Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-26-2004, 12:31   #136 (permalink)
GIROSAVO's Avatar
Member: 26549
Originally Posted by El Unix
;***Remove acustic shock protection*** © Sinclair, § kay, zzt121, (R) LeLLik
;Comment the unneded
172D8E: 2E 2D ;incoming
172D96: 45 44 ;family
172D9E: 47 46 ;friends
172DA6: 49 48 ;study
172DAE: 4B 4A ;vip
172DB6: 4D 4C ;leisure
172DBC: 4F 4E ;pivate
172DC2: 51 50 ;work
172DC8: 53 52 ;Recieved
172DD4: 32 33 ;reminders
172DDA: 34 33 ;alarm
;172DEC: 37 36 ;sms (doesn't cut off)
172DF2: 39 38 ;inf. services
172DF8: 57 52 ;turn on (doesn't cut off)
172DFE: 59 15 ;turn off
172E14: E06D 0DF3 ;other calls
This is for M55 v10 and not for S55 !!! Why is it here ????
There is a problem, when I call, the ringtone that I have selected is not personal, but it is that default and when I stop the call, the phone still ringing in loop !
; © Sinclair, § kay, zzt121, ® LeLLik
; S55V20
; (p) Giro
; Luki's Siemens Modding Forum
27F214: 2E 2D ;incoming
27F21C: 45 44 ;family
27F224: 47 46 ;friends
27F22C: 49 48 ;study
27F232: 4B 4A ;vip
27F238: 4D 4C ;leisure
27F23E: 4F 4E ;private
27F244: 51 50 ;work
27F24A: 53 52 ;received
27F256: 32 33 ;reminders
27F25C: 34 33 ;alarm
;27F26E: 37 36 ;sms (doesn't cut off)
27F274: 39 38 ;inf. services
27F27A: 57 52 ;turn on (doesn't cut off)
27F280: 59 15 ;turn off
27F28A: E06D 0DF3 ;other calls
; S55V91
; (p) Giro
27F22E: 2E 2D ;incoming
27F236: 45 44 ;family
27F23E: 47 46 ;friends
27F246: 49 48 ;study
27F24C: 4B 4A ;vip
27F252: 4D 4C ;leisure
27F258: 4F 4E ;private
27F25E: 51 50 ;work
27F264: 53 52 ;received
27F270: 32 33 ;reminders
27F276: 34 33 ;alarm
;27F288: 37 36 ;sms (doesn't cut off)
27F28E: 39 38 ;inf. services
27F294: 57 52 ;turn on (doesn't cut off)
27F29A: 59 15 ;turn off
27F2A4: E06D 0DF3 ;other calls
Best Regards to authors
Old 01-13-2005, 04:03   #137 (permalink)
Member: 104959
Midlets can Send SMS silently
;By MartiM
; ENGLISH:
; Desactivate all the warnings when a Midlet tries to send an SMS.
; It is useful when you want for instance that the Midlet SecureSMS could send the SMS to you without
; warning the threaf about it.
; CATALAN:
; Parche per desactivar les alertes que fan els Midlets Java quan proven
; d'enviar un SMS o connectar internet.
; Així els Midlets Java poden enviar SMS d'amagat de l'usuari.
; Serveix perque per exemple el Midlet SecureSMS pugui enviar un SMS
; sense demanar confirmació al lladre del telefon.
; more info: www.iespana.es/mminbcn/
59D320: 2D04 CC00
Old 01-22-2005, 01:01   #138 (permalink)
zdob's Avatar
Member: 2911
Thanks Meter: 3
[GLOW=red]This is topic for patch only. Other reply 'll be deleted. Use other topics for discussing.. [/GLOW]
Thread for discussing:
The list of the members which are not respecting the authors:
Old 02-01-2005, 09:37   #139 (permalink)
GIROSAVO's Avatar
Member: 26549
;***Auto-Answer with (no Siemens) BT Headset***
;Firmware: S55v20
;Authors: lalo & Giro
;Released: 26/01/05
;This patch allow the auto-answer, with no Siemens BlueTooth Headset, after 7 seconds.
;Need flag for auto-answer in Setup->Accessories->Headset.
;No need to set Headset profile, only connect and pair your BT Headset to phone.
329984: E6F88806 DA7B6098
3B9860: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01CDA82D0EE48443D1BE01CDA701850
3B9870: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48443D16DA92B06148402D12E6FCA698
3B9880: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD7B0088D088C0E00E88E0E6FC9E04
3B9890: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D00E6FED606E00FDAD16CF10806
3B98A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F88806DB00DA63B29DDA7180F5DB00
;Customization
;change XXYY if you want auto-answer after:
;A60E = 15sec.
;C409 = 10sec.
;D606 = 7sec.
;E204 = 5sec.
;3B9896: D606 XXYY ;XXYY = time delay in ms/0,25 swapped byte(s)
Old 06-06-2005, 23:29   #140 (permalink)
misko903's Avatar
Member: 89407
;*** Change light off speed ***
;Firmware: S55_v91
;Author: (C) ValeraVi, (P) Antoine[KNet] www.beinspired.cz
;Release: 2004-02-02
;Version: 2
61736E: CC E0
61736F: 00 0F ;yF, y-lower tetrade of LOBYTE of HIWORD of delay
617392: E06E E6FE
617395: 0F 00 ;HIBYTE of LOWORD of delay
617394: E0 18
;At address 617394 - HEX number - delay before each step of decrease
; of illumination. Increase delay to decrease speed of illumination
; turn off.
; By default delay = 06. If you change to:
; 03 - illumination is turned off 2 times faster.
; 0C - illumination is turned off 2 times slower.
; 12 - 3 times slower.
; 18 - 4 times slower.
; and so on.
Old 06-06-2005, 23:40   #141 (permalink)
misko903's Avatar
Member: 89407
;*** Flex Memory (or other) on left key ***
; Firmware : S55 v91
; Author : (C) Braindead, (P) Antoine[KNet] www.beinspired.cz
; Homepage: www.hundkotzemaus.de
32499D: 7106B8 74240C ;or other entry from table.
;In the previous line write entry point gathered from Smelter (List-Menu-Entry)
;last 2 bytes must be swapped XXYYZZ -> XXZZYY
Old 06-06-2005, 23:41   #142 (permalink)
misko903's Avatar
Member: 89407
;*** ArrowUp key as "Durat./Charge -> Groups" or what you want ***
;Firmware: S55_v91
;Release: 2004-02-15
;Version: 2
; does not conflict with LongPress ArrowUp.
32472E: 46FD0E00 FAAB0000
6B0000: FFFFFFFFFFFFFFFF 46FD3B003D08DA72
6B0008: FFFFFFFFFFFFFF 4C59E00EE00FDA
6B0012: FFFFFFFFFFFF FA72A44E46FD
6B0018: FFFFFFFFFFFF 0E00FA723247
6B000F: FFFFFF 67BEA9 ;entry point - groups
Old 06-06-2005, 23:42   #143 (permalink)
misko903's Avatar
Member: 89407
;*** Long press of ArrowUp key as "Calendar" or what you want ***
;Firmware: S55_v91
;Release: 2004-02-14
;Version: 3
;Thnx to: SiNgle
;fixed hand's free bug
3249C6: DAE36810 DA724C59 ;prevent light off in function
3249CA: 48402D04E6 E00EE00FDA
3249D2: DA672E2B EA00A44E
3249CF: FC1900 672CAF ;entry point. of Calendar
Old 06-07-2005, 00:00   #144 (permalink)
misko903's Avatar
Member: 89407
; *** Improved Net Indicator ***
; (c) Chaos, converted to S55v20 by ACiD [mrp]
; Firmware: S55v91
; (i) dnn, Show 7 station (Current + 6 available) /06.05.2005
; if you use the vibra logo patch you have to do some changes:
; with vibra logo:
;32C5BA: DA7B1890 DA7B00B8
;3BB872: FFFFFFFF DA7B1890
; without vibra logo:
32C5BA: DA7216C3 DA7B00B8
3BB872: FFFFFFFF DA7216C3
; Show six (7) avialable Base Stations
; 900mhz - green
; 1800mhz - red
;Standard net indicator is changed to mini NetMonitor,
;shows actual gsm cell and 6 nearest
;900MHz indicated by green colour, 1800MHz - red
; in both cases:
; в обоих случаях:
3BB800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFE23EE00CD7400800D41F0600E103
3BB810: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 49202D1C47F2FF002D19E11347F26900
3BB820: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED15E12347F26100ED11E13347F25800
3BB830: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED0DE14347F25000ED09E15347F24400
3BB840: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED05E16347F23900ED01E173D7400800
3BB850: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A85F46F57D008D0207F30800C03E06FE
3BB860: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9B0146FEA1018D0226FE6700E00D88C0
3BB870: FFFF 88F0
3BB876: FFFFFFFFFFFFFFFFFFFF 98F098C048C00D0108C1
3BB880: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 08C406FF0C0046FF2A3FFDBDDB00
;(i)dnn value 6->7 BTS
;3BB888: 1E3F 2A3F ; 8:3F2A - ValueSotaGSMBand6 (8:3F1E - 5ая BTS)
;(i)dnn
;if is something wrong with pixels, apply next line
;3BB880: 08C4 08C3 ;add r12,3
; ##### Picture 314 #####
; Picture Table Index
0CC9D0: 1D090500 05090500
; Picture Data
0B3E23: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFF181818FFFF
0B3E33: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 181818FFFF181818FFFF181818FFFF18
0B3E43: 9898FF98989898FF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 315 #####
0CC9D8: 1D090500 05090500
; Picture Data
0B4000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFF181818FFFF181818FFFF
0B4010: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F 181818FFFF181818FFFF181818FFFF18
0B4020: 2F2FFF98989898FF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 316 #####
0CC9E0: 1D090500 05090500
; Picture Data
0B4105: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4115: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B4125: 2F2FFF2F2F2F2FFF98989898FF989898 FCFCFFFFFCFCFCFFFFFFFFFFFF0F0F0F
; ##### Picture 317 #####
0CC9E8: 1D090500 05090500
; Picture Data
0B420A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B421A: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B422A: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 FCFCFFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 318 #####
0CC9F0: 1D090500 05090500
; Picture Data
0B430F: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B431F: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFC8
0B432F: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 319 #####
0CC9F8: 1D090500 05090500
; Picture Data
0B4414: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4424: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFC8C8C8FFFFC8
0B4434: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 320 #####
0CCA00: 1D090500 05090500
; Picture Data
0B4519: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4529: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 FCFCFCFFFFC8C8C8FFFFC8C8C8FFFFC8
0B4539: 9898FF98989898FF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 321 #####
0CCA08: 1D090500 05090500
; Picture Data
0B461E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B462E: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B463E: 2F2FFF98989898FF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 322 #####
0CCA10: 1D090500 05090500
; Picture Data
0B4723: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFC8C8C8FFFF
0B4733: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B4743: 2F2FFF2F2F2F2FFF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 323 #####
0CCA18: 1D090500 05090500
; Picture Data
0B4828: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFC8C8C8FFFFC8C8C8FFFF
0B4838: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B4848: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 411 #####
0CCCD8: 1D090500 05090500
; Picture Data
0B86AE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B86BE: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B86CE: 9898FF98989898FF98989898FF989898 FCFCFFFFFCFCFCFFFFFFFFFFFF0F0F0F
; ##### Picture 412 #####
0CCCE0: 1D090500 05090500
; Picture Data
0B87B3: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B87C3: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B87D3: 2F2FFF98989898FF98989898FF989898 FCFCFFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 413 #####
0CCCE8: 1D090500 05090500
; Picture Data
0B88B8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B88C8: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFF18
0B88D8: 2F2FFF2F2F2F2FFF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 414 #####
0CCCF0: 1D090500 05090500
; Picture Data
0B89BD: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B89CD: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFF181818FFFF18
0B89DD: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 415 #####
0CCCF8: 1D090500 05090500
; Picture Data
0B8AC2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B8AD2: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFF181818FFFF181818FFFF18
0B8AE2: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 416 #####
0CCD00: 1D090500 05090500
; Picture Data
0B8BC7: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B8BD7: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F 181818FFFF181818FFFF181818FFFF18
0B8BE7: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F 1818FFFF181818FFFFFFFFFFFF0F0F0F
Old 06-10-2005, 18:53   #145 (permalink)
misko903's Avatar
Member: 89407
;*** Replacement of hyphens in the end of the CB-message blanks ***
;Firmware: S55v91
;© rreezzoo & Bo$s
;§ bo_dmtr
;override 20 with any desirable character hex value
;default - remove
1EAD41: 2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D2D 202020202020202020202020202020202020202020202020
Old 06-11-2005, 16:20   #146 (permalink)
misko903's Avatar
Member: 89407
;*** Hourly beep v2 ***
;S55v91
;(C) ACiD [mrp], SiNgle, RizaPN
;(m) @ 21A0C0 by avkiev
;(p) Antoine[KNet]
;you may choose sound from list at adress:
;http://www.vi-soft.com.ua/siemens/pa..._ringtones.vkp
31AB00: 98809890 DA61C0A0
#pragma enable old_equal_ff
21A0C0: 9880989088C0D7400D00F2FCBC4446FC
21A0D0: 0A00DD0CD7400300F2FC08C148C12D07
21A0E0: E6FC
21A0E2: 3A ; Sound from sound list
21A0E3: 00DAA484ADE01C9D01E00CD740
21A0F0: 0300F6FC08C198C0DB00
#pragma disable old_equal_ff
Old 06-11-2005, 21:41   #147 (permalink)
misko903's Avatar
Member: 89407
;*** Skined Soft Keys ***
;S55v91
;(c) Matr!x (M55v10)
;(p) ACiD[mrp] S55v20
;(p) Antoine[KNet] S55v91
; !In that archive you can find oval skin for soft-keys, background color is white.
; If you want to change background color use Paint + SPC (Picture 112)
; Choose one of variants - A, B or C
5CAB22: DA9CB8AE DA7B8090
3B9080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA9CB8AEE6FE7000E6FC3600E6FD4200
3B9090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA7216C3E6FE7000E6FC0000E6FD4200
3B90A0: FFFFFFFF FA7216C3
;Variant A
; ##### Picture 112 #####
0CC380: 65400500 2F0E0500
; Picture Data
058000: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE FFFF0000000000000000000000000000
058010: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
058020: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000FFFFFF
058030: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058040: DFDFDFDFDFDFDFDFDFDFDFDFDF9F9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058050: 9F9F9F9F9F9FDF9FFE9FFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C000FF00C0
058060: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058070: FEFEFEFEFEFEDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058080: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C00000C0C0
058090: DFDFDFDFDFDFDFDFFFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0580A0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0580B0: DFDFDFDFDFDFDFDFDFDFDFDFDFFEFEFE C0C0C0C0C0C0C0C0C0C0C00000C0C0C0
0580C0: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0580D0: FEFEFEFEFEFEFEFEFEFEFEFEFEFE9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0580E0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C00000C0C0C0C0
0580F0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058100: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058110: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C00000C0C0C0C0C0
058120: 9FDF9FFEFE9FFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058130: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058140: FEDFDFDF9FDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C00000C0C0C0C0C0C0
058150: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058160: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058170: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDF9F C0C0C0C0C0C0C00000C0C0C0C0C0C0C0
058180: 9F9F9F9F9F9F9F9F9FFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058190: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0581A0: FEFEFEFEFEFEDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C00000C0C0C0C0C0C0C0C0
0581B0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0581C0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0581D0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C00000C0C0C0C0C0C0C0C0C0
0581E0: DF9F9F9F9F9F9F9F9F9F9F9F9F9F9FFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
0581F0: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058200: FEFEFEFEFEFEFEFEFEFEFEDFDFDFDFDF C0C0C0C00000C0C0C0C0C0C0C0C0C0C0
058210: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058220: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058230: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C000FF00C0C0C0C0C0C0C0C0C0C0
058240: DFDFDFDFDFDFDF9F9F9F9F9F9F9F9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058250: 9F9F9FFEFEFEFEFEFEFEFEFEFEFEDEDE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058260: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C000FFFFFF0000000000000000000000
058270: FEDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
058280: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
058290: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF FFFF0F0F0F0F0F0F0F0F0F0F0F0F0F0F
;Variant B
;0CC380: 65400500 2F0E0500
; Picture Data
;058000: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE FFFF0000000000000000000000000000
;058010: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
;058020: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000FFFFFF
;058030: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058040: DFDFDFDFDFDFDFDFDFDFDFDFDF9F9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058050: 9F9F9F9F9F9FDF9FFE9FFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C000FF00C0
;058060: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058070: FEFEFEFEFEFEDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058080: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C00000C0C0
;058090: DFDFDFDFDFDFDFDFFFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0580A0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0580B0: DFDFDFDFDFDFDFDFDFDFDFDFDFFEFEFE C0C0C0C0C0C0C0C0C0C0C00000C0C0C0
;0580C0: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0580D0: FEFEFEFEFEFEFEFEFEFEFEFEFEFE9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0580E0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C00000C0C0C0C0
;0580F0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058100: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058110: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C00000C0C0C0C0C0
;058120: 9FDF9FFEFE9FFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058130: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058140: FEDFDFDF9FDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C00000C0C0C0C0C0C0
;058150: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058160: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058170: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDF9F C0C0C0C0C0C0C00000C0C0C0C0C0C0C0
;058180: 9F9F9F9F9F9F9F9F9FFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058190: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0581A0: FEFEFEFEFEFEDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C00000C0C0C0C0C0C0C0C0
;0581B0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0581C0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0581D0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C00000C0C0C0C0C0C0C0C0C0
;0581E0: DF9F9F9F9F9F9F9F9F9F9F9F9F9F9FFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;0581F0: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058200: FEFEFEFEFEFEFEFEFEFEFEDFDFDFDFDF C0C0C0C00000C0C0C0C0C0C0C0C0C0C0
;058210: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058220: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058230: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C00000C0C0C0C0C0C0C0C0C0C0C0
;058240: DFDFDFDFDFDFDF9F9F9F9F9F9F9F9F9F C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058250: 9F9F9FFEFEFEFEFEFEFEFEFEFEFEDEDE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
;058260: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C00000000000000000000000000000
;058270: FEDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
;058280: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
;058290: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000F0F0F0F0F0F0F0F0F0F0F0F0F0F
Old 06-11-2005, 21:42   #148 (permalink)
misko903's Avatar
Member: 89407
;S55v91
;Variant C
; Picture Data
058000: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE FF000000000000000000000000000000
058020: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 0000000000000000000000000000FF00
058030: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058050: 9F9F9F9F9F9FDF9FFE9FFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C00000C0
058260: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C000FF000000000000000000000000
058290: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00FF0F0F0F0F0F0F0F0F0F0F0F0F0F0F
Old 06-11-2005, 21:58   #149 (permalink)
misko903's Avatar
Member: 89407
*** Skined Soft Keys for Small Fonts ***
;S55v91
;(p) ACiD[mrp] S55v20, small fonts wlodixon
; Picture Data
058000: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058010: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058020: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058050: 9F9F9F9F9F9FDF9FFE9FFEFEFEFEFEFE C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0C0
058080: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C0C0C0C0C0DFDF00
058090: DFDFDFDFDFDFDFDFFFDFDFDFDFDFDFDF 00000000000000000000000000000000
0580A0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF 00000000000000000000000000000000
0580B0: DFDFDFDFDFDFDFDFDFDFDFDFDFFEFEFE 00000000000000000000DFDFDF00C0C0
0580E0: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C0C0C0C0C0C0C000DF00C0C0C0C0
058230: DFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF C0C0C000DF00C0C0C0C0C0C0C0C0C0C0
058260: FEFEFEFEFEFEFEFEFEFEFEFEFEFEFEFE C000DFDFDF0000000000000000000000
Old 06-12-2005, 00:01   #150 (permalink)
misko903's Avatar
Member: 89407
;*** Change fat figures in a calendar ***
;S55v91
;original patch by © Matr!x on M55 v10
;(p) Girosavo S55v20, Antoine[KNet] S55v91
;Luki's Siemens Modding Forum
13EEB: 386C6C6C6C6C38000618381818181818000630 FC84B4B4B484FC0006FCECCCECECECFC0006FC
13EFE: 68081830607800063058183018583000061C3C2C 84F484BC84FC0006FC84F484F484FC0006FCB4B4
13F12: 6C7C0C0C00067C6060780C0C780006386060786C 84F4F4FC0006FC84BC84F484FC0006FC84BC84B4
13F26: 6C3800067C0C18183030300006386C6C386C6C38 84FC0006FC84F4ECDCDCFC0006FC84B484B484FC
13F3C: 386C6C3C0C0C38 FC84B484F484FC
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 13:58
S55+blacklist patch KERKENNAH E-Gold Based Phones 1 12-19-2004 09:57
S55 Flash Patching :) Acidmrp E-Gold Based Phones 3 09-21-2003 20:55
S55 flashing 2% zoki E-Gold Based Phones 3 06-10-2003 23:07
S55 flashing zoki E-Gold Based Phones 4 03-31-2003 07:53
Page generated in 0.50164 seconds with 9 queries
