S55 Flash Patching maybe some mod can make this sticky... http://www.gsm-dev.de/S55ProfilLogo.gif *** Profil Logo on MainScreen *** ;Firmware : S55 v20 ;Author : ACiD [mrp] ;Homepage: www.gsm-dev.com ; uses pictures 286 to 292 (old SMS Pictures) ; sample pictures included 32CC2E: DA7216C3 DA7BF88F ; call refresh Profil Logo 3B8FF8: FFFFFFFF DA7216C3 ; call PicturePaint (Akku Symbol malen) 3B8FFC: FFFFFFFF DA927CA5 ; call GetSelectedProfile 3B9000: FFFF C08C ; movbz r12, rl4 ;hier steht jetzt die Profilnummer in r12 3B9002: FFFF F0EC ; mov r14,r12 3B9004: FFFFFFFF E6FC1E01 ;mov r12, #100 3B9008: FFFF 00EC ;add r14, r12 3B900A: FFFF E00C ;mov r12, #0 (xPos) 3B900C: FFFF E08D ;mov r13, #8 (yPos) 3B900E: FFFFFFFF DA7216C3 ; call PicturePaint (Akku Symbol malen) 3B9012: FFFF DB00 ;rets ; ##### Picture 286 ##### ; Picture Table Index 0CC8F0: 32140100 20080100 ; Picture Data 08FF20: 7FFFE403FFF7FF6EBF9000FFFFFF7DDF 00000000C8000080C8000080A99BCC80 08FF30: 20207F5FFF7FFE40203EEFBF7DDF00A8 AA52A2809A52AA809992A68000000000 ; ##### Picture 287 ##### ; Picture Table Index 0CC8F8: 32140100 20080100 ; Picture Data 093F20: 00008002403D3F3C012104C0663F0201 00000000808000008000000084990000 093F30: 934000473F1D003026C1E33F3301B366 8AA28000888A0000E6B1800000000000 ; ##### Picture 288 ##### ; Picture Table Index 0CC900: 32140100 20080100 ; Picture Data 097F20: 7FC0FC07E07FFF4061FE0FF0C07F4037 0000000080000000800800008CAC0000 097F30: FFBF79807F7E1FCFBCFF0FFF200F9FF9 82A800008AA80000E664000000000000 ; ##### Picture 289 ##### ; Picture Table Index 0CC908: 31130100 20080100 ; Picture Data 09BF20: 00A803F003807F00A80FFC07807F00A8 00000000700128008801420083318B00 09BF30: 3E0F07807F00A87C0F83807F00F87CC7 80A18A008AA14A0071A1290000000000 ; ##### Picture 290 ##### ; Picture Table Index 0CC910: 31130100 20080100 ; Picture Data 09FF20: FE0203F00807FFFF838E1C101FFFFFC0 000000009000800090008020F2639930 09FF30: 9806607FFFFFE0100200FFFFFFF83003 9514A2A094548A209333B19000000000 ; ##### Picture 291 ##### ; Picture Table Index 0CC918: 31130100 20080100 ; Picture Data 0A3F20: BFD7FFFFFFFF7FFEEFFFFFFBFFFFFFD7 0000000060A800009428000046A90000 0A3F30: 8FE3FFAFFFFFFE0380FFDFFFAFFC0000 24AA800094AA000062A9800000000000 ; ##### Picture 292 ##### ; Picture Table Index 0CC920: 31130100 20080100 ; Picture Data 0A7F60: 00000FFFC7C07F3478000007607F20FE 0000000082008000820080005446A4C0 0A7F70: 1FF80FC07F1FFE00003F807F39D78780 54A8CA802888A8802866A68000000000 |
;*** Handsfree mode on Left_Key *** ;Firmware : S55 v20 ;Author : ACiD [mrp] ;Homepage: www.gsm-dev.com 32499C: DA7106B8 DA7134F5 ; call UserPoz on LeftKey press once -> handsfree on press twice -> handsfree off ... |
Handsfreemode before call http://www.gsm-dev.de/Patches/S55HandsFreePatch.gif ;*** activate handsfree mode befor doing by left key call version 2 *** ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com ; if you do not have an profil logo you need to read the comments. ; Source Code included. download vkp |
Handsfreemode before call ;*** Using LEFT_SIDE_DOWN-key for Handsfreemode *** ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 1) first you need the ;*** activate handsfree mode befor doing by left key call version 2 *** patch 2) undo this line: 32499C: DA7106B8 DA7B4C90 3) apply this line: 324A06: DC5C9887A897DC49 DA7134F5FA72804E |
; allow only "112" in keylocked mod (not 98 and 911): ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 2400DE: EA20 0D0F ; allow no keypress in keylock mode: ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 2400C2: EA20 0D1D |
this is an useless patch unless you don't want to make own patches. If you want to make own patches you my need to turn off phone without saving EEPROM: *** Software Reset on Left_Key *** ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 32499C: DA7106B8 B748B7B7 ; srst (software reset) |
; Firmware : S55 v20 ; Author : original by RizaPN improved by Chaos, ; SiNgle, mamaich ported to S55 by ACiD [mrp] ; yeahhh team work ; Homepage: www.gsm-dev.com ;AT+CGSN ;Display IMEI, as usual ;AT+CGSN:page,offset ;Dump 128 bytes of memory starting at address page:offset ;AT+CGSN.page,offset,data ;Search data on the given page, starting from offset. Data is a ;hexadecimal string without spaces. Offset is in range 0...3FFF. ;AT+CGSN*page,offset,data ;Write data to memory (RAM) at address page:offset. Data is a hexadecimal ;string without spaces. ;AT+CGSN@seg,offset ;Inter-segment call to address seg:offset. On return, values of r14 and r15 ;will be displayed. Note that seg is the segment, not the page (eg. if you ;wrote procedure to 11:500, call it at 4:4500). Procedure should end with ;far return. No need to serve WD because S55 turns it off 001E42A2: 147EE000 549C6100 00219BBE: FFFFFFFFFFFFFFFF E004BB029DFECB00 00219BC6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49992827F230008D0C47F20A008D06 00219BD6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182 00219BE6: FFFFFFFFFFFF CB001F88CB00 00219BEC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182 00219BFC: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997 00219C0C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0 00219C1C: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDAE21203080698C0 00219C2C: FFFFFFFFFFFFFFFF 98F098E09850CB00 00219C34: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4 00219C44: FFFF CB00 00219C46: FFFFFFFF 998C7C44 00219C4A: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00 00219C54: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAE15ECDF084F095DC49993827F32A00 00219C64: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FAE0147EBBA9F0F4BBA7F0E44930 00219C74: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D2127F312002D18E6FD0D0A 00219C84: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC 00219C94: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D25 00219CA4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D23DC4FB98E08E10DFADA61F29C 00219CB4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBBFF0EFBBBD0D1926F04000F020BBC3 00219CC4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D03B98208210DFB2020A758A7A708E1 00219CD4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0AF010F0DEF0C2DC4F998D498D3DF5 00219CE4: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 28C13DFABBA506F04000FAE1C4C5 00219CF2: FFFFFFFFFFFF ECFFECFEDB00 |
; Disable Java verification ; Firmware : S55 v20 ; Author : original by ?Chaos?, ported to S55 by ACiD [mrp] ; Homepage: www.gsm-dev.com 5B4826: 3D 0D |
; deletes the "copy all entrys to addressbook question and the ; selection of default book on sim change or twin bill change ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com 8B2B06: DA927264 E6FC1000 ; mov r12, #10h 8B2B0A: 48403D04 DA730E87 ; calls HideSelectDefaultBook() 8B2B0E: DA92C29A FACB322B ; don't ask to copy bull**** |
; left_key for changing profile ; Firmware : S55 v20 ; Author : Braindead ; Homepage: www.hundkotzemaus.de 32499C: DA7106B8 DA73D022 ; call SelectProfileMenu ; left_key for flex_mem ; Firmware : S55 v20 ; Author : Braindead ; Homepage: www.hundkotzemaus.de 32499C: DA7106B8 DA74240C |
; change batt down sound into... ; Firmware : S55 v20 ; Author : RizaPN, ACiD [mrp] ; Homepage: www.gsm-dev.com ;4EFFD9: 3C 1C ; Tut 4EFFD9: 3C 0C ; ausschalten ;4EFFD9: 3C 4C ; klick (keypressed) |
; Yet another Profil Logo ; Provider Name -> Profil Logo ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com http://www.gsm-multifund.de/Moderato.../YAPL/YAPL.gif VKlay Patch Source Code |
; change style of locked softkey ; Firmware : S55 v20 ; Author : Braindead ; Homepage: www.hundkotzemaus.de ; Version 1: http://home.arcor.de/childofbodom/1.bmp 5CAF80: AA 00 ; Version 2: http://home.arcor.de/childofbodom/2.bmp 5CAF80: AA FF |
; shows the time instat of the provider name. ; Provider Name -> Time ; Firmware : S55 v20 ; Author : ACiD [mrp] ; Homepage: www.gsm-dev.com ; v2 should now work with any provider http://www.gsm-multifund.de/Moderato.../TimePatch.gif download vkp |
; Unhide Explorer Menu for Phone without SIM Card ; 108976: C404 5E05 ;--------------------- But there is a little problem if you use Option "Sent via ... " when you are without SIM card. It switches off the phone ! |
