Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-24-2003, 04:47   #16 (permalink)
Acidmrp's Avatar
Member: 15315
; Vibra Logo v2 (bug fixed):
; Firmware : S55 v20
; Author : ACiD [mrp]
; Homepage: www.gsm-dev.com
;uses Pictures
;293 --> Vibra off
;294 --> Vibra on
download vkp
Old 11-25-2003, 04:50   #17 (permalink)
Acidmrp's Avatar
Member: 15315
; S55 HourBeep
; Author : ACiD [mrp], SiNgle, RizaPN
31AB00: 98809890 DA61C0A1
0021A1C0: 9880989088C0D7400D00F2FCBC4446FC
0021A1D0: 0A00DD0CD7400300F2FC08C148C12D07
0021A1E0: E6FC4100DAA40CADE01C9D01E00CD740
0021A1F0: 0300F6FC08C198C0DB00
Old 11-25-2003, 15:34   #18 (permalink)
Acidmrp's Avatar
Member: 15315
; no dial tone if phone is in silent mode (all signal sounds off).
00239EEC: DAA40CAD DA6140A2
0021A240: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8840D7404300F2F4ECFF48412D02DAA4
0021A250: FFFFFFFFFFFF 0CAD9840DB00
Old 11-28-2003, 14:48   #19 (permalink)
Acidmrp's Avatar
Member: 15315
; KeyLock -> Fast LightDown
62A5DA: DAA284A5 DAA1F875
Old 12-13-2003, 20:38   #20 (permalink)
Acidmrp's Avatar
Member: 15315
*** S55 Digital Clock in Keylock mode ***
; Author : ACiD [mrp], RizaPN
v_klay Patch download
Sample Pictures:
Version A
Version B
Old 01-03-2004, 16:10   #21 (permalink)
Acidmrp's Avatar
Member: 15315
;AOBA AutoOn By Alarm
;(C) SiNgle, Translated to S55 by ACiD [mrp]
;S55v20
271F84: EA00 0D35
Old 01-05-2004, 03:31   #22 (permalink)
ValeraVi's Avatar
Member: 24687
;*** Change layout of keys in the calculator ***
;Firmware: S55_v20
;Author:   ValeraVi
;Release:  2004-01-04
;Set percent on the one press of right soft key and more.
;Layout of keys "*", "#" and rigth soft key will be:
; wheh "e" (exponent) and "." (decimal point) is not entered:
; % . = (+- sign) e + - * / (in memory) (out memory)
; wheh "." (decimal point) is entered:
; % = (+- sign) e + - * / (in memory) (out memory)
; wheh "e" (exponent) is entered:
; % = (+- sign) + - * / (in memory) (out memory)
;wheh "e" and "." is not enter
1EAF81: 95202E3D2B2D2A2F96319525932223956500 95252E3D963195652B2D2A2F932223952000
;wheh "." is entered
1EAF61: 95203D2B2D2A2F96319525932223956500   95253D963195652B2D2A2F932223952000
;wheh "e" is entered
1EAF72: 95203D2B2D2A2F9631952593222300       95253D9631952B2D2A2F2093222300
.vkp file
Old 01-05-2004, 03:33   #23 (permalink)
ValeraVi's Avatar
Member: 24687
;*** Setup Illumination by 5% step ***
;Firmware: S55_v20
;Author:   SiNgle (M55), ValeraVi (ported to S55)
;Release:  2004-01-05
27DD76: 06FC0A00 06FC0500
27DDAC: 26FC0A00 26FC0500
61753E: E0AC E05C
617552: F441AE35 F4412237
617570: E0AC E05C
617584: F441AE35 F4412237
;brightness codes:
1AF722: 676765722056312E30390044455354524F59454400 000103081012161E242B3034384044485054586064
.vkp file
Old 01-09-2004, 16:35   #24 (permalink)
Member: 48709
Originally posted by Mates
Does "DisableAeroCheck" patch exist for S55 ?
You can use Smelter.
Or try one of this variants:
;1st variant
;(c) Skylord, Viper_Rus, SiNgle, GerAN, avkiev
71_67: EF FF ;S55 - DisableAeroCheck
;2nd variant
;(c) tatarin
71_73: EF FF ;S55 - DisableAeroCheck
;3rd variant
;(c) tatarin
71_79: EF FF ;S55 - DisableAeroCheck
;4th variant
;(c) Talon
71_8D: EF FF ;S55 - DisableAeroCheck
Old 01-09-2004, 20:49   #25 (permalink)
GSM-Java's Avatar
Member: 28435
Thanks Meter: 16
You can find some patches on www.siemens-java.com !
Old 01-12-2004, 08:02   #26 (permalink)
Member: 48848
Originally posted by avkiev
If you know Russian - you can use SiemPROM.
If not - try one of this variants:
;1st variant
;2nd variant
;(c) tatarin
;3rd variant
;(c) tatarin
;4th variant
;(c) Talon
For Avkiev:
- thanks for your information
For other:
- functional patch for V_Klay
; DisableAeroCheck
BE2FEF: EF FF
Old 01-12-2004, 10:27   #27 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Selection of the standard position of cursor in the profiles ***
;original patch by ACiD[mrp] for s45iv04
;Adapted by Girosavo for S55v20
3322EC: 3D02 CC00
3322EE: E00C E05C ; to replace with "5 ' by 0... 7 for the selection of the position of the cursor
Old 01-12-2004, 10:54   #28 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Enable NetMonitor ***
;original patch by RizaPN for sl45v56
;Mený --> #
61FC62: 2D 0D
Old 01-12-2004, 13:59   #29 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Change Beep if call succesfull ***
;Firm: S55v20
23DB1C: 13 3D ; Change 3D with 3a 3b 3c 3e 01 5a
Old 01-12-2004, 14:48   #30 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Change time for AutoKeyLock ***
325986: C832 E803 ; 5 seconds
The value 3E8=1000 (millisecons ??) I think no, because it not corresponds (1000 milliseconds are 1 second or no?? ).... the same is default value 32C8=13000 (1 minute)...I don't know, but it works !! ......if anyone explain me in another topic.....
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 12:58
S55+blacklist patch KERKENNAH E-Gold Based Phones 1 12-19-2004 08:57
S55 Flash Patching :) Acidmrp E-Gold Based Phones 3 09-21-2003 19:55
S55 flashing 2% zoki E-Gold Based Phones 3 06-10-2003 22:07
S55 flashing zoki E-Gold Based Phones 4 03-31-2003 06:53
Page generated in 0.51372 seconds with 9 queries
