05-28-2003, 20:10 | #197 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | no much time today to fix animated operator logo but some little patch for you ;*** profile selection standard cursor position*** ;Firmware : S/ME45i-v04 ;Author : ACiD [mrp] ;homepage: www.gsm-dev.com 58BB16: 3D02 CC00 58BB18: E00C E0?C ;replace '?' with 0..7 to select standard cursor pos |
05-29-2003, 10:58 | #198 (permalink) |
Major Poster Join Date: Feb 2003 Location: Zgorzelec / Lower Silesia / Poland Age: 45
Member: 22810 Status: Offline Thanks Meter: 0 | hey! how works gfx menu for you? i still have problems withs this duck and bithday cake, and phone hangs. and acid, can you write what that last pach does? i dont understand what is 'standard cursor profile selection' ((( ps. acid, you are the best )) greets, Petec |
05-29-2003, 12:18 | #199 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | RizaPN is the best without him all this would not exist. gfx menu has the same bug here if you want to select an new profile normaly, the cursor is on the selected profile item, with this path you can set the curset per default on you favorit profile. this evening i have an new patch for you, "show selected profil" this will show the selected profile on main screen. You can begin to draw some 32*8 sized pictures for each profile (1..7) |
05-29-2003, 13:01 | #200 (permalink) | |
Member: 22810 Status: Offline Thanks Meter: 0 | Quote:
and of course, RizaPN is the bestest )) greets, Petec | |
05-29-2003, 17:46 | #201 (permalink) |
Freak Poster Join Date: May 2003 Location: Athens, Greece
Member: 29130 Status: Offline Thanks Meter: 5 | Help on "show icon for incoming call" Hi, I need some HELP regarding the patch : *** Show an icon "home/office/mobile" on incoming call *** ( @skylord I think ) Very usefull patch, and I applied it correctly . No problems ! BUT what the author failed to mention is that for the nice icons, some fonts have been replaced .... You may don't know that the fonts that have replaced are for 4 GREEK capital letters ! And it happens for me to be Greek ! ..... So, I need urgently HELP. I like the patch and I need it . I must change the addresses where the icons have been placed... Probably those at 0B4xxx 0B9xxx and 07Axxx (?)... Unfortunately 'ffmod' doesn't show addresses for individual fonts. I need therefore some suggestions. Probably if all Unicode chars are implemented I will find some unused for me place. More IMPORTANT I need to know what must I change inside the code part of the patch to refer to the new addresses where I have to put the icons. I didn't had any similar problem for the SL45i case applying the same titled patch. Please help ! Last edited by dspmobile; 05-29-2003 at 17:56. |
05-29-2003, 21:25 | #202 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | ;*** show profile logo on main screen ;Firmware : S/ME45i-v04 ;Author : ACiD [mrp] ;homepage: www.gsm-dev.com ;uses picture 296..302 resolution 32*8 5CFFD8: FFFFFFFF DAC89C43 5CFFDC: FFFFFFFF DACC3466 5CFFE0: FFFFFFFF DAC60817 5CFFE4: FFFF C08C 5CFFE6: FFFF F0EC 5CFFE8: FFFFFFFF E6FC2701 5CFFEC: FFFF 00EC 5CFFEE: FFFF E00C 5CFFF0: FFFF E08D 5CFFF2: FFFFFFFF DAC89C43 5CFFF6: FFFF DB00 564FC0: DAC89C43 DAFCD8FF 0DE868: 1224 2008 0DE870: 1424 2008 0DE878: 1523 2008 0DE880: 1123 2008 0DE888: 1522 2008 0DE890: 1522 2008 0DE898: 1520 2008 |
05-29-2003, 23:32 | #203 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Italy - Rome Age: 45
Member: 26549 Status: Offline Thanks Meter: 1 | nice ACiD !! but why the image that is overlapped to the Operator logo is always 35*20 or 36*21....and not 32*8 ?? I think that the SW doesn't know taht now the images are 32*8, there are another hex values to change...what do you think ?? |
05-30-2003, 09:01 | #204 (permalink) |
Member: 15315 Status: Offline Thanks Meter: 1 | sorry, i don't know what you mean... you can change resolution of profile-logo by changing this values: 0DE868: 1224 2008 0DE870: 1424 2008 0DE878: 1523 2008 0DE880: 1123 2008 0DE888: 1522 2008 0DE890: 1522 2008 0DE898: 1520 2008 but remember not to make them to big so they don't get overlapped. If you want to make them much bigger you haver to change adress of picture. x/y pos can be changed here: 5CFFEE: FFFF E0xC 5CFFF0: FFFF E0yD |
05-30-2003, 15:06 | #205 (permalink) | |
in fact, 32*8 is to little for draw smthg sensible. acid - is ithat possibility to see profile logo in the place of operator logo with logo operator 's resolution? or Acid or someone else- maybe d'you nice profile pics in 32*8 resolution? greets, Petec | |
05-30-2003, 15:40 | #206 (permalink) |
Member: 29130 Status: Offline Thanks Meter: 5 | To @Skylord or @ChaOS or anybody who can help ... Regarding my previous post about : *** Show an icon "home/office/mobile" on incoming call *** patch Which part of the code at 07Cxxx are the addresses of the icons, in order to be modified ? For me , I first reverted back the 07Axxx part of the patch ( not the 07Cxxx part ) and I didn't notice any change .... Icons still showing on incoming calls and had replaced 4 Greek capital letters. Second I reverted back the 0B4xxx & 0B9xxx parts and at last Icons changed back to the missing characters ! How can I change the position of the Icons ? What is the use of 07Axxx part since it did not change anything by restoring only it ? Which tool should help me the better ? I tried to use "ffmod" , but I don't understand the 'addressing' when it operates in 'font' mode . At what address each font resides ? Besides for some fonts, especially Greek, the bottom part is missing. Maybe the font size is greater than assumed... Also pressing the 'back' arrow , it doesn't go back but still goes forward.... I really appreciate the work that has been done by the creators of these patches and also the tools for modification of flashes or flash updating etc. I am gratefull for that . But I need some help here... Although 'newbe' or Junior for the forum, I have some tech experience ! Thanks in advance, and please if you know something about , just post it ! Dimitrios Last edited by dspmobile; 05-30-2003 at 15:47. |
05-31-2003, 10:27 | #207 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Poland Age: 41
Member: 24439 Status: Offline Thanks Meter: 0 | @Acidmrp can you make patch just like for SL45. I think about Call minutes beep modification. This means: 0:50, 1:50, 2:50, etc.. It will be very usefull patch |
05-31-2003, 12:39 | #208 (permalink) |
Junior Member Join Date: Apr 2003 Location: Italy Age: 44
Member: 26307 Status: Offline Thanks Meter: 0 | How to change the icons Few time ago i've made and published a patch in the italian siemens forum in order to change the icons home/fax/cell/office.. you have to change the fonts and the addresses are: 07A228: 000D3FF04CE852E8520852A8520852A8520852A84C083FF0 000c000007000f801fc03fe07ff020202ba022a022a07ff0 0b4739: 000D3FF04CE852E8520852A8520852A8520852A84C083FF0 000c000007000f801fc03fe07ff020202ba022a022a07ff0 0b94FE: 000D3FF04CE852E8520852A8520852A8520852A84C083FF0 000c000007000f801fc03fe07ff020202ba022a022a07ff0 07a2cd: 000d0ff80808155020207ff87ff8492849287ff83ff00000 000c000007000f801fc038e070702da02da0202020207ff0 0b47b6: 000d0ff80808155020207ff87ff8492849287ff83ff00000 000c000007000f801fc038e070702da02da0202020207ff0 0b957b: 000d0ff80808155020207ff87ff8492849287ff83ff00000 000c000007000f801fc038e070702da02da0202020207ff0 07a393: 000d00000fc0303047884848333014a0249023103ff00000 000930003f0061805e8052804c8040804c80408061803f00 0b484c: 000d00000fc0303047884848333014a0249023103ff00000 000930003f0061805e8052804c8040804c80408061803f00 0b9611: 000d00000fc0303047884848333014a0249023103ff00000 000930003f0061805e8052804c8040804c80408061803f00 07a372: 000A0C000F80174018C0174010401AC010401AC010400F80 000830003e0041005d0063005d0041005500490041003e00 0b4833: 000A0C000F80174018C0174010401AC010401AC010400F80 000830003e0041005d0063005d0041005500490041003e00 0b95f8: 000A0C000F80174018C0174010401AC010401AC010400F80 000830003e0041005d0063005d0041005500490041003e00 these are my images, but you can change them calculating the hex code with flash fonter 4.. Bye |
06-01-2003, 14:10 | #209 (permalink) |
Member: 29130 Status: Offline Thanks Meter: 5 | Icons for fonts in incoming calls To @Kite Thanks for your answer for "Icons on incomming calls". The way you formatted addresses and byte contents for icons helps me understand what it does... It is the same byte content 3 times and since it subsitutes fonts for characters , it goes for normal, bold, and small font for the same character each time. Of course the initial character is substituted by an Icon. You just have changed the icons in the original posted patch. Am I right ? BUT my problem is that at these locations ( addresses ) the 4 Greek capital letters reside... ( for lg4 pack i.e. Mediterinean ). I do not want to design new icons ... These letters are : "capital XI" at unicode code 03 9E, "capital SIGMA" at 03 A3 , "capital PSI" at code 03 A8 and "capital OMEGA" at 03 A9. Your 1st block represents my first mentioned char and so on. The real need of mine is to to put these icons in another place in order not to loose these characters needed in my language - Greek. So I need to know where in the code part of the patch refers to these addresses 07Axxx, 0B4xxx, 0B9xxx. I also need to relate Addresses in Flash memory with Unicode hex values representing characters in order to find new locations . There are "empty" places like the one for Unicode 03 A2 ( not assigned ) or 03 CF ( also not assigned ). I might also find some place in the Cyrillic area - unicode 04 xx - which is of no use for me , as it was Greek area for Russians. Using "ffmod" I can see some "empty" locations but I can't relate them to addresses in Flash memory. Besides it is a beta with problems in the 'font' part although quite usefull for images and ringtones. Any ideas ? Last edited by dspmobile; 06-02-2003 at 07:52. |
06-01-2003, 22:58 | #210 (permalink) |
Member: 26307 Status: Offline Thanks Meter: 0 | if you give me a flash of your greek s45i i can try to help you. Send it to me: [email protected] |
S/Me45i-v04: Flash Patches | patch_me | x4x, x5x Flashpatching | 329 | 05-30-2010 10:49 |
821sc flash patch cid3 dead after flash | cetech | Z3X-Team Products | 26 | 07-17-2009 12:12 |
L760 flashing patched flash problem | Steph | NSPRO | 4 | 12-05-2008 11:04 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Need flash patched with Spanish lang for Neptune ! | Kilowat | Mitsubishi | 4 | 05-21-2002 07:24 |
