Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 05-14-2004, 19:20   #16 (permalink)
Member: 52595
;*** Eliminate the request of confirmation before activating handsfree during call ***
;original patch by © avkiev (m55v10)
;adapted for SL55 v16 by Roxxy
;Luki's Siemens Modding Forum
2DD4FC: E01CE6FD4907E00E DAAFA02EFA6D10D5
Old 05-18-2004, 13:23   #17 (permalink)
Member: 52595
;*** Shortcut Key 1 from vocal message to other ***
;Firmware: SL55 v14
;Author: Roxxy
;Release: 18.05.2004
2F6065: 2C 0A
2F61B4: 32 31
2F6421: 0C 0F
2F6441: 6DCE6A 6E94EE
2F5C98: 3D 0D
2F5ED2: 3D 0D
2F63CB: 20 5A
Old 05-23-2004, 20:12   #18 (permalink)
Member: 52595
;*** Extended Call list ***
;Firmware: SL55 v16
;Author : Roxxy, adapted from © Matr!x
;Green button -> "Calls dialed"
;Red button -> "Calls received"
;Red button -> "Calls missed"
;Red button -> Ready
2E1147: 8F4AA3 61CC69
2169CC: FFFFFFFF DA8F4AA3
;2169D0: FFFFFFFF FA8F4EA3 ;1-Dialed, 2-Received
2169D0: FFFFFFFFFFFFFFFF DA8F4EA3FA8F02A3 ;1-Dialed, 2-Received, 3-Missed
Old 05-27-2004, 13:29   #19 (permalink)
Member: 52595
;*** Cool changes in menu separator***
;Firmware: SL55 v14
;Author: © ILL! M55v10(V11)
; S55v20 (p) KiRiK
;Adapted for SL55 v14 by Roxxy
;Line
;4BFF1: 55555555555555555555555F FFFFFFFFFFFFFFFFFFFFFFFF
;53FF3: AAAAAAAAAAAAAAAAAAAAAAFF FFFFFFFFFFFFFFFFFFFFFFFF
;Dosh dat dot
;4BFF1: 55555555555555555555555F 8F11E23C4788F11E23C4788F
;53FF3: AAAAAAAAAAAAAAAAAAAAAAFF 8F11E23C4788F11E23C478FF
;Spaced Dots
;4BFF1: 55555555555555555555555F 22222222222222222222222F
;53FF3: AAAAAAAAAAAAAAAAAAAAAAFF 8888888888888888888888FF
;Nothing
4BFF1: 55555555555555555555555F 00000000000000000000000F
53FF3: AAAAAAAAAAAAAAAAAAAAAAFF 00000000000000000000007F
Old 05-27-2004, 13:32   #20 (permalink)
Member: 52595
;*** View Flash SMS as Fullscreen ***
;Firmware: SL55 v14
;Author: Roxxy and Lalo
302D52: 3D 2D
302D69: 0C 1C
Old 06-18-2004, 22:42   #21 (permalink)
cls
Member: 34356
Thanks Meter: 9
;*** Disable aero check ***
;SL55 v16
;by Girosavo
2F0E94: 3D 0D
Old 06-22-2004, 13:58   #22 (permalink)
cls
Member: 34356
Thanks Meter: 9
;*** Deletes the softkeys from mainscreen ***
;SL55 v16
;original patch by SiNgle on M55v11
;adapted by Giro
2E0AFC: 2D 0D
2E0BD8: 3D05 CC00
Old 06-22-2004, 13:59   #23 (permalink)
cls
Member: 34356
Thanks Meter: 9
; Change style of locked softkey
; Firmware : SL55v16
;adapted by Lalo
; Version 1:
610568: AA 00
; Version 2:
;610568: AA FF
Old 06-24-2004, 23:32   #24 (permalink)
lalo.lerry's Avatar
Member: 50673
Thanks Meter: 2
;*** VIN. Vibra Indicator ***
;Firmware : SL55 v.16
;Author : Lalo
;(adapted from an Acid S55 patch -great respect to him-)
;luki's Siemens Modding Forum
;Release : 25.6.2004 - v1
;This patch shows vibra state icon using n.289 (vibra off) and n.290 (vibra on) pictures, based on SPC numeration.
;choosen resolution is 21*9*2, that is the defoult one for icons, but you can of course make your own and change it.
;The icon stays just under the Accu simbol in stand-by, and is always visible even when digiting numbers (like profile logo patch).
2E73CE: DA6EEC6C DA61E069
2169E0: FFFFFFFFFFFFFFFF DA6EEC6CDA9824E9
2169E8: FFFFFFFFFFFFFFFF E00E48402D0108E1
2169F0: FFFFFFFFFFFFFFFF 06FE2101E6FC5000
2169F8: FFFFFFFFFFFFFFFF E6FD0900DA6EEC6C
216A00: FFFF DB00
;patch customization:
;2169F2: 2101 zzzz ; number in hex swapped bytes of the first picture
;2169F6: 50 xx ;xPos, form the left side
;2169FA: 09 yy ;yPos, form the top
;note: if you change position, be carefull to avoid overlapping.
;NN.289-290 PICTURES DATA SAMPLES:
; ##### Picture 289 #####
; Picture Table Index
0F6E52: 32140100 15090300
; Picture Data
0AFF20: 000003F000003F00000FE000003F0000 FFFFFFFFFFC0FFFFC0FC3FC0FCF33FC3
0AFF30: 3FC1FCC43F0003FF800000BF00FFFFC0 FFC0F3CF3C3FF3C0FCF3C3F3CFC0F3FC
0AFF40: 0001BF03F7FFFC00033F1FC7FFFFE007 3F3CF3C0FFC3FF33CFC0FC3FC0FFFFC0
0AFF50: 3F7FBFFBFFFE1F3F7FFF7DBFFFFE3F3F FFFFFFFFFFC00F0F0F0F0F0F0F0F0F0F
0AFF60: DE3EDFFFFC3F1F8E1F6FFFFE3F07040F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0AFF70: B7FFFE3F0100076FFFFF3F000023FFFC 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0AFF80: 0F3F00847DFFE007BF01CEFFFC0003BF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0AFF90: 01FFFFE00001FF007FFFF87D883F003F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0AFFA0: C00000003F0000000000003F 0F0F0F0F0F0F0F0F0F0F0F0F
; ##### Picture 290 #####
0F6E5A: 31130100 15090300
; Picture Data
0B3F20: 0000003800007F0000002400007F0000 FFFFFFFFFFC0FFFFC0FFFFC0FCF33F33
0B3F30: 000400007F0000002400007F00000044 CFC0F3CF3F3CF3C0FCF33F33CFC0F3CF
0B3F40: 00007FFFFC008800007FFFFFF1080000 003CF3C0FCF33F33CFC0FFFFC0FFFFC0
0B3F50: 7FFFFC0E1FE0007FFFFC180110007FFF FFFFFFFFFFC00F0F0F0F0F0F0F0F0F0F
0B3F60: FC100010007FFFFC100070007FFFFC10 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0B3F70: 0110007FFFFC100010007FFFFC100070 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0B3F80: 007FFFFC100110007FFFFCD00010007F 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0B3F90: FFFCD00070007FFEAC180110007FFFFF 0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F0F
0B3FA0: E7FFE0007F 0F0F0F0F0F
Enjoy it!
© Lalo 2004 Luki's Siemens Modding Forum
Old 09-02-2004, 15:38   #25 (permalink)
cls
Member: 34356
Thanks Meter: 9
;*** Change Default Vibra ***
;© Divisi0n_by_zer0 M55v10
;(p) KiRiK SL55v14
;!Identical with S55v20 - don't be scared!
10F0EE: F401 FA00 ;vibra duration in ms
10F0F2: F401 FA00 ;pause duration in ms
;duration is in milliseconds in hex format, then swap the two bytes
;duration is 500 ms by default (01F4), changed to 250 ms (00FA) in the patch
;substitute FA00 with what you need
;vibra and pause duration may differ
Old 01-22-2005, 00:55   #26 (permalink)
zdob's Avatar
Member: 2911
Thanks Meter: 3
[GLOW=red]This is topic for patch only. Other reply 'll be deleted. Use other topics for discussing.. [/GLOW]
Thread for discussing:
The list of the members which are not respecting the Authors
SL55 flash patching (Thread for discussing) 3aTmr x4x, x5x Flashpatching 29 03-21-2006 20:40
SL55 java patch chrisonic E-Gold Based Phones 5 10-17-2004 16:49
SL55 Flash Patches Acidmrp E-Gold Based Phones 3 04-06-2004 14:46
SL55 Flash Patching Acidmrp E-Gold Based Phones 2 09-24-2003 14:30
Sl55 flash with russian? odyssey x1x to x45/x50 1 05-21-2003 07:03
Page generated in 0.21725 seconds with 10 queries
