11-19-2004, 13:32 | #1 (permalink) |
Junior Member Join Date: Sep 2004 Age: 54
Member: 82887 Status: Offline Thanks Meter: 0 | Screen Capturer I'd like to capture image from my c45 with this Screen Capturer v2.0, but problem is the software doen't want to connect to my mobile. No respon at all. Does anyone know? Or do I need to patch my C45 first to get connected to Screen Capturer? Where can I get that patch? |
11-19-2004, 22:49 | #3 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 41
Member: 91303 Status: Offline Thanks Meter: 0 | You also need to experiment with the settings of the program. For example for sl45 I have to use 19200 as speed, AT+CGSN type 3. I don't know if it will work for you too but you can try. Regards Froster |
11-20-2004, 01:21 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Ankara, Turkey Age: 50
Member: 69110 Status: Offline Thanks Meter: 0 | @darshan_ss: actually there are two options for screen capturing of c45; (1) Siemens Screenshot v1.0.2.0 by ACID[mrp] and (2) Screen Capturer v2.0 by Riza. For the first one you need as misko903 stated an open "BFB patch" and for the second one you will need "ATCGSN Patch". The problem is that for version 50 I could not find any "ATCGSN Patch" and "BFB patch" that I obtained according to the instructions of ACiD[mrp] did not work for Siemens Screenshot. Thus, two alternatives gave no positive result but if you can find "ATCGSN Patch" for c45 version 50 please let me know. I have "ATCGSN Patch" for c45 version 38 but it does not work for version 50. In case we have "ATCGSN Patch" for c45, we can also employ ADVANCED AT+CGSN Debugger for Siemens Mobiles v1.5.7.0 that has a Playfield option for screen capturing. Here are some basic patches for c45 version 50. you will need them before you attempt to capture the screen; ; C45 v50 lg1 T9lg1 - Patch made by "Smelter" © avkiev ; http://www.avkiev.siemens-club.ru/Si...er/Smelter.htm ;************************************************* ****** ;Standard patches : 0D7ADA: 3D0A CC00 ; DisableFirstCRC1 0D7AE8: 3D03 CC00 ; DisableFirstCRC2 0DC080: 2D 0D ; DisableSecondCRC 0A19CA: 2D 0D ; EnableDevMenu 341C6C: 3D 0D ; DisableAircraftCheck 07FF64: 01149013D513911302140314 000000000000000000000000 ; OpenHiddenEEPROM 092B24: 76 60 ; Open BFB ;************************************************* **** Regards, Naransula Last edited by naransula; 11-20-2004 at 01:35. |
11-20-2004, 01:44 | #6 (permalink) |
Member: 69110 Status: Offline Thanks Meter: 0 | @lalo.lerry: I have attempted to capture the screen of c45 version 50 after applying the BFB patch required for Siemens Screenshot v1.0.2.0 but there was no positive result. Could you modify the patch placed below in order to test screen capturing by means of Screen Capturer v2.0 and ADVANCED AT+CGSN Debugger for Siemens Mobiles for version 50? I don't have version 38 installed on my c45. Thus, I could not test whether the second solution work or not. Thanks in advance for your kind help, Naransula ; Firmware : C45 v38 ; Author : original by RizaPN improved by Chaos, SiNgle, Dr.On ; mamaich ported to C45 by ACiD[mrp] ; yeahhh team work ; Homepage: www.gsm-dev.com ;---- New block. Segment address:220000-------- 0022E162: E280DD00 883BE500 ;---- New block. Segment address:E50000-------- 00253AF2: FFFFFFFFFFFFFFFF E004BB029DFECB00 00253AFA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49992827F230008D0C47F20A008D06 00253B0A: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 67F2DF00292747F20F00ED035C447182 00253B1A: FFFFFFFFFFFF CB001F88CB00 00253B20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 885088E088F088C0E00C88C088D0F182 00253B30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7C44F19266F40F0F47F90A008D010997 00253B40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 47F80A008D01098706F430308840F0C0 00253B50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 66FCFF3FF2FD02FEDADEC25E080698C0 00253B60: FFFFFFFFFFFFFFFF 98F098E09850CB00 00253B68: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F01E7C81E00DBBD8F01EE6FD2000BBD4 00253B78: FFFF CB00 00253B7A: FFFFFFFF 998C7C44 00253B7E: FFFFFFFFFFFFFFFFFFFF E004BBBC8D01BBBACB00 00253B88: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DADE983CF084F095DC49993827F32A00 00253B98: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02FADDE280BBA9F0F4BBA7F0E44930 00253BA8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D1729342D4E27F312002D18E6FD0D0A 00253BB8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBB3E17BE1FAE6FD2000DC4F992EBBAC 00253BC8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0D0A29A12DF99DF629B19DF30D53 00253BD8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBD28D51DC4FB98E08E10DFA88408850 00253BE8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D088E088F0E00CE00DE00EE00F 00253BF8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBC28D1A70C4BBBF8D175C8C70C4BBBB 00253C08: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D1370D4BBB88D105C8D70D4BBB48D0C 00253C18: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70E4BBB18D095C8E70E4BBAD8D0570F4 00253C28: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BBAA8D025C8F70F498509840DAE5823C 00253C38: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E4BB96F0E5BB9498D098C098509840 00253C48: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0D1A26F04000F020BB968D03B9820821 00253C58: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0DFB2020A758A7A708E12D0BF010F0DE 00253C68: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0C2DC4F998D498D3DF528C13DFACA00 00253C78: FFFFFFFFFFFFFFFFFFFF 683B06F04000FADEA437 00253C82: FFFFFFFFFFFF ECF5ECF4DB00 |
11-20-2004, 02:54 | #9 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | ok, will get a look when I have TIME. If you could tell me if C45v38 version patch work will be much helpfull, I don't want to waste time adapting a not working patch. BTW, S45iv04 version doesn't work |
11-20-2004, 03:04 | #10 (permalink) |
Member: 69110 Status: Offline Thanks Meter: 0 | c45v50 "ATCGSN Patch" would be the best solution. I noticed that the empty space occupied by c45v38 ""ATCGSN Patch" is also available on virgin c45v50. the only problem is with the version differences and the entry point to the patch. I hope this information saves your time :-) |
11-23-2004, 02:03 | #11 (permalink) |
Member: 70990 Status: Offline Thanks Meter: 1 | @darshan_ss: If you want to take images from your c45, please try this: Siemens Screenshot by ACiD. http://mobiletuning.de/ Navigate... GSM-Dev Projekte > alle... > Siemens Screenshot > Download Hope it's usefull for you!? BR genetic1 |
javax.comm - Mobile phone screen capture | from_far_away | Java, iOS, Android, Symbian development | 1 | 10-11-2006 06:37 |
