Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 08-02-2005, 08:04   #316 (permalink)
Member: 81025
Originally Posted by lalo.lerry
Please post the original M55 patch in patch format, I want to check it by my own
Lalo
translated from russian
;*** Incoming call name and icon v2
;(Unknown/Home/Work/Mobile/Fax/Fax2)
;Displays the name only at exact coincidence of address book number and caller ID by provider, in other case displays "Unknown"
;+ Icons between softkey pics
01B6AC: FA216AB8 FA2164B7
01B8C4: DA2164B7 DA21A0B6
0DA9F6: DA9AF2C7 DA7510DD
#pragma enable old_equal_ff
55DD10: D7400700F2FBBA3C88B048B02D0B48B1
55DD20: 2D0F48B22D1348B32D1748B42D1B48B5
55DD30: 2D1FDB00E6FEA311DA9AF2C7FA757CDD
55DD40: E6FEAE11DA9AF2C7FA757CDDE6FEB411
55DD50: DA9AF2C7FA757CDDE6FEB611DA9AF2C7
55DD60: FA757CDDE6FEAA11DA9AF2C7FA757CDD
55DD70: E6FEAB11DA9AF2C7FA757CDD98E006FE
55DD80: 2A00E6FC2B00E6FD4400DA2DB2D2DB00
#pragma disable old_equal_ff
;Uncomment the next string if using automatic SMS-translit patch
;45DBD3: 954E6F726D616C2044756D6D69652D2D2D2D3100 9B1D353837323541423D4B399595959595959500 ;Unknown
45DC0D: 954B69737300 9B24303A4100 ;Fax
45DC13: 95486F6C6964617900 9B24303A4195203200 ;Fax 2
45DC2C: 9548656172746163686500 9B133E403E34413A3E3900 ;Home
45DC59: 9553686F7070696E6700 9B2030313E4738399500 ;Work
45DC6C: 954368616D7061676E6500 9B1C3E31383B4C3D4B3900 ;Mobile
;Uncomment following strings if illumination does not light up while incoming call
;01B6A6: DA21F2EE DA7500DD
;55DD00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA2160EEE03CE6FDFF7FDAA036D2DB00
;Uncomment the following 2 strings if using automatic SMS-translit patch
55DD36: A311 9F11
45DBA7: 955375624D656E75205469633100 9B1D353837323541423D4B399500
;55DD80: 2A pp ;first pic to use like icon
55DD84: 2B 00 ;2B - abcisse (X)
55DD88: 44 00 ;44 - ordinate (Y)
;Duck pics references (0x2A-0x2F) replacement on corresponding icon references from address book
308150: 31130500472F0F0131130500EA320F01 0F0B0300723F07010F0B0300883F0901
308160: 311305008D360F0131130500303A0F01 0F0B0300693F0A010F0B0300B43F0901
308170: 311305000000100131130500A3031001 0F0B0300303F09010F0B03005C3F0901
Old 08-02-2005, 08:07   #317 (permalink)
Member: 81025
I have forgotten to specify, this patch for version M55 919111
Old 08-02-2005, 11:01   #318 (permalink)
Member: 78176
lalo.lerry: What about my ask for the patch, Eliminate Screen Message Screensaver Active Press "#" to Unlock??
I won't ask you for more patches, but please adopt this one to S55 v91 (and v91 with incflex3)
Old 08-02-2005, 19:00   #319 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
@belwer:
Ehmm... can you post the english version or traslation???
@MagicOl:
Yes I'll make it but not before 10 August, I'm in holiday nowadays and don't have all my patching stuff with me
Old 08-05-2005, 09:00   #320 (permalink)
Member: 81025
hi
I am trying to find the vibra control method (I want to disable vibra while clock alarm and while CB message) but still unsuccessfully
I assume 0xD1DCC0 function concerns it. Does somebody understood what this procedure does and what arguments it demands?
Old 08-23-2005, 19:24   #321 (permalink)
misko903's Avatar
Member: 89407
hi big patchers,
i want to adapt miniGPS for S55. i have source code, and as said DeadManS, only what is different, are adresses of functions:
- Epprom (read/write)
- Fileread
- draw string
He said, that they are already explored, so please... where is list of functions, or can you give me these functs?
MANY THANKS!
Old 09-02-2005, 11:37   #322 (permalink)
Member: 81025
Hi Misko!
What kind of info should be read from EEPROM?
You can find info about file open/output function pointers in Call logging patch.
Would you post the full source code or link on it?
Let's make it together :-)
Old 09-22-2005, 08:06   #323 (permalink)
misko903's Avatar
Member: 89407
http://forum.gsmhosting.com/vbb/show...hlight=miniGPS
that is source code, ok, lets make it togeether. but i havent computer, maybe in october. i am looking forward for it. try to contact acid mrp, he is experienced, maybe he will help us. or lalo, but hes expert for s45i. or avkiev.
i am going ot school now, its late
Old 09-25-2005, 23:36   #324 (permalink)
misko903's Avatar
Member: 89407
hahaaaaaa i have ported auto profile switching to S55, it needs hourly beep and its beeping every minute after hour, counting to 10 (example: 10:00-10:09 beeping)
@belwer
what about cooperation? where are you? im waiting for your help
Old 09-29-2005, 19:43   #325 (permalink)
KoTsK's Avatar
Member: 17360
; S55V91: Disable msg "keys locked"
; (c) avkiev
321EDE: DA72 0D01
Old 09-30-2005, 08:57   #326 (permalink)
misko903's Avatar
Member: 89407
@kotsk:
patch doesnt work, but do you have some S55v91/20 adresses/instructions? i need it for porting advanced patches. i want to port miniGPS, but firstly i need adresses of 2 instructions
Old 10-03-2005, 09:27   #327 (permalink)
Member: 78176
KoTsK: That patch if I good remember disable the screen when pressing "#" to block the keyboard. I am looking for patch to deactivate message after the ScreenSaver is in active mode ;-)
By the way, the patch by lalo.lerry "Eliminate Screen in Keyboard Lock Mode" make some bugs, after pressing 1-9 key the lock mode is turning off. ;-(
Maybe the patch for Digital Camera is the problem, but after unpatching (removing) this patch the problem still was in my phone, so I decided to remove the whole patch - I don't want the patch is turning my phone on in keyboard lock mode after pressing some keys.
Old 10-03-2005, 19:44   #328 (permalink)
Member: 142556
Unhappy SecureSMS problem :(
Hi!
I'd like to start using the SecureSMS patch for S55 (v20, or v91 doesn't matter) but I'm experiencing a little problem, when I insert different SIM card the phone tries to launch the SecureSMS MIDLET and exits with a message like this:
Error: One or more MIDlet class(s) not found: GSM
Is there any way to get it working properly?
THX, greets.
Old 10-03-2005, 20:40   #329 (permalink)
KoTsK's Avatar
Member: 17360
@MagicOl
oups! forgive me
@piotrg___
have you put the requested java files into your phone?
Old 10-04-2005, 08:36   #330 (permalink)
misko903's Avatar
Member: 89407
hi, kotsk, are'nt you interested to miniGPS patch? i am finding some volunteers to port it to S55/M55, because i am too weak to do this alone. so?
M55 flash patching(Thread for discussing) zdob x4x, x5x Flashpatching 880 01-25-2010 05:37
X6x Flash patching(THE Thread for discussing) : zdob x6x and x7x Flashpatching 196 09-04-2006 19:12
SL55 flash patching (Thread for discussing) 3aTmr x4x, x5x Flashpatching 29 03-21-2006 20:40
S55 flash with wrong flash file. WillGsm E-Gold Based Phones 2 01-29-2005 13:58
Page generated in 0.24647 seconds with 11 queries
