02-09-2003, 12:13 | #16 (permalink) |
Junior Member Join Date: Feb 2003 Location: Russia Age: 52
Member: 21009 Status: Offline Thanks Meter: 0 | 0x3B07C4 : 1E -> 21 UP arrow unlock keypad 0x3B07C7 : 03 -> 04 0x3B07CA : 1F -> 1E PTT button for VoiceDial 0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA EC F6 0D 0F Last edited by Yurgen1; 02-09-2003 at 12:34. |
02-10-2003, 10:12 | #18 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Turn AeroCheck Off ... Turn off AeroOff: This is one method (modify EEPROM value). There is also another method ... 0x5FE626 : ?? -> 0A (?? is whatever) RizaPN ps: - could somebody which has Aeroplane Check on in his SL45v56, post here the original value of that 0x5FE626 address ? I can not turn my Aero check ON (want to try another method without touching EEPROM area) ... Last edited by rizapn; 02-10-2003 at 10:31. |
02-10-2003, 11:24 | #20 (permalink) | |
Junior Member Join Date: Feb 2003 Location: Kiev, UA Age: 53
Member: 20791 Status: Offline Thanks Meter: 0 | Quote:
Personaly Thank Denk! | |
02-10-2003, 11:37 | #21 (permalink) |
Junior Member Join Date: Feb 2003 Location: Moscow, Russia
Member: 21092 Status: Offline Thanks Meter: 0 | Werefox, I know your site well. InitService doesn't work on my computer because of WIN XP... That's why I'm trying another solutions but they don't work either. |
02-10-2003, 13:35 | #22 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Disable Aeroplane check ... Turn off Aeroplane Check : 0x4522F2 : 3D -> 0D ~~~~~~~~~~~~~~~~~ Modify #[UpperRight] from "View New CB" to "Java" It will keep the ability to use # button to view the flash message when it is there... If you already apply this patch with the old values, don't forget to reset all data to the original ones 0x3B31AC : 7D 03 -> B0 0D ... 0x3B3398 : DA D9 1A 49 -> DA D8 B4 E1 ... (see table) ~~~~~~~~~~~~~~~~~ RizaPN Last edited by rizapn; 02-10-2003 at 14:54. |
02-11-2003, 17:03 | #24 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | *** Toggling between SIM-Location and Addressbook when entering SMS Recipient No. *** 0x341EAB : 09 -> 11 0x341EBC : 0D 0F F0 C8 -> E6 FC FF FF 0x341EC0 : F0 D9 E0 8E DA D4 FC 33 -> D7 40 34 00 54 FC 1C 3E 0x341EC8 : 48 40 EA 20 -> CD 09 0D 01 Remark: It is rather dirty patch. SIM Location and Addressbook data will be toggled if there is data inside the Addressbook. For example : first time, pressing Left soft key will enter to Addressbook, then 2nd time (press RED then press Left soft key again), it will enter to SIM Location, ... It also happened if we select "Insert From" option ... RizaPN Last edited by rizapn; 02-12-2003 at 00:22. |
02-12-2003, 00:26 | #28 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @drzonca and Wind: Yes, you are right... I did a wrong copy-paste. It was my original note. When I do disassembly, I use flash (not file) address, and like Wind wrote: I always use 0xA00000 as a start address. RizaPN |
02-12-2003, 08:33 | #29 (permalink) |
Junior Member Join Date: Feb 2003 Age: 40
Member: 20789 Status: Offline Thanks Meter: 0 | Hi Riza Thanks for all your patches they are very good! But can you add shortcut on the right arrow key (or whatever) for VIBRATOR option??? so we don't have to turn in on/off throught profiles... PLEASE |
02-12-2003, 15:57 | #30 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | @rizapn you are great! thanks! i can't still believe it! I have a question to the PTT-funktion: is it possible, to edit the ptt-function: To open the mp3-player direct (not voice-dail) and chose the next mp3-title in the mp3-player play-mode (the fast forward play-mode is terrible!) Last edited by vikado77; 02-12-2003 at 21:16. |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
Problem to flash 7200! 2nd Boot Error | Maurone | Twisterflasher | 1 | 03-26-2005 18:17 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
Dead SLik.. Unknown flash type. Pls Help | Death_star | Siemens-Benq RingTones and WallPapers | 12 | 03-16-2003 00:30 |
Dead SLik.. Unknown flash type. Pls Help | Death_star | x1x to x45/x50 | 18 | 03-07-2003 17:13 |
