06-21-2004, 14:03 | #151 (permalink) | |
Junior Member Join Date: Apr 2004 Age: 52
Member: 62543 Status: Offline Thanks Meter: 0 | Quote:
same problem with a 128k Lang Pack | |
06-21-2004, 17:33 | #153 (permalink) |
Junior Member Join Date: May 2004 Age: 40
Member: 66014 Status: Offline Thanks Meter: 0 | Than try the other function too. (i don't know the exact name cos i have only Hungarian lang ) Menu:9-4-5-1 and 9-4-5-2 And dont copy back the hidden files. I hope it will work. I had this prob 2 times after each other and than something solved it |
06-22-2004, 21:21 | #155 (permalink) |
Major Poster Join Date: Mar 2004 Age: 43
Member: 59175 Status: Offline Thanks Meter: 0 | can anyone write a patch to increase speed of autorepetition of the keyboard(for v11) when writing text in email section? a patch to increase speed of autorepetition of the keyboard(for v11) exists, but doesn't have efect when writing text in email section! |
06-24-2004, 19:37 | #156 (permalink) |
Member: 66014 Status: Offline Thanks Meter: 0 | I also have a bug. When i write an sms and want to select a name from adresbook I can't jump to a name I want to. So when i want to jump to names beggining with "k" nothing happens |
07-01-2004, 14:13 | #157 (permalink) |
Junior Member Join Date: Jul 2004 Location: Czechia Age: 46
Member: 71089 Status: Offline Thanks Meter: 0 | Problems after IncFlex 3 1) Changing profiles is without any problems 2) AutoProfile is without any problems 3) HandsFree mode before call by left side - key does not work 4) I have applied this patch over the "clear" firmware (original backup). But there is too much mistakes in our translation (Czech mutation). Therefore I used the software Siemens Language Editor v 1.4 to correct them. But this software does not work with this new firmware with increased memory. How can I correct them now? PS: From Supernet2 patch I use only voltage percentage, the others are hidden on my phone. I use transparent numbers and everything seems to work fine for me |
07-01-2004, 14:41 | #158 (permalink) |
Member: 71089 Status: Offline Thanks Meter: 0 | Protecting incomming message by PhoneCode Thank you for developing perfect patch which is protecting Inbox and Outbox by PhoneCode. But when the new message arrives, anybody can simply read it by pressing the soft key under the envelope picture. Is it possible to protect incomming unread message as well? Thank you once more. |
07-01-2004, 14:45 | #159 (permalink) |
Member: 71089 Status: Offline Thanks Meter: 0 | Indentification of the caller's number type Has anybody adapted the patch which is showing small icon of the number type from which is the caller calling from (home/office/mobile/fax)? This patch worked fine for me o my old S45i and I have heard that for M55 it is already adapted as well. |
07-01-2004, 14:56 | #160 (permalink) |
Member: 71089 Status: Offline Thanks Meter: 0 | Phone switches off after aplying Patch "Date&Time instead of Provider Name" When I have applied patch which should show provider name as 09:12 Fr 05 Dec, after shwitching on the phone only shows the startup animation and then I can hear only one beep (instead three) when try to register and then immediately shut down. I have tried to do this several times by renewing the FUBU from backup but without success. Nor removing of this patch helped, the only way how to repair phone was to load the backup of fullflash. Has anybody the same experience and what is the solution? |
07-02-2004, 07:03 | #161 (permalink) | |
Member: 71089 Status: Offline Thanks Meter: 0 | Quote:
07-02-2004, 07:06 | #162 (permalink) |
Member: 71089 Status: Offline Thanks Meter: 0 | Big font for provider Name Is it possible to make the font for showing provider name bigger (much more)? Then would be nice that in screensaver mode would be the time big like on SonyEricssons... |
07-02-2004, 09:53 | #163 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Italy - Rome Age: 45
Member: 26549 Status: Offline Thanks Meter: 1 | Quote:
change with this if you have 2 language PhoneType S55_20, 0D0000, 20000,6,8,a,c,e,10,12,16,2a,3c,0,0 | |
M55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 880 | 01-25-2010 05:37 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
S55 flash with wrong flash file. | WillGsm | E-Gold Based Phones | 2 | 01-29-2005 13:58 |
