06-12-2005, 00:21 | #151 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Slovakia Age: 41
Member: 89407 Status: Offline Thanks Meter: 0 | ; not in "Hight" or "Low" *** ;S55v91 ;(c)avkiev, (p)Antoine[KNet] ;www.beinspired.cz 12C0D1: 5C 00 12C102: 5C 00 14FF05: 5C 00 14FF22: 5C 00 |
06-12-2005, 00:34 | #152 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Creating only High-photos, without Low-quality *** ;Firmware: S55v91 ;(c)avkiev, (p)Antoine[KNet] ;www.beinspired.cz ;Before this patch you must apply patch: ; "Pictures from foto camera will be placed in "Camera" folder, ; not in "Hight" or "Low"" 14FF2F: 58 00 |
06-13-2005, 14:24 | #153 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Disabled key names will be invisible *** ; Firmware : S55 v91 ; Author : Braindead ; Ported : Antoine[KNet] ; www.beinspired.cz 5CB034: AA FF |
06-13-2005, 14:26 | #154 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Disabled key names will be filled *** ; Firmware : S55 v91 ; Author : Braindead ; Ported : Antoine[KNet] ; www.beinspired.cz 5CB034: AA 00 |
06-14-2005, 20:12 | #155 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Disable message new SMS *** ; Firmware: S55v91 ; (c) $Lava, (p) Antoine[KNet] ; www.beinspired.cz 338560: E6FC3600 EA003E86 |
06-15-2005, 16:52 | #156 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Change "empty" to "function" in favourites *** ; Firmware: S55v91 ; (c)Girosavo, (p)Antoine[KNet] ; thank lalo.lerry - right SK ; www.beinspired.cz 129252: E104E104 190B190B ; text "Clean up" or another text ;in following line choose entry from smelter in format ZZYYXX: 129256: 40F072 D4CD67 ; Entry "Clean up" or another Entry 129286: 6901 1B0D ; text from "Set" to "Choose" |
06-15-2005, 17:40 | #157 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Modify 0 + Right SoftKey from "Select Line" to "Calendar" or other * ; Firmware: S55v91 ; Adapted by Girosavo ; Corrected Entry point Antoine[KNet] 32B172: 4840 E014 32B582: 4840 E004 32B198: 5202 FD0C ; ...Calendar Text (swapped Handle bytes from Smelter-YYXX) 32B57F: 621822 672CAF ; ...Calendar Entry ;In the previous line write entry point gathered from Smelter (List-Menu-Entry) ;last 2 bytes must be swapped XXYYZZ -> XXZZYY |
07-02-2005, 22:41 | #158 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** EKS. Eliminate Keylock Screen *** ;Firmware : S55 v91 ;Author : Lalo ;luki's Siemens Modding Forum ;Release : 29.06.05 - v1 ;Updated : 01.07.05 - v2 changed mechanism ;This patch eliminates "Keypad locked - press&hold # to release" screen when pressing any key. ;NOTE: ;1.It eliminates also emergency call if keylocked possibility ;2.Sometime screen refresh is a little bit slow after long pressing #, but keyboard is unlocked immediately. ;3.Conflict with "view missed calls..." ;Improuvement v2: ;now keylock screen never appears, even when # is pressed. 324E84: DC59D4C8 FA7BC090 3B90C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49D478020046F714003D0FF0C8F0D9 3B90D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08C4DC5DD49C0200A88CDC49D4780400 3B90E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F793012D02DA64EA4FFA72A44E Last edited by misko903; 07-02-2005 at 22:55. |
07-05-2005, 05:31 | #159 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | ;*** EKS. Eliminate Keylock Screen *** ;Firmware : S55 v91 ;Author : Lalo ;luki's Siemens Modding Forum ;Release : 29.06.05 - v1 ;Updated : 01.07.05 - v2 changed mechanism ;Updated : 05.07.05 - v2.1 fixed bug ;This patch eliminates "Keypad locked - press&hold # to release" screen when pressing any key. ;NOTE: It eliminates also emergency call if keylocked possibility. ;Improuvement v2.1: ;fixed screen refresh and insert digit screen bug 324E84: DC59D4C8 FA7BC090 3B90C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49D478020046F714003D0FF0C8F0D9 3B90D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08C4DC5DD49C0200A88CDC49D4780400 3B90E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F793012D05E01CDACF70A9DA64EA4F 3B90F0: FFFFFFFF FA72A44E ;CUSTOMIZATION: ;Change long pressing unlocking button: ;3B90C8: 14 xx ;14=# ;change xx with any button code value ;Enjoy it, Misko! ;© Lalo 2005 Luki's Siemens Modding Forum |
07-10-2005, 18:14 | #160 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Dynamic replacing of Provider name v7.2 *** ;adapted for S55v91 by Mich3L ;(c) avkiev ;bugfix Antoine[KNet] ;corrected values in 0,000 and 00mA, KeyLockState ;v7.2 added Null customization /* The name of the Provider is change to dynamic changed string. The Frequency of the renovation is a frequency of the questioning to network by telephone. 24 bytes in area 21A900-21A917 are three cyclic buffers, which define content of the screen. First buffer (21A900-21A907) defines strings when keyboard isn't locked. Second (21A908-21A90F) - if keyboard is locked. Third (21A910-21A917) - in screensaver mode. Replacing string consist of two parts, separated with Space. Example N1: (21A900) = 12h. It means, that ProviderName will changed with results of function N1 and function N2, separated with Space. In our example it will be "Time + Date". Because of next byte is 45h, then next string will be "Temperature + Akku" It's cycle, 8 times, after this cycle we again return to byte (21A900)=12h Example N2: if you want always "Time+Temperature" fill this area with 14h. If total length of string more than 16 (?) chars - string will be truncated (not in screensaver) Screenshots: http://avkiev.kiev.ua/Siemens/Patche...r/provider.htm Avaliable functions: +---+------------------+-----------+------+----------------------------------+ | N | Description | Format | Len |Comments | +---+------------------+-----------+------+----------------------------------+ | 0 | Null | | N/A |X0 displays only X (from X=0 to B)| | 1 | Time | 18:39 | 5 | | | 2 | Date, DayOfWeek | 17 May Mo | 6-10 | | | 3 | Day of week | Monday | 5-8 | | | 4 | Temperature | 25,7'C | 6 | | | 5 | Akkumulator | 3,812 10% | 9 | | | 6 | Current cuircut | 58mA | 4,5 | | | 7 | Provider | UA UMC | ? |Current provider | | 8 | Level of Signal | -65dB | 5,6 |"-" - 1800, "_" - 900 | | 9 | Net Info | 6502:531 | 8,9 |CI:CH - Current cell and channel | | A | Status | AGkSV9 | 6 |Alarm,GPRS,Keylock,Sound,Vibra,900| | B | Word in memory | 65535 | 4,5 |Monitor of word in memory | +---+------------------+-----------+------+----------------------------------+ All other - empty */ 31AAF0: F2FF02FE DA6118A9 ;Three cyclic 8-bytes buffers, adjust their #pragma disable warn_no_old_on_apply 21A900: FFFFFFFFFFFFFFFF 1245657812456578 ;Keyboard isn't locked 21A908: FFFFFFFFFFFFFFFF 9898989898989898 ;Keyboard is locked 21A910: FFFFFFFFFFFFFFFF 2020202020202020 ;Screensaver mode #pragma enable warn_no_old_on_apply #pragma enable old_equal_ff 21A918: 88508860887088C0 21A920: 88D088E0DA73123F98E088408840E6F5 21A930: 20C1A9D509D1B9D509A1BB10E7FF2000 21A940: B9F509A1BB0BE10DB9D598D098C09870 21A950: 98609850E6FE2101E03FDB00D7400300 21A960: F2F62001686706F6100098403D0926F6 21A970: 0800D7401000F2F7BC393D0226F60800 21A980: 06F60029D7408601A9C647FA21003D01 21A990: 7C4667FC0F0049C12D2149C22D5E49C3 21A9A0: 2D7D49C4EA20F0AA49C5EA202AAB49C6 21A9B0: EA207CAB49C7EA20AAAB47FC0800EA20 21A9C0: B2AB47FC0900EA2000AC47FC0A00EA20 21A9D0: 42AC47FC0B00EA20ACACCB00D7500D00 21A9E0: F2FCBC04F2FDBE04BB6DB9D509A1B9C5 21A9F0: 09A1E7FF3A00B9F509A1BB63B9D509A1 21AA00: B9C509A1CB00D7600D00F2F6C404F3FE 21AA10: C204F3FFC004E6FC1EC1B87C28C2B86C 21AA20: E03D8850DABF1CAF9850CB008850004C 21AA30: D7408601A9C4F0C6DA6796FAF0E4F0F5 21AA40: 9850E10FB9F5F0C5E03DDABFAE81F05C 21AA50: E7FF9100B9F509A1CB00D7500D00F2F4 21AA60: C204F2FDC004BB2EB9D509A1B9C509A1 21AA70: E7FF2000B9F509A1E11D47F80A008D01 21AA80: E12DE6FCA72ABBD2E7FF2000B9F509A1 21AA90: BBBAE12DE6FCB42ABBC9CB00BBB4E15D 21AAA0: E6FCBB2ABBC3CB00ECEFF2F5F7F9FBFD 21AAB0: FF000204090F14191D2228ACB8ADAEAF 21AAC0: B0ABF0DCF6FD0EFEE0A65B66F3FD0EFE 21AAD0: F3FC0CFE06F63030CB00F6FC0EFEE6FD 21AAE0: 64004BDDF2FD0CFEBBEFF076BBEBCB00 21AAF0: D7406900F2FCB239E6FDAA0A20CDBBED 21AB00: B9E509A1B9D509A1E7FF2C00B9F509A1 21AB10: B9C509A1E7FF2700B9F509A1E7FF4300 21AB20: B9F509A1CB000DD90D8CD7401000F2FC 21AB30: 9C38BBD3B9F509A1E7FF2C00B9F509A1 21AB40: B9E509A1B9D509A1B9C509A1E7FF2000 21AB50: B9F509A1D7400F00F2FD2828BBB3E7FE 21AB60: 250047FD3A003D03E7FD3100F1ECB9D5 21AB70: 09A1B9C509A1B9E509A1CB00D7401000 21AB80: F2FCB638BB3C47FE30002D02B9E509A1 21AB90: B9D509A1B9C509A1E7FF6D00B9F509A1 21ABA0: E7FF4100B9F509A1CB00F2FF02FEBBBC 21ABB0: CB00D7500800F2FDE23EF2F6E83EE7FF 21ABC0: 110046FD7D008D02E7FF2D00B9F509A1 21ABD0: E10DF0C6BB1447FE30002D02B9E509A1 21ABE0: B9D509A1B9C509A1E7FF6400B9F509A1 21ABF0: E7FF4200B9F509A1CB00EA00C8AA0D93 21AC00: D7400800F2FCE43EBB57E7FF3A00B9F5 21AC10: 09A1D7400800F2FCE23E46FC7D008D02 21AC20: 06FC5101BBECB9E509A1B9D509A1B9C5 21AC30: 09A1CB0048402D0227FC2000B9C509A1 21AC40: CB00D7400A00F2F4C03F6841E7FC6100 21AC50: BBF1DA71C6B8E7FC6700BBECD7401000 21AC60: F2F4BC39E7FC6B00BBE5DAA4C0B0E7FC 21AC70: 530048402D06E7FC730048412D02E7FC 21AC80: 4200B9C509A1DA922E5FE7FC7600BBD2 21AC90: D7400800F2FDE23EE7FC390046FD7D00 21ACA0: 8D02E7FC3100B9C509A1CB00D7400900 21ACB0: F2FC6C39BB01CB00F6FC0EFEE6F61027 21ACC0: 5B66F2F70CFEBB9947FC30002D02B9C5 21ACD0: 09A1F0C7BB94B9F509A1B9E509A1B9D5 21ACE0: 09A1B9C509A1CB00 #pragma disable old_equal_ff ;21AA88: E7FF CB00 ;Don't display DayOfWeek in function 2 (Date). ;21AB2A: D740 0D14 ;Don't display voltage in function 5, ; just percentages of Akku. ;21AB4C: E7FF CB00 ;Don't display percentages in function 5, ; just Voltage of Akku ; Adjusting of function B (Monitoring of word in memory) ; In this example word 0009:39C6 = 02796C (MainscreenCounter) ;will be monitored. ;21ACAE: 0900 0900 ; Page = adr/4000h ;21ACB2: 6C39 6C39 ; Offset = adr%4000h Last edited by misko903; 07-11-2005 at 21:11. |
07-10-2005, 18:16 | #161 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** Play Sound on CarKit Profil selection *** ; S55v91 ; 2004 by ACiD[mrp] ; adapted for S55v91 by Mich3L ; fixed by Mich3L ; v1.1 : conflict with provider7, relocated + customization by Antoine[KNet] 331DCE: 88908880 DA61D0AF 21AFD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48C33D05E6FC3B00DAA484ADE03C8890 21AFE0: FFFFFFFF 8880DB00 ;21AFD6: 3B xx ;replace xx with any sound in sound list Last edited by misko903; 07-11-2005 at 21:12. |
07-11-2005, 20:59 | #162 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | *** RON. Remove operator name v3 *** ;Firmware : S55v91 ;Author : Lalo ;Release : v3 ;first line: 31A9CC: 8890 DB00 ;second line: ;always: 3252AA: D460 0D42 ;phone in normal mode (not netserching, not GPRS mode...): ;32526E: D4C0 0D15 |
07-15-2005, 19:10 | #163 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** RCA+IC. Remove Comma in Adress book and Incomming Calls v3 *** ;Firmware: S55v91 ;Authors: © SiNgle, § AlexSid ;Ported : Antoine[KNet] ;Version 3 ;Release: 14.07.05 ;1A6F76: 2C 20 ; for icomming calls, cause bug - don't display commas in sms 86574C: DA964020 CC00CC00 865F50: DA964020 CC00CC00 86608E: DA964020 CC00CC00 866146: DA964020 CC00CC00 867556: DA964020 CC00CC00 86D6E0: DA964020 CC00CC00 880480: DA964020 CC00CC00 8805A2: DA964020 CC00CC00 88169C: DA964020 CC00CC00 8A1386: DA964020 CC00CC00 8B40E2: DA964020 CC00CC00 |
07-21-2005, 14:26 | #164 (permalink) |
Junior Member Join Date: Sep 2004 Age: 51
Member: 81025 Status: Offline Thanks Meter: 0 | Remained symbols counter in current segment SMS (unicode) ;c Broken Brain ;adapted for S55v91 by belwer 2E57A0: DABF1892 DA6180A4 2E57BA: F0C8 F0CA #pragma enable old_equal_ff 21A480: 8840DABF1892F6F80EFEF0A898E02D09 21A490: 46FA04018D0326FA04010D0EE6FE4200 21A4A0: 0D0846FA58028D0326FA58020D05E6FE 21A4B0: 98005BEEF2FA0CFEDB00 #pragma disable old_equal_ff |
07-30-2005, 12:50 | #165 (permalink) |
Member: 89407 Status: Offline Thanks Meter: 0 | ;*** LCC. Left Characters Countdown *** ;Firmware : S55v91 ;Authors : M55 Broken Brain, § «Serg°H» ;Ported : Antoine[KNet] ;Release : v2 (unicode support) ;This patch changes left characters contdown when writing an SMS: ;instead of counting from 760 to 0 countdown is splitted in left characters for each single SMS. ;NOTE: SMS free characters lenght varies, because in multiple SMS ;first 8 characters are occupied by header in each SMS. 2E57A1: BF1892 BF60F3 2E57BB: C8 CA 7FF360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8840DABF1892F6F80EFEF0A898E02D09 7FF370: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FA04018D0326FA04010D0EE6FE4200 7FF380: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D0846FA58028D0326FA58020D05E6FE 7FF390: FFFFFFFFFFFFFFFFFFFF 98005BEEF2FA0CFEDB00 |
S55 flash with wrong flash file. | WillGsm | E-Gold Based Phones | 2 | 01-29-2005 13:58 |
S55+blacklist patch | KERKENNAH | E-Gold Based Phones | 1 | 12-19-2004 09:57 |
S55 Flash Patching :) | Acidmrp | E-Gold Based Phones | 3 | 09-21-2003 19:55 |
S55 flashing 2% | zoki | E-Gold Based Phones | 3 | 06-10-2003 22:07 |
S55 flashing | zoki | E-Gold Based Phones | 4 | 03-31-2003 07:53 |
