02-16-2005, 16:15 | #406 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 41
Member: 91303 Status: Offline Thanks Meter: 0 | ;Author: Froster ;Before installing the add on you need to have RBL 2.2 installed. ;Patch gives the possibility of displaying the readings from ;the netmonitor only when the keylock is active or inactive. 454F20: DAE0BACACC00 DAE4B050CC00 3B3A4C: DAE0BACACC00 DAE4B050CC00 454BCA: DAE010CA DAE4E050 3B36E4: DAE010CA DAE4E050 4450B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0DAA3924098D098C048402D02 4450C0: FFFFFFFFFFFFFFFFFFFF FAE0BACAFAE4D050DB00 ;batery reading invisible on keylock ;4450C0: FFFFFFFFFFFFFFFFFFFF FAE4D050FAE0BACADB00 ;batery reading visible when keyboard is active 4450D0: FFFFFFFFFFFFFFFF 26FC1A00E00DDB00 4450E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D0DAA3924098D098C048402D02 4450F0: FFFFFFFFFFFFFFFFFFFF FAE010CAFAE40051DB00 ;net reading invisible on keylock ;4450F0: FFFFFFFFFFFFFFFFFFFF FAE010CAFAE40051DB00 ;net reading visible when keyboard is active 445100: FFFFFFFFFFFFFFFF E00CE00DDB00 |
02-17-2005, 09:18 | #407 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Monthly Calendar (Binary File) ;*** Monthly Calendar (Binary File) *** ;Firmware : sl45v56 ;Author : rizapn ;Published : Febr 17, 2005 ;It is a binary file to display a calendar using monthly format. ;Just to demonstrate how the additional functions is also possible to be ;implemented using a binary file. ;Key usage: ;- UP/DOWN or 3/9 : Prev/Next Year ;- LEFT/RIGHT : Prev/Next Month ;- 2/8 : Prev/Next 10 years ;- 1/7 : Prev/Next 100 years ;Download the source from http://www.geocities.com/rizapn/sl45/cal.asm and ;http://www.geocities.com/rizapn/sl45/sl45.inc or from the attachment. ;After downloading the latest sfe (v2.41), or at least 2.39 ;enter these commands through the Windows' DOS prompt ... sfe a cal.asm p > cal.txt del Calendar.bin sfe p Calendar.bin cal.txt 08,CAL ;and then transfer the created Calendar.bin file to your MMC. ;Or just extract it from the attached file and then copy it. ;ps: rename the attachment file from .zip.txt to .zip only ... ;rizapn Last edited by rizapn; 02-17-2005 at 10:59. |
02-20-2005, 15:14 | #408 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Sokomin Game ;*** Sokomin Game *** ;Firmware : sl45v56 ;Author : rizapn ;Published : Febr 20, 2005 ;My first game written totally in C166 bytecode ... ;Sokomin is a name that I choose for my SL45 midlet porting of Sokoban game. :It is also possible to put it in the firmware as a patch (to change the built-in ;Move The Box game). Get the source from my place, ;http://www.geocities.com/rizapn and ;http://groups.yahoo.com/group/z-soft/files/Siemens ... ;rizapn |
02-20-2005, 18:37 | #409 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | So, I might have forgotten to publish one auto record patch from August last year... if someone doesn't want auto answer patch, you can try this one. ;*** Auto Record v3 BETA & Vibra when connected*** ; Firmware: SL45i v56 ; Author: rizapn (main patch), vBartek (ideas), rc-flitzer (some corrections) ; Release: August 7th, 2004 ; Does auto record any incoming and outgoing call. ; Vibrates 1 times short when connection is established (only if vibra is enabled). ; Patch is selectable through profile 1, function 14. 0x3AC4C8: F0C8F0D9 DAC7B0E6 0x3AC51C: F0C8F0D9 DAC7B4E6 0x27E6B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01C0D13D7403700F2FC043A2D12D740 0x27E6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0E00F2FC423A9AFC07D0DADEA6172D02 0x27E6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC36C02DAD414F3E00CD7403700F6FC 0x27E6E0: FFFFFFFFFFFFFFFF 043AF0C8F0D9DB00 ; If you do not want vibra when connecting, uncomment this: ; 0x27E6D0: DAC36C02 CC00CC00 ; If you want to skip vibra flag (always vibrate when connected), use this: ; 0x27E6CE: 2D02 CC00 ; If you want to make it selectable with other function / profile, use this: ; 0x27E6C0: 0E00 xxxx ; where xxxx is 0E00 (profile 1) or 3600 (profile 2&3) ; 0x27E6C4: 423A xxxx ; 423A (profile 1) or 6C09 (profile 2) or 6E09 (profile 3) ; 0x27E6C9: D0 x0 ; where x is function number minus one (0-F for function 1-16) |
02-21-2005, 14:16 | #410 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** Sokomin Game (Update) *** ;Firmware : sl45v56 ;Author : rizapn ;Updated : Feb 21, 2005 ;Source is available for download in my sites, both Geocities and Yahoo!Group ;Attached is .bin and .vkp version ;Patch (.vkp) version will overwrite the old "Move the Box" game. I don't use Help ;because all Move the Box levels is also included in the Sokomin (level 112-118) ;rizapn |
02-23-2005, 12:50 | #411 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | ;*** Enable MP3 and VoiceDialing in Carkit and in Dockstation *** ; ;Firmware: SLIK56 ;Author: abomin ;Release: 23.02.2005 ; ; Enable MP3 in Carkit and in Dockstation 3B85A1: 21 2D ; ; Enable VoiceDialing in Carkit 46A820: 9A0A 0D14 ; ; Thanks to trustkill for testing ;------------------------------- |
02-24-2005, 23:30 | #412 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Poznan, Poland Age: 37
Member: 94448 Status: Offline Thanks Meter: 0 | Thermomether in binary file I make my first bin file, and first patch which I publishing in this forum. Its a simply thermomether. Let's check it: Download Last edited by sc0ty; 02-26-2005 at 22:45. |
03-01-2005, 14:12 | #414 (permalink) |
No Life Poster Join Date: Dec 2000 Age: 44
Member: 2911 Status: Offline Thanks Meter: 3 | [GLOW=red]This is topic for patch only. Other reply 'll be deleted. Use other topics for discussing.. [/GLOW] P.S. If you not so silly then do not do it again.........because i see a lot of people which don't respected our work and still post stupid messages in this section ...... Thread for discussing: The list of the members which are not respecting the authors and something else: waiting for bad messages |
03-01-2005, 16:39 | #415 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | New version of my binary thermomether. This version isn't switched off thermomether after 2 minuts like v1.0 Download And my new patch - fast animated logo when keylocked ;***Fast animated logo when keylocked*** ;sc0ty ([email protected]) ;Mar 01, 2005 ;Poznan, Poland ;About 10 seconds after keylock starts fast animated logo. ;If you want to see mainscreen you can press any key. 0x3B37F6: E6F95501 DAC790D5 0x27D560: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403400F2FE1C3E08E146FE0A003D01 0x27D570: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00ED7403400F6FE1C3E06FE8702E00C 0x27D580: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00DDAC1EC22DAF0AC7FDAF0C07EDB00 0x27D590: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403400F2FC1E3E46FC0A003D1D46FC 0x27D5A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF2D1726F01000E6FCFA15E6FD1F03 0x27D5B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAD6DE31E6FC9600E00DE6FE60D5E6FF 0x27D5C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C700DADA68FCE6FCFFFFD7403400F6FC 0x27D5D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1E3EE6F95501DB0008C1D7403400F6FC 0x27D5E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1E3EE6F95501DB00DAD66002E00CD740 0x27D5F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3400F6FC1E3EFAD62031E8D5C7008ED5 0x27D600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C7008ED5C7008ED5C70060D5C7001000 0x27D610: FFFF C400 ;max frames: 0x27D56C: 0A00 ;number of first image 0x27D57C: 8702 ;delay befor run logo 0x27D59A: 0A00 ;delay (ms) before show next frame 0x27D5B4: 9600 |
03-02-2005, 13:07 | #416 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Russia, Zelenograd Age: 35
Member: 70080 Status: Offline Thanks Meter: 2 | ;*** MP3 indicators v 2.0 *** ;sc0ty ([email protected]) ;Poznan, Poland ;Befor you apply this patch, you must undo previous version ;This patch adding a regulation of volume, trebble and bass in MP3 player 0x3BA188: 46F13E00 FAE0F27C 0x2122F6: 26F02200 DAE0867D 0x407C22: FFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC7EEABECF1ECFCECFDECFEECFF 0x407C30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00C88C0E6FCFF00E6FD4300E6FE6500 0x407C40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FF1300DAC0D0E50802E01C88C0E6FC 0x407C50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF00E6FD4300E6FE6500E01FDAC0D0E5 0x407C60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0802F0C026FC400066FCFF3FF2FD02FE 0x407C70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FF8103E6FE9C3DDAC71685EC00E600 0x407C80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3200F0D026FD4100F0CD06FCFF00F3F2 0x407C90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B42F07F23000B92CF0CD06FC1500F3F2 0x407CA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B52F07F23000B92CF0CD06FCFF00F3F2 0x407CB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B62F07F23000B92CFC00E09CF2FD02FE 0x407CC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E026FE400066FEFF3F88C088D088E0 0x407CD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FCFF00E6FD4600E6FE6500E6FFFF00 0x407CE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAD658A30806FCFFFCFEFCFDFCFCFCF1 0x407CF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DB00E6003200ECF146F133003D0BF3F2 0x407D00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B52F49232D380921DAD07A5CDAE0227C 0x407D10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FCF1DB0046F136003D0BF3F2B52F4920 0x407D20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D2A2921DAD07A5CDAE0227CFCF1DB00 0x407D30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F131003D0BF3F2B62F49232D1C0921 0x407D40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAD0985CDAE0227CFCF1DB0046F13400 0x407D50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0BF3F2B62F49202D0E2921DAD0985C 0x407D60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAE0227CFCF1DB0046F135003D04DADC 0x407D70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8046FCF1DB00DAE0227C46F13E00FCF1 0x407D80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FADB8CA1DB0046FE4D00BD0546FE6000 0x407D90: FFFFFFFFFFFFFFFFFFFFFFFF ED02DAE0227C26F02200DB00 0x305C7A: F01C4921FD01 E6003200F7F2 0x305C80: E112E6003200 B52FE6FCB038 0x305C98: F01C4921FD01E112 E6003200F7F2B62F 0x305CA0: E6003200 E6FCB038 0x107468: 0070020000280400 0070000000280200 0x107470: 00C00300003805000060010000EC0200 00C00300003804000060000000EC0200 0x107480: 0060010000EC02 0060030000EC04 0x305C07: 21 23 0x305C0B: 14 34 0x305C1B: 21 23 0x305C1F: 14 34 0x305D00: 3D 0D 0x305D3E: 3D 0D ;co-ordinate x of text (both values must be identical): 0x407C36: FF 00 0x407CD2: FF 00 ;co-ordinate y of text (second value = first value + 3): 0x407C3A: 43 43 0x407CD6: 46 46 ;width of text (both values must be identical): 0x407C3E: 65 65 0x407CDA: 65 65 ;height of text: 0x407C42: 13 0D 0x407CDE: FF 09 ;font of text: 0x407CBB: 9C 9C ;xC x is a number of font ;co-ordinate x of black line: 0x407C50: FF 00 ;co-ordinate y of black line: 0x407C54: 43 43 ;width of black line: 0x407C58: 65 65 ;Text "Vol-# Treb-# Bass-#" in asciiz 0x407D9C: FFFFFFFF 566F6C2D 0x407DA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 302020547265622D302020426173732D 0x407DB0: FFFF 3000 0x407C8C: FF 05 ;number of letter of figure volume 0x407C9C: 15 15 ;number of letter of figure bass 0x407CAC: FF 0D ;number of letter of figure trebble ;------------------------------------------------------------------------- 0x407CFA: 33 33 ;3x x - number of button bass + 0x407D16: 36 36 ;3x x - number of button bass - 0x407D32: 31 31 ;3x x - number of button trebble + 0x407D4E: 34 34 ;3x x - number of button trebble - 0x407D6A: 35 35 ;3x x - number of button illumination on/off ;*** Just Another Additional Display for MP3Player *** ;Author: RizaPN ;Release October 14, 2003 ;Thanks to mamaich for all info regarding this patch ;MODIFIED BY sc0ty ([email protected]) Jan 11, 2005 ;Show current time in MP3 player (without volume level) 0x3BD966: DAC7EEAB DAC710DB 0x3BE0FC: 4B 64 0x3BE10C: 23 10 0x3BE8A4: DAC7EEAB DAC710DB 0x27DB10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC7EEABE0CE00E0F2FF00FEE6F4202D 0x27DB20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 898E899E898E08E3E6F4DE25BB09E6F4 0x27DB30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 003ADC4FB99E08E1E6F4DC25BB01DB00 0x27DB40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A5D7400D00A844F6F40EFE5B55F3F8 0x27DB50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0CFEF3F90EFE06F43030DC6FB99EE48E 0x27DB60: FFFFFFFFFFFFFFFFFFFF 0100E4BE020008E2CB00 Last edited by Seklth; 03-02-2005 at 13:37. |
03-02-2005, 15:55 | #417 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** EBIN. Entry-point for Binary file *** ;Firmware : sl45v56 ;Author : rizapn ;Created : March 2, 2005 ;Executing binary file through entry point ;The needed BIN file should be *copied* into the folder a:\zbin ;and the filename should be zaX.bin ... (X = a..p) ;The entry-point are : ; zaa.bin -> 0E47310h, zab.bin -> 0E47314h, zac.bin -> 0E47318h, ; zad.bin -> 0E4731Ch, ... zap.bin -> 0E4734Ch ;We can also execute some other file by using : mov r4, #YYXX ;then calls 0E47350h (filename = a:\zbin\zYX.bin). For example : ; zaq.bin -> E6F41000FAE45073 ; 1000 -> aq (10=16dec=q, 00=0=a) ; zba.bin -> E6F40001FAE45073 ; 0001 -> ba (00=a, 01=b) 0x447300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2A2A204542494E2076312E30202A2A2A 0x447310: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0040D1EE0140D1CE0240D1AE0340D18 0x447320: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0440D16E0540D14E0640D12E0740D10 0x447330: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0840D0EE0940D0CE0A40D0AE0B40D08 0x447340: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0C40D06E0D40D04E0E40D02E0F40D00 0x447350: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8840E6FC100088C0E6FC0008E0FDE6FE 0x447360: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9233E6FF9103DAC7B4830802984006F4 0x447370: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6161E6FF2000E00EE0FDE6FC0008DC5D 0x447380: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E49C0900E48C0A00E085E004FAE4F87F 0x447390: FFFF DB00 ;Filename: 0x447392: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 613A5C7A62696E5C7A61612E6269 0x4473A0: FFFF 6E00 ;rizapn |
03-02-2005, 17:05 | #418 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | *** AOLR - Animated Operator Logo Retro *** ;Firmware: SL45v56 ;Author: cyperghost ;Created: Oktober 2004 ;As sc0ty created his screensaver patch (Fast animated logo when keylocked) I decided to ;release this patch now. It loads Animated Operator Logo from flash now like the old AOL Patches did ;for full pleasure please remove LOL Patch. With slighlty modifications of sc0ty's patch we can make ;full sized screen saver ;In short words: ;SOL3 gots Animation from flash ;sc0ty's patch (need to be modified but you find out if look to LOL) ;animation is loadable from MMC using Screen Style Set in mobiles optionsmenu ;Keep in mind you need SOL3 installed 0x27D198: 3C4E 8702 |
03-03-2005, 15:24 | #420 (permalink) |
Member: 60520 Status: Offline Thanks Meter: 0 | ; Calendar with long month names ; source code for tuning and binary (english and german) in here: ; home.arcor.de/sagem-x-5/cal2.rar |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
