06-12-2004, 12:29 | #136 (permalink) | |
Major Poster Join Date: Nov 2003
Member: 44393 Status: Offline Thanks Meter: 0 | Quote:
06-12-2004, 14:50 | #137 (permalink) |
Junior Member Join Date: Jun 2004 Age: 50
Member: 68598 Status: Offline Thanks Meter: 0 | Hi @ ACiD [mrp] you have a little error in your patch. I have corrected it here You wrote: Code: B00000: Code: :0D0000: Big Thanx Here the fixed patch: German LGP fixed and here for all, who have problem to make the BigFlex-Patch a patched Fubu only with english Language S55_Memory_1_71_patched DIGIXP |
06-12-2004, 19:13 | #138 (permalink) |
Member: 44393 Status: Offline Thanks Meter: 0 | Avkiev or somebody else? I have lag pack4 with Greek lang in it.I cut the other langs with notepad so I can use only Greek by applying increase flex mem patch v2 and when I compile the lgp file with lang editor the lengh of the vklay_mem file is 11 mb. so it doesn't work. Can you explain to me step by step how can I have the langpack4_only Greek (must be 64k), PLEASE??? Thanks |
06-14-2004, 09:07 | #139 (permalink) |
Junior Member Join Date: Jan 2004 Location: POLAND (Kalisz)
Member: 50065 Status: Offline Thanks Meter: 0 | May someone remake the following patch for S55 ? Code: ;*** M55V10: Show type of incoming call (Home/Work/Mobile/Fax/Fax2) *** ;© Matr!x - 08/05/2004 ;!Number must be in international format (+XXXXXXXXXXX) ;!Number in address book must be the same as in incoming call number 01B073: 21BEE8 5500DD 01B07A: 36B2 30B1 01B292: 30B1 6CB0 0D9C1F: 9A1CB9 5510DD 35DD00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA21BEE8E03CE6FDFF7FDAA076C3DB00 35DD10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400700F2FBBA3C48B02D0B48B12D0E 35DD20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48B22D1148B32D1448B42D1748B52D1A 35DD30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DB00E6FEA111DA9A1CB9DB00E6FEA211 35DD40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DA9A1CB9DB00E6FEA311DA9A1CB9DB00 35DD50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FEA411DA9A1CB9DB00E6FEA611DA9A 35DD60: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 1CB9DB00E6FEA711DA9A1CB9DB00 45DBED: 95536B796C696E6500 95486F6D6520202000 45DBF6: 9552756E6E696E6700 95576F726B20202000 45DBFF: 9544696E6E657200 954D6F62696C6500 45DC07: 954964656100 954661782000 45DC0D: 954B69737300 954661782000 45DC13: 95486F6C6964617900 954661782032202000 |
06-14-2004, 10:11 | #140 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | Quote:
if you want to use this for BigFlex Patch just applay it on anthoer position (not the one perdefined in Patch) | |
06-14-2004, 17:44 | #141 (permalink) | |
Junior Member Join Date: Jun 2004 Age: 46
Member: 68867 Status: Offline Thanks Meter: 0 | Quote:
... PhoneType S55_20, 000000, x0000,6,8,a,c,e,10,12,16,2a,3c,43,0 AllLangs x MaxMsgId 3836 LgPackId lg1 ; ; ; Language data ; LangId 1 ... x= number of languages(if only greek, the n. is 1) | |
06-18-2004, 21:56 | #145 (permalink) |
Junior Member Join Date: Apr 2004 Age: 40
Member: 63571 Status: Offline Thanks Meter: 0 | Hi. Could someone make anothet modification of soft keys? I like the style of the new x65 series. In those models the two soft keys are joined together (no empty part between them). And there is also an icon between the two sides that indicates the function of up arrow key. And there coud be another modification that makes the same in the upper part of the screen just like in x65 models |
06-19-2004, 01:57 | #146 (permalink) |
Junior Member Join Date: Apr 2004 Age: 52
Member: 62543 Status: Offline Thanks Meter: 0 | Voice Command back after IncFlex3 Dear S55 Flash Patch Community, I used IncFlex3 with the description. Specialty was, that I created a own lang pack with English, German and 2B4.Deutsch from ACID using SLE. This was then 192k long. Everything else was like described by avkiev. And everything works great. But, if I use the "Enable voice dialling and commands after inc. flex" patch from avkiev, my phone goes off right after switching on. Undo patch brings me back of course. Now, my quesiton, does anybody has similar experience and maybe knows how to fix? Meanwhile I will test with shorter Lang Pack, since in avkiev it was not bigger than 128k. Will let you know. Thanks to all the great patcher out there |
06-19-2004, 14:45 | #147 (permalink) |
Member: 68598 Status: Offline Thanks Meter: 0 | Hello I see a little bug in the IncFlex3. When I look in Drive Info, i have free 1.96MB about normaly is 1.71MB What this?? I have more Space free as the Handy can, lol Greez DIGIXP |
06-19-2004, 15:26 | #148 (permalink) |
Crazy Poster Join Date: Dec 2003 Location: Deutschland Age: 37
Member: 46269 Status: Offline Thanks Meter: 0 | I found a bug too. If more free space than 1000kb the phone displays 0.10MB. When I delete some little files with size of 2kb the phone displays free space 1.18, after deleting one file more (2kb) the phone displays 1.20MB and so on. Can anybody fix these bugs? Mfg Athlon |
06-21-2004, 00:34 | #149 (permalink) |
Member: 68598 Status: Offline Thanks Meter: 0 | @Acidmrp What the problem in the send SMS by change Sim? Nobody can say, why come the Error-Message "One or more MIDlet Class(s) not found: GSM.jar" I have used this and the Advanced Patch. Nothing works . Why?? Must be a another Patch ,too? GSM.jar and GSM.jad are in the Orginally Path(a:\Java\jam\SecureSMS\) Please help me to fix this problem. @Acidmrp I can send you a Fubu from my S55 with the SecureSMS-Patch, so you can look for the Problem. When you want, i send you a PN with the Link(i think send by Mail can be a problem with your or my Providers I hope you can help me DIGIXP |
06-21-2004, 13:26 | #150 (permalink) | |
Junior Member Join Date: May 2004 Age: 40
Member: 66014 Status: Offline Thanks Meter: 0 | Quote:
Try it. | |
M55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 880 | 01-25-2010 05:37 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
S55 flash with wrong flash file. | WillGsm | E-Gold Based Phones | 2 | 01-29-2005 13:58 |
