02-03-2004, 15:14 | #46 (permalink) |
Freak Poster Join Date: Mar 2003 Location: Kyiv, Ukraine Age: 47
Member: 24687 Status: Offline Thanks Meter: 1 | Key 1 long press -> Midlet run Code: ;*** Key 1 long press -> Midlet run *** ;Author: SiNgle, Chaos ;Ported to S55 by: ValeraVi ;Release: 2004-02-02 ;Version: 1 ;Midlet must have path and name: A:\Java\Jam\Prog\Prog.jar 32B5B6: DA623C2248423D02 DAABE000EA006AB6 6B00E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FCEE00E6FDAC02E01EFA97ACAF 6B00EE: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 413A5C4A6176615C6A616D5C50726F67 6B00FE: FFFFFFFFFFFFFFFFFFFF 5C50726F672E6A617200 |
02-04-2004, 14:48 | #47 (permalink) |
Freak Poster Join Date: Apr 2003 Location: Italy - Rome Age: 45
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Modify * + Right SoftKey from Profiles to Games & More *** ;Firm: S55v20 ;04/02/04 ;by Girosavo 32B208: 5601 FB07 ; see another text 32B61B: 732023 722EF0 ;see another Entry Point 32B620: DA7378AB CC00CC00 |
02-04-2004, 22:19 | #48 (permalink) |
Junior Member Join Date: Oct 2003 Location: Greece Age: 44
Member: 41556 Status: Offline Thanks Meter: 0 | try these changes (apply only if they are error free for your eep) activate only one each time (by removing the ";") with v-klay ;- - - - - - - - - - - - - - - - - - - - - - - ;created by Phoenix, www.myphone.gr ;Disable Aero-Check, s55 v.20 ;0xBE329D: EF FF ;0xBE32B9: EF FF ;0xBE32BD: EF FF ;0xBE32C0: EF FF ;0xBE32C4: EF FF ;0xBE32C7: EF FF ;0xBE32D5: EF FF ;0xBE32DC: EF FF ;- - - - - - - - - - - - - - - - - - - - - - - for my eep, the working one is the first |
02-06-2004, 09:18 | #49 (permalink) |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | ; S55 BlackList original by SiNgle (M55) ; ; S55 v20 ; ; don't play any sound / vibra when caller is in black list ; ; 2004 by ACiD [mrp] ; GSM Development Crew www.gsm-dev.com ; join us at http://www.handyhacking.com/ http://www.mobiletuning.de/Moderator...5BlackList.vkp |
02-09-2004, 11:55 | #50 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Hide message "Keyboard is locked" *** ;original patch by RizaPN for sl45v56 ;Adapted for S55v20 by Girosavo 321EDE: DA72AA86 CC00CC00 Last edited by GIROSAVO; 02-23-2004 at 10:20. |
02-09-2004, 12:13 | #51 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Hide messages when sound turned off/on *** ;original patch by © Matr!x for M55v10 ;Adapted for S55v20 by Girosavo 321F1C: DA731E84 CC00CC00 321F32: DA731E84 CC00CC00 Last edited by GIROSAVO; 02-23-2004 at 10:20. |
02-09-2004, 13:17 | #52 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Short press UP Arrow Key --> Links *** ;original patch by RizaPN ?, © Matr!x ? ;Adapted by Girosavo for S55v20 324944: E6 DA 324945: FCE600 72D6EF ; New MMS (see table for other Entry Points) 324948: DA8D8A9C4840 CC00CC00CC00 32494F: 30 00 Last edited by GIROSAVO; 02-23-2004 at 10:35. |
02-09-2004, 15:42 | #53 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | Big respect for the authors of these patches !! ;*** Modify Left Arrow Key from GPRS Info to Inbox *** ;original patch by © Matr!x ? ;Adapted by Girosavo for S55v20 32499D: 7106B8 6EB23B ; Inbox Last edited by GIROSAVO; 02-23-2004 at 10:36. |
02-16-2004, 15:43 | #54 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Modify 0 + Right SoftKey from "Select Line" to "Calendar" *** ;original patch by RizaPN for sl45v56 ;Adapted by Girosavo for S55v20 32B172: 4840 E014 32B198: 5202 FD0C ; ...another Text 32B57F: 621822 7276EF ; ...another Entry 32B582: 4840 E004 Last edited by GIROSAVO; 02-23-2004 at 10:24. |
02-17-2004, 19:35 | #55 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Change Info T9 to Language Selector *** ;original patch by © SiNgle ;Adapted ( and implemented ) by Girosavo for S55v20 ;New SMS-> Left soft-> change lang 1229DA: 9C01 0907 ; ....see text 2F9DB3: 9E8082 6760DA ; ....see Entry 5DF3AC: DA9EBE7A CC00CC00 ;hide selected language msgbox Last edited by GIROSAVO; 02-23-2004 at 10:40. |
02-18-2004, 12:03 | #56 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** New sms-> green button ...from "Send to" to "Language Selector" *** ;original patch by © SiNgle, Matr!x,Alexsid ;Adapted by Girosavo for S55v20 2F9DC2: E6 DA 2F9DC3: FEEE00 6760DA ;...another Entry 2F9DC6: E07F DB00 5DF3AC: DA9EBE7A CC00CC00 ;hide selected language msgbox Last edited by GIROSAVO; 02-23-2004 at 10:44. |
02-19-2004, 09:21 | #57 (permalink) |
Junior Member Join Date: Feb 2004 Location: RUSSIA (Moscow) Age: 39
Member: 53049 Status: Offline Thanks Meter: 0 | ; *** Runnig midlets by pressing keys 1-9 *** ;Firmware: S55_v20 ;Authors (on M55): Chaos, SiNgle ;Ported to S55 by: ValeraVi ;Release: 2004-02-14 ;Version: 1 ; CAUTION: Redo patch "Key 1 long press -> Midlet run". ; Copy midlet in the folder a:\java\keys\N\, where N=1..9 - ; number of hot key. Then on the hot key set set "Start". ; For key 1 u needn't do this. ;If you don't want to use key 1, ; uncomment this string of patch (address 32B5B6). 32B5B6: DA623C2248423D02 DAAB4001EA006AB6 322D92: DA67A6DA DAAB4001 12733A: 9A01AF0AAE0A DC04DC04DC04 6B0120: FFFFFFFFFFFFFFFF 613A5C6A6176615C 6B0128: FFFFFFFFFFFFFFFF 6B6579735C305C2E 6B0130: FFFFFFFFFFFFFFFF 6A61720000000000 6B0138: FFFFFFFFFFFFFFFF 0000000000000000 6B0140: FFFFFFFFFFFFFFFF E6FE2001E6FF3E38 6B0148: FFFFFFFFFFFFFFFF D740AC02992E08F1 6B0150: FFFFFFFFFFFFFFFF D7400900B92F3DF8 6B0158: FFFFFFFFFFFFFFFF D7500900F3F23D38 6B0160: FFFFFFFFFFFFFFFF F7F24C38E6FC4B01 6B0168: FFFFFFFFFFFFFFFF DA672E2BE6FC3F38 6B0170: FFFFFFFFFFFFFFFF E09DE01EFA97ACAF |
02-23-2004, 15:14 | #58 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Change Info T9 to Language Selector in NewMail*** ;S55v20 ;by Girosavo ;Luki's forum http://www.forumcommunity.net/?c=3784 1206F8: 9C01 0907 ; ...text 2D8BB3: 9E8082 6760DA ;...Entry |
02-23-2004, 15:40 | #59 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Change Info T9 to Language Selector in NewMMS*** ;S55v20 ;by Girosavo ;Luki's forum http://www.forumcommunity.net/?c=3784 13FC02: 9C01 0907 ;..change text 832931: 9E8082 6760DA ;...change Entry |
02-23-2004, 16:02 | #60 (permalink) |
Member: 26549 Status: Offline Thanks Meter: 1 | ;*** Change Info T9 to Language Selector in Notes *** ;S55v20 ;by Girosavo ;Luki's forum http://www.forumcommunity.net/?c=3784 149DF0: 9C01 0907 ;...text 8AE7B1: 9E8082 6760DA ;...Entry |
S55 flash with wrong flash file. | WillGsm | E-Gold Based Phones | 2 | 01-29-2005 13:58 |
S55+blacklist patch | KERKENNAH | E-Gold Based Phones | 1 | 12-19-2004 09:57 |
S55 Flash Patching :) | Acidmrp | E-Gold Based Phones | 3 | 09-21-2003 19:55 |
S55 flashing 2% | zoki | E-Gold Based Phones | 3 | 06-10-2003 22:07 |
S55 flashing | zoki | E-Gold Based Phones | 4 | 03-31-2003 07:53 |
