Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-09-2003, 12:13   #16 (permalink)
Member: 21009
Short UP arrow to unlock keypad, and PTT button for VoiceDial when keypad is locked :
0x3B07C4 : 1E -> 21 UP arrow unlock keypad
0x3B07C7 : 03 -> 04
0x3B07CA : 1F -> 1E PTT button for VoiceDial
0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA EC F6 0D 0F
Old 02-10-2003, 09:44   #17 (permalink)
Member: 21092
Hi!
RizaPN wrote how to make AeroOFF, I tried to make as he said but aero confirmation is still working.
Somebody write this patch again, please.
Old 02-10-2003, 10:12   #18 (permalink)
Member: 9891
Thanks Meter: 2
Turn AeroCheck Off ...
Turn off AeroOff:
This is one method (modify EEPROM value). There is also another method ...
0x5FE626 : ?? -> 0A (?? is whatever)
RizaPN
ps:
- could somebody which has Aeroplane Check on in his SL45v56, post here the original value of that 0x5FE626 address ? I can not turn my Aero check ON (want to try another method without touching EEPROM area) ...
Old 02-10-2003, 11:10   #19 (permalink)
Member: 21092
Original value of 0x5FE626 is 09 FF
0x5FE626 : ?? -> 0A - it doesn' work :-(
Old 02-10-2003, 11:24   #20 (permalink)
Member: 20791
Originally posted by Demiurrg
Hi!
U know russian? Shure! Please, visit my site. All of russians made it under my description.
Personaly Thank Denk!
Old 02-10-2003, 11:37   #21 (permalink)
Member: 21092
Werefox, I know your site well. InitService doesn't work on my computer because of WIN XP...
That's why I'm trying another solutions but they don't work either.
Old 02-10-2003, 13:35   #22 (permalink)
Member: 9891
Thanks Meter: 2
Disable Aeroplane check ...
Turn off Aeroplane Check :
0x4522F2 : 3D -> 0D
Modify #[UpperRight] from "View New CB" to "Java"
It will keep the ability to use # button to view the flash message when it is there...
If you already apply this patch with the old values, don't forget to reset all data to the original ones
0x3B31AC : 7D 03 -> B0 0D ...
0x3B3398 : DA D9 1A 49 -> DA D8 B4 E1 ... (see table)
RizaPN
Old 02-10-2003, 17:01   #23 (permalink)
Member: 21092
YES! Rizapn, you are great again! Now AERO is really OFF!!!
Old 02-11-2003, 17:03   #24 (permalink)
Member: 9891
Thanks Meter: 2
*** Toggling between SIM-Location and Addressbook when entering SMS Recipient No. ***
0x341EAB : 09 -> 11
0x341EBC : 0D 0F F0 C8 -> E6 FC FF FF
0x341EC0 : F0 D9 E0 8E DA D4 FC 33 -> D7 40 34 00 54 FC 1C 3E
0x341EC8 : 48 40 EA 20 -> CD 09 0D 01
Remark:
It is rather dirty patch. SIM Location and Addressbook data will be toggled if there is data inside the Addressbook. For example : first time, pressing Left soft key will enter to Addressbook, then 2nd time (press RED then press Left soft key again), it will enter to SIM Location, ...
It also happened if we select "Insert From" option ...
RizaPN
Old 02-11-2003, 20:54   #25 (permalink)
Member: 9095
To RizaPN:
Great patch again! But I think that address should be 0x34xxxx not 0xD4xxxx, right?
Old 02-11-2003, 21:51   #26 (permalink)
vikado77's Avatar
Member: 13636
hi,
can somebody make a fubu with the sms, key-lock and illumination function.
it's new for me.
thanks!
Old 02-11-2003, 22:08   #27 (permalink)
Member: 12263
fantastic work Riza! great!
for the address: Riza think always with start address A00000....
Wind
Old 02-12-2003, 00:26   #28 (permalink)
Member: 9891
Thanks Meter: 2
@drzonca and Wind:
Yes, you are right... I did a wrong copy-paste. It was my original note. When I do disassembly, I use flash (not file) address, and like Wind wrote: I always use 0xA00000 as a start address.
RizaPN
Old 02-12-2003, 08:33   #29 (permalink)
Member: 20789
Hi Riza
Thanks for all your patches they are very good!
But can you add shortcut on the right arrow key (or whatever) for VIBRATOR option???
so we don't have to turn in on/off throught profiles...
PLEASE
Old 02-12-2003, 15:57   #30 (permalink)
vikado77's Avatar
Member: 13636
@rizapn
you are great! thanks!
i can't still believe it!
I have a question to the PTT-funktion:
is it possible, to edit the ptt-function:
To open the mp3-player direct (not voice-dail) and chose the next mp3-title in the mp3-player play-mode (the fast forward play-mode is terrible!)
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 10:51
Problem to flash 7200! 2nd Boot Error Maurone Twisterflasher 1 03-26-2005 18:17
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 03:20
Dead SLik.. Unknown flash type. Pls Help Death_star Siemens-Benq RingTones and WallPapers 12 03-16-2003 00:30
Dead SLik.. Unknown flash type. Pls Help Death_star x1x to x45/x50 18 03-07-2003 17:13
Page generated in 0.30318 seconds with 9 queries
