Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 01-12-2004, 16:03   #31 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Enable Band Selection ***
;original patch by RizaPN for sl45v56
;Adapted by Girosavo for S55v20
;Setup --> Network --> Band Selection
;-Automatic
;-GSM 900
;-GSM 1800
;-GSM 1900
12688A: 0502 FA01
Old 01-12-2004, 23:42   #32 (permalink)
ValeraVi's Avatar
Member: 24687
@GIROSAVO
;*** Change time for AutoKeyLock ***
;Firmware: S55_v20
;Authors:  SiNgle (M55), ValeraVi (S55)
;Release:  2004-01-17
;Version:  1
325986: C832 9065
; All delays - in numbers of ~5 ms intervals.
; Code is calculated as: Num = Delay_MS / 5,
;then exchange the lower and higher bytes.
;Example: 65000 ms / 5 = 0x32C8, => C832
;         130000 ms / 5 = 0x6590, => 9065
;At 325986: - change the autokeylock delay.
other patches you can found here: .vkp files
Old 01-20-2004, 19:34   #33 (permalink)
Acidmrp's Avatar
Member: 15315
; Call logging
; Author: Chaos, converted to S55v20 by ACiD [mrp]
; Firmware: S55v20
; Homepage: www.gsm-dev.com
; After installing the Patch Information about Calls are stored in a:\calls.txt
; Format: Date, Time, Type, time of calling, Number
; (Type: D - Dialed, I - Incoming)
23AC76: DA6322A6 DA7B0095
003B9400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 001F1C1F1E1F1E1F1F1E1F1E1F000000
003B9410: FFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C63616C6C732E74787400
003B9500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F03000F0F088C088D088E0D7400700
003B9510: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F10C163D06D7500700F6F15A14F6F1
003B9520: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C14D7500700F2FE5A14F2F1E2003D02
003B9530: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48E69D75D7700D00F3F8BC04F3F9BE04
003B9540: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F3FAC004F3FBC2040D1329813D11E7F8
003B9550: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3B0029913D0DE7F9170029A13D0929B1
003B9560: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D01E1CBC0BD06FD0014D740EE01A9AD
003B9570: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 26F13C009DEAF12ABB60E7F22E00BB6D
003B9580: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F12BBB5BBB68F129BB58E7F23A00BB65
003B9590: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F128BB53BB60E7F2440048E69D02E7F2
003B95A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4900BB5BBB58D7400700F2F4DE33D740
003B95B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0700F2F4E200E7F2FF00092126F43C00
003B95C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9DFC06F43C00BB39E7F23A00BB46F128
003B95D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB34BB41D7400700F2F45C1447F89100
003B95E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D03E7F22B00BB39E6F5300FE6FE083C
003B95F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE60140D0ED7400700998EF128612B
003B9600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 012ABB2BF1287C41612B412B2D02012A
003B9610: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB2429919DF0E1D2BB20E1A2BB1E98E0
003B9620: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D098C088F0DA6322A698F0F0E020FE
003B9630: FFFFFFFFFFFFFFFFFFFF 2D01BB1606F03000DB00
003B963A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F32F00093127F20A009DFC07F23A00
003B964A: FFFFFFFFFFFFFFFFFFFFFFFF 8810F123BB059810BB03CB00
003B9656: FFFFFFFF E7F22000
003B965A: FFFFFFFFFFFF B92F08F1CB00
003B9660: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F08EF09F26F01000F0E066FEFF3FF2FF
003B9670: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 02FE88F088E006FE080088F088E0E6FD
003B9680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EE01E6FC1014E6FE0101E6FF8001DAD2
003B9690: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ECAD46F4FFFF3D0306F008000D17ECF4
003B96A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C4E00DE00EE02FDAD242AFF0D866FD
003B96B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF3FF2FE02FEF0F9FCF8F0C8DAD292AF
003B96C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 080498D098E0F0C8DAD2D4AF06F01000
003B96D0: FFFF CB00
Old 01-21-2004, 14:08   #34 (permalink)
Acidmrp's Avatar
Member: 15315
; Call Logging v3b
; Firmware: S55v20
; new: Better Log Format by ACiD [mrp]
; - added an ',' between each information
; - changed Type into "In", "Out", "Missed"
; Format: "Date, Time, Type, time of calling, Number"
; (Type: Out = Dialed, In = Incoming, Missed)
; Examples:
; 21.01, 14:56, Out, 00:54, 112
; 21.01, 14:57, In, 00:32, 112
; 21.01, 15:00, Missed, , 112
; Hint:
; Dialed numbers with time 0:00 will not be logged.
003B9520: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5C14D7500700F2FE5A14F2F1E2003D03
003B9530: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48E6EA907A96D7700D00F3F8BC04F3F9
003B9540: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BE04F3FAC004F3FBC2040D1329813D11
003B9550: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F83B0029913D0DE7F9170029A13D09
003B9560: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 29B13D01E1CBC0BD06FD0014D740EE01
003B9570: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9AD26F13C009DEAF12ACA009696E7F2
003B9580: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2E00CA00BC96F12BCA009696CA00B296
003B9590: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F129CA009696E7F23A00CA00BC96F128
003B95A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB7ACA00B296D7500700F2FE5A14F2F1
003B95B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E2002D2A48E69D06E7F24900BB7FE7F2
003B95C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E009D08E7F24F00BB79E7F27500BB76
003B95D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F27400BB73BB6DD7400700F2F4DE33
003B95E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400700F2F4E200E7F2FF00092126F4
003B95F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3C009DFC06F43C00BB4EE7F23A00BB5E
003B9600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F128BB49BB569D14E7F24D00BB57E7F2
003B9610: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6900BB54E7F27300BB51E7F27300BB4E
003B9620: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F26500BB4BE7F26400BB48BB42BB41
003B9630: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400700F2F45C1447F891003D03E7F2
003B9640: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2B00BB3CE6F5300FE6FE083CE6FE6014
003B9650: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D0ED7400700998EF128612B012ABB2E
003B9660: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F1287C41612B412B2D02012ABB272991
003B9670: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9DF0E1D2BB23E1A2BB2198E098D098C0
003B9680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA6322A698F0F0E020FE2D01BB19
003B9690: FFFFFFFFFFFF 06F03000DB00
003B9696: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E7F32F00093127F20A009DFC07F23A00
003B96A6: FFFFFFFFFFFFFFFFFFFFFFFF 8810F123BB089810BB06CB00
003B96B2: FFFFFFFFFFFFFFFFFFFF E7F22C00BB02E7F22000
003B96BC: FFFFFFFFFFFF B92F08F1CB00
003B96C2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F08EF09F26F01000F0E066FEFF3FF2FF
003B96D2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 02FE88F088E006FE080088F088E0E6FD
003B96E2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EE01E6FC1014E6FE0101E6FF8001DAD2
003B96F2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ECAD46F4FFFF3D0306F008000D17ECF4
003B9702: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C4E00DE00EE02FDAD242AFF0D866FD
003B9712: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF3FF2FE02FEF0F9FCF8F0C8DAD292AF
003B9722: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 080498D098E0F0C8DAD2D4AF06F01000
003B9732: FFFF CB00
Old 01-21-2004, 17:18   #35 (permalink)
GIROSAVO's Avatar
Member: 26549
Please no questions in this topic.
;*** Modify # + Right SoftKey from View CB to Calendar***
;21/01/2004
32B288: 5402 FD0C ; also another Text....
32B615: 6ED818 67F4AE ; also another Entry.....
Old 01-22-2004, 11:00   #36 (permalink)
Acidmrp's Avatar
Member: 15315
; *** Improved Net Indicator ***
; (c) Chaos, converted to S55v20 by ACiD [mrp]
; Firmware: S55v20
; www.gsm-dev.com
; Show six (6) avialable Base Stations
; 900mhz - green
; 1800mhz - red
; if you use the vibra logo patch you have to do some changes:
; with vibra logo:
; 0032C5BA: DA7B1890 DA7B00B8
; 003BB870: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA7B189098F098C048C00D0108C1
; without vibra logo:
0032C5BA: DA7216C3 DA7B00B8
003BB870: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88F0DA7216C398F098C048C00D0108C1
; in both cases:
003BB800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FFE23EE00CD7400800D41F0600E103
003BB810: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 49202D1C47F2FF002D19E11347F26900
003BB820: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED15E12347F26100ED11E13347F25800
003BB830: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED0DE14347F25000ED09E15347F24400
003BB840: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ED05E16347F23900ED01E173D7400800
003BB850: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A85F46F57D008D0207F30800C03E06FE
003BB860: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9B0146FEA1018D0226FE6700E00D88C0
003BB880: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 08C406FF0C0046FF1E3FFDBDDB00
; ##### Picture 314 #####
; Picture Table Index
0CC9D0: 1D090500 05090500
; Picture Data
0B3E23: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFF181818FFFF
0B3E33: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 181818FFFF181818FFFF181818FFFF18
0B3E43: 9898FF98989898FF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 315 #####
0CC9D8: 1D090500 05090500
; Picture Data
0B4000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFF181818FFFF181818FFFF
0B4010: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F 181818FFFF181818FFFF181818FFFF18
0B4020: 2F2FFF98989898FF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 316 #####
0CC9E0: 1D090500 05090500
; Picture Data
0B4105: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4115: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B4125: 2F2FFF2F2F2F2FFF98989898FF989898 FCFCFFFFFCFCFCFFFFFFFFFFFF0F0F0F
; ##### Picture 317 #####
0CC9E8: 1D090500 05090500
; Picture Data
0B420A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B421A: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B422A: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 FCFCFFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 318 #####
0CC9F0: 1D090500 05090500
; Picture Data
0B430F: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B431F: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFC8
0B432F: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 319 #####
0CC9F8: 1D090500 05090500
; Picture Data
0B4414: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4424: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFC8C8C8FFFFC8
0B4434: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 320 #####
0CCA00: 1D090500 05090500
; Picture Data
0B4519: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B4529: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 FCFCFCFFFFC8C8C8FFFFC8C8C8FFFFC8
0B4539: 9898FF98989898FF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 321 #####
0CCA08: 1D090500 05090500
; Picture Data
0B461E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B462E: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B463E: 2F2FFF98989898FF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 322 #####
0CCA10: 1D090500 05090500
; Picture Data
0B4723: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFC8C8C8FFFF
0B4733: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B4743: 2F2FFF2F2F2F2FFF98989898FF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 323 #####
0CCA18: 1D090500 05090500
; Picture Data
0B4828: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFC8C8C8FFFFC8C8C8FFFF
0B4838: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F C8C8C8FFFFC8C8C8FFFFC8C8C8FFFFC8
0B4848: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 C8C8FFFFC8C8C8FFFFFFFFFFFF0F0F0F
; ##### Picture 411 #####
0CCCD8: 1D090500 05090500
; Picture Data
0B86AE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B86BE: FFFFFFFFFFFFFFFFFFC0C0C0C0FF9898 FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B86CE: 9898FF98989898FF98989898FF989898 FCFCFFFFFCFCFCFFFFFFFFFFFF0F0F0F
; ##### Picture 412 #####
0CCCE0: 1D090500 05090500
; Picture Data
0B87B3: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B87C3: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFFFC
0B87D3: 2F2FFF98989898FF98989898FF989898 FCFCFFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 413 #####
0CCCE8: 1D090500 05090500
; Picture Data
0B88B8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B88C8: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFFFCFCFCFFFF18
0B88D8: 2F2FFF2F2F2F2FFF98989898FF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 414 #####
0CCCF0: 1D090500 05090500
; Picture Data
0B89BD: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B89CD: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFFFCFCFCFFFF181818FFFF18
0B89DD: 2F2FFF2F2F2F2FFF2F2F2F2FFF989898 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 415 #####
0CCCF8: 1D090500 05090500
; Picture Data
0B8AC2: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B8AD2: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F FCFCFCFFFF181818FFFF181818FFFF18
0B8AE2: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F 1818FFFF181818FFFFFFFFFFFF0F0F0F
; ##### Picture 416 #####
0CCD00: 1D090500 05090500
; Picture Data
0B8BC7: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFCFCFCFFFFFCFCFCFFFF
0B8BD7: FFFFFFFFFFFFFFFFFFC0C0C0C0FF2F2F 181818FFFF181818FFFF181818FFFF18
0B8BE7: 2F2FFF2F2F2F2FFF2F2F2F2FFF2F2F2F 1818FFFF181818FFFFFFFFFFFF0F0F0F
Old 01-26-2004, 15:06   #37 (permalink)
Acidmrp's Avatar
Member: 15315
why do you still ask questions in this topic?
I won't answer any question here. Please make extra topic.
; **** Advanced Net Indicator in Keylock mode ****
; 2004 by ACiD [mrp]
; GSM Development Crew www.gsm-dev.com
; join us at http://www.handyhacking.com/
; S55 v20
; Patch Version v.09 BETA
download vkp
Old 01-27-2004, 13:58   #38 (permalink)
Acidmrp's Avatar
Member: 15315
please undo old version first.
; S55 v20
Problems fixed:
- GSM900 / GSM1800 detection
- -5dB Offset
; Patch Version v.1 BETA
download vkp
Old 01-27-2004, 17:42   #39 (permalink)
Acidmrp's Avatar
Member: 15315
Sorry, can't edit in new board
new version:
S55 v20
Old 02-03-2004, 12:34   #40 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** Change Date in Calendar (Feb2004 --> 03.02.2004) ***
;S55 V20
;© Matr!x, Adapted by Girosavo
89989E: 3C9A CC86
Old 02-03-2004, 12:46   #41 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** No "List is empty!" message ***
;S55 V20
8BC0AC: FA9E8E7E CC00CC00
Old 02-03-2004, 13:19   #42 (permalink)
GIROSAVO's Avatar
Member: 26549
;*** To remove title and to extend the menu ***
;S55 V20
;© Matr!x, adapted by Girosavo
90B894: DAD0B6BB CC00CC00
Old 02-03-2004, 13:37   #43 (permalink)
ValeraVi's Avatar
Member: 24687
;*** Change light off speed ***
;Firmware: S55_v20
;Author:   ValeraVi
;Release:  2004-02-02
;Version:  2
61736E: CC E0
61736F: 00 0F ;yF, y-lower tetrade of LOBYTE of HIWORD of delay
617392: E06E E6FE
617395: 0F 00 ;HIBYTE of LOWORD of delay
617394: E0 18
;At address 617394 - HEX number - delay before each step of decrease
; of illumination. Increase delay to decrease speed of illumination
; turn off.
; By default delay = 06. If you change to:
; 03 - illumination is turned off 2 times faster.
; 0C - illumination is turned off 2 times slower.
; 12 - 3 times slower.
; 18 - 4 times slower.
; and so on.
Old 02-03-2004, 14:05   #44 (permalink)
ValeraVi's Avatar
Member: 24687
;*** Change light off delay after last press some key ***
;Firmware: S55_v20
;Author:   ValeraVi
;Version:  1
617514: 1405 280A
6175BA: 1405 280A
; At ad******* 617514 and 6175BA - HEX word (2 bytes) - multiplier,
;what is used for calculating the illumination off delay after
;last press of some key. Specify bigger multiplier for longer delay.
; By default multiplier = 0x0514 (1405, if we swap bytes for patch).
;If you change to:
; 0x028A (8A02) - illumination is off after 2 times smaller interval
;                 of time than usually.
; 0x0A28 (280A) - illumination is off after 2 times bigger interval
; 0x0F3C (3C0F) - ... 3 times bigger ...
; 0x1450 (5014) - ...  4 times bigger ...
; and so on
Old 02-03-2004, 14:10   #45 (permalink)
ValeraVi's Avatar
Member: 24687
;*** Disable question "Always allow network connections?" ***
;Author:           SiNgle
;Ported to S55 by: ValeraVi
;Version:          1
59D2FC: 2D04 CC00
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 12:58
S55+blacklist patch KERKENNAH E-Gold Based Phones 1 12-19-2004 08:57
S55 Flash Patching :) Acidmrp E-Gold Based Phones 3 09-21-2003 19:55
S55 flashing 2% zoki E-Gold Based Phones 3 06-10-2003 22:07
S55 flashing zoki E-Gold Based Phones 4 03-31-2003 06:53
Page generated in 1.77174 seconds with 12 queries
