02-17-2003, 19:44 | #5 (permalink) |
No Life Poster Join Date: Dec 2002 Location: U.K Age: 35
Member: 18319 Status: Offline Thanks Meter: 0 | yer ok but wont you beable to bye a buzzer that will stand the polyphonic ring tones i meen like a nokia or some other make of buzzer and put it on the SL45i |
02-17-2003, 22:16 | #6 (permalink) | |
Freak Poster Join Date: Feb 2003 Location: Latvia, Riga Age: 46
Member: 20879 Status: Offline Thanks Meter: 0 | Quote:
02-17-2003, 22:27 | #7 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | But rather take tis one, sounds like polyphonic, and fits for SL It`s best collection from the previous site http://www.mrneo.pisem.net/Music/Pol...polyphonic.zip |
02-18-2003, 00:57 | #8 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | @ Robbiesl42 Yes, it might work... But where could be found a buzzer with those capabilitys and also compatible with SL45 hardware? I guess thatīs the most difficult thing. Maybe with some Russian help this goes on... I refer Russians, because theyīre very good on tunning phones, but others too (Croatian, Servian, etc... and of course Chinese). |
02-18-2003, 14:00 | #10 (permalink) |
Junior Member Join Date: Jul 2002 Age: 25
Member: 13992 Status: Offline Thanks Meter: 0 | The SL45 does not use a buzzer. It uses the loudspeaker to create the ring. Its all in the way the thing is wired and there is no way you will get polyphonic ring tones with firmware modifications. From the service manual: "The SL45 has no ringer component. Responsible for the audio output of the ringer tones is the loudspeaker. The ringer tones are generated by a signal RINGIN from the EGOLD+ (Miscellaneous M11). This signal goes to the mono audio amplifier inside the Schalke-ASIC." Which basically means, no way, no how. |
03-03-2003, 04:51 | #13 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Hi All... As you know we can use BIN file as our SL ringtone (use ffmod or any other MelodyChanger s/w). Data stored inside that BIN file is : frequency and duration (fL fH dL dH ==> freq_in_word dur_in_word). Using this format, actually we can use not only MIDI like ringtone (MIDI has only some predetermined frequency with some fixed duration), but also (in my opinion) WAV like format. I don't have any experience with that format (freq+duration) to create WAV like, but I have some experience with that BIN file (for ringtone). So, if anyone has that kind of information, maybe we can share, and create some "unusual" ringtone for our phone ... RizaPN |
03-03-2003, 14:38 | #15 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | That's why I post that. If someone know how to convert WAV file to a sequences of frequency and duration data (WAV is a sequence of voltage/amplituda), then yes, it is possible. RizaPN |
Nokia Indin Polyphonic Ring Tones | tanveeranjum | Nokia Multimedia | 0 | 02-16-2010 20:30 |
Bollywood Midi Ring tones Polyphonic only | shoaibk7 | Nokia Multimedia | 0 | 12-03-2005 20:40 |
Free Bollywood PolyPhonic Ring Tones | Kashif | Nokia Multimedia | 8 | 04-03-2004 08:21 |
free polyphonic ring tones | omps | GSM Mobile Links | 0 | 07-23-2003 10:45 |
