 12 more fixed shortcut (button 0-9,*,# followed by LeftSoftKey)
;Assign your favourites function to them, and you can use
;all button for phone numbers shortcut ...
0x55DA78: DA8770CC
0x27F966: DA8714CD
0x07CC70: FFFFFFFFFFFFFFFF 46FF0B003D1AF04C
0x07CC78: FFFFFFFFFFFFFFFF D7404400F3F4FF37
0x07CC80: FFFFFFFFFFFFFFFF 48413D0249402D06
0x07CC88: FFFFFFFFFFFFFFFF 2841D7404400F7F8
0x07CC90: FFFFFFFFFFFFFFFF FF370D0BBB0B0822
0x07CC98: FFFFFFFFFFFFFFFF E005D7601F0299A2
0x07CCA0: FFFFFFFFFFFFFFFF 9992A982DAE2FAFF
0x07CCA8: FFFFFFFFFFFFFFFF E00CDB00D7405B00
0x07CCB0: FFFFFFFFFFFFFFFF F3F45B2427F43000
0x07CCB8: FFFFFFFFFFFFFFFF 9D0509463D02E1A4
0x07CCC0: FFFFFFFFFFFFFFFF 0D01E1B447F40B00
0x07CCC8: FFFFFFFFFFFFFFFF EDFCC042F0125C21
0x07CCD0: FFFFFFFFFFFFFFFF 002106F2D80CCB00
;Modify this list as you like.
;The first 2 byte is text code for LeftSoftKey
;and the last 3 byte is function entry-point
;Example: 01EC is "Calc.", and F65D38 is its entry-point
0x07CCD8: FFFFFFFFFF 01ECF65D38 ; 0.Calendar
0x07CCDD: FFFFFFFFFF 00A5E994CA ; 1.Inbox
0x07CCE2: FFFFFFFFFF 01ADE99466 ; 2.SMS
0x07CCE7: FFFFFFFFFF 0057E99508 ; 3.Outbox
0x07CCEC: FFFFFFFFFF 02F1E99548 ; 4.Archive
0x07CCF1: FFFFFFFFFF 0097E99624 ; 5.New email
0x07CCF6: FFFFFFFFFF 04DAF65EAA ; 6.Notes
0x07CCFB: FFFFFFFFFF 01FEF65D50 ; 7.Appointment
0x07CD00: FFFFFFFFFF 0109F65D44 ; 8.Calendar
0x07CD05: FFFFFFFFFF 0287F65DAA ; 9.Internet
0x07CD0A: FFFFFFFFFF 01BFF65D1C ; *.Games
0x07CD0F: FFFFFFFFFF 0447F65D64 ; #.Explorer
0x07CD14: FFFFFFFF 48603D13
0x07CD18: FFFFFFFFFFFFFFFF 46FC2A013D10D740
0x07CD20: FFFFFFFFFFFFFFFF 5B00F3F45C243D0B
0x07CD28: FFFFFFFFFFFFFFFF D7404400F3F4FF37
0x07CD30: FFFFFFFFFFFFFFFF 3D06BBBCD7501F02
0x07CD38: FFFFFFFFFFFFFFFF 9932A922F0C14861
0x07CD40: FFFFFFFFFFFFFFFF 3D0946FC42013D06
0x07CD48: FFFFFFFFFFFFFFFF E7F4FF00D7405B00
0x07CD50: FFFFFFFFFFFFFFFF F7F45C24F0D65C2D
0x07CD58: FFFFFFFFFFFFFFFF DB00FFFFFFFFFFFF
Old 12-18-2003, 09:59   #44 (permalink)
Member: 9891
Thanks Meter: 2
;*** VIS. Vibra Toggle Shortcut ***
;Author : RizaPN
;Update : December 17, 2003
;Use '#' followed by RightSoftKey to become a Vibra Toggle
;If you want to use another button, just use 87CD80 as a
;Vibra toggle function entry-point ...
0x5645E8: AA 9A
0x5648A8: DAF17684 DA8780CD
0x07CD80: FFFFFFFFFFFFFFFF DAF7A6D4E6FC1000
0x07CD88: FFFFFFFFFFFFFFFF E6FEF70048402D04
0x07CD90: FFFFFFFFFFFFFFFF E6FDCCD4FAC66014
0x07CD98: FFFFFFFFFFFFFFFF E6FDBAD4FAC61814
Old 12-18-2003, 10:00   #45 (permalink)
Member: 9891
Thanks Meter: 2
;*** VIN. Vibra Indicator ***
;Author : RizaPN
;Modify an unknown indicator (hope it is not used in a "normal"
;phone usage) to become a Vibra ones.
0x565012: DAC5B401 DAF7A6D4
;Vibra image sample (image is taken from SL45 thread)
0x0D94FD: 807F9F 010000
0x0D9500: 408D5F4D76BF5175 25E4804912402514
0x0D9508: 3F5376BF238D5F 8049B240255480
0x0D9510: 7F9F E000
S/ME45i-v04: Flash Patching ... rizapn x4x, x5x Flashpatching 1282 07-05-2015 12:16
821sc flash patch cid3 dead after flash cetech Z3X-Team Products 26 07-17-2009 12:12
L760 flashing patched flash problem Steph NSPRO 4 12-05-2008 10:04
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Need flash patched with Spanish lang for Neptune ! Kilowat Mitsubishi 4 05-21-2002 07:24
Page generated in 0.47855 seconds with 9 queries
